Guten Morgen zusammen,
Meine Logfiles füllen sich... leider nicht mit besonders brauchbaren Dingen.
[code]
2017.03.29 20:59:09.605 4: sduino/msg READ: MS;P0=483;P1=-975;P2=-1949;P3=-4002;P4=370;D=03410202020101020101010201010101010201010201020201020202020101010101010101;CP=0;SP=3;R=6;O;
2017.03.29 20:59:09.610 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 20:59:09.610 5: sduino: Starting demodulation at Position 2
2017.03.29 20:59:09.610 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 20:59:10.385 4: sduino/msg READ: MS;P0=479;P1=-977;P2=-1945;P3=-3948;P4=360;D=03410202020101020101010201010101010201010201020201020202020101010101010101;CP=0;SP=3;R=6;
2017.03.29 20:59:10.389 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 20:59:10.389 5: sduino: Starting demodulation at Position 2
2017.03.29 20:59:10.389 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:00:28.367 4: sduino/msg READ: MS;P2=488;P4=-972;P5=-1945;P6=-3996;P7=370;D=26742525252424252424242524242424242524242524252524252525252424242424242424;CP=2;SP=6;R=7;O;
2017.03.29 21:00:28.371 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:00:28.372 5: sduino: Starting demodulation at Position 2
2017.03.29 21:00:28.372 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:04:25.366 4: sduino/msg READ: MS;P2=506;P4=-959;P5=-1937;P6=-3996;P7=360;D=26742525252424252424242524242424242524242524252524252525252424242424242424;CP=2;SP=6;R=15;O;
2017.03.29 21:04:25.373 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:04:25.373 5: sduino: Starting demodulation at Position 2
2017.03.29 21:04:25.374 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:04:25.605 4: sduino/msg READ: MS;P0=511;P1=-954;P2=-1927;P3=-3982;P4=390;D=03410202020101020101010201010101010201010201020201020202020101010101010101;CP=0;SP=3;R=11;O;
2017.03.29 21:04:25.611 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:04:25.611 5: sduino: Starting demodulation at Position 2
2017.03.29 21:04:25.612 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:05:44.367 4: sduino/msg READ: MS;P2=494;P4=-968;P5=-1937;P6=-3994;P7=378;D=26742525252424252424242524242424242524242524252524252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.29 21:05:44.373 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:05:44.373 5: sduino: Starting demodulation at Position 2
2017.03.29 21:05:44.374 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:07:03.366 4: sduino/msg READ: MS;P2=502;P4=385;P5=-961;P6=-1937;P7=-3988;D=27452626262525262525252625252525252625252625262625262626262525252525252525;CP=2;SP=7;R=11;O;
2017.03.29 21:07:03.377 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:07:03.377 5: sduino: Starting demodulation at Position 2
2017.03.29 21:07:03.378 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:09:41.604 4: sduino/msg READ: MS;P0=501;P1=-954;P2=-1949;P3=-3996;P4=380;D=03410202020101020101010201010101010201010201020201020202020101010101010101;CP=0;SP=3;R=10;O;
2017.03.29 21:09:41.610 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:09:41.610 5: sduino: Starting demodulation at Position 2
2017.03.29 21:09:41.611 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:11:01.317 4: sduino/msg READ: MS;P0=473;P1=-978;P2=-1950;P3=-3960;P4=360;D=03410202020101020101010201010101010201010201020201020202020101010101010101;CP=0;SP=3;R=10;
2017.03.29 21:11:01.330 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:11:01.331 5: sduino: Starting demodulation at Position 2
2017.03.29 21:11:01.331 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:13:38.603 4: sduino/msg READ: MS;P0=494;P1=-974;P2=-1948;P3=-3996;P4=372;D=03410202020101020101010201010101010201010201020201020202020101010101010101;CP=0;SP=3;R=6;O;
2017.03.29 21:13:38.609 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:13:38.610 5: sduino: Starting demodulation at Position 2
2017.03.29 21:13:38.610 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:16:17.400 4: sduino/msg READ: MS;P0=501;P1=-955;P2=-1936;P3=-3948;P4=368;D=03410202020101020101010201010101010201010201020201020202020101010101010101;CP=0;SP=3;R=11;
2017.03.29 21:16:17.405 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:16:17.406 5: sduino: Starting demodulation at Position 2
2017.03.29 21:16:17.406 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:24:10.842 4: sduino/msg READ: MS;P0=498;P1=-965;P2=-4004;P3=374;P4=-1950;D=02310404040101040101010401010101010401010401040401040404040101010101010101;CP=0;SP=2;R=9;O;
2017.03.29 21:24:10.847 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:24:10.848 5: sduino: Starting demodulation at Position 2
2017.03.29 21:24:10.848 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:25:29.365 4: sduino/msg READ: MS;P2=496;P4=-958;P5=-1923;P6=-4010;P7=370;D=26742525252424252424242524242424242524242524252524252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.29 21:25:29.371 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:25:29.371 5: sduino: Starting demodulation at Position 2
2017.03.29 21:25:29.372 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:30:45.365 4: sduino/msg READ: MS;P2=499;P4=379;P5=-959;P6=-1939;P7=-3992;D=27452626262525262525252625252525252625252625262526262626262525252525252525;CP=2;SP=7;R=11;O;
2017.03.29 21:30:45.375 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:30:45.376 5: sduino: Starting demodulation at Position 2
2017.03.29 21:30:45.377 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:30:45.603 4: sduino/msg READ: MS;P0=496;P1=-965;P2=-1937;P3=-4002;P4=370;D=03410202020101020101010201010101010201010201020102020202020101010101010101;CP=0;SP=3;R=11;O;
2017.03.29 21:30:45.609 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:30:45.610 5: sduino: Starting demodulation at Position 2
2017.03.29 21:30:45.610 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:33:23.364 4: sduino/msg READ: MS;P2=490;P4=-966;P5=-1953;P6=-3992;P7=376;D=26742525252424252424242524242424242524242524252425252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.29 21:33:23.375 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:33:23.376 5: sduino: Starting demodulation at Position 2
2017.03.29 21:33:23.376 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:34:42.840 4: sduino/msg READ: MS;P0=505;P1=-951;P2=-3990;P3=386;P4=-1939;D=02310404040101040101010401010101010401010401040104040404040101010101010101;CP=0;SP=2;R=9;O;
2017.03.29 21:34:42.846 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:34:42.846 5: sduino: Starting demodulation at Position 2
2017.03.29 21:34:42.847 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:36:01.830 4: sduino/msg READ: MS;P0=498;P1=-970;P2=-3996;P3=378;P4=-1938;D=02310404040101040101010401010101010401010401040101040404040101010101010101;CP=0;SP=2;R=11;O;
2017.03.29 21:36:01.835 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:36:01.836 5: sduino: Starting demodulation at Position 2
2017.03.29 21:36:01.836 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:36:02.139 4: sduino/msg READ: MS;P0=471;P1=-969;P2=-1936;P3=-3960;P4=360;D=03410202020101020101010201010101010201010201020101020202020101010101010101;CP=0;SP=3;R=10;
2017.03.29 21:36:02.144 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:36:02.145 5: sduino: Starting demodulation at Position 2
2017.03.29 21:36:02.145 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:38:39.854 4: sduino/msg READ: MS;P0=-946;P1=518;P2=-1934;P3=-3986;P4=394;D=13401212121010121010101210101010101210101210121010121212121010101010101010;CP=1;SP=3;R=10;O;
2017.03.29 21:38:39.859 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:38:39.860 5: sduino: Starting demodulation at Position 2
