FHEM => Anfängerfragen => Thema gestartet von: Edi77 am 17 April 2017, 22:32:13
Titel: System FileLog & ESPEasyMega
Beitrag von: Edi77 am 17 April 2017, 22:32:13
Im LogFile kommt bei mir immer wieder ein Eintrag ich vermute vom EasyESP 2.0.0 dev.7 wenn auf der LCD geschrieben wird.
Ich würde gerne verhindern das mir das LogFile voll läuft, wie kann ich das am besten machen?
<script language="javascript"><!--
function dept_onchange(frmselect) {frmselect.submit();}
//--></script><head><title>ESP58</title><style>* {font-family:sans-serif; font-size:12pt;}h1 {font-size:16pt; color:black;}h6 {font-size:10pt; color:black; text-align:center;}.button-menu {background-color:#ffffff; color:blue; margin: 10px; text-decoration:none}.button-link {padding:5px 15px; background-color:#0077dd; color:#fff; border:solid 1px #fff; text-decoration:none}.button-menu:hover {background:#ddddff;}.button-link:hover {background:#369;}th {padding:10px; background-color:black; color:#ffffff;}td {padding:7px;}table {color:black;}.div_l {float: left;}.div_r {float: right; margin: 2px; padding: 1px 10px; border-radius: 7px; background-color:#080; color:white;}.div_br {clear: both;}</style></head><h1>Welcome to ESP Easy Mega: ESP58</h1><BR><a class="button-menu" href=".">Main</a><a class="button-menu" href="config">Config</a><a class="button-menu" href="controllers">Controllers</a><a class="button-menu" href="hardware">Hardware</a><a class="button-menu" href="devices">Devices</a><a class="button-menu" href="notifications">Notifications</a><a class="button-menu" href="tools">Tools</a><BR><BR><form><table><TH>Tools<TH><TR><TD>System<TD><a class="button-link" href="/?cmd=reboot">Reboot</a><a class="button-link" href="log">Log</a><a class="button-link" href="sysinfo">Info</a><a class="button-link" href="advanced">Advanced</a><BR><BR><TR><TD>Wifi<TD><a class="button-link" href="/?cmd=wificonnect">Connect</a><a class="button-link" href="/?cmd=wifidisconnect">Disconnect</a><a class="button-link" href="/wifiscanner">Scan</a><BR><BR><TR><TD>Interfaces<TD><a class="button-link" href="/i2cscanner">I2C Scan</a><BR><BR><TR><TD>Settings<TD><a class="button-link" href="/upload">Load</a><a class="button-link" href="/download">Save</a><TR><TD>Firmware<TD><a class="button-link" href="/update">Load</a><a class="button-link" href="http://www.letscontrolit.com/wiki/index.php/EasyOTA" target="_blank">?</a><TR><TD>Filesystem<TD><a class="button-link" href="/filelist">Flash</a><a class="button-link" href="/SDfilelist">SD Card</a><BR><BR><TR><TD>Command<TD><input type='text' name='cmd' value='NeoPixel,6,0,0,0'><TR><TD><TD><input class="button-link" type='submit' value='Submit'><TR><TD></table></form><h6>Powered by www.letscontrolit.com</h6></body><script language="javascript"><!--
Titel: Antw:System FileLog & ESPEasyMega
Beitrag von: Thorsten Pferdekaemper am 18 April 2017, 07:55:48
zeig doch mal die Log-Einträge, dann kann man vielleicht was dazu sagen.
...und was hat das JavaScript, das Du mitgegeben hast, damit zu tun?
   Thorsten
Beitrag von: dev0 am 18 April 2017, 08:03:13
Du scheinst _irgendwie_ auf das ESPEasy Webinterface zuzugreifen, dabei wird anscheinend der Inhalt ins Log geschrieben.
Beitrag von: Thorsten Pferdekaemper am 18 April 2017, 08:21:53
Achso, das ist der Eintrag im Log...
Beitrag von: dev0 am 18 April 2017, 08:47:31
Vielleicht ;)
Beitrag von: Edi77 am 18 April 2017, 17:09:44
Ja, der Java Eintrag ist der Logfile Eintrag.
