ich versucher gerade einen HM-PB-6-WM55 anlegen zu lassen (culCUBE ohne hmid, de soll nur lauschen). bei allen geräten klapt es nur bei dem HM-PB-6-WM55 nicht.
nach dem er im anlernmodus ist wird das device angelegt, aber ohne channels und ohn subtype/model. setzen des model per hand bringt nichts
CFGFN
DEF 2FBD07
IODev cubeCUN
LASTInputDev cubeCUN
MSGCNT 35
NAME HM_2FBD07
NOTIFYDEV global
NR 388
STATE ???
TYPE CUL_HM
cubeCUN_MSGCNT 35
cubeCUN_RAWMSG A162CA0102FBD07F100000202000A000B000C0018000000::-54:cubeCUN
cubeCUN_RSSI -54
cubeCUN_TIME 2016-12-31 14:04:01
lastMsg No:2C - t:10 s:2FBD07 d:F10000 0202000A000B000C0018000000
protLastRcv 2016-12-31 14:04:01
protResnd 1 last_at:2016-12-31 14:04:01
protSnd 2 last_at:2016-12-31 14:04:01
protState CMDs_done
rssi_at_cubeCUN min:-56.5 avg:-51.24 max:-44.5 lst:-54 cnt:35
Readings:
2016-12-31 14:03:24 D-firmware 1.2
2016-12-31 14:03:24 D-serialNr LEQ0636100
2016-12-31 14:04:01 PairedTo 0x000000
2016-12-31 14:04:01 R-pairCentral 0x000000
2016-12-31 14:04:01 RegL_00. 02:00 0A:00 0B:00 0C:00 18:00 00:00
2016-12-31 14:00:24 trigger Short_160
2016-12-31 14:00:20 triggerTo_4B24C0 Short_160
2016-12-31 14:00:21 triggerTo_HM_az_hz Short_160_ack
2016-12-31 14:00:24 triggerTo_HM_bz_hz Short_160_ack
2016-12-31 14:00:23 triggerTo_HM_ku_hz Short_160_ack
2016-12-31 14:00:21 triggerTo_HM_sz_az Short_160_ack
2016-12-31 14:00:22 triggerTo_HM_wz_hz Short_160_ack
2016-12-31 14:00:24 trigger_cnt 160
Helper:
BNO 160
BNOCNT 9
HM_CMDNR 44
cSnd ,01F100002FBD0700040000000000
Ack:
4B24C0 HM_2FBD07:11
Expert:
def 1
det 0
raw 1
tpl 0
Io:
newChn +2FBD07,00,00,00
nextSend 1483189441.77258
prefIO
rxt 0
vccu
p:
2FBD07
00
00
00
Mrssi:
mNo 2C
Io:
cubeCUN -52
Prt:
bErr 0
sProc 0
Rspwait:
Q:
qReqConf
qReqStat
Role:
chn 1
dev 1
Rpt:
IO cubeCUN
flg A
ts 1483189441.67398
ack:
HASH(0x80ed7b8)
2C8002F100002FBD0700
Rssi:
At_cubecun:
avg -51.2428571428571
cnt 35
lst -54
max -44.5
min -56.5
Shadowreg:
DbLogExclude .*
IODev cubeCUN
autoReadReg 4_reqStatus
expert 2_raw
firmware 1.2
model unknown
room CUL_HM
serialNr LEQ0636100
subType
Löschen, neu anlernen schon versucht?
Und
Meines Wissens werden die Kanäle mancher Geräte erst bei erfolgreichem Anlernen angelegt. Warum willst Du das nicht tun ("ohne hmID")?
gelöscht und hmid beim culCube gesetzt, danach einmal anlernmode gestezt und das selbe. model unknown.
Zitatmodel unknown.
sniffe mal die anlernmessage. da muss der modelcode drinstehen.