2017.03.29 21:38:39.860 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:39:59.565 4: sduino/msg READ: MS;P0=483;P1=-972;P2=-1952;P3=-3956;P4=368;D=03410202020101020101010201010101010201010201020101020202020101010101010101;CP=0;SP=3;R=11;
2017.03.29 21:39:59.571 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:39:59.571 5: sduino: Starting demodulation at Position 2
2017.03.29 21:39:59.572 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:41:17.966 4: sduino/msg READ: MS;P0=483;P1=-970;P2=-1942;P3=-3956;P4=368;D=03410202020101020101010201010101010201010201020101020202020101010101010101;CP=0;SP=3;R=11;
2017.03.29 21:41:17.970 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:41:17.971 5: sduino: Starting demodulation at Position 2
2017.03.29 21:41:17.971 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:49:11.855 4: sduino/msg READ: MS;P0=508;P1=-1933;P2=-953;P3=-4004;P4=390;D=03420101010202010202020102020202020102020102020101010101010202020202020202;CP=0;SP=3;R=10;O;
2017.03.29 21:49:11.861 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:49:11.861 5: sduino: Starting demodulation at Position 2
2017.03.29 21:49:11.862 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:53:08.361 4: sduino/msg READ: MS;P2=506;P4=379;P5=-961;P6=-1940;P7=-3986;D=27452626262525262525252625252525252625252625252626262626262525252525252525;CP=2;SP=7;R=11;O;
2017.03.29 21:53:08.367 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:53:08.368 5: sduino: Starting demodulation at Position 2
2017.03.29 21:53:08.368 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:53:08.600 4: sduino/msg READ: MS;P0=503;P1=-963;P2=-1931;P3=-3990;P4=382;D=03410202020101020101010201010101010201010201010202020202020101010101010101;CP=0;SP=3;R=11;O;
2017.03.29 21:53:08.605 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:53:08.606 5: sduino: Starting demodulation at Position 2
2017.03.29 21:53:08.606 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:55:46.361 4: sduino/msg READ: MS;P2=494;P4=-968;P5=-1945;P6=-3996;P7=374;D=26742525252424252424242524242424242524242524242525252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.29 21:55:46.368 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:55:46.368 5: sduino: Starting demodulation at Position 2
2017.03.29 21:55:46.369 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:55:47.095 4: sduino/msg READ: MS;P0=487;P1=-962;P2=-1942;P3=-3968;P4=368;D=03410202020101020101010201010101010201010201010202020202020101010101010101;CP=0;SP=3;R=11;
2017.03.29 21:55:47.101 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:55:47.101 5: sduino: Starting demodulation at Position 2
2017.03.29 21:55:47.102 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:57:05.592 4: sduino/msg READ: MS;P0=484;P1=-975;P2=-1953;P3=-4012;P4=368;D=03410202020101020101010201010101010201010201010201020202020101010101010101;CP=0;SP=3;R=11;O;
2017.03.29 21:57:05.598 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:57:05.598 5: sduino: Starting demodulation at Position 2
2017.03.29 21:57:05.599 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 21:58:24.591 4: sduino/msg READ: MS;P0=491;P1=-969;P2=-1949;P3=-4008;P4=373;D=03410202020101020101010201010101010201010201010201020202020101010101010101;CP=0;SP=3;R=6;O;
2017.03.29 21:58:24.596 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 21:58:24.596 5: sduino: Starting demodulation at Position 2
2017.03.29 21:58:24.596 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:01:02.592 4: sduino/msg READ: MS;P0=488;P1=-970;P2=-1953;P3=-3998;P4=366;D=03410202020101020101010201010101010201010201010201020202020101010101010101;CP=0;SP=3;R=10;O;
2017.03.29 22:01:02.598 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:01:02.598 5: sduino: Starting demodulation at Position 2
2017.03.29 22:01:02.599 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:06:18.826 4: sduino/msg READ: MS;P0=490;P1=-972;P2=-3997;P3=376;P4=-1955;D=02310404040101040101010401010101010401010401010104040404040101010101010101;CP=0;SP=2;R=11;O;
2017.03.29 22:06:18.832 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:06:18.833 5: sduino: Starting demodulation at Position 2
2017.03.29 22:06:18.833 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:08:56.357 4: sduino/msg READ: MS;P2=512;P4=379;P5=-949;P6=-1939;P7=-3992;D=27452626262525262525252625252525252625252625252526262626262525252525252525;CP=2;SP=7;R=11;O;
2017.03.29 22:08:56.368 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:08:56.369 5: sduino: Starting demodulation at Position 2
2017.03.29 22:08:56.370 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:10:15.354 4: sduino/msg READ: MS;P2=493;P4=-967;P5=-1935;P6=-3998;P7=370;D=26742525252424252424242524242424242524242524242425252525252424242424242424;CP=2;SP=6;R=10;O;
2017.03.29 22:10:15.361 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:10:15.362 5: sduino: Starting demodulation at Position 2
2017.03.29 22:10:15.362 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:10:15.591 4: sduino/msg READ: MS;P0=495;P1=-960;P2=-1948;P3=-3998;P4=380;D=03410202020101020101010201010101010201010201010102020202020101010101010101;CP=0;SP=3;R=11;O;
2017.03.29 22:10:15.596 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:10:15.597 5: sduino: Starting demodulation at Position 2
2017.03.29 22:10:15.598 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:10:15.825 4: sduino/msg READ: MS;P0=496;P1=-971;P2=-4004;P3=373;P4=-1946;D=02310404040101040101010401010101010401010401010104040404040101010101010101;CP=0;SP=2;R=10;O;
2017.03.29 22:10:15.829 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:10:15.830 5: sduino: Starting demodulation at Position 2
2017.03.29 22:10:15.830 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:10:15.958 4: sduino/msg READ: MS;P0=493;P1=-959;P2=-1929;P3=-3928;P4=376;D=03410202020101020101010201010101010201010201010102020202020101010101010101;CP=0;SP=3;R=10;
2017.03.29 22:10:15.962 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:10:15.963 5: sduino: Starting demodulation at Position 2
2017.03.29 22:10:15.963 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:11:34.590 4: sduino/msg READ: MS;P0=492;P1=-970;P2=-1945;P3=-4006;P4=376;D=03410202020101020101010201010101010201010201010102020202020101010101010101;CP=0;SP=3;R=9;O;
2017.03.29 22:11:34.594 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:11:34.595 5: sduino: Starting demodulation at Position 2
2017.03.29 22:11:34.595 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:14:12.355 4: sduino/msg READ: MS;P2=505;P4=388;P5=-960;P6=-1930;P7=-3976;D=27452626262525262525252625252525252625252625252526262626262525252525252525;CP=2;SP=7;R=11;O;
2017.03.29 22:14:12.362 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:14:12.363 5: sduino: Starting demodulation at Position 2
2017.03.29 22:14:12.363 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:16:51.380 4: sduino/msg READ: MS;P0=482;P1=-968;P2=-1954;P3=-3956;P4=368;D=03410202020101020101010201010101010201010201010102020202020101010101010101;CP=0;SP=3;R=9;
2017.03.29 22:16:51.386 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:16:51.387 5: sduino: Starting demodulation at Position 2
2017.03.29 22:16:51.387 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:18:09.356 4: sduino/msg READ: MS;P2=496;P4=-969;P5=-1941;P6=-4014;P7=372;D=26742525252424252424242524242424242524242524242425252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.29 22:18:09.367 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:18:09.369 5: sduino: Starting demodulation at Position 2
2017.03.29 22:18:09.370 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:20:48.432 4: sduino/msg READ: MS;P0=481;P1=-970;P2=-1951;P3=-3964;P4=368;D=03410202020101020101010201010101010201010201010102020202020101010101010101;CP=0;SP=3;R=6;
