FHEM => Sonstiges => Thema gestartet von: vbs am 08 Februar 2017, 12:46:24
Titel: Seit Kurzem permanent perfmon Logs
Beitrag von: vbs am 08 Februar 2017, 12:46:24
Hi Leute,
seit ein paar Tagen hab ich permanent perfmon-Einträge im Log, sieht ungefähr so aus:
2017.02.08 09:40:40.566 1: Perfmon: possible freeze starting at 09:40:39, delay is 1.566
2017.02.08 10:25:48.101 1: Perfmon: possible freeze starting at 10:25:47, delay is 1.101
2017.02.08 10:33:53.329 1: Perfmon: possible freeze starting at 10:33:52, delay is 1.329
2017.02.08 10:59:58.007 3: DbLog benDbLog: Creating Push-Handle to database mysql:database=fhem;host=localhost;port=3306 with user fhem
2017.02.08 10:59:58.009 3: DbLog benDbLog: Push-Handle to db mysql:database=fhem;host=localhost;port=3306 created
2017.02.08 11:06:36.224 1: Perfmon: possible freeze starting at 11:06:35, delay is 1.224
2017.02.08 11:12:03.063 1: Perfmon: possible freeze starting at 11:12:02, delay is 1.063
2017.02.08 11:52:13.184 1: Perfmon: possible freeze starting at 11:52:12, delay is 1.184
2017.02.08 11:58:39.276 1: Perfmon: possible freeze starting at 11:58:38, delay is 1.276
2017.02.08 12:26:07.236 1: Perfmon: possible freeze starting at 12:26:06, delay is 1.236
2017.02.08 12:36:17.543 3: DbLog benDbLog: Creating Push-Handle to database mysql:database=fhem;host=localhost;port=3306 with user fhem
2017.02.08 12:36:17.566 3: DbLog benDbLog: Push-Handle to db mysql:database=fhem;host=localhost;port=3306 created
2017.02.08 12:36:21.877 3: DbLog benDbLog: Creating Push-Handle to database mysql:database=fhem;host=localhost;port=3306 with user fhem
2017.02.08 12:36:21.879 3: DbLog benDbLog: Push-Handle to db mysql:database=fhem;host=localhost;port=3306 created
2017.02.08 12:37:34.513 3: DbLog benDbLog: Creating Push-Handle to database mysql:database=fhem;host=localhost;port=3306 with user fhem
2017.02.08 12:37:34.514 3: DbLog benDbLog: Push-Handle to db mysql:database=fhem;host=localhost;port=3306 created
2017.02.08 12:39:35.336 1: Perfmon: possible freeze starting at 12:39:34, delay is 1.336
Evtl. hängt das mit Änderungen zusammen die ich gemacht habe, evtl. hängts auch mit nem FHEM-Update von vor ein paar Tagen zusammen. Das komische ist, dass apptime überhaupt keine Hänger meldet:
                                  name             function    max  count    total  average maxDly
                              HMLAN0           HMLAN_Read    304   2412    11013     4.57      0 HASH(HMLAN0)
                      env_nty_motion          notify_Exec    199     49      377     7.69      0 HASH(env_nty_motion); HASH(fl_motion)
                    ku_lightLedFloor        WifiLight_Set    143     28      151     5.39      0 HASH(ku_lightLedFloor); ku_lightLedFloor; HSV; 350,100,20; 0.6
                         smartlights      SMARTLIGHTS_Set    143   1669      358     0.21      0 HASH(smartlights); smartlights; submit
         tmr-PRESENCE_StartLocalScan HASH(0x55ac19119e78)    126    488     3427     7.02   1055 HASH(wz_base)
         tmr-PRESENCE_StartLocalScan HASH(0x55ac1a6ff488)    121    489     3482     7.12     96 HASH(wz_openelec)
                   nty_envLuminosity          notify_Exec    118   2624      470     0.18      0 HASH(nty_envLuminosity); HASH(env_thpl)
         tmr-statistics_PeriodChange HASH(0x55ac191f80d8)    114      5      474    94.80      1 HASH(env_stats)
                    wz_lightLedCouch        WifiLight_Set    102    210      106     0.50      0 HASH(wz_lightLedCouch); wz_lightLedCouch; HSV; 0,0,0; 960
