hi everybody,
it is a great pleasure to present an integration of EIB/KNX in FHEM.
EIB is a standard bus for house/building automation. It is merely used
in hotels, hospitals etc.
But it is now about to become used in private houses as well.
EIB defines a set of transport media, but the common transport medium
is a twisted pair cable. (for more information use google ;) )
Since last week two new FHEM module have been committed to the CVS
repository:
- TUL
- EIB
The TUL module is used to define the transport device. The EIB
definitions will represent actuators (switches, lights, sensors,
etc..)
I will update the commandref.HTML right after my vacations end of
July.
The TUL module has been designed to work with EIBD server and TPUART
modems. Latter one will make FHEM users happy, who use a NAS or
FritzBox and do not want to have an own server for EIBD. So you could
just use the TUL stick from busware.de (see bus connection later).
So the definition of the io device will look like this:
EIBD:
define tul TUL eibd:
[:] address>
example: define tul TUL eibd:localhost 1.1.249
TPUART:
define tul TUL tpuart:
example: define tul TUL tpuart:COM5 1.1.249
Now we need to define the actuators:
(in EIB actuators are controlled by sending commands on group
addresses)
define light1 EIB
attr light1 IODev tul
define light
**Bus-Connection**
Up to now EIB bus couplers for RS232, USB or even network are very
expensive.
Nowadays busware.de will soon offer an USB-Stick for connecting to EIB
on a reasonable price: http://busware.de/tiki-index.php?page=TUL
TUL is an open source hardware module providing a powerful atmega32u4
and a TPUART. The current firmware is a transparent TPUART modem
providing bus connection over TPUART. It can be used over EIBD Linux
server or directly by FHEM module.
Hi sorry I was only nearby finished an clicked wrong button ;(
So the FHEM integration is now in early beta state and will need some
work. But it is already very stable running on Dirs Tostmann's house.
The great thing is that the integration in FHEM will allow to combine
all different kind of protocols and devices to achieve tremendous
results and successs.
So the WAF of the EIB could be increased by combining the EIB module
with FS20 and use a FS20 remote control to control your light,
jalousies etc.
On the other hand a lots of environment monitoring sensors
(temperature, wind speed, etc.) are cheaper and better to install on a
radio basis (ie. 868Mhz devices) and can easily be integrated in FHEM
and so be used to control the jalousie ....
I hope you will like the integration.
Comments welcome ;)
cu
Maz
http://mazcity.de
Blog/Tech Knowhow: http://knowhow.amazers.net
Hi Maz, I probably will.
Quick question: when using:
just to make sure: the "EIBD" is the generic bcusdk-eibd, right? Or is it
some other kind of daemon just running on the TUL?
Anyhow, EIB integration is really great! (and now reduces my bad feelings
about having posted EIB related stuff in this forum
Thanks, Best Regards, Jens
Maz has in fact written two interface handlers:
FHEM => eibd => (any supported BCU i.e. TUL) => bus
FHEM => TPUART (i.e. TUL) => bus
The reason is mainly to make "eibd" expendable as it might not run on smaller embedded systems. So you can connect to the bus directly via TUL, which is a serial TPUART over USB.
eibd is of course:
http://www.auto.tuwien.ac.at/~mkoegler/index.php/eibd
Am 07.07.2011 um 13:47 schrieb auto-mate:
> just to make sure: the "EIBD" is the generic bcusdk-eibd, right? Or is it some other kind of daemon just running on the TUL?
> Anyhow, EIB integration is really great! (and now reduces my bad feelings about having posted EIB related stuff in this forum
Hi Jens,
wie Tosti bereits schrieb, ist mit eibd/eibd-Server die Implementation
von TU-Wien gemeint. Das musste auch das von Dir angemerkte bcusdk-
eibd sein.
Der eibd muss mit dem -i Parameter gestartet werden. z.B.
eibd -i -t 100 tpuarts:/dev/ttyACM0
Die Firmware von TUL is so ausgelegt, dass eibd darüber sich mit dem
EIB-Bus verbinden kann. Aber eibd unterstützt auch ganz viele andere
Netzkonnektoren (Z.B. LAN-Konnektor, etc.).