2017.03.29 22:20:48.436 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:20:48.437 5: sduino: Starting demodulation at Position 2
2017.03.29 22:20:48.437 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:22:07.046 4: sduino/msg READ: MS;P0=496;P1=-950;P2=-1933;P3=-3952;P4=376;D=03410202020101020101010201010101010201010201010101020202020101010101010101;CP=0;SP=3;R=9;
2017.03.29 22:22:07.052 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:22:07.053 5: sduino: Starting demodulation at Position 2
2017.03.29 22:22:07.054 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:23:25.813 4: sduino/msg READ: MS;P0=482;P1=-981;P2=-4012;P3=369;P4=-1947;D=02310404040101040101010401010101010401010401010101040404040101010101010101;CP=0;SP=2;R=6;O;
2017.03.29 22:23:25.817 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:23:25.817 5: sduino: Starting demodulation at Position 2
2017.03.29 22:23:25.818 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:27:22.813 4: sduino/msg READ: MS;P0=489;P1=-972;P2=-3999;P3=376;P4=-1954;D=02310404040101040101010401010101010401010401010101040404040101010101010101;CP=0;SP=2;R=10;O;
2017.03.29 22:27:22.816 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:27:22.817 5: sduino: Starting demodulation at Position 2
2017.03.29 22:27:22.817 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:27:22.993 4: sduino/msg READ: MS;P0=481;P1=-969;P2=-1944;P3=-3952;P4=368;D=03410202020101020101010201010101010201010201010101020202020101010101010101;CP=0;SP=3;R=11;
2017.03.29 22:27:22.997 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:27:22.997 5: sduino: Starting demodulation at Position 2
2017.03.29 22:27:22.998 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:33:58.722 4: sduino/msg READ: MS;P0=491;P1=-949;P2=-1943;P3=-3960;P4=368;D=03410202020101020101010201010101010201010102020202020202020101010101010101;CP=0;SP=3;R=9;
2017.03.29 22:33:58.727 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:33:58.727 5: sduino: Starting demodulation at Position 2
2017.03.29 22:33:58.728 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:35:16.602 4: sduino/msg READ: MS;P0=491;P1=-981;P2=-1938;P3=-4012;P4=374;D=03410202020101020101010201010101010201010102020202020202020101010101010101;CP=0;SP=3;R=6;O;
2017.03.29 22:35:16.607 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:35:16.608 5: sduino: Starting demodulation at Position 2
2017.03.29 22:35:16.608 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:37:54.362 4: sduino/msg READ: MS;P2=487;P4=-962;P5=-1960;P6=-4004;P7=372;D=26742525252424252424242524242424242524242425252525252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.29 22:37:54.375 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:37:54.376 5: sduino: Starting demodulation at Position 2
2017.03.29 22:37:54.377 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:39:13.601 4: sduino/msg READ: MS;P0=498;P1=-953;P2=-1924;P3=-3990;P4=372;D=03410202020101020101010201010101010201010102020202020202020101010101010101;CP=0;SP=3;R=9;O;
2017.03.29 22:39:13.605 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:39:13.605 5: sduino: Starting demodulation at Position 2
2017.03.29 22:39:13.605 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:41:51.601 4: sduino/msg READ: MS;P0=517;P1=-954;P2=-1936;P3=-3990;P4=392;D=03410202020101020101010201010101010201010102020202020202020101010101010101;CP=0;SP=3;R=10;O;
2017.03.29 22:41:51.604 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:41:51.605 5: sduino: Starting demodulation at Position 2
2017.03.29 22:41:51.605 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:51:04.596 4: sduino/msg READ: MS;P0=502;P1=-953;P2=-1940;P3=-3996;P4=378;D=03410202020101020101010201010101010201010102020102020202020101010101010101;CP=0;SP=3;R=9;O;
2017.03.29 22:51:04.600 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:51:04.601 5: sduino: Starting demodulation at Position 2
2017.03.29 22:51:04.601 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:53:42.596 4: sduino/msg READ: MS;P0=505;P1=-953;P2=-1940;P3=-3992;P4=368;D=03410202020101020101010201010101010201010102020102020202020101010101010101;CP=0;SP=3;R=9;O;
2017.03.29 22:53:42.602 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:53:42.602 5: sduino: Starting demodulation at Position 2
2017.03.29 22:53:42.603 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 22:55:01.356 4: sduino/msg READ: MS;P2=483;P4=-976;P5=-1941;P6=-3994;P7=370;D=26742525252424252424242524242424242524242425252524252525252424242424242424;CP=2;SP=6;R=10;O;
2017.03.29 22:55:01.360 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 22:55:01.361 5: sduino: Starting demodulation at Position 2
2017.03.29 22:55:01.361 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:00:18.157 4: sduino/msg READ: MS;P0=479;P1=-973;P2=-1947;P3=-3960;P4=360;D=03410202020101020101010201010101010201010102020102020202020101010101010101;CP=0;SP=3;R=10;
2017.03.29 23:00:18.161 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:00:18.161 5: sduino: Starting demodulation at Position 2
2017.03.29 23:00:18.161 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:09:30.349 4: sduino/msg READ: MS;P2=501;P4=-961;P5=-1941;P6=-4004;P7=380;D=26742525252424252424242524242424242524242425252424252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.29 23:09:30.354 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:09:30.354 5: sduino: Starting demodulation at Position 2
2017.03.29 23:09:30.355 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:13:27.592 4: sduino/msg READ: MS;P0=490;P1=-977;P2=-1947;P3=-3998;P4=374;D=03410202020101020101010201010101010201010102010202020202020101010101010101;CP=0;SP=3;R=10;O;
2017.03.29 23:13:27.596 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:13:27.596 5: sduino: Starting demodulation at Position 2
2017.03.29 23:13:27.597 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:18:43.585 4: sduino/msg READ: MS;P0=510;P1=-964;P2=-1938;P3=-3992;P4=384;D=03410202020101020101010201010101010201010102010201020202020101010101010101;CP=0;SP=3;R=10;O;
2017.03.29 23:18:43.591 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:18:43.592 5: sduino: Starting demodulation at Position 2
2017.03.29 23:18:43.592 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:21:21.820 4: sduino/msg READ: MS;P0=495;P1=-969;P2=-4004;P3=376;P4=-1941;D=02310404040101040101010401010101010401010104010401040404040101010101010101;CP=0;SP=2;R=10;O;
2017.03.29 23:21:21.826 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:21:21.827 5: sduino: Starting demodulation at Position 2
2017.03.29 23:21:21.827 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:23:59.820 4: sduino/msg READ: MS;P0=494;P1=-968;P2=-4002;P3=376;P4=-1942;D=02310404040101040101010401010101010401010104010401040404040101010101010101;CP=0;SP=2;R=10;O;
2017.03.29 23:23:59.826 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:23:59.826 5: sduino: Starting demodulation at Position 2
2017.03.29 23:23:59.827 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:29:15.348 4: sduino/msg READ: MS;P2=482;P4=-976;P5=-1943;P6=-4002;P7=370;D=26742525252424252424242524242424242524242425242524252525252424242424242424;CP=2;SP=6;R=6;O;
2017.03.29 23:29:15.354 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:29:15.355 5: sduino: Starting demodulation at Position 2
2017.03.29 23:29:15.355 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:29:15.820 4: sduino/msg READ: MS;P0=491;P1=-970;P2=-4002;P3=375;P4=-1950;D=02310404040101040101010401010101010401010104010401040404040101010101010101;CP=0;SP=2;R=6;O;
