Nach eben erfolgtem Update hängt FHEM. Im Log steht
2016.12.26 23:52:25 1: Including fhem.cfg
2016.12.26 23:52:25 3: telnetPort: port 7072 opened
2016.12.26 23:52:28 3: WEB: port 8083 opened
2016.12.26 23:52:28 3: WEBphone: port 8084 opened
2016.12.26 23:52:28 3: WEBtablet: port 8085 opened
2016.12.26 23:52:28 4: [MyTwilight] url=http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=695681%20and%20u=%27c%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys
2016.12.26 23:52:28 4: HttpUtils url=http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=695681%20and%20u=%27c%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys
2016.12.26 23:52:29 4: http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=695681%20and%20u=%27c%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys: HTTP response code 200
2016.12.26 23:52:29 4: HttpUtils http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=695681%20and%20u=%27c%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys: Got data, length: 2882
2016.12.26 23:52:29 4: [MyTwilight] got weather info from yahoo for 695681
2016.12.26 23:52:29 4: [MyTwilight] answer={"query":{"count":1,"created":"2016-12-26T22:53:37Z","lang":"en-US","results":{"channel":{"units":{"distance":"km","pressure":"mb","speed":"km/h","temperature":"C"},"title":"Yahoo! Weather - Spardorf, BY, DE","link":"http://us.rd.yahoo.com/dailynews/rss/weather/Country__Country/*https://weather.yahoo.com/country/state/city-695681/","description":"Yahoo! Weather for Spardorf, BY, DE","language":"en-us","lastBuildDate":"Mon, 26 Dec 2016 11:53 PM CET","ttl":"60","location":{"city":"Spardorf","country":"Germany","region":" BY"},"wind":{"chill":"34","direction":"270","speed":"22.53"},"atmosphere":{"humidity":"76","pressure":"33592.99","rising":"0","visibility":"25.91"},"astronomy":{"sunrise":"8:12 am","sunset":"4:22 pm"},"image":{"title":"Yahoo! Weather","width":"142","height":"18","link":"http://weather.yahoo.com","url":"http://l.yimg.com/a/i/brand/purplelogo//uh/us/news-wea.gif"},"item":{"title":"Conditions for Spardorf, BY, DE at 09:00 PM CET","lat":"49.6012","long":"11.05482","link":"http://us.rd.yahoo.com/dailynews/rss/weather/Country__Country/*https://weather.yahoo.com/country/state/city-695681/","pubDate":"Mon, 26 Dec 2016 09:00 PM CET","condition":{"code":"29","date":"Mon, 26 Dec 2016 09:00 PM CET","temp":"3","text":"Partly Cloudy"},"forecast":[{"code":"39","date":"26 Dec 2016","day":"Mon","high":"8","low":"2","text":"Scattered Showers"},{"code":"28","date":"27 Dec 2016","day":"Tue","high":"5","low":"2","text":"Mostly Cloudy"},{"code":"26","date":"28 Dec 2016","day":"Wed","high":"5","low":"1","text":"Cloudy"},{"code":"30","date":"29 Dec 2016","day":"Thu","high":"3","low":"-1","text":"Partly Cloudy"},{"code":"34","date":"30 Dec 2016","day":"Fri","high":"2","low":"-2","text":"Mostly Sunny"},{"code":"34","date":"31 Dec 2016","day":"Sat","high":"1","low":"-3","text":"Mostly Sunny"},{"code":"30","date":"01 Jan 2017","day":"Sun","high":"1","low":"-2","text":"Partly Cloudy"},{"code":"28","date":"02 Jan 2017","day":"Mon","high":"1","low":"0","text":"Mostly Cloudy"},{"code":"28","date":"03 Jan 2017","day":"Tue","high":"0","low":"-2","text":"Mostly Cloudy"},{"code":"28","date":"04 Jan 2017","day":"Wed","high":"0","low":"-2","text":"Mostly Cloudy"}],"description":"<![CDATA[<img