ich habe einen HM-MOD-Em-8, dieser ist mit einer VCCU (Cul) gepairt, oder eben nicht richtig, da ein R-pairCentral set_0x123456 drin steht.
list:
CFGFN
CUL_0_MSGCNT 125
CUL_0_RAWMSG A0B59A2403815C223A7B34204::-39:CUL_0
CUL_0_RSSI -39
CUL_0_TIME 2017-03-14 22:16:07
DEF 3815C2
IODev CUL_0
LASTInputDev CUL_0
MSGCNT 125
NAME HM_3815C2
NR 2659
STATE CMDs_pending
TYPE CUL_HM
channel_01 HM_3815C2_Btn_01
channel_02 HM_3815C2_Btn_02
channel_03 HM_3815C2_Btn_03
channel_04 HM_3815C2_Btn_04
channel_05 HM_3815C2_Btn_05
channel_06 HM_3815C2_Btn_06
channel_07 HM_3815C2_Btn_07
channel_08 HM_3815C2_Btn_08
lastMsg No:59 - t:40 s:3815C2 d:23A7B3 4204
protCmdPend 21 CMDs_pending
protErrIoAttack 17 last_at:2017-03-14 22:15:22
protErrIoId_23A7B3 21 last_at:2017-03-14 22:15:22
protLastRcv 2017-03-14 22:16:07
protResnd 2 last_at:2017-03-14 22:15:16
protSnd 2 last_at:2017-03-14 22:15:13
protState CMDs_pending
rssi_at_CUL_0 lst:-39 min:-53.5 max:-33.5 cnt:104 avg:-39.71
Readings:
2017-03-14 22:11:13 CommandAccepted yes
2017-03-14 22:15:13 D-firmware 1.0
2017-03-14 22:15:13 D-serialNr MEQ0046663
2017-03-14 22:15:13 R-pairCentral set_0x123456
2017-03-14 22:16:07 battery ok
2017-03-14 22:15:22 sabotageAttackId_ErrIoId_23A7B3 cnt:21
2017-03-14 22:15:22 sabotageAttack_ErrIoAttack cnt 17
2017-03-14 22:57:39 state CMDs_pending
cmdStack:
++A0011234563815C200050000000000
++A0011234563815C2000802010A120B340C56
++A0011234563815C20006
++A0111234563815C20400
++A0011234563815C200040000000000
++A0011234563815C201040000000001
++A0011234563815C20103
++A0011234563815C202040000000001
++A0011234563815C20203
++A0011234563815C203040000000001
++A0011234563815C20303
++A0011234563815C204040000000001
++A0011234563815C20403
++A0011234563815C205040000000001
++A0011234563815C20503
++A0011234563815C206040000000001
++A0011234563815C20603
++A0011234563815C207040000000001
++A0011234563815C20703
++A0011234563815C208040000000001
++A0011234563815C20803
Helper:
HM_CMDNR 89
cSnd 011234563815C200040000000000,011234563815C200050000000000
mId 00D9
rxType 16
Expert:
def 1
det 0
raw 1
tpl 0
Io:
newChn +3815C2,02,00,00
nextSend 1489526167.44634
nextSendLRmsg A0B59A2403815C223A7B34204
prefIO
rxt 2
vccu
p:
3815C2
00
00
00
Mrssi:
mNo 59
Io:
CUL_0 -37
Prt:
bErr 0
sProc 2
wuReSent 2
Q:
qReqConf
qReqStat
Role:
dev 1
Rssi:
At_cul_0:
avg -39.7115384615385
cnt 104
lst -39
max -33.5
min -53.5
Shadowreg:
RegL_00: 02:01 0A:12 0B:34 0C:56
IODev CUL_0
IOgrp VCCU:CUL_0
autoReadReg 4_reqStatus
expert 2_full
firmware 1.0
model HM-MOD-Em-8
room CUL_HM
serialNr MEQ0046663
subType remote
webCmd getConfig:clear msgEvents
Ich habe das Gerät schon mehrmals gelöscht und neu angelernt, aber immer mit dem selben Ergebnis.
Marek
Hallo Marek
Hast Du auch in der Bedienungsanleitung gelesen, wie dieser Teilnehmer angelernt wird? In diesem Fall soll man nur kurz auf den Taster druecken, dann blinkt die LED!
Gruss Christoph
Device nicht wieder löschen. So langeSTATE CMDs_pending steht, will FHEM noch was zum Device senden, diese hört aber nicht. In diesem Fall einfach den config-Button am Device nochmal drücken, auch mehrmals - bis STATE CMDs_pending weg ist.
@pc1246
Gruss Christoph
Ja, wenn ich den config-Knopf kurz drücke blinkt die LED grün und geht dann aus. Dann gibt es ein neues Gerät unter CUL_HM.
@automatisierer
ZitatDevice nicht wieder löschen. So lange
Code: [Auswählen]
STATE CMDs_pending
Code: [Auswählen]
STATE CMDs_pending
weg ist.
Ich kann den Config-Knopf so oft drücken wie ich will, es bleibt bei CMDs_pending. Auch nach jetzt etwa einem Monat, steht es noch auf CMDs_pending.