2017.03.29 23:29:15.825 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:29:15.826 5: sduino: Starting demodulation at Position 2
2017.03.29 23:29:15.826 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:33:12.820 4: sduino/msg READ: MS;P0=486;P1=-968;P2=-4002;P3=373;P4=-1956;D=02310404040101040101010401010101010401010104010104040404040101010101010101;CP=0;SP=2;R=11;O;
2017.03.29 23:33:12.824 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:33:12.824 5: sduino: Starting demodulation at Position 2
2017.03.29 23:33:12.824 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:34:31.819 4: sduino/msg READ: MS;P0=482;P1=-975;P2=-4007;P3=361;P4=-1951;D=02310404040101040101010401010101010401010104010104040404040101010101010101;CP=0;SP=2;R=11;O;
2017.03.29 23:34:31.823 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:34:31.824 5: sduino: Starting demodulation at Position 2
2017.03.29 23:34:31.824 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:37:09.347 4: sduino/msg READ: MS;P2=492;P4=-959;P5=-1943;P6=-4002;P7=378;D=26742525252424252424242524242424242524242425242425252525252424242424242424;CP=2;SP=6;R=8;O;
2017.03.29 23:37:09.354 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:37:09.354 5: sduino: Starting demodulation at Position 2
2017.03.29 23:37:09.355 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:41:07.123 4: sduino/msg READ: MS;P0=483;P1=-967;P2=-1944;P3=-3952;P4=368;D=03410202020101020101010201010101010201010102010102020202020101010101010101;CP=0;SP=3;R=10;
2017.03.29 23:41:07.128 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:41:07.129 5: sduino: Starting demodulation at Position 2
2017.03.29 23:41:07.129 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:43:45.252 4: sduino/msg READ: MS;P0=482;P1=-956;P2=-1946;P3=-3964;P4=368;D=03410202020101020101010201010101010201010102010101020202020101010101010101;CP=0;SP=3;R=10;
2017.03.29 23:43:45.258 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:43:45.258 5: sduino: Starting demodulation at Position 2
2017.03.29 23:43:45.259 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:45:03.347 4: sduino/msg READ: MS;P2=513;P4=383;P5=-952;P6=-1928;P7=-3998;D=27452626262525262525252625252525252625252526252526262626262525252525252525;CP=2;SP=7;R=11;O;
2017.03.29 23:45:03.353 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:45:03.354 5: sduino: Starting demodulation at Position 2
2017.03.29 23:45:03.354 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:47:42.306 4: sduino/msg READ: MS;P0=474;P1=-972;P2=-1959;P3=-3980;P4=360;D=03410202020101020101010201010101010201010102010101020202020101010101010101;CP=0;SP=3;R=11;
2017.03.29 23:47:42.310 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:47:42.311 5: sduino: Starting demodulation at Position 2
2017.03.29 23:47:42.311 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:50:19.816 4: sduino/msg READ: MS;P0=-955;P1=508;P2=-3987;P3=390;P4=-1928;D=12301414141010141010101410101010101410101014101010141414141010101010101010;CP=1;SP=2;R=9;O;
2017.03.29 23:50:19.822 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:50:19.822 5: sduino: Starting demodulation at Position 2
2017.03.29 23:50:19.823 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.29 23:55:35.362 4: sduino/msg READ: MS;P0=-1927;P2=-954;P3=518;P4=-4000;P5=388;D=34523030303232303232323032323232323032323232303030303030303232323232323232;CP=3;SP=4;R=11;O;
2017.03.29 23:55:35.368 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.29 23:55:35.369 5: sduino: Starting demodulation at Position 2
2017.03.29 23:55:35.370 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:02:10.351 4: sduino/msg READ: MS;P2=502;P4=-960;P5=-1935;P6=-3988;P7=386;D=26742525252424252424242524242424242524242424252525252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.30 00:02:10.355 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:02:10.355 5: sduino: Starting demodulation at Position 2
2017.03.30 00:02:10.356 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:03:29.591 4: sduino/msg READ: MS;P0=505;P1=-1927;P2=-968;P3=-3994;P4=388;D=03420101010202010202020102020202020102020202010101010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 00:03:29.595 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:03:29.595 5: sduino: Starting demodulation at Position 2
2017.03.30 00:03:29.595 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:06:07.597 4: sduino/msg READ: MS;P0=519;P1=-943;P2=-1924;P3=-3980;P4=394;D=03410202020101020101010201010101010201010101020202020202020101010101010101;CP=0;SP=3;R=11;O;
2017.03.30 00:06:07.601 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:06:07.601 5: sduino: Starting demodulation at Position 2
2017.03.30 00:06:07.601 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:08:45.352 4: sduino/msg READ: MS;P2=500;P4=-959;P5=-1936;P6=-3986;P7=384;D=26742525252424252424242524242424242524242424252525252525252424242424242424;CP=2;SP=6;R=12;O;
2017.03.30 00:08:45.358 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:08:45.359 5: sduino: Starting demodulation at Position 2
2017.03.30 00:08:45.360 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:08:45.831 4: sduino/msg READ: MS;P0=496;P1=-970;P2=-3989;P3=377;P4=-1952;D=02310404040101040101010401010101010401010101040404040404040101010101010101;CP=0;SP=2;R=10;O;
2017.03.30 00:08:45.836 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:08:45.837 5: sduino: Starting demodulation at Position 2
2017.03.30 00:08:45.837 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:15:20.346 4: sduino/msg READ: MS;P2=512;P4=-957;P5=-1929;P6=-4002;P7=390;D=26742525252424252424242524242424242524242424252524252525252424242424242424;CP=2;SP=6;R=12;O;
2017.03.30 00:15:20.353 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:15:20.353 5: sduino: Starting demodulation at Position 2
2017.03.30 00:15:20.354 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:17:58.347 4: sduino/msg READ: MS;P2=496;P4=381;P5=-967;P6=-1950;P7=-3996;D=27452626262525262525252625252525252625252525262625262626262525252525252525;CP=2;SP=7;R=9;O;
2017.03.30 00:17:58.352 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:17:58.352 5: sduino: Starting demodulation at Position 2
2017.03.30 00:17:58.352 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:20:36.584 4: sduino/msg READ: MS;P0=496;P1=-1944;P2=-958;P3=-4002;P4=372;D=03420101010202010202020102020202020102020202010102010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 00:20:36.590 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:20:36.591 5: sduino: Starting demodulation at Position 2
2017.03.30 00:20:36.591 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:28:30.821 4: sduino/msg READ: MS;P0=500;P1=-967;P2=-1926;P3=-3981;P4=378;D=03410202020101020101010201010101010201010101020201020202020101010101010101;CP=0;SP=3;R=10;O;
2017.03.30 00:28:30.826 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:28:30.827 5: sduino: Starting demodulation at Position 2
2017.03.30 00:28:30.827 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:31:08.583 4: sduino/msg READ: MS;P0=493;P1=-1943;P2=-966;P3=-4010;P4=374;D=03420101010202010202020102020202020102020202010201010101010202020202020202;CP=0;SP=3;R=6;O;
2017.03.30 00:31:08.587 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:31:08.588 5: sduino: Starting demodulation at Position 2
2017.03.30 00:31:08.588 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:33:46.810 4: sduino/msg READ: MS;P0=513;P1=-957;P2=-1940;P3=-3998;P4=385;D=03410202020101020101010201010101010201010101020101020202020101010101010101;CP=0;SP=3;R=10;O;
2017.03.30 00:33:46.815 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:33:46.816 5: sduino: Starting demodulation at Position 2