src=\"http://l.yimg.com/a/i/us/we/52/29.gif\"/>\n<BR />\n<b>Current Conditions:</b>\n<BR />Partly Cloudy\n<BR />\n<BR />\n<b>Forecast:</b>\n<BR /> Mon - Scattered Showers. High: 8Low: 2\n<BR /> Tue - Mostly Cloudy. High: 5Low: 2\n<BR /> Wed - Cloudy. High: 5Low: 1\n<BR /> Thu - Partly Cloudy. High: 3Low: -1\n<BR /> Fri - Mostly Sunny. High: 2Low: -2\n<BR />\n<BR />\n<a href=\"http://us.rd.yahoo.com/dailynews/rss/weather/Country__Country/*https://weather.yahoo.com/country/state/city-695681/\">Full Forecast at Yahoo! Weather</a>\n<BR />\n<BR />\n(provided by <a href=\"http://www.weather.com\" >The Weather Channel</a>)\n<BR />\n]]>","guid":{"isPermaLink":"false"}}}}}}
2016.12.26 23:52:29 4: [MyTwilight] 29=Partly Cloudy 3, correction: 1.6°
2016.12.26 23:52:29 1: HMLAN_Parse: MyHMLAN new condition disconnected
2016.12.26 23:52:29 3: Opening MyHMLAN device 192.168.178.28:1000
2016.12.26 23:52:29 1: HMLAN_Parse: MyHMLAN new condition init
2016.12.26 23:52:29 3: MyHMLAN device opened
2016.12.26 23:52:29 3: Opening MyCUL device /dev/serial/by-id/usb-busware.de_CUL868-if00
2016.12.26 23:52:30 3: MyCUL: Possible commands: BCFiAZEGMRTVWXefmltux
2016.12.26 23:52:30 3: MyCUL device opened
2016.12.26 23:52:30 3: Opening MyHChh device /dev/serial/by-id/usb-Arduino__www.arduino.cc__0043_75335313137351608232-if00
2016.12.26 23:52:30 3: Setting MyHChh serial parameters to 9600,8,N,1
2016.12.26 23:52:30 3: MyHChh device opened
2016.12.26 23:53:48 1: Including ./log/fhem.save
2016.12.26 23:53:53 3: Device Dachzimmer.Heizung added to ActionDetector with 000:10 time
2016.12.26 23:53:53 4: Device Dachzimmer.Heizung is unknown
Modification of a read-only value attempted at ./FHEM/98_HMinfo.pm line 933, <aSave> line 5.
Ich habe sonst nichts verändert. Was läuft da falsch?
Ich habe jetzt erst mal meine Sicherung der SD-Karte wieder zurückgespielt...
Das Gerät mit dem Namen
Dachzimmer.Heizung ist anscheinend unbekannt. Hast du das gelöscht oder umbenannt? Es wird wahrscheinlich versucht von hminfo eine TempLIst zuzuweisen, aber das Gerät existiert nicht, zumindest nicht zu dem Zeitpunkt des Zuweisungsversuchs.
Zitat von: Benni am 27 Dezember 2016, 08:00:43
Das Gerät mit dem Namen Dachzimmer.Heizung ist anscheinend unbekannt. Hast du das gelöscht oder umbenannt? Es wird wahrscheinlich versucht von hminfo eine TempLIst zuzuweisen, aber das Gerät existiert nicht, zumindest nicht zu dem Zeitpunkt des Zuweisungsversuchs.
FHEM lief vor dem Update seit Monaten fehlerfrei. Sonst habe ich noch nichts verändert (Das sollte die Vorbereitung sein, um nun u.a. meinen Harmony Hub zu integrieren). Auch Dachzimmer.Heizung funktionierte problemlos, bzw. funktioniert nach der Rückspielung meines Backups wieder ganz normal. Was kann ich denn nun tun, damit das Update funktioniert?
Bitte, kann mir irgend jemand helfen? Ich habe keine Peilung, was ich machen soll, damit das Update funktioniert...
Ich kenn mich mit dem HM-Zeugs nicht aus, aber die einzige Info, die Du bisher gegeben hast, lässt ja nur Bennis Schlussfolgerung zu
Evtl. die fhem.cfg manuell bearbeitet, dass die Reihenfolge nicht mehr stimmt ? Stell doch mal ein list des devices Dachzimmer.Heizung ein. Vielleicht hat sich an der definition oder Attributen etwas geändert ? Dieses device mal löschen, update, restart und dann neudefinieren ?