Marek
Zitat von: Marekh am 15 März 2017, 16:01:28
@pc1246
@automatisierer
Marek
Hallo Marek
Loesche mal die events vom device! Sonst hast du niemals eine Chance! Dann mach noch mal ein pairforsec auf der VCCU, und dann druecke kurz die Taste!
Wenn dann wirklich ein neues device erscheint, dann ist etwas nicht richtig! Ich hatte mit dem aber glaube ich auch meine Probleme! Solange noch cmds_pending dasteht, keine weiteren Befehle absenden, aber dafuer kannst Du noch mal die Taste druecken, evtl. auch mehrmals bis pending weg ist! Dann erst ein getconfig mit wieder Tastendruecken!
Viel Erfolg und Gruss Christoph
Ich habe mal alles gelöscht, auch den Cul und VCCU.
Danach den CUL neu installiert und es mal testweise ohne VCCU angelernt. Jetzt ging es.
ListInternals:
CFGFN
CUL_1_MSGCNT 292
CUL_1_RAWMSG A0BEAA2403815C2F100014105::-34:CUL_1
CUL_1_RSSI -34
CUL_1_TIME 2017-03-15 21:47:20
DEF 3815C2
IODev CUL_1
LASTInputDev CUL_1
MSGCNT 292
NAME HM_3815C2
NR 148
STATE HM_3815C2_Btn_01 LongRelease
TYPE CUL_HM
lastMsg No:EA - t:40 s:3815C2 d:F10001 4105
protErrIoAttack 8 last_at:2017-03-15 21:22:50
protErrIoId_23A7B3 8 last_at:2017-03-15 21:22:50
protLastRcv 2017-03-15 21:47:20
protResnd 14 last_at:2017-03-15 21:40:59
protSnd 106 last_at:2017-03-15 21:47:20
protState CMDs_done
rssi_at_CUL_1 max:-28.5 min:-41 cnt:292 lst:-34 avg:-34.06
Readings:
2017-03-15 21:24:16 CommandAccepted yes
2017-03-15 21:46:21 D-firmware 1.0
2017-03-15 21:46:21 D-serialNr MEQ0046663
2017-03-15 21:26:53 PairedTo 0xF10001
2017-03-15 21:24:16 R-pairCentral 0xF10001
2017-03-15 21:26:53 RegL_00: 02:01 05:00 0A:F1 0B:00 0C:01 12:00 14:03 18:00 00:00
2017-03-15 21:47:20 battery ok
2017-03-15 21:22:50 sabotageAttackId_ErrIoId_23A7B3 cnt:8
2017-03-15 21:22:50 sabotageAttack_ErrIoAttack cnt 8
2017-03-15 21:47:20 state HM_3815C2_Btn_01 LongRelease
Helper:
HM_CMDNR 234
cSnd 01F100013815C20103,01F100013815C20103
mId 00D9
rxType 16
Expert:
def 1
det 0
raw 1
tpl 0
Io:
newChn +3815C2,00,00,00
nextSend
nextSendLRmsg
prefIO
rxt 2
vccu
p:
3815C2
00
00
00
Mrssi:
mNo EA
Io:
CUL_1 -32
Prt:
bErr 0
sProc 0
Rspwait:
Q:
qReqConf
qReqStat
Role:
dev 1
Rpt:
IO CUL_1
flg A
ts 1489610840.1312
ack:
HASH(0x22a69f8)
EA8002F100013815C200
Rssi:
At_cul_1:
avg -34.0667808219178
cnt 292
lst -34
max -28.5
min -41
Shadowreg:
IODev CUL_1
expert 2_full
firmware 1.0
model HM-MOD-Em-8
room CUL_HM
serialNr MEQ0046663
subType remote
Allerdings sehen meine Reading in den Channels immer noch nicht gut aus, ich hatte da früher immer ein on/off und jetzt dieses LongRelease 7_5:
CFGFN
DEF 3815C201
NAME HM_3815C2_Btn_01
NR 150
STATE LongRelease 7_5 (to CUL_1)
TYPE CUL_HM
chanNo 01
device HM_3815C2
Readings:
2017-03-15 21:47:20 state LongRelease 7_5 (to CUL_1)
2017-03-15 21:47:20 trigDst_F10001 noConfig
2017-03-15 21:47:20 trigger Long_5
2017-03-15 21:47:20 trigger_cnt 5
Helper:
BNO 5
BNOCNT 7
peerIDsRaw ,00000000
Expert:
def 1
det 0
raw 1
tpl 0
Role:
chn 1
Shadowreg:
model HM-MOD-Em-8
peerIDs 00000000,
Marek
Moin Marek
Guck Dir mal das Register "triggerMode" an!
Gruss Christoph
Hallo Marek,
das von Dir geschilderte Problem hatte ich auch. Siehe:
https://forum.fhem.de/index.php/topic,66283.0.html (https://forum.fhem.de/index.php/topic,66283.0.html)
Die alternative Firmware für den CUL wirkt Wunder.
Jan_Mayen
@pc1246
set EM-8-channel regSet triggerMode sensor
macht ein open/closed
Marek
