Ich habe seit ein paar Tagen wieder das Problem, dass mein Neigungssensor nicht signieren will, obwohl ich das störende RPi-Modul erstmal ausgestellt habe... Das Problem ist dieses Mal auch ein anderes: aesKeyNbr der VCCU steht auf 00, obwohl 2 AES-Schlüssel eingetragen sind und ich auch nichts bewußt an der Konfiguration geändert habe:
DEF F3A460
IODev nanoCUL
LASTInputDev nanoCUL
MSGCNT 6
NAME VCCU
NOTIFYDEV global
NR 72
NTFY_ORDER 50-VCCU
STATE nanoCUL:ok,
TYPE CUL_HM
assignedIOs nanoCUL
lastMsg No:50 - t:3F s:F3A460 d:000000 020220127B50
nanoCUL_MSGCNT 6
nanoCUL_RAWMSG A0F50943FF3A460000000020220127B50::-40.5:nanoCUL
nanoCUL_RSSI -40.5
nanoCUL_TIME 2017-01-18 19:22:23
protLastRcv 2017-01-18 19:22:23
rssi_at_nanoCUL max:-40.5 cnt:6 min:-40.5 avg:-40.5 lst:-40.5
Readings:
2017-01-18 17:48:06 CommandAccepted yes
2017-01-18 11:00:11 aesKeyNbr 00
2016-12-28 21:28:24 aesReqTo Garage_TorNeigung
2017-01-18 16:53:41 state nanoCUL:ok,
2016-10-30 11:09:32 unknown_3E84A8 received
2016-10-18 21:01:26 unknown_400FE5 received
2016-10-16 22:03:09 unknown_469DBC received
2016-10-20 21:10:30 unknown_46F729 received
2016-11-04 21:43:08 unknown_4B50C1 received
2016-10-26 22:42:29 unknown_4CFDD8 received
2016-11-19 20:18:47 unknown_4CFDD9 received
2016-10-22 15:22:25 unknown_4EA476 received
2017-01-02 14:24:43 unknown_510207 received
2016-12-19 12:12:03 unknown_510223 received
2016-12-21 10:46:25 unknown_51027E received
2016-12-21 10:46:27 unknown_510299 received
2016-12-20 11:52:20 unknown_5102AC received
2016-12-04 10:19:22 unknown_51033C received
2017-01-02 14:15:24 unknown_510371 received
2016-10-29 00:00:39 unknown_F3A461 received
Helper:
HM_CMDNR 80
mId FFF0
rxType 1
supp_Pair_Rep 0
Ack:
Expert:
def 1
det 0
raw 0
tpl 0
Io:
nextSend 1484763743.81609
vccu VCCU
ioList:
nanoCUL
Mrssi:
mNo 50
Io:
nanoCUL -38.5
Prt:
bErr 0
sProc 0
Rspwait:
Q:
qReqConf
qReqStat
Role:
chn 1
dev 1
vrt 1
Rssi:
At_nanocul:
avg -40.5
cnt 6
lst -40.5
max -40.5
min -40.5
Tmpl:
IODev nanoCUL
IOList nanoCUL
IOgrp VCCU
hmKey 01:<key1>
hmKey2 02:<key2>
model CCU-FHEM
room VCCU
subType virtual
webCmd virtual:update
Der Neigungssensor hat natürlich auch 2 Schlüssel gesetzt, die auch schon mal funktioniert haben, eine bewusste Änderung gab es auch hier nicht (aesCommReq habe ich temporär deaktiviert):
DEF 4B50C1
IODev nanoCUL
NAME Garage_TorNeigung
NOTIFYDEV global
NR 140
NTFY_ORDER 50-Garage_TorNeigung
STATE closed
TYPE CUL_HM
Readings:
2017-01-18 16:53:41 Activity alive
2016-12-28 21:52:08 CommandAccepted yes
2017-01-15 14:28:27 D-firmware 1.5
2017-01-15 14:28:27 D-serialNr NEQ0674842
2017-01-15 14:26:33 PairedTo 0xF3A460
2016-12-10 14:56:58 R-cyclicInfoMsg on
2016-12-06 20:34:53 R-pairCentral 0xF3A460
2016-12-06 20:34:53 R-sabotageMsg on
2016-12-28 21:52:09 R-sign on
2017-01-15 14:26:33 RegL_00. 02:01 09:01 0A:F3 0B:A4 0C:60 10:01 14:06 00:00
2017-01-15 14:26:33 RegL_01. 08:01 20:60 22:64 23:00 30:06 00:00
2017-01-15 14:41:35 aesCommToDev fail
2016-12-28 21:28:24 aesKeyNbr 04
2017-01-18 11:00:11 aesReqTo VCCU
2017-01-16 14:32:54 alive yes
2017-01-18 11:00:11 battery ok