Es geht wie schon beschrieben um das FHEM System Logfile also
attr global logfile .....
Ich weiß auch das man mit :(?!blablabla).* etwas ausschließen kann.
Aber wie kann ich das auf attr global logfile ..... anwenden?
Beitrag von: dev0 am 18 April 2017, 17:27:08
Der Logeintrag könnte bspw. durch einen falsch angewendeten http request aus einem notify, at, etc. kommen. Dort solltest Du ansetzen und den Aufruf korrigieren.
Beitrag von: Edi77 am 18 April 2017, 17:38:39
Das mit dem Aufruf würde ich ehr ausschließen, habe ich schon überprüft, hängt wohl mit der noch frühen ESPEasyMega 2.0.0 dev.7 zusammen.
Auf einem ESPEasy 147RC8 und 120 läuft der gleiche Aufruf ohne Probleme.
Beitrag von: dev0 am 18 April 2017, 17:59:03
Sehr unwahrscheinlich.
Beitrag von: Thorsten Pferdekaemper am 18 April 2017, 18:11:48
wie sieht das ganze denn auf der FHEM-Seite aus? D.h. wie genau wird denn von FHEM aus "auf der LCD geschrieben"?
Gibt's dafür ein Modul oder geht das per 99_myUtils-Funktion oder...?
   Thorsten
Beitrag von: Edi77 am 18 April 2017, 18:37:23
Der Aufruf
Wie schon beschrieben, der identische Aufruf unter ESPEasy147 146 145 120 funktioniert.
define OLED_ESP58 dummy
define esp_oled58 at +*00:01 {\
my $temp=(ReadingsVal ("KS300","temperature","0"));;\
my $humi=(ReadingsVal ("KS300","humidity","0"));;\
my $wind=(ReadingsVal ("ESP86_DWohnz_10_Count_ber1","state","0"));;\
my $rain=(ReadingsVal ("KS300","rain","0"));;\
my $israining=(ReadingsVal ("KS300","israining","0"));;\
my $pressnn=(ReadingsVal ("BMP180OUTDOOR","pressure-nn","0"));;\
my $energieb=(ReadingsVal ("POWERZAEHLER","power","0"));;\
my $energiee=(ReadingsVal ("POWERZAEHLER","feed_L1","0"));;\
my $HeizWasser=(ReadingsVal ("Heizung_Wasser_Temp","state","0"));;\
# Log 3, "set OLED_ESP58: $temp$humi";;\
{GetHttpFile("192.168.1.58:80","/control?cmd=lcdcmd,clear")};;\
{GetHttpFile("192.168.1.58:80","/control?cmd=lcd,1,1,T:+$temp+H:+$humi+HT:+$HeizWasser")};;\
{GetHttpFile("192.168.1.58:80","/control?cmd=lcd,2,1,Wi:+$wind+Re:+$rain")};;\
{GetHttpFile("192.168.1.58:80","/control?cmd=lcd,3,1,hPa:+$pressnn+$israining")};;\
{GetHttpFile("192.168.1.58:80","/control?cmd=lcd,4,1,B:+$energieb+E:+$energiee+Watt")};;\
define FileLog_OLED_ESP58 FileLog ./log/OLED_ESP58-%Y-%m.log OLED_ESP58:.*
attr FileLog_OLED_ESP58 logtype text
attr FileLog_OLED_ESP58 room MQTT
define FileLog_esp_oled58 FileLog ./log/esp_oled58-%Y-%m.log esp_oled58:.*
attr FileLog_esp_oled58 logtype text
attr FileLog_esp_oled58 room MQTT
Beitrag von: dev0 am 18 April 2017, 19:24:02
Beende den Perlteil des at mal mit "return undef;".
Beitrag von: Edi77 am 19 April 2017, 23:43:42
Wenn ich
"return undef;".
eingebe, geht der Aufruf nicht mehr.
Beitrag von: dev0 am 20 April 2017, 00:00:54
return undef;
Ohne die Anführungszeichen und Satzzeichen. Syntax ist für den Def Editor.
Beitrag von: Thorsten Pferdekaemper am 20 April 2017, 08:26:08
...am besten mal nach der Änderung, wenn es nicht funktioniert, ein "list esp_oled58" liefern.