Du könntest mit
attr global exclude_from_update 98_HMinfoein evtl. Update dieses(oder auch anderer, die auf HM bezogen sind[siehe Dein Logfile]) Moduls ausschließen.
Grüße Markus
Kann mir dann wenigstens jemand verraten, wie man das von FHEM erzeugte Backup wieder zurückspielt? Das im Wiki angegebene restore https://wiki.fhem.de/wiki/Update#R.C3.BCcksichern_beim_Update_.C3.BCberschriebener_Dateien (https://wiki.fhem.de/wiki/Update#R.C3.BCcksichern_beim_Update_.C3.BCberschriebener_Dateien) ist offenbar ein FHEM-Befehl, der aber nicht funktioniert, wenn FHEM, wie bei mir, gar nicht mehr hoch kommt. Und das Rückschreiben des kompletten SD-Backups ist doch immer ein ziemlicher Akt...
Zitat von: KölnSolar am 27 Dezember 2016, 14:35:16
Ich kenn mich mit dem HM-Zeugs nicht aus, aber die einzige Info, die Du bisher gegeben hast, lässt ja nur Bennis Schlussfolgerung zuEvtl. die fhem.cfg manuell bearbeitet, dass die Reihenfolge nicht mehr stimmt ? Stell doch mal ein list des devices Dachzimmer.Heizung ein. Vielleicht hat sich an der definition oder Attributen etwas geändert ? Dieses device mal löschen, update, restart und dann neudefinieren ?
Du könntest mit
Grüße Markus
Wie gesagt, ich habe vor und nach dem Update nichts verändert. Für weiteres rumprobieren müsste ich jetzt erst mal das simple restore des FHEM-Backups hin kriegen. Bei mir hängt u.a. die komplette Heizungssteuerung an FHEM, und die sollte nicht all zu lange aus sein...
ZitatWie gesagt, ich habe vor und nach dem Update nichts verändert.
Ich meinte mit
ZitatVielleicht hat sich an der definition oder Attributen etwas geändert ?
auch nicht, dass Du etwas verändert hast, sondern in den Modulen ;)
ZitatFür weiteres rumprobieren müsste ich jetzt erst mal das simple restore des FHEM-Backups hin kriegen.
Ahh, verstehe jetzt das vordergründigste Problem. Ich mach das ggfs. händisch. Die alten Files findet man unter /opt/fhem/restoreDir/Datum , wobei das Verzeichnis Datum die Syntax yyyy-mm-tt hat. Diese Unterverzeichnisstruktur unter diesem Verzeichnis ist wie die "normale" fhem-Struktur.
Wie lange hattest Du denn schon kein Update mehr gemacht ?
Das mit dem Backup-Verzeichnis habe ich schon verstanden. Ein einfaches cp -rp ... tut es bei mir aber nicht, um FHEM wieder rückzubügeln. Letztes Update war am 2016-04-09.
Ich mach jetzt erst mal ein
# rpi-update
# apt-get update && apt-get upgrade -y && reboot
das wird aber eher nicht zur Problemlösung beitragen :(
ZitatDas mit dem Backup-Verzeichnis habe ich schon verstanden. Ein einfaches cp -rp ... tut es bei mir aber nicht, um FHEM wieder rückzubügeln.
Da hat sich natürlich ne Menge geändert :(
Zitateinfaches cp
Bin jetzt auch nicht der Linux-Guru. Ich komme aber klar und kann mir ggfs. auch die Berechtigungen wieder zurechtbiegen. Deshalb mag ich Dir aber jetzt nicht sagen, wie ich es mache und Du kommst dann überhaupt nicht mehr weiter... :'(
So, ein
cp -rp /opt/fhem/restoreDir/2016-12-27/* /opt/fhem/
hilft bei mir wenigstens, den lauffähigen Stand mal schnell zurück zu spielen.