         tmr-PRESENCE_StartLocalScan HASH(0x55ac187126a8)     95    493     3548     7.20    942 HASH(fl_ben)
         tmr-PRESENCE_StartLocalScan HASH(0x55ac199fb4c0)     85    489     3554     7.27    273 HASH(wz_sub)
         tmr-PRESENCE_StartLocalScan HASH(0x55ac1a1bd3a0)     85    488     3409     6.99    905 HASH(sz_z1_pres)
                 tmr-Calendar_Wakeup HASH(0x55ac18389660)     77      4      166    41.50      1 HASH(calGoogle)
         tmr-PRESENCE_StartLocalScan HASH(0x55ac1a66d8e8)     67    487     3339     6.86    564 HASH(sz_tabS_pres)
                         tmr-at_Exec HASH(0x55ac1a678ea8)     53      1       53    53.00      0 HASH(fl_motionTimer)
               tmr-SYSSTAT_GetUpdate HASH(0x55ac199feb70)     48    136     4090    30.07      1 HASH(fl_benStats)
                                TRX0             TRX_Read     41   1381     1304     0.94      0 HASH(TRX0)
                        nty_presence          notify_Exec     36      8      100    12.50      0 HASH(nty_presence); HASH(presence)
             tmr-SB_PLAYER_GetStatus HASH(0x55ac17ab8c98)     32     54     1548    28.67    449 HASH(ku_sb)
                         tmr-at_Exec HASH(0x55ac1bb6dfb8)     32      1       32    32.00      0 HASH(fl_motionTimer)
                            sbserver       SB_SERVER_Read     32    457      770     1.68      0 HASH(sbserver)
Hat jemand eine Idee, was man da machen kann und wieso apptime davon nichts mitbekommt?
Danke euch!
Titel: Antw:Seit Kurzem permanent perfmon Logs
Beitrag von: P.A.Trick am 08 Februar 2017, 21:51:39
Hm maxdly ist hier z.B zu hoch:
Was ist denn wz_base?
Beitrag von: vbs am 08 Februar 2017, 22:52:45
Ich glaube ich weiß was passiert ist. Theorie: Es liegt nicht an FHEM, also da blockiert nix. Aber die Systemzeit meines Systems scheint nicht geradeaus zu laufen, manipuliert durch den ntpd. Der ntpd benutzt bei mir im Normalfall die Pool-Server von pool.ntp.org. Jedoch läuft parallel der DHCP-Client dhclient. Wenn nun ein DHCP-Event auftritt (zum Beispiel die regelmäßige Lease-Erneuerung), dann trägt dhclient den DHCP-Server als NTP-Server in die ntp.conf ein und startet den ntpd neu, der dann fortan meinen DHCP-Server nutzt anstatt die Pool-Server.
Mein DHCP-Server ist eine FritzBox und offenbar läuft mein System mit der Box als NTP-Server nicht so rund. Ich hab jetzt den NTP-Server in der FritzBox deaktiviert, so dass bei DHCP-Events der dhclient nicht mehr am NTP-Server manipuliert.
Werde das beobachten ob es hilft.
Quelle:
When the DHCP client program, dhclient, receives a list of NTP servers from the DHCP server, it adds them to ntp.conf and restarts the service. To disable that feature, add PEERNTP=no to /etc/sysconfig/network.
https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/6/html/Deployment_Guide/s1-Understanding_the_ntpd_Configuration_File.html
PS.: wz_base ist mein PC im Wohnzimmer :)
Beitrag von: P.A.Trick am 08 Februar 2017, 23:00:06
Hört sich unwahrscheinlich an! Hast du so etwas wie presence o.ä. Laufen?
Beitrag von: marvin78 am 08 Februar 2017, 23:03:36
Nutzt du readingsProxy? Mach mal ein
apptime maxDly
und schaue, ob sich readingsProxy_setNotfiyDev unter den Übeltätern befindet. Das ist bei mir aktuell die Ursache für viele Freezes und ich habe noch nicht analysieren können warum.
Beitrag von: vbs am 08 Februar 2017, 23:10:52
Ja presence hab ich, aber IIRC forking, also sollte nicht blockieren.
