Ich möchte gerne mit HTTPMOD die Bestellungen aus unserem Webshop holen. Nicht über die IP wundern, im Moment ist die Webseite noch lokal. Ich komme mit der Anmeldung nicht weiter.
List
BUSY 0
CHANGED
DEF http://192.168.178.110/Steinmuhlys-shop/administrator/index.php?option=com_virtuemart&view=orders 60
HTTPCookies 9e357f6b6f50f63bf31ae06edd49ad82=ul9qnjgruam61dt5n724khfhv4
Interval 60
LASTSEND 1490988479.69998
MainURL http://192.168.178.110/Steinmuhlys-shop/administrator/index.php?option=com_virtuemart&view=orders
ModuleVersion 3.3.5 - 29.9.2016
NAME testbestellung
NR 306
STATE ???
TRIGGERTIME 1490988539.69797
TRIGGERTIME_FMT 2017-03-31 21:28:59
TYPE HTTPMOD
addr http://192.168.178.110:80
buf
code 200
conn
data
displayurl http://192.168.178.110/Steinmuhlys-shop/administrator/index.php?option=com_virtuemart&view=orders
header Cookie: 9e357f6b6f50f63bf31ae06edd49ad82=ul9qnjgruam61dt5n724khfhv4
host 192.168.178.110
httpheader HTTP/1.1 200 OK
Date: Fri, 31 Mar 2017 19:27:55 GMT
Server: Apache/2.4.17 (Win32) OpenSSL/1.0.2d PHP/5.6.21
X-Powered-By: PHP/5.6.21
P3P: CP="NOI ADM DEV PSAi COM NAV OUR OTRo STP IND DEM"
X-Frame-Options: SAMEORIGIN
Expires: Wed, 17 Aug 2005 00:00:00 GMT
Last-Modified: Fri, 31 Mar 2017 19:27:55 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Content-Length: 6098
Connection: close
Content-Type: text/html; charset=utf-8
httpversion 1.1
hu_blocking 0
hu_filecount 39
hu_portSfx
ignoreredirects 0
loglevel 4
path /Steinmuhlys-shop/administrator/index.php?option=com_virtuemart&view=orders
protocol http
redirects 0
timeout 2
value 0
Httpcookiehash:
9e357f6b6f50f63bf31ae06edd49ad82:
Options path=/; HttpOnly
Value ul9qnjgruam61dt5n724khfhv4
QUEUE:
Readings:
Request:
data
header
ignoreredirects 0
retryCount 0
type update
value 0
Sslargs:
enableCookies 1
httpVersion 1.1
room steinmuhlys
sid01IgnoreRedirects 1
sid1Data username=xxx&passwd=xxx&lang=&option=com_login&task=login&return=aW5kZXgucGhw&3118b99da300520918bfefbf473d5574=1
sid1Header1 Content-Type: text/html
sid1Header2 Accept: */*
sid1Header3 X-PersonasInteractive-Addon: true
sid1URL http://192.168.178.110/Steinmuhlys-shop/administrator/index.php
userattr sid01IgnoreRedirects:0,1 sid1Data sid1Header1 sid1Header2 sid1Header3 sid1URL
verbose 5
Log
HTMLCODE der Startseite
</body>
</html>
no error
2017.03.31 21:18:34 5: testbestellung: looking for Cookies in HTTP/1.1 200 OK
Date: Fri, 31 Mar 2017 19:18:28 GMT
Last-Modified: Fri, 31 Mar 2017 19:18:28 GMT
Pragma: no-cache
Connection: close
2017.03.31 21:18:34 5: testbestellung: ExtractSid called, context reading, num
2017.03.31 21:18:34 4: testbestellung: CheckAuth decided no authentication required
2017.03.31 21:18:34 5: testbestellung: Read starts parsing response to update with defined readings:
2017.03.31 21:18:34 3: testbestellung: Read response to update didn't match any Reading
2017.03.31 21:18:34 5: testbestellung: HandleSendQueue called, qlen = 0
Ich habe versucht mit Burp Suite die entsprechenden Daten auszulesen, komme aber nicht so ganz damit klar. Welche Daten brauche ich genau. Und wie kann ich dort mitschneiden um es hier zu posten ?
Vielen Dank für Eure Hilfe,
Beate
