FHEM - Hausautomations-Systeme => Homematic => Thema gestartet von: Kusselin am 11 März 2017, 21:07:19
Titel: Sieht die "list" vom Device O.K. aus?
Beitrag von: Kusselin am 11 März 2017, 21:07:19
Hallo Zusammen,
habe versucht den Temp-Feuchte Sensor HM Homematic 132030 Funk-Wandthermostat für Smart Home / Hausautomation mit meinem CUL zu pairen...nun meine Frage...sieht das Pairing o.k. aus?
   CFGFN
   CUL868_MSGCNT 469
   CUL868_RAWMSG A0CB984702D899700000000D92F::-76.5:CUL868
   CUL868_RSSI -76.5
   CUL868_TIME 2017-03-11 20:59:49
   DEF        2D8997
   IODev      CUL868
   LASTInputDev CUL868
   MSGCNT     469
   NAME       HM_2D8997
   NOTIFYDEV  global
   NR         708
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 HM_2D8997_Weather
   channel_02 HM_2D8997_Climate
   channel_03 HM_2D8997_WindowRec
   channel_06 HM_2D8997_remote
   channel_07 HM_2D8997_SwitchTr
   lastMsg    No:B9 - t:70 s:2D8997 d:000000 00D92F
   protCmdDel 7
   protLastRcv 2017-03-11 20:59:49
   protResnd  2 last_at:2017-03-11 13:18:00
   protResndFail 1 last_at:2017-03-11 13:18:02
   protSnd    66 last_at:2017-03-11 13:18:04
   protState  CMDs_done
   rssi_at_CUL868 lst:-76.5 avg:-63.05 min:-82.5 max:-37.5 cnt:469
   Readings:
     2017-03-11 13:17:39   Activity        alive
     2017-03-11 13:17:39   CommandAccepted yes
     2017-03-11 13:17:39   D-firmware      1.1
     2017-03-11 13:17:39   D-serialNr      LEQ0592936
     2017-03-11 13:17:40   PairedTo        0x123456
     2017-03-11 13:17:40   R-burstRx       on
     2017-03-11 13:17:40   R-cyclicInfoMsg on
     2017-03-11 13:17:40   R-cyclicInfoMsgDis 0
     2017-03-11 13:17:40   R-pairCentral   0x123456
     2017-03-11 13:17:40   RegL_00.          01:01 02:01 09:01 0A:12 0B:34 0C:56 0F:00 11:00  12:16 16:00 18:00 19:00 1A:00 00:00
     2017-03-11 13:18:02   RegL_07.
     2017-03-11 20:49:41   battery         ok
     2017-03-11 20:49:41   batteryLevel    3.1
     2017-03-11 20:49:41   desired-temp    21.0
     2017-03-11 20:49:41   measured-temp   21.7
     2017-03-11 13:18:04   state           CMDs_done
     2017-03-11 13:17:41   time-request    -
   Helper:
     HM_CMDNR   185
     cSnd       011234562D899702040000000008,011234562D899702040000000009
     mId        00AD
     rxType     6
     supp_Pair_Rep 0
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +2D8997,00,00,00
       nextSend   1489262389.17462
       prefIO
       rxt        0
       vccu
       p:
         2D8997
         00
         00
         00
     Mrssi:
       mNo        B9
       Io:
         CUL868     -74.5
     Prt:
       awake      0
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_cul868:
         avg        -63.0565031982943
         cnt        469
         lst        -76.5
         max        -37.5
         min        -82.5
     Shregw:
       07         02
     Shadowreg:
   IODev      CUL868
   actCycle   000:10
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   1.1
   model      HM-TC-IT-WM-W-EU
   msgRepeat  1
   room       CUL_HM
   serialNr   LEQ0592936
   subType    thermostat
   webCmd     getConfig:clear msgEvents
Titel: Antw:Sieht die "list" vom Device O.K. aus?
Beitrag von: betateilchen am 11 März 2017, 21:10:42
warum fragst Du?
Drei Dinge fallen mir auf:
Beitrag von: Kusselin am 11 März 2017, 21:16:42
Zitat von: betateilchen am 11 März 2017, 21:10:42
warum fragst Du?
  • Die Nummerierung der Channels. Aber genau das gleiche habe ich neulich in meiner Installation auch festgestellt, aber solange alles funktioniert (und das tut es) mache ich mir darüber keine Gedanken.
  • Die Firmware ist relativ alt.
  • Deine Frage ist im komplett falschen Forumbereich.
zu 1:) da kenne ich mich nicht aus..wenn du aber sagst das es o.k. ist dann....
zu 2.) habe einen Raspi mit CUL 868 im HM Modus...das man ein Firmware Update der Komponenten ohn CCU machen kann wusste ich nicht! Wie funzt das also wie geht man hier vor?
zu 3:) sorry das tut mir leid...dann soll der admin das bitte entsprechend verschieben..
Beitrag von: betateilchen am 11 März 2017, 21:23:25
zu 2: ein Update wird mit einem CUL vermutlich nicht funktionieren (zumindest weiß ich das nicht genau) aber das habe ich ja auch nicht behauptet :)
zu 3: Du kannst den Thread auch selbst nach Homematic verschieben. Links unten auf der Seite müsste es einen entsprechenden Button geben.
Beitrag von: Kusselin am 11 März 2017, 22:48:52
Hi betateilchen,
Danke Dir..Beitrag verschoben.
Nun sag doch mal wie ich ein Update anstossen kann?
Beitrag von: Thorsten Pferdekaemper am 11 März 2017, 23:38:32
die Firmware-Version ist meiner Meinung nach ok. Ich habe von den Teilen sogar welche mit Firmware 1.0 laufen und keine Probleme.
Der Rest sieht meiner Meinung nach auch ok aus.
Ansonsten: https://wiki.fhem.de/wiki/HomeMatic_Firmware_Update
    Thorsten
Beitrag von: martinp876 am 12 März 2017, 16:20:53
Die Kanäle sind von eq3so festgelegt und nicht änderbar. Also alles ok.