TUL ist preislich sehr attraktiv, da Alternativen erst beim doppelten
Und weit darüber anfangen. Auch wenn nur ein Bus-Sniffer / Bus-Monitor
benötigt wird, ist TUL sehr gut geeignet, da es out of the Box alle
Telegramme auf dem seriellen Anschluss ausgibt.
Es sind aber auch einige Leute hier unterwegs, die FHEM nur auf ein
NAS oder ein Fritzbox laufen lassen und kein Extra-Server für eibd
haben wollen (obwohl TuxRail von busware eine sehr attraktive
Möglichkeit wäre anstatt von NAS und FB). Für diesen Einsatzzweck habe
ich dann noch ein Modus in FHEM-Modul aufgenommen, damit der TUL
direkt an NAS/Fritzbox angeschlossen werden kann und aus FHEM direkt
angesprochen werden kann.
Wenn Du das Modul in Betrieb hast, wäre ein Feedback sehr hilfreich.
Maz
@Maz
hatte mich ja schon geoutet, dass ich mich für Wire-Kompontenen an
FHEM@FritzBox7390 interessiere. Zwar ist das TUL ja schonwieder-ein-
neues Teil, aber ohne Hardware-Interfaces geht ja wohl nichts..
Only for confirmation:
- The TUL works on FB7390 2.0 USB Port and adressed directly from
FHEM@FB7390
Questions:
The TUL has to be flashed like CUL (it is shipped without Software!)?
The EIB ist directly connected to TUL and then interacts with attached
EIB sensors and actors?
Are there (by now) any protokoll restrictions to existent EIB
Installations?
Jörg (JWK)
P.S.: Thanks for the enlargement of homeautomation@FHEM. Any
proprietary restriction looses its burden at any time.
Hi Jörg,
> FHEM@FB7390
This is also my expectation and what we (Tosti and me) had in mind
when we started the efforts.
As CUL is running on FB without any issues, I expect that TUL will do
as well.
> Questions:
Yes. But the firmware's available here: http://busware.de/tiki-download_file.php?fileId=54
BTW: And TUL is "officially" supported by LUFA so the current firmware
is a standard LUFA compilation.
Yes. I suppose you have insights in EIB. So you can send group
commands (Telegrams) using FHEM.
> Installations?
Depends which "protocols" you refer to. EIB defines a lot of protocols
on different layers and to be offered by different devices....
With the current firmware and FHEM modules you can receive/ send any
EIB group telegrams (switching on, off, values from sensors). I have
in my test installation a series of switches and lamps and I can
switch them all on off... and I have also a presence sensor that in
intervals sends the current lightning value in lumen as a two digit
hex value. This value is also captured in FHEM and you could write
notifications to act on that values... so switch lights when it is too
dark... etc....
So there is no restriction regarding the EIB-Group communication
protocol. However there is for simplicity some fields of the telegram
filled with default values (ie. repetition count, severity etc.) But
it is expected that this settings are best suited for FHEM
integration.
After my vacations (so by mid August) I will create a video explaining
this by examples.
The next step for the firmware is to implement support for the FT1.2
protocol, so you can use ETS directly over TUL (Now you would need
eibd server... but ETS is only needed at initialization time of the
components to assign physical addresses and define group adresses,
that is in most installations done by the system integrator)
The FHEM-Module is of course in betta status and will be improved day
by day. The TUL Stick is very promising and offers great opportunities
at a very competetive price and is in production stage.
I hope, all your questions are answered well. Let me know if there are
any more issues.
cu
Maz
> Jörg (JWK)
Hi Maz,
it's it possible to use a EIB/IP Gateway without eibd? Or is it on the
roadmap to support this? I already tried eibd but it has to much
dependencies for my NAS. My preferred way is to connect directly with
the EIBnet/IP protocol.
If not, i'm order a TUL...
Did autocreate actual create the cfg entry's for the detected TUL EIB
devices?
Thanks for the Work!
Regards
Domi
unfortunately not now. I will keep it in mind for a later (really
later :) ) time.
(I do not want to reinvent everything... and right now eibd offers a
full list of protocols / connectors, so I think it is a good idea to
have in FHEM a support for eibd and let eibd do what it can do best...
