Ich habe seit ein paar Tagen den Bewegungsmelder HM-SEC-MDIR-2. Dieser meldet ja auch die brightness. Allerdings habe ich immer nur einen Wert zwischen 32 und 33.
Anbei ein List vom Gerät:
CHANGED
DEF 516795
HMLAN1_MSGCNT 1671
HMLAN1_RAWMSG E516795,0000,17FDF3C3,FF,FFCC,9F84105167952573A20601210E
HMLAN1_RSSI -52
HMLAN1_TIME 2017-04-10 20:56:29
IODev HMLAN1
LASTInputDev HMLAN1
MSGCNT 1671
NAME FL_Bewegungsmelder
NOTIFYDEV global
NR 145
NTFY_ORDER 50-HM_516795
STATE noMotion
TYPE CUL_HM
lastMsg No:9F - t:10 s:516795 d:2573A2 0601210E
protLastRcv 2017-04-10 20:56:29
protResnd 1 last_at:2017-04-07 22:46:10
protSnd 590 last_at:2017-04-10 19:40:36
protState CMDs_done
rssi_at_HMLAN1 cnt:1671 lst:-52 max:-40 min:-71 avg:-52.65
Readings:
2017-04-07 23:00:25 Activity alive
2017-04-07 23:09:19 CommandAccepted yes
2017-04-07 23:00:25 D-firmware 1.6
2017-04-07 23:00:25 D-serialNr NEQ1462236
2017-04-07 23:09:20 PairedTo 0x2573A2
2017-04-07 23:09:20 R-brightFilter 7
2017-04-07 23:09:20 R-captInInterval off
2017-04-04 21:19:34 R-evtFltrNum 1
2017-04-04 21:19:34 R-evtFltrPeriod 1 s
2017-04-07 23:09:20 R-minInterval 30
2017-04-07 22:54:15 R-pairCentral 0x2573A2
2017-04-07 22:50:49 R-sabotageMsg on
2017-04-04 21:19:34 R-sign off
2017-04-07 23:09:20 RegL_00. 02:01 0A:25 0B:73 0C:A2 10:01 00:00
2017-04-07 23:09:20 RegL_01. 01:12 02:71 08:00 22:00 00:00
2017-04-10 20:56:29 battery ok
2017-04-10 20:56:29 brightness 33
2017-04-10 20:56:29 cover open
2017-04-10 19:41:08 motion off
2017-04-10 19:40:36 motionCount 163_next:30s
2017-04-10 19:41:08 motionDuration 124
2017-04-07 22:52:32 powerOn 2017-04-07 22:52:32
2017-04-10 20:56:29 recentStateType info
2017-04-10 19:41:08 state noMotion
2017-04-10 19:33:09 statw 0
2017-04-10 19:40:36 trigDst_2573A2 noConfig
2017-04-10 19:40:36 trigger_cnt 163
Helper:
HM_CMDNR 159
PONtest 0
cSnd 012573A251679501040000000001,012573A25167950103
mId 00C0
peerIDsRaw ,00000000
rxType 28
supp_Pair_Rep 0
Expert:
def 1
det 0
raw 1
tpl 0
Io:
newCh 1
newChn +516795,00,00,00
nextSend 1491850589.25641
prefIO
rxt 2
vccu
p:
516795
00
00
00
Mrssi:
mNo 9F
Io:
HMLAN1 -50
Prt:
bErr 0
sProc 0
sleeping 0
try 1
Rspwait:
Q:
qReqConf
qReqStat
Role:
chn 1
dev 1
Rssi:
At_hmlan1:
avg -52.6576900059844
cnt 1671
lst -52
max -40
min -71
Shadowreg:
Tmpl:
IODev HMLAN1
actCycle 000:20
actStatus alive
autoReadReg 4_reqStatus
event-on-change-reading .*
expert 2_defReg+raw
firmware 1.6
model HM-SEC-MDIR-2
peerIDs 00000000,
room Flur
serialNr NEQ1462236
showtime 1
subType motionDetector
Ich habe den Bewegungsmelder auch bereits auf Werkseinstellung zurückgesetzt und ungepeert, aber das hat keine Veränderung gebracht. Die brightness ändert sich nicht, egal ob hell oder dunkel.
brightFilter habe ich bereits schon auf Werte zwischen 0 und 7 gesetzt. Es ändert sich nichts.
Hat noch jemand eine Idee? Gerät vielleicht defekt?
Desmo
ich habe zwei von den Teilen hier im Einsatz ... funktionieren prächtig. brightFilter steht bei mir auf 7 (default), und bei intensiver Einstrahlung erhalte ich Werte bis 250.
Entweder ist es bei dir seeeehr dunkel, oder das Ding ist defekt ;D
Hallo.
Wie ist denn der Sensor verbaut? Evtl. zu sehr im schatten oder in einer "dunklen Ecke"?
Verdammt der ist also echt defekt :( danke! Hab einen neuen bestellt.
Zitat von: darkness am 11 April 2017, 06:51:38
Hallo.
Der Sensor steht im Flur auf einem Schrank. Selbst wenn ich den Sensor in die Sonne stelle, bleibt der Wert bei 32.
