FHEM => fhem-users => Thema gestartet von: Guest am 17 Januar 2012, 20:35:53
Titel: CUL sendet nicht (Homematic)
Beitrag von: Guest am 17 Januar 2012, 20:35:53
Hallo FHEM-Freunde
Problem: CUL sendet nicht. (Homematic)
         CUL liest alle Befehle
Fritz!Box 7390 (84.05.05-1854 ), Update auf Fhem 5.2 – 7390 SVN, 1xCUL
V 1.44 CUL868,
Dimmer: 1xHM-LC-DIM1T-FM,
Sender: 1xHM-PB-4DIS-WM
Das Pairen des Dimmer zum Sender hat gut funktioniert.
fhem.cfg:
attr global autoload_undefined_devices 1
attr global logfile ./log/fhem-%Y-%m.log
attr global modpath .
attr global port 7072 global
attr global statefile ./log/fhem.save
attr global userattr webCmd
attr global verbose 3
define WEB FHEMWEB 8083 global
define WEBphone FHEMWEB 8084 global
attr WEBphone smallscreen 1
define WEBtablet FHEMWEB 8085 global
attr WEBtablet touchpad 1
define Logfile FileLog ./log/fhem-%Y-%m.log fakelog
define autocreate autocreate
attr autocreate autosave 1
attr autocreate device_room %TYPE
attr autocreate filelog ./log/%NAME-%Y.log
attr autocreate weblink 1
attr autocreate weblink_room Plots
define initialUsbCheck notify global:INITIALIZED usb create
#define CUL CUL /dev/ttyACM0@9600 1234
define CUL CUL /dev/ttyACM0@38400 1234
attr CUL rfmode HomeMatic
define CUL_HM_dimmer_18439A CUL_HM 18439A
attr CUL_HM_dimmer_18439A devInfo 110000
attr CUL_HM_dimmer_18439A firmware 1.2
attr CUL_HM_dimmer_18439A hmClass receiver
attr CUL_HM_dimmer_18439A model HM-LC-DIM1T-FM
attr CUL_HM_dimmer_18439A room CUL_HM
attr CUL_HM_dimmer_18439A serialNr IEQ0381629
attr CUL_HM_dimmer_18439A subType dimmer
define FileLog_CUL_HM_dimmer_18439A FileLog ./log/CUL_HM_dimmer_18439A-
%Y.log CUL_HM_dimmer_18439A
attr FileLog_CUL_HM_dimmer_18439A logtype text
attr FileLog_CUL_HM_dimmer_18439A room CUL_HM
define CUL_HM_remote_16B0E1 CUL_HM 16B0E1
attr CUL_HM_remote_16B0E1 devInfo 940201
attr CUL_HM_remote_16B0E1 firmware 1.0
attr CUL_HM_remote_16B0E1 hmClass sender
attr CUL_HM_remote_16B0E1 model HM-PB-4DIS-WM
attr CUL_HM_remote_16B0E1 room CUL_HM
attr CUL_HM_remote_16B0E1 serialNr IEQ0100286
attr CUL_HM_remote_16B0E1 subType remote
define FileLog_CUL_HM_remote_16B0E1 FileLog ./log/CUL_HM_remote_16B0E1-
%Y.log CUL_HM_remote_16B0E1
attr FileLog_CUL_HM_remote_16B0E1 logtype text
attr FileLog_CUL_HM_remote_16B0E1 room CUL_HM
Die Geräte FHEM werden angezeigt.
Alle Befehle von der Hansender werden angezeigt und ausgeführt.
Wenn ich ein
set CUL_HM_dimmer_18439A on
mache, kommt folgede Antwort im Telnet (inform on):
CUL_HM CUL_HM_dimmer_18439A on
CUL_HM CUL_HM_dimmer_18439A resend nr 2
CUL_HM CUL_HM_dimmer_18439A resend nr 3
CUL_HM CUL_HM_dimmer_18439A MISSING ACK
Gemachte Tests:
get CUL raw V
CUL raw => V 1.44 CUL868
get CUL raw X
CUL raw => 21  900
list .* CUL_RSSI
CUL_HM_dimmer_18439A -52.5
CUL_HM_remote_16B0E1 -44
Frage: Was kann ich noch machen?
       ist meine CUL-Sender defekt?
Danke für jede Hilfe.
Aller Anfang ist schwer.
Tom
Beitrag von: rudolfkoenig am 17 Januar 2012, 22:02:05
Das hatten wir gerade, bitte Thread lesen.
Titel: Re: CUL sendet nicht (Homematic)
Beitrag von: Guest am 18 Januar 2012, 13:51:18
Hallo Rudolf
Danke für die Antwort.
Ich habe schon Stunden gesucht.
Ich weiss aber nicht, wo ansetzen.
Ist es die Hardware die nicht geht, oder mache ich etwas falsch.
Auch CUL Baudrate 9600 oder 38400 habe ich getest.
Ich bin auch nicht zu weit vom Sender. (2 Meter)
Für einen kleine Strohalm, wo ich weiter suchen kann, wäre ich
dankbar.
Mit Gruss
Tom
Titel: AW: Re: CUL sendet nicht (Homematic)
Beitrag von: Guest am 18 Januar 2012, 14:29:50
Schau mal die letzten Einträge im Thread "fhem 5.2-7390 mit zwei CUL
Transceivern ??" an. Da steht ziemlich präzise die Vorgehenswesie die mir
geholfen hat.
Ignisquivir
Fritz!Box 7390 (84.05.07-21400 ), Fhem 5.2 – 7390 SVN, 2xCUL V 1.44 CUL868,
2xHM-LC-Sw4-SM, 1xHM-LCSw1-FM, KS300
-----Ursprüngliche Nachricht-----
Von: fhem-users@googlegroups.com [mailto:fhem-users@googlegroups.com] Im
Auftrag von Tom
Gesendet: Mittwoch, 18. Januar 2012 13:51
An: FHEM users
Betreff: [FHEM] Re: CUL sendet nicht (Homematic)
Hallo Rudolf
Für einen kleine Strohalm, wo ich weiter suchen kann, wäre ich dankbar.
Mit Gruss
Tom
Beitrag von: Guest am 18 Januar 2012, 21:30:54
Hallo Ignisquivir
Es hat sehr geholfen. Jetzt kann ich auch senden.
Was war falsch:
- kein hmID beim CUL        set CUL hmId 112233
- Dimmer HM-LC-DIM1T-FM   und  Remote HM-PB-4DIS-WM neu angelernt.
Danach wurden die Geräte im FHEM angezeigt aber es konnte noch nicht
gesendet werden.
Dimmer auf Lernmodus und vom FHEM    set CUL_HM_dimmer_18439A on
gesendet.
Damit wurde das FHEM mit dem Dimmer verbunden.
Jetzt geht es auch. Jetzt binn ich auch sicher, dass der Sender i.O.
ist.
Mit Gruss
Tom