The direct TUL connection has been implemented for NAS/FB devices...
also for you :)
(You might maybe consider a TuxRail from busware... (I think it will
support eibd and you have a full debian)
> devices?
I do not use autocreate and so I did not took care about that :( So I
am afraid it will not be supported now. I will check how autocreate
work and maybe contact Rudi for that and implement that in case this
is not so complex. For complex devices (like Rollos) it will not be
possible ;(
How many actors do you have in your installation?
BTW: As it seems that "Rolläden" work all in different ways, I am also
preparing an own smart module for that issue.
(Both to be expected right after my vacations by mid of August)
You are welcome. I am looking forward to seeing your feedback.
cu
Maz
> I will check how autocreate work ...
Autocreate listens for the "global:UNDEFINED" event, which is triggered if the
modules ParseFn() returns "UNDEFINED" to Dispatch(). As far as I see this is
done by 10_EIB.pm correctly, i.e. autocreate for EIB devices should work.
On the "UNDEFINED" event autocreate creates a device by calling the modules
DefineFn with the parameters reported by the UNDEFINED event, then it creates
the corresponding FileLog. If autocreate "knows" that the device is a sensor,
then it also creates a Plot for the device. This is not yet the case for EIB
devices.
also
ich bekomms nicht zum laufen
Am TUL leuchtet bei den Busklemmen eine LED Orange wenn ich ihn mit
dem Bus verbinde.
Von den Adressen her hab ich dem TUL die des KNX/Ethernet Gateways
gegeben um eine Fehlkonfiguration ausschließen zu können.
Doppelbelegung durch ausschalten des Gateways vermieden.
Die vorgeschlagene 1.1.254 hab ich auch probiert.
Es wird weder etwas vom Bus angezeigt noch kann ich an eine
Gruppenadresse was senden.
Konfig ist:
CUL:
mknod /dev/ttyACM0 c 166 0
chmod 666 /dev/ttyACM0
TUL:
mknod /dev/ttyACM1 c 166 1
chmod 666 /dev/ttyACM1
Frage so nebenbei wie wird dabei eigentlich festgelegt welches Gerät
die eins und welches die zwei bekommt?
define TUL1 TUL /dev/ttyACM1 1.1.254
define lightOG EIB 0/0/2
attr lightOG IODev TUL1
Im Logfile hab ich:
2011.07.22 17:10:36 2: FHEMWEB port 8083 opened
2011.07.22 17:10:36 2: FHEMWEB port 8084 opened
2011.07.22 17:10:36 3: Unknown IODev specified
2011.07.22 17:12:47 3: CUL opening CUN868 device 10.0.1.12:2323
2011.07.22 17:12:47 3: CUL device opened
2011.07.22 17:12:47 3: HMLAN opening HMLAN1 device 10.0.1.13:1000
2011.07.22 17:12:47 3: HMLAN device opened
2011.07.22 17:12:47 3: CUL opening CUL868 device /dev/ttyACM0
2011.07.22 17:12:47 3: TUL opening TUL1 device /dev/ttyACM1
2011.07.22 17:12:47 1: /dev/ttyACM1 protocol is not supported
2011.07.22 17:12:47 3: TUL device opened
Use of uninitialized value in string eq at /usr/local/fhem/lib/FHEM/
00_TUL.pm line 824, <$fh> line 16.
2011.07.22 17:12:47 2: FHEMWEB port 8083 opened
2011.07.22 17:12:47 2: FHEMWEB port 8084 opened
2011.07.22 17:14:53 1: define: Define lightOG: wrong group name
format: specify as 0-15/0-15/0-255
2011.07.22 17:16:13 2: EIB set lightOG on
SimpleWrite data: 1
00_TUL.pm line 849.
00_TUL.pm line 849.
2011.07.22 17:16:35 2: EIB set lightOG off
SimpleWrite data: 0
00_TUL.pm line 849.
00_TUL.pm line 849.
Konsolenmeldung nach dem Start:
DiskStation> perl5.8.8 /usr/local/fhem/bin/fhem.pl /volume1/FHEM/
fhem.cfg
DiskStation> Use of uninitialized value in string eq at /usr/local/
fhem/lib/FHEM/00_TUL.pm line 824, <$fh> line 16.