2017.03.30 00:33:46.816 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:36:24.347 4: sduino/msg READ: MS;P2=489;P4=376;P5=-973;P6=-1942;P7=-3998;D=27452626262525262525252625252525252625252525262526262626262525252525252525;CP=2;SP=7;R=9;O;
2017.03.30 00:36:24.351 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:36:24.352 5: sduino: Starting demodulation at Position 2
2017.03.30 00:36:24.352 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:39:02.820 4: sduino/msg READ: MS;P0=500;P1=-965;P2=-1936;P3=-3999;P4=373;D=03410202020101020101010201010101010201010101020102020202020101010101010101;CP=0;SP=3;R=10;O;
2017.03.30 00:39:02.824 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:39:02.824 5: sduino: Starting demodulation at Position 2
2017.03.30 00:39:02.824 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:40:21.577 4: sduino/msg READ: MS;P0=506;P1=-1929;P2=-948;P3=-3986;P4=384;D=03420101010202010202020102020202020102020202010202010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 00:40:21.582 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:40:21.583 5: sduino: Starting demodulation at Position 2
2017.03.30 00:40:21.583 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:44:18.344 4: sduino/msg READ: MS;P2=510;P4=380;P5=-948;P6=-1929;P7=-3986;D=27452626262525262525252625252525252625252525262525262626262525252525252525;CP=2;SP=7;R=10;O;
2017.03.30 00:44:18.350 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:44:18.350 5: sduino: Starting demodulation at Position 2
2017.03.30 00:44:18.351 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:53:31.582 4: sduino/msg READ: MS;P0=497;P1=-1959;P2=-960;P3=-3996;P4=372;D=03420101010202010202020102020202020102020202020101010101010202020202020202;CP=0;SP=3;R=6;O;
2017.03.30 00:53:31.586 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:53:31.587 5: sduino: Starting demodulation at Position 2
2017.03.30 00:53:31.587 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:53:31.819 4: sduino/msg READ: MS;P0=496;P1=-973;P2=-4001;P3=378;P4=-1942;D=02310404040101040101010401010101010401010101010404040404040101010101010101;CP=0;SP=2;R=5;O;
2017.03.30 00:53:31.823 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:53:31.823 5: sduino: Starting demodulation at Position 2
2017.03.30 00:53:31.824 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 00:58:47.809 4: sduino/msg READ: MS;P0=495;P1=-961;P2=-3992;P3=374;P4=-1943;D=02310404040101040101010401010101010401010101010104040404040101010101010101;CP=0;SP=2;R=10;O;
2017.03.30 00:58:47.815 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 00:58:47.815 5: sduino: Starting demodulation at Position 2
2017.03.30 00:58:47.816 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:01:33.133 4: sduino/msg READ: MS;P0=493;P1=-1952;P2=-972;P3=-3990;P4=378;D=03420101010202010202020102020202020102020202020201010101010202020202020202;CP=0;SP=3;R=10;O;
2017.03.30 01:01:33.137 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:01:33.138 5: sduino: Starting demodulation at Position 2
2017.03.30 01:01:33.138 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:05:22.808 4: sduino/msg READ: MS;P0=486;P1=-980;P2=-4000;P3=373;P4=-1942;D=02310404040101040101010401010101010401010101010104040404040101010101010101;CP=0;SP=2;R=5;O;
2017.03.30 01:05:22.814 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:05:22.815 5: sduino: Starting demodulation at Position 2
2017.03.30 01:05:22.815 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:09:19.798 4: sduino/msg READ: MS;P0=500;P1=-960;P2=-3993;P3=375;P4=-1939;D=02310404040101040101010401010101010401010101010101040404040101010101010101;CP=0;SP=2;R=10;O;
2017.03.30 01:09:19.802 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:09:19.802 5: sduino: Starting demodulation at Position 2
2017.03.30 01:09:19.803 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:10:38.339 4: sduino/msg READ: MS;P2=499;P4=-966;P5=-1937;P6=-3988;P7=382;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=8;O;
2017.03.30 01:10:38.345 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:10:38.346 5: sduino: Starting demodulation at Position 2
2017.03.30 01:10:38.346 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:10:38.569 4: sduino/msg READ: MS;P0=492;P1=-1941;P2=-981;P3=-4014;P4=372;D=03420101010202010202020102020202020102020202020202010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 01:10:38.575 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:10:38.576 5: sduino: Starting demodulation at Position 2
2017.03.30 01:10:38.576 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:11:57.863 4: sduino/msg READ: MS;P0=499;P1=-1935;P2=-959;P3=-3996;P4=383;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 01:11:57.869 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:11:57.870 5: sduino: Starting demodulation at Position 2
2017.03.30 01:11:57.870 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:14:35.363 4: sduino/msg READ: MS;P2=494;P4=379;P5=-961;P6=-1950;P7=-3994;D=27452626262525262525252625252525252526262626262626262626262525252525252525;CP=2;SP=7;R=11;O;
2017.03.30 01:14:35.367 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:14:35.368 5: sduino: Starting demodulation at Position 2
2017.03.30 01:14:35.368 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:14:35.611 4: sduino/msg READ: MS;P0=494;P1=-1931;P2=-966;P3=-4000;P4=368;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 01:14:35.615 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:14:35.615 5: sduino: Starting demodulation at Position 2
2017.03.30 01:14:35.615 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:15:54.362 4: sduino/msg READ: MS;P2=500;P4=-962;P5=-1936;P6=-4004;P7=384;D=26742525252424252424242524242424242425252525252525252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.30 01:15:54.369 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:15:54.369 5: sduino: Starting demodulation at Position 2
2017.03.30 01:15:54.370 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:17:13.338 4: sduino/msg READ: MS;P2=505;P4=-961;P5=-1945;P6=-3998;P7=384;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=12;O;
2017.03.30 01:17:13.352 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:17:13.352 5: sduino: Starting demodulation at Position 2
2017.03.30 01:17:13.353 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:17:13.798 4: sduino/msg READ: MS;P0=496;P1=-972;P2=-4003;P3=374;P4=-1950;D=02310404040101040101010401010101010401010101010101040404040101010101010101;CP=0;SP=2;R=12;O;
2017.03.30 01:17:13.804 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:17:13.805 5: sduino: Starting demodulation at Position 2
2017.03.30 01:17:13.805 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:22:30.349 4: sduino/msg READ: MS;P0=498;P1=-1933;P2=-952;P3=-3944;P4=376;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=11;
2017.03.30 01:22:30.353 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:22:30.353 5: sduino: Starting demodulation at Position 2
2017.03.30 01:22:30.354 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:25:07.610 4: sduino/msg READ: MS;P0=491;P1=-1955;P2=-960;P3=-3988;P4=374;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 01:25:07.614 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:25:07.615 5: sduino: Starting demodulation at Position 2
2017.03.30 01:25:07.615 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:26:26.339 4: sduino/msg READ: MS;P2=507;P4=-958;P5=-1944;P6=-3996;P7=378;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=12;O;
2017.03.30 01:26:26.343 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:26:26.343 5: sduino: Starting demodulation at Position 2