Ja stimmt, klingt unwahrscheinlich, aber folgende Indizien:
- System lief problemlos und auf einmal fing das an -> Systemzeit war ok bis ein DHCP-Event die NTP-Config verdreht hat
- perfmon bemerkt ein Problem, apptime meldet aber keine Blockierung -> offenbar ist perfmon sensibel ggü. Zeitsprüngen, apptime jedoch nicht
- systemd meldet andauernd, dass sich die Systemzeit geändert hat:
Feb  8 09:01:43 minion systemd[1]: Time has been changed
Feb  8 09:08:53 minion systemd[1]: Time has been changed
Feb  8 09:24:06 minion systemd[1]: Time has been changed
Feb  8 09:40:40 minion systemd[1]: Time has been changed
Feb  8 09:52:46 minion systemd[1]: Time has been changed
Feb  8 09:59:36 minion systemd[1]: Time has been changed
Feb  8 10:14:43 minion systemd[1]: Time has been changed
Feb  8 10:25:47 minion systemd[1]: Time has been changed
Feb  8 10:33:53 minion systemd[1]: Time has been changed
Feb  8 10:41:00 minion systemd[1]: Time has been changed
Feb  8 10:50:30 minion systemd[1]: Time has been changed
Feb  8 11:06:36 minion systemd[1]: Time has been changed
Feb  8 11:12:02 minion systemd[1]: Time has been changed
Feb  8 11:20:28 minion systemd[1]: Time has been changed
Feb  8 11:35:25 minion systemd[1]: Time has been changed
Feb  8 11:52:12 minion systemd[1]: Time has been changed
Feb  8 11:58:39 minion systemd[1]: Time has been changed
Die perfmon-Meldungen decken sich zeitlich 1:1 mit den systemd-Meldungen:
Also gerade aufgrund der Logeinträge würde ich Geld drauf wetten, dass das der Grund ist.
@marvin78:
Nee, hab kein readingsProxy
Beitrag von: herrmannj am 08 Februar 2017, 23:15:43
Zitatoffenbar ist perfmon sensibel ggü. Zeitsprüngen
yepp. Perfmon misst die relative Verzögerung. Wenn die Uhr sich ändert könnte dieser Effekt auftreten, der Zeitsprung muss jedoch eine Sekunde betragen. Das wäre viel weil bei Dir ja auch häufig.
vg
joerg
Beitrag von: vbs am 09 Februar 2017, 10:13:17
Hm, ich hatte ja eigentlich gedacht, dass der NTP-Server der FritzBox evtl. zu ungenau ist und daher auch die Probleme kommen. Es stellt sich heraus, dass mein System (Ubuntu-VM) plötzlich generell ein Problem hat, die Zeit synchron zu halten. Nach 90 Minuten Laufzeit hab ich schon knapp 10 Sekunde Offset zur Referenzzeit.
Seltsam... Ich hab ntpd installiert vor ca. 2 Wochen nachdem ich VMWare's Timekeeping Best Practice gelesen habe und daraufhin hat das System die Zeit zumindest stabil mit einem Offset von ca. 80 ms gehalten. Und nun fängt es auf einmal so stark an zu driften :(
Beitrag von: Wernieman am 09 Februar 2017, 10:30:09
Also eigentlich macht npd keine Zeitsprünge. npd läsr die Softwareuhr schneller/langsamer laufen, aber keine Zeitsprünge.
Es sei denn ... Du hast einen Cron mit ntpdate eingerichtet.
was sagt denn ein "ntpq -p" auf Deinem System?
Beitrag von: vbs am 09 Februar 2017, 10:40:42
Doch doch, ntpd macht schon Zeitsprünge, nennt sich "steps". Das passiert wenn der aktuelle Offset größer ist als der konfigurierte step threshold (default 128 ms).
Du kannst auch ntpd mit "-x" starten. Das ist dann der Slew Mode in dem wirklich nie steps gemacht werden.