2017-01-18 11:00:11 contact closed (to VCCU)
2017-01-16 14:32:54 cover closed
2017-01-15 14:23:24 powerOn 2017-01-15 14:23:24
2017-01-16 14:32:54 recentStateType info
2017-01-18 11:00:11 state closed
2017-01-15 14:41:35 trig_aes_VCCU fail:13
2017-01-18 11:00:11 trigger_cnt 23
Helper:
HM_CMDNR 1
mId 0043
rxType 12
Expert:
def 1
det 0
raw 1
tpl 0
Io:
newChn +4B50C1,00,02,00
rxt 2
vccu VCCU
p:
4B50C1
00
02
00
prefIO:
nanoCUL
Mrssi:
mNo
Prt:
bErr 0
sProc 0
Q:
qReqConf
qReqStat
Role:
chn 1
dev 1
Tmpl:
IODev nanoCUL
IOgrp VCCU:nanoCUL
actCycle 028:00
actStatus alive
autoReadReg 4_reqStatus
expert 2_raw
firmware 1.5
model HM-SEC-TIS
peerIDs 00000000,
room Garage
serialNr NEQ0674842
subType threeStateSensor
Offenbar wird der default Key (00) beim Verifizieren der Signatur verwendet, so dass die Signierung fehlschlägt. Komischerweise funktioniert das mit meinem Handsender, der bzgl. der Verschlüsselung die gleichen Einstellungen hat.
Hat jemand eine Idee?
bitte sniffe die Raw-Messages.
EDIT:
Wie genau hast Du es ausgestellt? Wenn Du es nur in Fhem deaktiviert hast, dann mischt sich die Firmware von dem Ding immernoch in den Funkverkehr ein, ich sollte das Ding dann am besten in den Bootloader schicken...
Fuehre mal bitte folgendes aus (als root):
echo 18 >/sys/class/gpio/export
echo out >/sys/class/gpio/gpio18/direction
echo 0 >/sys/class/gpio/gpio18/value
sleep 0.2
echo 1 >/sys/class/gpio/gpio18/value
Damit resettest Du das Modul und es landet (wie bei einem Kaltstart auch) im Bootloader und mischt sich nicht mehr in den Funkverkehr ein.
Viele Gruesse
Michael
Zitat von: tndx am 21 Januar 2017, 20:55:05
Und nun mit dem RPi-Modul im Bootloader, nach Deiner Anleitung (oh Wunder, es geht wieder!):
Gut :-)
10_CUL_HM.pm 13085 2017-01-15 13:24:15Z martinp876
ist bereits im Einsatz, und sollte eh besser mit dem RPi-Modul zurechtkommen, selbst wenn es noch aktiv wäre?!
Ja, sollte jetzt keine Probleme mehr geben. Ich hatte Martin einen Patch dafür geschickt, der in diese Version eingeflossen ist.
Kannst Du was erkennen, was hier das Problem ist/war?
2017.01.21 20:32:53.504 4: CUL_send: nanoCULAs 11 3E A002 F3A460 4B50C1 04E484169D69ED04
2017.01.21 20:32:53.535 4: CUL_Parse: nanoCUL A 11 3E A002 F3A460 4B50C1 04A1340000340D00 43 -40.5
Der HMUART kannte Garage_TorNeigung noch "halb", allerdings mit Keyindex 0 und hat fast gleichzeitig mit dem CUL den Signaturrequest losgeschickt. Da kam dann zum Schluss nur Murks raus, der CUL hat den zweiten Request auch gesehen und deshalb hat Fhem die KeyNbr 0 bei der VCCU eingetragen, da der HMUART unter der hmId der VCCU eine Signatur mit ID 0 angefordert hat...
BTW: Wie aktiviere ich wieder das RPi-Modul, wenn ich es wieder brauche?
Einfach wieder definieren.
Wenn man jetzt das Modul auf "close" setzt oder (im laufenden Betrieb) das Dummy-Attribut setzt, wird jetzt auch automatisch der Bootloader betreten und damit das reinfunken unterbunden.
Michael
Hallo Michael,
vielen Dank!
Dann kann ich ja morgen wieder das RPi-Modul aktivieren und habe wieder normale Funkabdeckung! *freu*