Use of uninitialized value in concatenation (.) or string at /usr/
local/fhem/lib/FHEM/01_FHEMWEB.pm line 572.
Ideen?
Domi
Am 22.07.2011 um 17:43 schrieb domi:
Bitte somewhere in udev definieren:
/etc/udev/rules.d/50-udev.rules:
KERNEL=="ttyACM*", ATTRS{product}=="TPUART transparent", SYMLINK
+="tpuarttransparent"
dann in fhem.cfg z.B.:
define KNX TUL tul:/dev/tpuarttransparent 1.1.249
define Schlaf.Rollo EIB 8/0/7
attr Schlaf.Rollo IODev KNX
attr Schlaf.Rollo room Schlaf
Setzt natürlich vorraus, dass das TUL mit:
geflashed wurde.
Hi Domi,
1. Wenn die grüne LED nicht leuchtet, dann hast Du wahrscheinlich noch
kein Firmware auf dem TUL.
Tosti hat ja den Link gesendet, wo Du die Firmware findest.
2. Die FHEM definition ist nicht korrekt. Da hat Tosti auch schon
bereits die korrekte Bezeichnung geliefert: tul:/dev/xxx (wichtig ist
tul: am Anfang)
Im Log wird korrekter Weise angegben, dass das Protokoll nicht
verstanden wird, aber da ist noch wohl ein Fehler, dass die
Fehlermeldungen mit "uninitialized values" erscheinen.
Werde ich noch ausbessern.
Falls es nicht klappt, schicke mir ein PN oder poste hier.
Maz
Ich bin einen Schritt weitergekommen
Ist bei mir nicht möglich da das Mini Linux in meiner NAS udev nicht
hat
Vorerst behelfe ich mir mit mknod /dev/ttyACM0 c 166 0 für den CUL und
mknod /dev/ttyACM1 c 166 1 für den TUL
Wenn nach dem booten der CUL zuerst eingesteckt wird gehts :-)
Hab ich jetzt auch abgeändert
Firmware ist aufgespielt LED leuchtet grün. Ist der KNX Bus
angeschlossen leuchtet zusätzlich noch eine orange LED.
> Setzt natürlich vorraus, dass das TUL mit:http://busware.de/tiki-download_file.php?fileId=54 geflashed wurde.
Das ganze kommt auch hoch jedoch wenn vom Bus was ankommt stürzt fhem
ab. Log:
2011.07.22 20:17:28 0: Server started (version =VERS= from =DATE=
($Id: fhem.pl,v 1.147 2011-07-15 08:59:31 rudolfkoenig Exp $), pid
5284)
2011.07.22 20:19:16 3: CUL opening CUN868 device 10.0.1.12:2323
2011.07.22 20:19:16 3: CUL device opened
2011.07.22 20:19:17 3: HMLAN opening HMLAN1 device 10.0.1.13:1000
2011.07.22 20:19:17 3: HMLAN device opened
2011.07.22 20:19:17 3: CUL opening CUL868 device /dev/ttyACM0
2011.07.22 20:19:17 3: CUL device opened
2011.07.22 20:19:17 3: TUL opening KNX device tul:/dev/ttyACM1
2011.07.22 20:19:17 3: TUL setting KNX baudrate to 19200
2011.07.22 20:19:17 3: TUL device opened
2011.07.22 20:19:17 2: FHEMWEB port 8083 opened
2011.07.22 20:19:17 2: FHEMWEB port 8084 opened
2011.07.22 20:19:32 3: EIB Unknown device 0102 (0/1/2), Value 01,
please define it
2011.07.22 20:19:32 2: autocreate: define EIB_0102 EIB 0102
2011.07.22 20:19:32 1: define: Define EIB_0102: wrong group name
2011.07.22 20:19:32 1: ERROR: Define EIB_0102: wrong group name
2011.07.22 20:19:32 3: Control Byte 0x9c does not match expected mask
0xB0
2011.07.22 20:19:32 1: tul:/dev/ttyACM1 disconnected, waiting to
reappear
2011.07.22 20:19:37 3: TUL setting KNX baudrate to 19200
2011.07.22 20:19:37 1: TUL tul:/dev/ttyACM1 reappeared (KNX)
Argument "" isn't numeric in right bitshift (>>) at /usr/local/fhem/
lib/FHEM/00_TUL.pm line 729.
