Hallo miteinander,
nach der Definition von zwei Chromecast-Devices bekomme ich im LOG alle paar Sekunden eine Warnung:
2017.02.05 20:46:04 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5911) line 1.
2017.02.05 20:46:04 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5912) line 1.
2017.02.05 20:46:04 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5913) line 1.
2017.02.05 20:46:09 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5914) line 1.
2017.02.05 20:46:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5917) line 1.
2017.02.05 20:46:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5918) line 1.
2017.02.05 20:46:20 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5920) line 1.
2017.02.05 20:46:20 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5921) line 1.
2017.02.05 20:46:22 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5922) line 1.
2017.02.05 20:46:26 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5925) line 1.
2017.02.05 20:46:29 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5926) line 1.
2017.02.05 20:46:29 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5927) line 1.
2017.02.05 20:46:32 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5928) line 1.
2017.02.05 20:46:37 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5933) line 1.
2017.02.05 20:46:39 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5934) line 1.
2017.02.05 20:46:42 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5935) line 1.
2017.02.05 20:46:46 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5936) line 1.
2017.02.05 20:46:46 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5937) line 1.
2017.02.05 20:46:48 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5938) line 1.
2017.02.05 20:46:52 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 5939) line 1.
Habe die beiden Devices bereits entfernt und den RasPi neu gestartet. Danach war Ruhe. Seit etwa 30 Minuten tritt das Problem wieder auf.
Edit:
Nach einem Shutdown+Restart ist das LOG erst einmal in Ordnung. Allerdings ist die Reaktionszeit (RasPi 3) deutlich verlangsamt.
Mal schauen, wann das mit den LOG-Einträgen wieder anfängt.
Wäre echt Dankbar für ein paar Hinweise!
Stefan
Als erstes würde es Dir wahrscheinlich helfen, wenn du das Attribut stacktrace auf 1 setzt und dann die Details aus dem log hier postest.
Hilfreich wäre wahrscheinlich auch, wenn Du mehr darüber schreibst, was sonst noch definiert ist. Die Chromecast devices sind es vermutlich nicht, sondern soetwas wie ein notify, DOIF oder ähnliches
Schon mal vielen Dank!
2017.02.06 19:03:36 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 16302) line 1.
2017.02.06 19:03:36 1: stacktrace:
2017.02.06 19:03:36 1: main::__ANON__ called by (eval 16302) (1)
2017.02.06 19:03:36 1: (eval) called by ./FHEM/33_readingsGroup.pm (343)
2017.02.06 19:03:36 1: main::lookup2 called by ./FHEM/33_readingsGroup.pm (526)
2017.02.06 19:03:36 1: main::readingsGroup_value2html called by ./FHEM/33_readingsGroup.pm (1063)
2017.02.06 19:03:36 1: main::readingsGroup_2html called by ./FHEM/33_readingsGroup.pm (1550)
2017.02.06 19:03:36 1: main::readingsGroup_Get called by fhem.pl (3304)
2017.02.06 19:03:36 1: main::CallFn called by fhem.pl (1714)
2017.02.06 19:03:36 1: main::CommandGet called by fhem.pl (1107)
2017.02.06 19:03:36 1: main::AnalyzeCommand called by fhem.pl (976)
2017.02.06 19:03:36 1: main::AnalyzeCommandChain called by ./FHEM/01_FHEMWEB.pm (2387)
2017.02.06 19:03:36 1: main::FW_fC called by ./FHEM/01_FHEMWEB.pm (825)
2017.02.06 19:03:36 1: main::FW_answerCall called by ./FHEM/01_FHEMWEB.pm (526)
2017.02.06 19:03:36 1: main::FW_Read called by fhem.pl (3304)
2017.02.06 19:03:36 1: main::CallFn called by fhem.pl (674)Scheint, als ob ich das reproduzieren könnte mit dem Aufruf der Tablet UI.
Dort habe ich eine readingsGroup für den Batteriestatus und eine für Spritpreise.
Könnte das die richtige Spur sein, oder doch Richtung norify, DOIF suchen?
Oder die Anrufliste, oder...
Readingsgroup ist wohl die richtige Spur - fällt in meiner Auflistung unter "ähnliches"
Es scheint tatsächlich die rg zum Batteriestatus zu sein.
DEF .*:[bB]attery
NAME rgBatterieStatus
NR 411
NTFY_ORDER 50-rgBatterieStatus
STATE Initialized
TYPE readingsGroup
mayBeVisible 1
Content:
AMADCommBridge 1
AbwesendCamAn 1
test 1
test2 1
Content2:
DEVICES:
ARRAY(0x4367b20)
ARRAY(0x436cba8)
ARRAY(0x4353a58)
Fhem:
lastDefChange 1
last_update 1486489082.19689
Helper:
DEF
valueFormat { my ($wert) = $VALUE =~ m/(\d+)/; return $VALUE if ($wert eq ""); return "critical" if ($wert < 25); return "low" if ($wert < 50); return "ok" if ($wert > 50);}
Positions:
Flurschalter_13.battery 51:1
Flurschalter_4.battery 53:1
Flurschalter_7.battery 54:1
HM_50D474.battery 56:1
HueMotionFlur.battery 73:1
LaCrosse_05.battery 85:1
LaCrosse_1D.battery 86:1
LaCrosse_20.battery 87:1
Valueicon:
battery.critical measure_battery_25@red
battery.low measure_battery_50@yellow
battery.ok measure_battery_100@green
Values:
formated:
undef
ARRAY(0x4652258)
orig:
undef
ARRAY(0x45cb2a8)
prefixsuffix:
undef
ARRAY(0x45c0aa0)
room entwicklung
style style="text-align:left"
valueIcon {'battery.ok' => 'measure_battery_100@green', 'battery.low' => 'measure_battery_50@yellow', 'battery.critical' => 'measure_battery_25@red'}
Da hier die Battery über alle Devices etc. eingelesen werden, wird es wohl schwer da was zu finden.
Werde wohl auf einzelne Abfragen für die relevanten, batteriebetriebenen Sensoren / Aktoren umstellen.
Es sei denn, es fällt jemandem mein Fehler im rg auf?
Klar, wenn $VALUE nicht auf den regexp matcht, dann ist $wert undefiniert - BINGO
Ich danke Dir für die richtigen Hinweise.
Jetzt habe ich etwas ähnliches noch mit dem Kalendermodul. Werde suchen und wenn ich nicht weiterkomme im Kalenderforum um Rat fragen.
Danke nochmal!
Stefan