Ich hab momentan ntpd in diesem slew mode laufen und mal zu sehen wie sich der Offset entwickelt. Sieht momentan so aus (Offset wird immer größer):
    remote           refid      st t when poll reach   delay   offset  jitter
+ivanova.ganneff 192.53.103.108   2 u   42   64  377   20.710  12073.5 424.774
-ntp4.v-bits.nl  78.46.93.106     3 u    2   64  377   20.190  11445.2 520.284
*ntp0.rrze.uni-e .GPS.            1 u   58   64  377   18.378  11577.7 339.617
+s1.vlns.de      176.221.46.134   3 u    2   64  377   20.569  11568.2 418.842
Also seit ca. 8 Uhr nun ~ 12 s Offset. Wenn ich ihn ohne slew mode laufen lassen, dann setzt ntpd regelmäßig die Zeit hart, so dass der Offset auf 0 springt. Aber dann meckert auch FHEM's perfmon.
Die Uhr des Systems läuft einfach viel zu schnell/langsam. Offenbar auch so stark, dass ntpd das nicht ausgleichen kann. Ich glaube ntpd korrigiert maximal mit 0,5ms/s.
Im Moment (mit slew) hab ich keine Zeitsprünge aber dafür geht die Uhr einfach falsch  ::)
Beitrag von: herrmannj am 09 Februar 2017, 11:15:01
ZitatNach 90 Minuten Laufzeit hab ich schon knapp 10 Sekunde Offset zur Referenzzeit.
na denn erklären sich die perfmon Meldungen. Perfmon merkt das es (vermeintlich) später aufgerufen wird als geplant. Das genau meldet es dann: "Achtung, hier stimmt was nicht"
vg
joerg
Beitrag von: Wernieman am 09 Februar 2017, 11:17:03
Mir fällt spontan ein:
- Auf was für ein System/Distri arbeitest Du?
Beitrag von: vbs am 09 Februar 2017, 11:28:23
Der Rechner ist nativ ein Windows 10 mit Intel i5 CPU. Da läuft dann ein aktuelles VMWare Workstation mit einem Ubuntu 16.10 x64 Gast.
Laut diesem Best-Practice-Guide (https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1006427) sind da keine weiteren Kernel-Tweaks notwendig und es ist der Einsatz von ntpd anstatt der eigenen VMWare-Zeittools empfohlen.
Das Ganze lief halt jetzt ca. 2 Wochen ohne Probleme mit einem recht konstanten Offset von ca. 50 ms. Seit zwei Tagen dreht dir Uhr einfach total durch :(
Beitrag von: Wernieman am 09 Februar 2017, 13:46:58
Mhhhh ......
Habe gerade versucht mich auf die schnelle einzulesen und habe gerade anderweitiges gelesen.
Hast Du die VMTools installiert?
Allerdings gebe ich Dir Recht, das sehr unterschiedliche Angaben im Netz zu finden sind. Hast Du folgendes gelesen?
https://kb.vmware.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=1011771&sliceId=1&docTypeID=DT_KB_1_1&dialogID=780562710&stateId=1%200%20780582396 (https://kb.vmware.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=1011771&sliceId=1&docTypeID=DT_KB_1_1&dialogID=780562710&stateId=1%200%20780582396)
Bzw:
Geht die Uhr von Deinem Windows-Rechner richtig?
Beitrag von: vbs am 09 Februar 2017, 15:01:42
Ja die hab ich, aber die timeSync-Option gemäß BestPractices momentan deaktiviert.
Vielen Dank! Ich bin da auch schonmal drüber gestolpert und werde das nachher mal in Ruhe durcharbeiten.
Das hier fand ich auch interessant (ist aber schon sehr alt. Ich weiß nicht, ob das noch zutrifft):
http://vmblog.com/archive/2007/08/24/help-vmware-fixing-time-keeping-problems-with-the-guest-os.aspx#.WJx1-N8k7mF
Da gehts drum, dass VMWare die CPU-Frequenz des Hosts kennen muß. Wird normalerweise wohl automatisch erkannt. Vielleicht liegt da was im Argen bei mir. Mir ist nicht ganz klar, wie sich das verhalten soll, wenn die CPU dynamisch die Frequenz ändert.
Gehe ich eigentlich von aus. Ist ein normaler (hoffentlich) korrekt eingerichteter Windows-10-PC. Werde ich aber auch nochmal überprüfen nachher.