Use of uninitialized value in length at /usr/local/fhem/lib/FHEM/
00_TUL.pm line 748.
Use of uninitialized value in unpack at /usr/local/fhem/lib/FHEM/
00_TUL.pm line 748.
00_TUL.pm line 750.
2011.07.22 20:19:37 3: Control Byte 0x9c does not match expected mask
0xB0
2011.07.22 20:19:37 1: tul:/dev/ttyACM1 disconnected, waiting to
reappear
Use of uninitialized value in vec at /usr/local/fhem/bin/fhem.pl line
340.
390.
Can't call method "read" on an undefined value at /usr/local/fhem/lib/
FHEM/00_TUL.pm line 881.
Hallo Domi,
Habe eine neue Version von 10_EIB.pm eingecheckt, die jetzt auch
autocreate voll unterstützt.
(Es hat bisher gehackt, weil die Gruppen-Angabe vom Bus in einem Hex-
Format vorliegt und das EIB Modul erwartete im define ein Format nach
1/1/2. Jetzt werden beide Formate angenommen und es geht.)
Bei der direkten Anbindung des TUL (also ohne EIBD-Server) ist mir nun
aufgefallen, dass es Stabilitätsprobleme bestehen, insbesondere, wenn
zwischen drin der TUL abgesteckt wird und neu eingesteckt wird, bzw.
wenn die Busklemme ab/an-gesteckt wird. HIer bitte ich um Nachsicht.
Ich arbeite ab nächster Woche an das Abfangen der Prolemfälle.
Es wäre sehr hilfreich, wenn Du vorerst den Loglevel auf 5 setzen
könntest.
Ab und an verfällt das FHEM-Modul in ein Endlosschleife. Das erkennst
Du daran, dass nur noch Ausgaben wie
2011.07.23 13:17:44 5: buf len: 1 expected: 3
erscheint.
Hier hilft ein beherztes Neustarten. (logs an mich schicken wäre
hilfreich :) maz.rashid@googlemail.com)
cu
Maz
Hallo Maz,
vielen Dank für deine Hilfe.
Aktuell verwende ich folgende funktionierende Konfiguration:
define KNX TUL tul:/dev/ttyACM1 1.1.240
Über define lightOG EIB 0/0/2 und betätigen von on schaltet meine
Lampe an bei nochmaligem betätigen aus.
Über define lightOGrueck EIB 0/1/2 kommt die Rückmeldung zum aktuellen
Schaltzustand herein.
Dem TUL die Adresse 1.1.254 zu geben ist keine so gute Idee da diese
von ETS genutzt wird und somit unter umständen doppelt belegt ist.
Gelernte Gruppenadressen werden im Raum Unsorted gelistet.
Domi
erst mal ein Lob: FHEM ist ein prima Programm und relativ simpel
einzurichten!
Davor hatte ich ein selbst programmiertes System, welches mit eibd und
linknx funktionierte.
Ich habe mir FHEM und eibd auf einer FritzBox 7270 eingerichtet und
steuere jetzt damit unser KNX-System.
Falls interesse besteht, lade ich das kompilierte eibd für die
FritzBox hoch.
Leider hatte FHEM folgenden Bug:
die erste Zahl der Gruppenadresse wurde beim Senden verdoppelt. Also
wenn ich 1/3/5 ansteuern will, steuert mir FHEM stattdessen 2/3/5. Der
Bug tritt auch auf, wenn man die Gruppenadresse als Hex-Zahl eingibt.
Meine Lösung des Bugs:
in der 00_TUL.pm muss in Zeile 588 folgende Anpassung gemacht werden:
vorher: return (hex($1) << 12) | (hex($2) << 8) | hex($3);
nacher: return (hex($1) << 11) | (hex($2) << 8) | hex($3);
Ansonsten funktioniert's prima.
Verbesserungsvorschläge:
1. Egal welches Modul verwendet wird, die Werte werden immer in Hex
angezeigt. Das ist natürlich für Temperatursensoren unpraktisch.