Das
# rpi-update
vor dem Update hat nichts verbessert, aber wohl auch nicht geschadet.
Das
tritt vor dem abrussen von FHEM nicht immer auf, manchmal kommt auch
2016.12.27 15:44:26 4: Device Dachzimmer.Heizung is alive
also in Gänze z.B.
2016.12.27 15:42:14 1:
2016.12.27 15:42:15 1: update finished, "shutdown restart" is needed to activate the changes.
2016.12.27 15:44:02 0: Server shutdown
2016.12.27 15:44:07 1: Including fhem.cfg
2016.12.27 15:44:07 3: telnetPort: port 7072 opened
2016.12.27 15:44:08 3: WEB: port 8083 opened
2016.12.27 15:44:08 3: WEBphone: port 8084 opened
2016.12.27 15:44:08 3: WEBtablet: port 8085 opened
2016.12.27 15:44:09 4: [MyTwilight] url=http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=695681%20and%20u=%27c%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys
2016.12.27 15:44:09 4: HttpUtils url=http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=695681%20and%20u=%27c%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys
2016.12.27 15:44:09 4: http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=695681%20and%20u=%27c%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys: HTTP response code 200
2016.12.27 15:44:09 4: HttpUtils http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=695681%20and%20u=%27c%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys: Got data, length: 2835
2016.12.27 15:44:09 4: [MyTwilight] got weather info from yahoo for 695681
2016.12.27 15:44:09 4: [MyTwilight] answer={"query":{"count":1,"created":"2016-12-27T14:44:09Z","lang":"en-US","results":{"channel":{"units":{"distance":"km","pressure":"mb","speed":"km/h","temperature":"C"},"title":"Yahoo! Weather - Spardorf, BY, DE","link":"http://us.rd.yahoo.com/dailynews/rss/weather/Country__Country/*https://weather.yahoo.com/country/state/city-695681/","description":"Yahoo! Weather for Spardorf, BY, DE","language":"en-us","lastBuildDate":"Tue, 27 Dec 2016 03:44 PM CET","ttl":"60","location":{"city":"Spardorf","country":"Germany","region":" BY"},"wind":{"chill":"34","direction":"285","speed":"28.97"},"atmosphere":{"humidity":"80","pressure":"33796.17","rising":"0","visibility":"25.91"},"astronomy":{"sunrise":"8:12 am","sunset":"4:23 pm"},"image":{"title":"Yahoo! Weather","width":"142","height":"18","link":"http://weather.yahoo.com","url":"http://l.yimg.com/a/i/brand/purplelogo//uh/us/news-wea.gif"},"item":{"title":"Conditions for Spardorf, BY, DE at 03:00 PM CET","lat":"49.6012","long":"11.05482","link":"http://us.rd.yahoo.com/dailynews/rss/weather/Country__Country/*https://weather.yahoo.com/country/state/city-695681/","pubDate":"Tue, 27 Dec 2016 03:00 PM CET","condition":{"code":"26","date":"Tue, 27 Dec 2016 03:00 PM CET","temp":"4","text":"Cloudy"},"forecast":[{"code":"26","date":"27 Dec 2016","day":"Tue","high":"4","low":"2","text":"Cloudy"},{"code":"26","date":"28 Dec 2016","day":"Wed","high":"5","low":"1","text":"Cloudy"},{"code":"30","date":"29 Dec 2016","day":"Thu","high":"2","low":"-1","text":"Partly Cloudy"},{"code":"34","date":"30 Dec 2016","day":"Fri","high":"0","low":"-2","text":"Mostly Sunny"},{"code":"32","date":"31 Dec 2016","day":"Sat","high":"0","low":"-3","text":"Sunny"},{"code":"34","date":"01 Jan 2017","day":"Sun","high":"1","low":"-3","text":"Mostly