Beitrag von: dev0 am 09 Februar 2017, 15:47:48
Ich kann Dir, in einer VMWare Umgebung, auch nur empfehlen die Zeit der VMs nicht mit dem Host, sondern mit dem typischen Mechanismus der Betriebssysteme zu synchronisieren. Ich hatte selbst vor 4-5 Jahren bei einem internationalem Kunden größte Probleme die Zeitsynchronisierung in den Griff zu bekommen, da die Konfiguration der VM Hosts nicht unter unserer europäischen Hoheit lag.
In jedem Fall für Linux einen (zentralen) ntp Server und nicht den die Synchronisierung mit dem Host nutzen. Wenn die VMWare Tools installiert sind, dann sollten mit aktuellen Betriebssystemen auch keine Anpassungen mehr nötig sein.
Just my 2 cents...
Beitrag von: vbs am 09 Februar 2017, 16:38:03
Ja hab ich bei mir auch so eingerichtet. Aber ich glaube, dass in meinem Fall gar nicht die Zeitsynchronisierung selbst das Problem ist, sondern dass einfach die System-Uhr der VM viel zu langsam läuft (ungefähr 1 Minute in 10 Stunden). Normale kleine Unterschiede könnte ntpd wohl ausgleichen aber nicht in diesen Dimensionen.
Beitrag von: vbs am 10 Februar 2017, 09:06:30
Hm, also es ist komisch. Aber vorweg, das sieht jetzt (im Moment) so aus:
0.ubuntu.pool.n .POOL.          16 p    -   64    0    0.000    0.000   0.000
1.ubuntu.pool.n .POOL.          16 p    -   64    0    0.000    0.000   0.000
2.ubuntu.pool.n .POOL.          16 p    -   64    0    0.000    0.000   0.000
3.ubuntu.pool.n .POOL.          16 p    -   64    0    0.000    0.000   0.000
ntp.ubuntu.com  .POOL.          16 p    -   64    0    0.000    0.000   0.000
-62.4.12.66      145.238.203.14   2 u  128 1024  377   25.040    0.704  12.100
*hetzner0.intern 194.97.129.17    2 u  597 1024  377   20.077    1.716  13.263
-tartaros.dust-p 126.94.231.148   2 u  580 1024  377   21.429    2.237  13.428
+ntp1.m-online.n 212.18.1.106     2 u   53 1024  377   48.820   -8.851  10.319
+totoro.ax86.net 36.224.68.195    2 u  586 1024  377   18.389    1.482  13.533
Meiner Meinung nach traumhaft Werte, also erstmal gut :)
Aber so ganz trau ich dem Braten noch nicht. Was ich gemacht habe:
- ich hab wie beschrieben (https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1011771) den timeTracker aktiviert, der hat jedoch keine Fehler gezeigt (immer "behind 0 us")
- dann hab ich wie hier beschrieben (https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1591) "noTSC" in die config.ini eingetragen und dann waren die Werte gut. Aber ich hab dann das noTSC testweise als Gegenprobe wieder rausgenommen und es war immer noch gut  :o
Also das war so
- VM runtergefahren
- noTSC -> config.ini
- VM hochgefahren
-> Zeit war gut
- VM runter gefahren
- noTSC wieder rausgenommen
- VM hochgefahren
-> Zeit immer noch gut (??)
- Host-PC rebootet
-> Zeit wieder schlecht (??)
- VM runter
- wieder noTSC eingetragen
- VM hoch
-> Zeit wieder gut
- Host-PC rebootet
Sah aus als ob das Setzen von noTsc greift sobald man nur die VM rebootet, das Ausschalten jedoch ein Reboot des Host-PC erfordert  :o
Lange Rede, kurzer Sinn: mit dem noTsc gehts jetzt. Da das Verhalten für mich nicht so 100% konsistent ist, habe jedoch noch etwas Rest-Angst, dass das noch nicht die ganze Geschichte war.
Weiß jemand ob dieses noTsc irgendwelche Nachteile hat? Kommt mir auch etwas spanisch vor, dass man einfach diese Traumwerte bekommt wenn man es setzt? Muss doch einen Grund geben, warum das nicht defaultmäßig gesetzt ist?
Danke euch!