   Thorsten
Beitrag von: Edi77 am 23 April 2017, 04:03:43
Hat leider nicht funktioniert
   COMMAND    {
return undef;
   DEF        +*00:01 {
return undef;
   NAME       esp_oled58
   NR         440
   NTM        04:03:33
   PERIODIC   yes
   RELATIVE   yes
   REP        -1
   STATE      Next: 04:03:33
   TIMESPEC   00:01
   TRIGGERTIME 1492913013.89277
   TRIGGERTIME_FMT 2017-04-23 04:03:33
   TYPE       at
   Readings:
     2017-04-23 04:02:34   state           Next: 04:03:33
Beitrag von: Thorsten Pferdekaemper am 23 April 2017, 08:17:01
was meinst Du mit "nicht funktioniert"? Der Krempel ladet immer noch im Log oder es geht gar nicht?
   Thorsten
Beitrag von: dev0 am 23 April 2017, 08:17:55
Das gezeigte at scheint gar nicht der Auslöser für den Logeintrag zu sein. Wenn Du Dir Logeintrag näher ansiehst, dann geht es um einen (falschen?) Aufruf des NeoPixel Plugins und nicht des LCDs Plugins.
Nebenbei: die geschweiften Klammern um den GetHttpFile-Aufruf sind überflüssing und falsch. Zudem blockiert GetHttpFile() Dein FHEM, wenn der ESP nicht erreichbar ist, besser HttpUtils_NonblockingGet() verwenden. Weiterhin kann das ESPEasy Modul alles das, was Du da selbst versuchst umzusetzen.
Beitrag von: Edi77 am 23 April 2017, 23:11:22
Ja die Fehlermeldungen landen immer noch im Log.
DANKE @dev0
Wäre dieser Aufruf dann richtig?
HttpUtils_NonblockingGet({ url=>"http://192.168.1.58:80","/control?cmd=lcdcmd,clear" })
HttpUtils_NonblockingGet({ url=>"http://192.168.1.58/tools?cmd=NeoPixel,1,50,0,0" })
Mein jetziger Aufruf für NeoPixel war
define LEDAnzeige1_1_1 notify LEDAnzeige1_1:red "wget -q -O- 'http://192.168.1.58/tools?cmd=NeoPixel,1,50,0,0'"
Und da das der erste ESPEasy ist wo ich NeoPixel nutze ist das wohl auch die Ursache.
Ich suche noch eine Anleitung wie ich in ESPEasy ein Plugin hinzufüge, kennt da jemand eine?
Beitrag von: dev0 am 24 April 2017, 00:52:56
Warum nutzt Du nicht das ESPEasy Modul? Zu einfach?
Beim HttpUtils_NonblockingGet Aufruf fehlt der callback hash-Parameter. Siehe Wiki.
Bist Du sicher, dass es in NeoPixel Url "tools?cmd" heißen soll? Kenne ich so nicht, habe jetzt aber nicht nachgesehen.
Beitrag von: Edi77 am 24 April 2017, 02:31:55
Hallo @dev0
Es gibt zum ESPEasy Modul noch kein Wiki Eintrag.
Habe schon etwas gesucht jetzt aber noch nichts gefunden wie man im ESPEasy Modul LCD & NeoPixel ansteuert, aber vielleicht hast du gerade einen Link wo die Syntax gut beschrieben ist. Der ESPEasy Modul Three ist ja schon 57 Seiten stark
Beitrag von: dev0 am 24 April 2017, 08:04:53
Die Doku ist in der commandref zu finden.
Alle offiziellen Plugins sind im Modul auch mit einer Hilfe bedacht:
set <esp> help
Usage: 'set <esp> help <clearreadings|dots|erase|gpio|help|irsend|lcd|lcdcmd|lights|longpulse|mcpgpio|oled|oledcmd|pcapwm|pcfgpio|pcflongpulse|pcfpulse|pulse|pwm|pwmfade|raw|reboot|reset|servo|status|statusrequest>'
set <esp> help lcd
Usage: set <esp> lcd <row> <col> <text>
Nicht offizielle Plugins lassen sich über den RAW Befehl aufrufen:
set <esp> raw neopixel 1 255 255 255