2017.03.30 01:26:26.344 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:30:23.798 4: sduino/msg READ: MS;P0=498;P1=-965;P2=-4001;P3=381;P4=-1942;D=02310404040101040101010401010101010401010101010101040404040101010101010101;CP=0;SP=2;R=11;O;
2017.03.30 01:30:23.803 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:30:23.804 5: sduino: Starting demodulation at Position 2
2017.03.30 01:30:23.805 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:40:55.344 4: sduino/msg READ: MS;P2=495;P4=-976;P5=-1942;P6=-3998;P7=374;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=12;O;
2017.03.30 01:40:55.348 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:40:55.349 5: sduino: Starting demodulation at Position 2
2017.03.30 01:40:55.349 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:40:55.799 4: sduino/msg READ: MS;P0=499;P1=-972;P2=-3976;P3=383;P4=-1934;D=02310404040101040101010401010101010401010101010101040404040101010101010101;CP=0;SP=2;R=11;O;
2017.03.30 01:40:55.804 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:40:55.805 5: sduino: Starting demodulation at Position 2
2017.03.30 01:40:55.806 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:43:33.799 4: sduino/msg READ: MS;P0=500;P1=-971;P2=-3999;P3=377;P4=-1936;D=02310404040101040101010401010101010401010101010101040404040101010101010101;CP=0;SP=2;R=11;O;
2017.03.30 01:43:33.805 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:43:33.806 5: sduino: Starting demodulation at Position 2
2017.03.30 01:43:33.806 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:46:11.570 4: sduino/msg READ: MS;P0=498;P1=-1936;P2=-977;P3=-3996;P4=382;D=03420101010202010202020102020202020102020202020202010101010202020202020202;CP=0;SP=3;R=12;O;
2017.03.30 01:46:11.574 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:46:11.575 5: sduino: Starting demodulation at Position 2
2017.03.30 01:46:11.575 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:47:30.340 4: sduino/msg READ: MS;P2=500;P4=-965;P5=-1944;P6=-4002;P7=382;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=12;O;
2017.03.30 01:47:30.344 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:47:30.344 5: sduino: Starting demodulation at Position 2
2017.03.30 01:47:30.345 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 01:50:08.577 4: sduino/msg READ: MS;P0=496;P1=-1940;P2=-958;P3=-3992;P4=380;D=03420101010202010202020102020202020102020202020201010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 01:50:08.581 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 01:50:08.581 5: sduino: Starting demodulation at Position 2
2017.03.30 01:50:08.582 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:00:40.346 4: sduino/msg READ: MS;P2=505;P4=-953;P5=-1934;P6=-3990;P7=378;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=15;O;
2017.03.30 02:00:40.353 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:00:40.353 5: sduino: Starting demodulation at Position 2
2017.03.30 02:00:40.354 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:03:18.570 4: sduino/msg READ: MS;P0=492;P1=-1933;P2=-973;P3=-3998;P4=378;D=03420101010202010202020102020202020102020202020202010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 02:03:19.809 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:03:19.810 5: sduino: Starting demodulation at Position 2
2017.03.30 02:03:19.810 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:04:38.033 4: sduino/msg READ: MS;P0=498;P1=-1937;P2=-962;P3=-4016;P4=368;D=03420101010202010202020102020202020102020202020202010101010202020202020202;CP=0;SP=3;R=10;O;
2017.03.30 02:04:38.039 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:04:38.039 5: sduino: Starting demodulation at Position 2
2017.03.30 02:04:38.040 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:16:28.577 4: sduino/msg READ: MS;P0=501;P1=-1936;P2=-967;P3=-3990;P4=376;D=03420101010202010202020102020202020102020202020201010101010202020202020202;CP=0;SP=3;R=10;O;
2017.03.30 02:16:28.581 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:16:28.581 5: sduino: Starting demodulation at Position 2
2017.03.30 02:16:28.582 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:21:44.344 4: sduino/msg READ: MS;P2=497;P4=377;P5=-964;P6=-1954;P7=-3998;D=27452626262525262525252625252525252625252525252526262626262525252525252525;CP=2;SP=7;R=10;O;
2017.03.30 02:21:44.350 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:21:44.351 5: sduino: Starting demodulation at Position 2
2017.03.30 02:21:44.351 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:23:03.570 4: sduino/msg READ: MS;P0=498;P1=-1937;P2=-962;P3=-3992;P4=380;D=03420101010202010202020102020202020102020202020202010101010202020202020202;CP=0;SP=3;R=10;O;
2017.03.30 02:23:03.575 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:23:03.575 5: sduino: Starting demodulation at Position 2
2017.03.30 02:23:03.575 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:24:22.571 4: sduino/msg READ: MS;P0=512;P1=-1920;P2=-950;P3=-3996;P4=390;D=03420101010202010202020102020202020102020202020202010101010202020202020202;CP=0;SP=3;R=9;O;
2017.03.30 02:24:22.576 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:24:22.577 5: sduino: Starting demodulation at Position 2
2017.03.30 02:24:22.577 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:37:32.339 4: sduino/msg READ: MS;P2=504;P4=-955;P5=-1948;P6=-3984;P7=384;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=10;O;
2017.03.30 02:37:32.345 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:37:32.345 5: sduino: Starting demodulation at Position 2
2017.03.30 02:37:32.346 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:38:51.339 4: sduino/msg READ: MS;P2=491;P4=-974;P5=-1944;P6=-3990;P7=376;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=9;O;
2017.03.30 02:38:51.343 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:38:51.344 5: sduino: Starting demodulation at Position 2
2017.03.30 02:38:51.344 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:38:51.799 4: sduino/msg READ: MS;P0=497;P1=-964;P2=-1933;P3=373;P4=-3998;D=04310202020101020101010201010101010201010101010101020202020101010101010101;CP=0;SP=4;R=9;O;
2017.03.30 02:38:51.803 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:38:51.803 5: sduino: Starting demodulation at Position 2
2017.03.30 02:38:51.804 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:42:48.340 4: sduino/msg READ: MS;P2=506;P4=-956;P5=-1931;P6=-3992;P7=378;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=10;O;
2017.03.30 02:42:48.347 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:42:48.348 5: sduino: Starting demodulation at Position 2
2017.03.30 02:42:48.349 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:44:07.340 4: sduino/msg READ: MS;P2=505;P4=-956;P5=-1942;P6=-4002;P7=382;D=26742525252424252424242524242424242524242424242424252525252424242424242424;CP=2;SP=6;R=10;O;
2017.03.30 02:44:07.346 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:44:07.347 5: sduino: Starting demodulation at Position 2
2017.03.30 02:44:07.347 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:53:20.611 4: sduino/msg READ: MS;P0=490;P1=-1941;P2=-976;P3=-3994;P4=372;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 02:53:20.615 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:53:20.616 5: sduino: Starting demodulation at Position 2
2017.03.30 02:53:20.616 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:54:39.570 4: sduino/msg READ: MS;P0=491;P1=-1952;P2=-966;P3=-3996;P4=376;D=03420101010202010202020102020202020102020202020202010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 02:54:39.576 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:54:39.577 5: sduino: Starting demodulation at Position 2