Sunny"},{"code":"28","date":"02 Jan 2017","day":"Mon","high":"1","low":"-1","text":"Mostly Cloudy"},{"code":"28","date":"03 Jan 2017","day":"Tue","high":"0","low":"-3","text":"Mostly Cloudy"},{"code":"28","date":"04 Jan 2017","day":"Wed","high":"-1","low":"-3","text":"Mostly Cloudy"},{"code":"30","date":"05 Jan 2017","day":"Thu","high":"-1","low":"-3","text":"Partly Cloudy"}],"description":"<![CDATA[<img src=\"http://l.yimg.com/a/i/us/we/52/26.gif\"/>\n<BR />\n<b>Current Conditions:</b>\n<BR />Cloudy\n<BR />\n<BR />\n<b>Forecast:</b>\n<BR /> Tue - Cloudy. High: 4Low: 2\n<BR /> Wed - Cloudy. High: 5Low: 1\n<BR /> Thu - Partly Cloudy. High: 2Low: -1\n<BR /> Fri - Mostly Sunny. High: 0Low: -2\n<BR /> Sat - Sunny. High: 0Low: -3\n<BR />\n<BR />\n<a href=\"http://us.rd.yahoo.com/dailynews/rss/weather/Country__Country/*https://weather.yahoo.com/country/state/city-695681/\">Full Forecast at Yahoo! Weather</a>\n<BR />\n<BR />\n(provided by <a href=\"http://www.weather.com\" >The Weather Channel</a>)\n<BR />\n]]>","guid":{"isPermaLink":"false"}}}}}}
2016.12.27 15:44:09 4: [MyTwilight] 26=Cloudy 4, correction: 1.6°
2016.12.27 15:44:09 1: HMLAN_Parse: MyHMLAN new condition disconnected
2016.12.27 15:44:09 3: Opening MyHMLAN device 192.168.178.28:1000
2016.12.27 15:44:09 1: HMLAN_Parse: MyHMLAN new condition init
2016.12.27 15:44:09 3: MyHMLAN device opened
2016.12.27 15:44:10 3: Opening MyCUL device /dev/serial/by-id/usb-busware.de_CUL868-if00
2016.12.27 15:44:11 3: MyCUL: Possible commands: BCFiAZEGMRTVWXefmltux
2016.12.27 15:44:11 3: MyCUL device opened
2016.12.27 15:44:11 3: Opening MyHChh device /dev/serial/by-id/usb-Arduino__www.arduino.cc__0043_75335313137351608232-if00
2016.12.27 15:44:11 3: Setting MyHChh serial parameters to 9600,8,N,1
2016.12.27 15:44:11 3: MyHChh device opened
2016.12.27 15:44:21 1: Including ./log/fhem.save
2016.12.27 15:44:26 3: Device Dachzimmer.Heizung added to ActionDetector with 000:10 time
Was ich nun noch probiert habe ist
1. die fhem.save weg zu löschen
2. Dachzimmer.Heizung zu dektivieren
3. MyHChh (privates Perl-Modul von mir) zu deaktivieren
Hilft alles nicht, FHEM kommt nach dem Update nicht hoch.
Was könnte ich noch halbwegs zielführendes probieren? Kann die Verschiebung des SVN Repository was damit zu tun haben?...
ZitatKann die Verschiebung des SVN Repository was damit zu tun haben?...
Kann ich mir beim besten Willen nicht vorstellen.
ZitatWas könnte ich noch halbwegs zielführendes probieren?
Mal das tun, was man Dir vorgeschlagen hat ? List des devices einstellen, exclude probieren, log-Auszug des Updates einstellen...
Auch, wenn Du es Dir vermutlich nicht vorstellen kannst, aber Du hast ein individuelles Problem. Um Dir bei der Lösung zu helfen benötigen wir individuelle Informationen, auch wenn die nicht direkt oder unbedingt zur Lösung führen.
Wenn ich mir mein fhem angucke, sehe ich z.B., dass das 98_hminfo.pm einen Stand vom 5.12.16 hat. Also hast Du es gegenüber Deiner alten lauffähigen Version mit dem Update verändert :o Ob dann ein exclude hilft, kann ich Dir nicht sagen, aber möglich wäre es.
ZitatSo, ein
Code: [Auswählen]
ist doch prima, wenn das so klappt, dann hast Du aber doch jetzt die Voraussetzung geschaffen, um etwas auszuprobieren.
