In fhem the max radiator valve has something called RSSI. What is that?
http://lmgtfy.com/?q=RSSI
Thanks. I had assumed that RSSI was some max parameter and not a standard term. Dunno why I thought that, DOH!
Update: Do you know what the figures mean? What is a good level and what is not?
Hi malc_b
In the figure you see a lot of RSSI-levels of my MAX radiatorvalves (MAX_CV) and some wallthermostats (MAX_WT).
I think all levels are good (I have no problems) but de levels must not below -85 dB.
SibbeH