2017.03.30 02:54:39.577 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 02:54:39.807 4: sduino/msg READ: MS;P0=484;P1=-984;P2=-1934;P3=-3992;P4=372;D=03410202020101020101010201010101010201010101010101020202020101010101010101;CP=0;SP=3;R=11;O;
2017.03.30 02:54:39.813 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 02:54:39.813 5: sduino: Starting demodulation at Position 2
2017.03.30 02:54:39.814 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:02:30.586 4: sduino/msg READ: MS;P2=501;P4=-959;P5=-1949;P6=-3992;P7=382;D=26742525252424252424242524242424242425252525252525252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.30 03:02:30.590 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:02:30.591 5: sduino: Starting demodulation at Position 2
2017.03.30 03:02:30.591 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:05:08.834 4: sduino/msg READ: MS;P0=503;P1=-1935;P2=-966;P3=-4006;P4=378;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 03:05:08.839 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:05:08.840 5: sduino: Starting demodulation at Position 2
2017.03.30 03:05:08.840 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:05:09.086 4: sduino/msg READ: MS;P0=501;P1=-1935;P2=-966;P3=-3991;P4=384;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=10;O;
2017.03.30 03:05:09.092 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:05:09.092 5: sduino: Starting demodulation at Position 2
2017.03.30 03:05:09.093 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:07:46.585 4: sduino/msg READ: MS;P2=501;P4=-960;P5=-1951;P6=-3994;P7=384;D=26742525252424252424242524242424242425252525252525252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.30 03:07:46.589 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:07:46.590 5: sduino: Starting demodulation at Position 2
2017.03.30 03:07:46.590 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:07:47.085 4: sduino/msg READ: MS;P0=504;P1=-1932;P2=-965;P3=-4003;P4=373;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 03:07:47.089 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:07:47.089 5: sduino: Starting demodulation at Position 2
2017.03.30 03:07:47.090 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:09:06.086 4: sduino/msg READ: MS;P0=500;P1=-1938;P2=-968;P3=-4009;P4=378;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 03:09:06.089 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:09:06.090 5: sduino: Starting demodulation at Position 2
2017.03.30 03:09:06.090 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:10:25.086 4: sduino/msg READ: MS;P0=510;P1=-1915;P2=-951;P3=-3981;P4=388;D=03420101010202010202020102020202020201010101010101010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 03:10:25.092 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:10:25.092 5: sduino: Starting demodulation at Position 2
2017.03.30 03:10:25.093 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:18:18.827 4: sduino/msg READ: MS;P0=518;P1=-1929;P2=-952;P3=-3978;P4=396;D=03420101010202010202020102020202020201010101010102010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 03:18:18.833 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:18:18.834 5: sduino: Starting demodulation at Position 2
2017.03.30 03:18:18.834 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:22:15.827 4: sduino/msg READ: MS;P0=501;P1=-1940;P2=-954;P3=-3992;P4=382;D=03420101010202010202020102020202020201010101010102010101010202020202020202;CP=0;SP=3;R=11;O;
2017.03.30 03:22:15.831 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:22:15.831 5: sduino: Starting demodulation at Position 2
2017.03.30 03:22:15.832 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:27:31.596 4: sduino/msg READ: MS;P0=-960;P1=372;P2=495;P3=-1932;P4=-3982;D=24102323232020232020202320202020202023232323232320232323232020202020202020;CP=2;SP=4;R=10;O;
2017.03.30 03:27:31.600 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:27:31.601 5: sduino: Starting demodulation at Position 2
2017.03.30 03:27:31.601 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:30:09.828 4: sduino/msg READ: MS;P0=497;P1=-1944;P2=-962;P3=-4004;P4=374;D=03420101010202010202020102020202020201010101010201010101010202020202020202;CP=0;SP=3;R=10;O;
2017.03.30 03:30:09.834 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:30:09.835 5: sduino: Starting demodulation at Position 2
2017.03.30 03:30:09.835 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:31:28.588 4: sduino/msg READ: MS;P1=493;P2=-970;P3=-1930;P4=-3996;P5=356;D=14521313131212131212121312121212121213131313131213131313131212121212121212;CP=1;SP=4;R=12;O;
2017.03.30 03:31:28.592 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:31:28.592 5: sduino: Starting demodulation at Position 2
2017.03.30 03:31:28.593 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:35:25.828 4: sduino/msg READ: MS;P0=496;P1=-1950;P2=-970;P3=-3994;P4=380;D=03420101010202010202020102020202020201010101010201010101010202020202020202;CP=0;SP=3;R=10;O;
2017.03.30 03:35:25.834 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:35:25.835 5: sduino: Starting demodulation at Position 2
2017.03.30 03:35:25.835 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:42:00.578 4: sduino/msg READ: MS;P2=503;P4=-957;P5=-1936;P6=-4004;P7=374;D=26742525252424252424242524242424242425252525252424252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.30 03:42:00.589 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:42:00.590 5: sduino: Starting demodulation at Position 2
2017.03.30 03:42:00.590 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:45:58.076 4: sduino/msg READ: MS;P0=486;P1=-1952;P2=-976;P3=-3991;P4=373;D=03420101010202010202020102020202020201010101010201010101010202020202020202;CP=0;SP=3;R=6;O;
2017.03.30 03:45:58.080 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:45:58.080 5: sduino: Starting demodulation at Position 2
2017.03.30 03:45:58.081 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 03:57:48.585 4: sduino/msg READ: MS;P2=496;P4=-966;P5=-1932;P6=-4000;P7=374;D=26742525252424252424242524242424242425252525252425252525252424242424242424;CP=2;SP=6;R=12;O;
2017.03.30 03:57:48.592 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 03:57:48.592 5: sduino: Starting demodulation at Position 2
2017.03.30 03:57:48.593 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 04:00:26.829 4: sduino/msg READ: MS;P0=502;P1=-1942;P2=-960;P3=-4002;P4=376;D=03420101010202010202020102020202020201010101010201010101010202020202020202;CP=0;SP=3;R=12;O;
2017.03.30 04:00:26.833 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 04:00:26.833 5: sduino: Starting demodulation at Position 2
2017.03.30 04:00:26.834 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 04:01:46.910 4: sduino/msg READ: MS;P2=503;P4=-966;P5=-1940;P6=-4000;P7=380;D=26742525252424252424242524242424242425252525252425252525252424242424242424;CP=2;SP=6;R=11;O;
2017.03.30 04:01:46.915 4: sduino: Matched MS Protocol id 7 -> weatherID7
2017.03.30 04:01:46.915 5: sduino: Starting demodulation at Position 2
2017.03.30 04:01:46.915 5: sduino: Found wrong signalpattern, catched 0 bits, aborting demodulation
2017.03.30 04:04:23.583 4: sduino/msg READ: MS;P2=498;P4=-964;P5=-1932;P6=-4004;P7=380;D=26742525252424252424242524242424242425252525252425252525252424242424242424;CP=2;SP=6;R=12;O;
2017.03.30 04:04:23.587 4: sduino: Matched MS Protocol id 7 -> w
Du kannst mal versuchen mit "set sduino cc1101_bWidth" die bWidth auf ca 500 zu erhöhen.
Gruß Ralf
Guten Abend,
der Versuch "set sduino cc1101_bWidth 500" wird mit
Unknown argument cc1101_bWidth, choose one of ITClock close disableMessagetype enableMessagetype flash raw reset sendMsg
beantwortet.