Es wäre cool, wenn das Programm die Hex-Werte bei Temperatursensoren
automatisch in Grad umrechnet - auch damit sie als Graph geplottet
werden können.
Beispiel: FHEM zeigt momentan an: "Temperatursensor 0c5c On Off"
0c5c = 3164 => Temperatur ist 22,32 Grad
Die Umrechnung funktioniert wie folgt (code in php):
$zeile ist der Wert als Integer.
if ($zeile > 2048)
$solltemp = ($zeile - 2048)*0.02;
else
$solltemp = ($zeile)*0.01;
Ähnlich ist es bei den Dimmern, dort wird auch ein Hex-Wert statt
0-100% angezeigt. Dort sendet eibd einfach einen Wert von 00 bis FF.
2. Viele Geräte haben mehrere Gruppenadressen. Z.b. hat der
Temperatursensor eine Adresse bei dem der aktuelle Wert gesendet wird
und eine andere Adresse bei dem der Richtwert eingestellt werden kann.
Gut wäre es, wenn man die Adressen in FHEM zusammenfassen könnte, um
die Richttemperatur einfacher einstellen zu können.
Genau so ist es auch bei Dimmern. Es gibt eine Adresse bei dem man den
Wert einstellen kann und eine Adresse bei dem man die Lampe ein/aus-
Schalten kann.
3. Der Get-Befehl funktioniert nicht.
Mit Get hat eibd auch so seine Probleme. Es gibt allerdings ein
zweites Programm mit dem man recht einfach den Wert eines Gerätes
anfordern kann.
Der Wert wird dann ganz normal von eibd empfangen und an FHEM
geleitet.
exec("/var/usb/bin/groupread ip:127.0.0.1 1/3/2");
Also noch mal danke für die Implementierung von eibd.
Benjamin
Hi Benjamin,
bin gerade viel Unterwegs. Komme erst am Wochenende dazu, Dir zu
antworten..
cu
Maz
ich freue mich schon auf deine Antwort!
lg
Benjamin
On Sep 8, 10:11 pm, Maz wrote:
> Hi Benjamin,
> antworten..
> cu
> Maz
Danke. Ist in cvs korrigiert. War mir nicht aufgefalln, da ich Als
Hauptgruppe 0 verwende.
freut mich.
Dazu habe ich jetzt die Idee, dass als zusätzlicher Attribut der Typ
des Telegrams angegeben werden kann (Temperatur, Dimmer, Zeit, Datum,
etc.) und eine integrierte Umrechnung erfolgt.
> Schalten kann.
Das Problem ist, dass die Fantasie der Hersteller sehr weitreichend
ist. Es gibt solche Geräte und solche...
Leider kann ich gar nicht all die Varianten implementieren :(
Ich habe die Idee, dass man für ein EIB-Modul in FHEM vlt. mehrere
Adressen zum "hören" einrichten kann. Das senden erfolgt dann auf
einer Adresse.
Das lösu das Problem mit dem Temperatur-Sensor.
Für den Dimmer kannst Du entweder zwei Module definieren oder mit
einem notify macro dann an die zweite Adresse senden (z.B. wenn der
eingestellte Werte größer als 1 ist, dann wird wohl der Dimmwert
eingestellt worden sein, dann sendest du den Wert an die Dimm-
Adresse)
Get hatte ich nur rudimentär implementiert und wenig Zeit gehabt. Und
bin der Ansicht, dass man es nur sehr sehr selten benötigt. Wozu
verwendest Du Get?
Gerne.
Ich komme erst Ende des Monats die Umrechnungen einzubinden. Sorry.
Maz
eine Frage an die Spezialisten. Kann sich mal jemand folgendes anschauen:
https://groups.google.com/forum/#!searchin/fhem-users/7270/fhem-users/rPFWabHuDA4/xugqJCFMAY8J
Vielen Dank
wäre schöner gewesen, wenn Du wenigstens Gruppe und Thema genannt hättest.
Der Link ist aus Deiner Suche und nicht mehr funktionierend ;(
Sorry,war die ganze Woche weg.
Problem ist inzwischen soweit gelöst. Bei Interesse:
Group fhem, Theme Wheater und Sunrise
Gruss,
Tom
