FHEM => Frontends => SVG / Plots / logProxy => Thema gestartet von: reen am 19 Dezember 2016, 15:31:04
Titel: Kleines Problem mit Behaglichkeits-Plot
Beitrag von: reen am 19 Dezember 2016, 15:31:04
Hi zusammen,
ich habe mir aus dem wiki den Plot für die Behaglichkeitsanzeige aus Temperatur und Luftfeuchtigkeit erstellt.
GPlotfile:
#PlotProxy Func:logProxy_xy2Plot([[18,40],[24,33],[22,65],[17,75],[18,40]])
#PlotProxy Func:logProxy_xy2Plot([[19,20],[25,18],[27,32],[24,60],[21,80],[17,85],[16,75],[17,35],[19,20]])
#PlotProxy Func:logProxy_xy2Plot([[ReadingsVal("kue_MultiSensor","temperature",0),ReadingsVal("kue_MultiSensor","humidity",0)]])
plot "<IN>" using 1:2 axes x1y1 title 'Behaglich' ls l1fill lw 1 with lines,\
     "<IN>" using 1:2 axes x1y1 title 'Noch Behaglich' ls l4fill lw 1 with lines,\
     "<IN>" using 1:2 axes x1y1 title 'Wohnzimmer' ls l2fill lw 1 with points
Sensor:
   DEF        d344759d 32
   IODev      ZWAVE1
   LASTInputDev ZWAVE1
   MSGCNT     482
   NAME       kue_MultiSensor
   NR         41
   STATE      TRANSMIT_NO_ACK
   TYPE       ZWave
   ZWAVE1_MSGCNT 482
   ZWAVE1_RAWMSG 00040420028407
   ZWAVE1_TIME 2016-12-19 14:33:02
   ZWaveSubDevice no
   homeId     d344759d
   isWakeUp   1
   lastMsgSent 1482154382.83917
   nodeIdHex  20
   Readings:
     2016-12-18 19:53:53   CMD             ZW_APPLICATION_UPDATE
     2016-07-30 19:52:02   UNPARSED        SENSOR_BINARY 063004012200f7
     2016-12-19 10:27:00   alarm           HomeSecurity: Event cleared:  Previous Events cleared
     2016-12-19 10:27:00   basicSet        0
     2016-12-19 14:33:02   battery         100 %
     2016-12-18 19:53:55   configBatteryReportingThreshold 0
     2016-12-18 19:53:56   configCommandOptions BasicSetDefault
     2016-12-18 19:53:57   configEnableDisableLockConfiguration Disable
     2016-12-18 19:53:58   configEnableMotionSensor EnabledLevel5MaximumSensitivity
     2016-12-18 20:51:03   configGroup1Interval 3600
     2016-12-18 20:51:03   configGroup1Reports 241
     2016-12-18 20:51:03   configGroup2Interval 3600
     2016-12-18 20:51:03   configGroup2Reports 0
     2016-12-18 20:51:03   configGroup3Interval 3600
     2016-12-18 20:51:03   configGroup3Reports 0
     2016-12-18 20:51:03   configHumidityCalibration 0
     2016-12-18 20:51:03   configHumidityReportingThreshold 10
     2016-12-18 20:51:03   configLowBattery 20
     2016-12-18 20:51:03   configLowTempAlarm Disabled
     2016-12-18 20:51:03   configLuminanceCalibration 0
     2016-12-18 20:51:03   configLuminanceReportingThreshold 100
     2016-12-18 20:51:03   configOnTime    10
     2016-12-18 20:51:03   configReportingThreshold Enabled
     2016-12-18 20:51:03   configTemperatureCalibration 0
     2016-12-18 20:51:04   configTemperatureReportingThreshold 20
     2016-12-18 20:51:04   configUVReportingThreshold 2
     2016-12-18 20:51:04   configUltravioletCalibration 0
     2016-12-18 20:51:04   configWakeUp10MinutesOnPowerOn No
     2016-12-18 19:52:01   config_9        256
     2016-12-19 14:33:01   humidity        38 %
     2016-12-19 14:33:02   luminance       7 Lux
     2016-03-02 23:32:34   model           Aeotec MultiSensor 6
     2016-03-02 23:32:34   modelConfig     aeotec/multisensor6.xml
     2016-03-02 23:32:34   modelId         0086-0002-0064
     2016-08-27 16:27:22   state           TRANSMIT_NO_ACK
     2016-12-19 14:33:00   temperature     19.8 C
     2016-12-19 14:33:02   timeToAck       0.026
     2016-12-19 14:33:02   transmit        OK
     2016-12-19 14:33:02   ultraviolet     0 UV
     2016-12-19 14:33:02   wakeup          notification
   IODev      ZWAVE1
   WNMI_delay 0.3
   classes    ZWAVEPLUS_INFO VERSION MANUFACTURER_SPECIFIC ASSOCIATION_GRP_INFO ASSOCIATION POWERLEVEL ALARM WAKE_UP BATTERY SENSOR_BINARY SENSOR_MULTILEVEL CONFIGURATION FIRMWARE_UPDATE_MD MARK DEVICE_RESET_LOCALLY
   group      Multisensoren
   room       ZWave,a_EG_Küche
Die Formatierung des Plots funktioniert, auch der Sensor "Dot" wird angezeigt, aber leider nicht richtig (Koordinaten sind immer so, oder ähnung: (temo/hum ->  21/0)
Aus irgendeinem Grund wird also wohl das humidity Value nicht richtig ausgelesen.
Also erstes dachte ich, es liegt vielleicht am " %" im humidity Reading und habe folgendes versucht (ohne erfolg):
substr(ReadingsVal("kue_MultiSensor","humidity",0),0,length(ReadingsVal("kue_MultiSensor","humidity",0))-2)
Jetzt ist meine Vermutung dass es vielleicht an dem unterschiedlichen timestamp der Readings "temperature" und "humidity" liegt - könnte das sein?
Denn auch wenn ich im gplot file für das humidity-reading als default-angabe statt 0 die 10 wähle, wird die "Dot" humidity-Koordinate trotzdem bei 0 gesetzt.
Hat da jemand einen kleinen Tipp für mich?
Vielen Dank und freundliche Grüße
reen
Titel: Antw:Kleines Problem mit Behaglichkeits-Plot
Beitrag von: justme1968 am 19 Dezember 2016, 22:51:28
timestamps sind egal da die werte direkt aus dem aktuellen readings geholt werden.
es liegt an den einheiten an beiden werten. nimm mal für beides ReadingsNum statt ReadingsVal:#PlotProxy Func:logProxy_xy2Plot([[ReadingsNum("kue_MultiSensor","temperature",0),ReadingsNuml("kue_MultiSensor","humidity",0)]])
  andre
Beitrag von: reen am 19 Dezember 2016, 23:55:23
Danke andre, das hats gebracht! :)
