Hello ,
I have a problem with TCM310 module ,after plugging it everything
looks fine ( status connected to ACM0) I can read TCM base id , but
when TCM receive signal from sensor it blocks and there no
communication with module , only way is to remove it a place once
again. Similar situation is when i read id-base two or three times
but only then i get:
2012.01.13 14:56:12 1: get idbase: Bogus answer received:
A00100000021A3CB3001FFFFFF
2012.01.13 14:56:19 1: TCM310 sending 5500010005700838
2012.01.13 14:56:19 1: SW: 5500010005700838
2012.01.13 14:56:19 1: get idbase: Bogus answer received:
80010000000000000000000000
Regards
Check the serial line: there should be no postprocessing (echo/etc) defined.
Apart from that I have no idea.