Ein "list sduino" ergibt folgendes:
Clients :IT:CUL_TCM97001:OREGON:CUL_TX:Hideki:SD_WS07:SD_WS09: :SD_WS:RFXX10REC:Dooya:SOMFY:SD_WS_Maverick:SIGNALduino_un:
DEF /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_edit_by_Anfichtn_for_NanoC_NanoCUL_99991-if00-port0@57600
DMSG P7#722089F00
DevState initialized
DeviceName /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_edit_by_Anfichtn_for_NanoC_NanoCUL_99991-if00-port0@57600
FD 16
ITClock 300
MSGCNT 2334
NAME sduino
NR 212
NR_CMD_LAST_H 1
PARTIAL
RAWMSG MS;P0=487;P5=-1935;P6=-971;P7=-4002;D=07060505050606050606060506060606060506060605060605050505050606060606060606;CP=0;SP=7;R=253;O;
STATE opened
TIME 1490907798
TYPE SIGNALduino
unknownmessages 2017-03-30 14:36:23-MS;P1=-949;P2=512;P3=392;P4=-1927;P5=-3990;D=25312424242121242121212421212121212424212121212121242424242121212121212121;CP=2;SP=5;R=234;O;#2017-03-30 14:37:42-MS;P0=508;P1=-943;P2=-1919;P3=-3992;P4=384;D=03410202020101020101010201010101010202010101010102020202020101010101010101;CP=0;SP=3;R=234;O;#2017-03-30 14:37:42-MS;P0=518;P1=-947;P2=-3987;P3=393;P4=-1917;D=02310404040101040101010401010101010404010101010104040404040101010101010101;CP=0;SP=2;R=233;O;#2017-03-30 14:38:45-MU;P0=-312;P1=112;P2=-136;P3=3353;P4=-2452;P5=1876;P6=-1027;P7=-712;D=01234345656565656563656565434565656565656365456565657;CP=5;R=227;#2017-03-30 14:41:39-MS;P0=528;P1=-935;P2=-1911;P3=-3974;P4=400;D=03410202020101020101010201010101010202010101020202020202020101010101010101;CP=0;SP=3;R=233;O;#2017-03-30 14:45:36-MS;P1=-953;P2=503;P3=-1934;P4=-4000;P5=382;D=24512323232121232121212321212121212323212123212123232323232121212121212121;CP=2;SP=4;R=237;O;#2017-03-30 14:46:45-MU;P0=3371;P1=-2438;P2=1943;P3=-981;P4=-7280;D=01232323232323232323230321232323232323032101232304;CP=2;R=217;#2017-03-30 14:46:45-MU;P0=3366;P1=-2516;P2=-184;P3=1922;P4=-979;P5=-3952;P6=5912;P7=-6512;D=2343434343434343435670101343434343434343434340432;CP=3;R=228;#2017-03-30 14:46:55-MS;P0=-4000;P1=484;P3=523;P7=-1946;D=10131717171313171313131713131313131717131317131317171717171313131313131313;CP=1;SP=0;R=238;#2017-03-30 14:47:45-MU;P0=-572;P1=1932;P2=-966;P3=3371;P4=-2480;P5=-4312;P6=112;D=0121234121212121232141212121212121212321412123560;CP=1;R=217;#2017-03-30 14:47:45-MU;P0=-632;P1=1925;P2=-1010;P3=-4052;P4=5992;P5=-6440;P6=3389;P7=-2475;D=0121212121212121213456767121212671212121212621712121212121212126217121263;CP=1;R=228;#2017-03-30 14:49:33-MS;P0=-1952;P1=494;P2=-965;P3=-4006;P4=372;D=13421010101212101212121012121212121010121210101212101010101212121212121212;CP=1;SP=3;R=241;O;#2017-03-30 14:49:34-MS;P0=-963;P1=503;P2=-1929;P3=-4008;P4=370;D=13401212121010121010101210101010101212101012121010121212121010101010101010;CP=1;SP=3;R=241;O;#2017-03-30 14:49:45-MU;P0=-2484;P1=3327;P2=1872;P3=-1051;P4=-6984;D=010232323132023232323132023232323232323132320232314;CP=2;R=216;#2017-03-30 14:50:53-MS;P0=-1947;P1=490;P2=-962;P3=-3952;P4=376;D=13421010101212101212121012121212121010121210101010101010101212121212121212;CP=1;SP=3;R=242;#2017-03-30 14:51:15-MU;P0=-488;P1=3366;P2=-2505;P3=1891;P4=-1033;P5=-1768;D=012343434121234343414323434343434343434343415;CP=3;R=217;#2017-03-30 14:53:31-MS;P0=-963;P1=495;P2=-1952;P3=-3944;P4=376;D=13401212121010121010101210101010101212101210101210121212121010101010101010;CP=1;SP=3;R=243;#2017-03-30 14:56:08-MS;P0=499;P1=-961;P2=-1944;P3=-3997;P4=380;D=03410202020101020101010201010101010202010201010102020202020101010101010101;CP=0;SP=3;R=244;O;#2017-03-30 14:56:09-MS;P0=467;P1=-964;P2=-3968;P4=-1948;D=02010401010404010401010104040404040101010101010101;CP=0;SP=2;R=244;#2017-03-30 14:57:27-MS;P0=-966;P1=495;P2=-1949;P3=-3996;P4=380;D=13401212121010121010101210101010101212101210101012121212121010101010101010;CP=1;SP=3;R=245;O;#2017-03-30 14:58:46-MS;P0=494;P1=-1938;P2=-970;P3=-4004;P4=364;D=03420101010202010202020102020202020101020102020102010101010202020202020202;CP=0;SP=3;R=243;O;#2017-03-30 14:58:47-MS;P0=480;P1=-970;P2=-3964;P4=-1945;D=02010404040404010401010401040404040101010101010101;CP=0;SP=2;R=244;#2017-03-30 15:00:05-MS;P3=-964;P4=505;P5=-1930;P6=-4008;P7=382;D=46734545454343454343434543434343434545434543454343454545454343434343434343;CP=4;SP=6;R=244;O;#2017-03-30 15:00:05-MS;P0=492;P1=-1945;P2=-964;P3=-3998;P4=376;D=03420101010202010202020102020202020101020102010202010101010202020202020202;CP=0;SP=3;R=245;O;#2017-03-30 15:01:24-MS;P0=495;P1=-963;P2=-3997;P3=374;P4=-1931;D=02310404040101040101010401010101010404010401040401040404040101010101010101;CP=0;SP=2;R=246;O;
version V 3.3.1-dev SIGNALduino cc1101 - compiled at Mar 28 2017 22:31:59
Helper:
Dblog:
State:
Mydblog:
TIME 1490858862.45667
VALUE raw WS
Matchlist:
10:SD_WS07 ^P7#[A-Fa-f0-9]{6}F[A-Fa-f0-9]{2}
11:SD_WS09 ^P9#[A-Fa-f0-9]+
12:SD_WS ^W\d+x{0,1}#.*
13:RFXX10REC ^(20|29)[A-Fa-f0-9]+
14:Dooya ^P16#[A-Fa-f0-9]+
15:SOMFY ^YsA[0-9A-F]+
16:SD_WS_Maverick ^P47#[A-Fa-f0-9]+
1:IT ^i......
2:CUL_TCM97001 ^s[A-Fa-f0-9]+
4:OREGON ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
5:CUL_TX ^TX..........
7:Hideki ^P12#75[A-F0-9]+
X:SIGNALduino_un ^[uP]\d+#.*
QUEUE:
Readings:
2017-03-29 00:37:30 ITParms Unsupported command
2017-03-29 00:37:36 cmds V R t X F S P C r W x e
2017-03-29 00:37:41 config MS=1;MU=1;MC=1
2017-03-29 00:37:52 freeram 472
2017-03-30 23:03:10 ping OK
2017-03-30 09:32:00 raw C35 = 0D
2017-03-30 23:03:18 state opened
2017-03-30 15:09:39 uptime 1 14:56:37
2017-03-29 23:05:43 version V 3.3.1-dev SIGNALduino cc1101 - compiled at Mar 28 2017 22:31:59
XMIT_TIME:
1490892760
Getcmd:
Keepalive:
ok 1
retry 0
mcIdList:
10
11
12
18
43
47
msIdList:
0
1
13
14
15
17
2
22
23
25
3
32
33
35
38
4
41
45
6
7
muIdList:
16
20
21
24
26
27
28
29
30
31
34
36
37
39
40
42
44
46
48
49
5
50
51
8
9
flashCommand avrdude -c arduino -b 57600 -P [PORT] -p atmega328p -vv -U flash:w:[HEXFILE] 2>[LOGFILE]
room 99_System
verbose 4
anfichtn
Bitte mach mal ein
update all https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/dev-r33/controls_signalduino.txt
Update erfolgt, messages bleiben und werden weiter verworfen.
anfichtn
was ergibt ein "get ccconf"
Bei mir sieht es so aus:
ccconf: freq:433.920MHz bWidth:464KHz rAmpl:42dB sens:4dB (DataRate:5603.79Baud)
get ccconf ergibt
ccconf: freq:433.920MHz bWidth:464KHz rAmpl:42dB sens:8dB (DataRate:5603.79Baud)
anfichtn