Hilfreich wäre sicherlich, wenn Du prüfst, ob fhem sich verabschiedet oder Du nur nicht zugreifen kannst, es also irgendwo hängt. Ein Start mit attr global verbose 5, wäre auch noch einen Versuch wert. Vielleicht kommt dann ja was ganz anderes als das 98_hminfo.pm zum Vorschein.
List welchen Devices? Das Dachzimmer.Heizung kann ich komplett aus der fhem.cfg raus nehmen, aber FHEM läuft trotz dem nicht an.
habe ich ja schon probiert. Und - ja - FHEM russt komplett ab...
Log des (letzten) Updates + Anlauf (mit verbose 5) im Anhang...
So, habe jetzt nach dem Update die 98_HMinfo.pm aus dem Backup zurückgeholt:
# cp -p /opt/fhem/restoreDir/2016-12-27/FHEM/98_HMinfo.pm /opt/fhem/FHEM/98_HMinfo.pm
Und siehe da, FHEM läuft wieder. Dann muss der Fehler doch an der 98_HMinfo.pm liegen - oder? Und nun?
Ach..... mit dem vorgeschlagenen exclude wärst Du früher dahinter gekommen ::)
Schreib bitte den letzten Log-Auszug in code-tags oder, vielleicht besser, lösch das meiste und mach ......
Du hast schon editiert ;)
Wie gesagt, zu HM kann ich gar nix sagen. Vielleicht im HM-Unterforum einen neuen Thread eröffnen, nachdem Du per SuFu geguckt hast, was und warum die hminfo geändert wurde.
Die 98_HMinfo.pm aus dem trunk (https://svn.fhem.de/trac/browser/trunk/fhem/FHEM; Rev. 12817 vom 18.12.2016 13:03:46) läuft bei mir nicht. Die habe ich mir dann wohl auch mit dem Update eingefangen. Die aus dem letzten tag (21.12.2016 16:18:53; https://svn.fhem.de/trac/browser/tags/FHEM_5_7/FHEM; Rev. 9830 vom 08.11.2015 19:04:41) geht noch. Die vor dem Update bei mir installierte ist allerdings aktueller (Rev. 11172 vom 2016-04-02 14:15:14), als die im letzten tag, obwohl mein letztes Update lange davor war? Alles sehr verwirrend!?
Um zwischen Rev. 11172 und Rev. 12817 gab es 19 Revs. Selbst wenn ich jetzt ausprobieren würde, ab welchem mein Problem besteht, was mache ich dann damit?
ZitatUm zwischen Rev. 11172 und Rev. 12817 gab es 19 Revs. Selbst wenn ich jetzt ausprobieren würde, ab welchem mein Problem besteht, was mache ich dann damit?
Nix :-X
Ich dachte Du hättest vielleicht einen Thread gefunden, wo irgendwelche Neuerungen(andersartige Definition, Attribute...) beschrieben wären, die Du noch nicht implementiert hast. Verschieb doch den Beitrag ins HM-Unterforum oder mach dort einen neuen Thread auf. Die dortigen Experten sehen bestimmt sehr schnell, wo es hakt.
Erst mal zur Doku.: Mein Fehler tritt mit 98_HMinfo.pm ab Rev. 11535 (28.05.2016 09:53:40) auf, Rev. 11523 (26.05.2016 09:33:27) geht noch...
So, habe das jetzt unter HM als neuen Thread gestellt: https://forum.fhem.de/index.php?topic=63511.new#new (https://forum.fhem.de/index.php?topic=63511.new#new)
Ja, Updates können tödlich sein. Selbst schon erfahren.
send from OP3
Ha, da kann ich Dir vielleicht doch noch weiterhelfen. Ich hatte eben schon einmal in das neue SVN geguckt(und gelernt wie man es benutzt) und das neue Attribut autoLoadArchive im Verdacht. Wenn ich jetzt ins diff der von Dir genannten Versionen gucke, fällt es mir sofort wieder ins Auge. Setz doch mal das Attribut auf 0 und probier es noch einmal mit der neuen Version.(Die Stelle ist nach meinem Verständnis auch nicht sauber programmiert)
