Hallo zusammmen
ich habe heute einen
HM-WDS30-OT2-SM erhalten und gepairt, danach habe ich folgendeslist erhalten:Internals:
CFGFN
DEF 4BDC74
HMLAN1_MSGCNT 158
HMLAN1_RAWMSG E4BDC74,0000,37B9D733,FF,FFB0,9686704BDC7400000000BC64
HMLAN1_RSSI -80
HMLAN1_TIME 2017-04-21 18:24:58
HMLAN2_MSGCNT 33
HMLAN2_RAWMSG E4BDC74,0000,3E0D1F9F,FF,FF99,1E86704BDC7400000000DA64
HMLAN2_RSSI -103
HMLAN2_TIME 2017-04-21 13:20:30
HMLAN3_MSGCNT 162
HMLAN3_RAWMSG E4BDC74,0000,1A8C7B33,FF,FFA1,9686704BDC7400000000BC64
HMLAN3_RSSI -95
HMLAN3_TIME 2017-04-21 18:24:58
IODev HMLAN3
LASTInputDev HMLAN1
MSGCNT 353
NAME HM_4BDC74
NOTIFYDEV global
NR 33783
STATE T: 18.8
TYPE CUL_HM
channel_01 HM_4BDC74_T1
channel_02 HM_4BDC74_T2
channel_03 HM_4BDC74_T1_T2
channel_04 HM_4BDC74_T2_T1
channel_05 HM_4BDC74_Event
lastMsg No:96 - t:70 s:4BDC74 d:000000 00BC64
protCmdDel 26
protLastRcv 2017-04-21 18:24:58
protResnd 13 last_at:2017-04-21 12:37:56
protResndFail 4 last_at:2017-04-21 12:42:16
protSnd 18 last_at:2017-04-21 12:42:14
protState CMDs_done_Errors:1
rssi_at_HMLAN1 avg:-80.5 max:-62 min:-105 lst:-80 cnt:158
rssi_at_HMLAN2 lst:-103 avg:-88.72 max:-73 min:-105 cnt:33
rssi_at_HMLAN3 lst:-95 avg:-90.85 min:-99 max:-55 cnt:162
Helper:
HM_CMDNR 150
PONtest 0
cSnd 01456DEF4BDC7400050000000000,01456DEF4BDC74000802010A450B6D0CEF
mId 00A8
rxType 140
supp_Pair_Rep 0
Expert:
def 1
det 0
raw 1
tpl 0
Io:
newChn +4BDC74,00,00,00
nextSend 1492791898.75708
prefIO
rxt 2
vccu
p:
4BDC74
00
00
00
Mrssi:
mNo 96
Io:
HMLAN1 -80
HMLAN3 -93
Prt:
bErr 0
sProc 0
Q:
qReqConf
qReqStat
Role:
dev 1
Rssi:
At_hmlan1:
avg -80.5
cnt 158
lst -80
max -62
min -105
At_hmlan2:
avg -88.7272727272727
cnt 33
lst -103
max -73
min -105
At_hmlan3:
avg -90.8518518518519
cnt 162
lst -95
max -55
min -99
Shadowreg:
RegL_00. 02:01 0A:45 0B:6D 0C:EF
IODev HMLAN3
IOgrp vccu1:HMLAN3
actCycle 012:00
actStatus alive
autoReadReg 4_reqStatus
expert 2_raw
firmware 1.1
model HM-WDS30-OT2-SM
room CUL_HM
serialNr NEQ0532876
subType THSensor
webCmd getConfig:clear msgEvents
kann mir bitte jemand erklären, warum hier alle 3HMLANS enthalten sind und warum mir die channel 01 -04 keine Daten ausgeben?
channel05 zeigt mir HM_4BDC74_Event T: 18.6
dieser Sensor wurde als Bodenfeuchtigkeitssensor umgebaut
falls noch weitere Angaben für eine Erklärung notwendig sind, bitte bescheid geben
Gruss tagedieb
Dann klicke lassen auf channel_0x. Dann tauchen die entsprechenden Werte auf
Gesendet von dem teuren ding in meiner hand
hallo sash.sc
habe ich schon,und da erscheinen nur 3 Fragezeichen :-\
CFGFN
DEF 4BDC7401
NAME HM_4BDC74_T1
NOTIFYDEV global
NR 33785
STATE ???
TYPE CUL_HM
chanNo 01
device HM_4BDC74
Helper:
getCfgListNo
Expert:
def 1
det 0
raw 1
tpl 0
Role:
chn 1
peerIDs
gruss tagedieb
Hatte auch teilweise die Probleme gehabt.
Lösche das ganze device und lege bzw lerne es neu an.
Gruß Sascha
Hallo sash.sc
Danke für den Hinweis, werde ich morgen probieren, denn ich habe de Sensor im Garten
Gruss tagedieb
Notfalls sogar mehrmals löschen und wieder anlernen.
Vor dauerndem Löschen und neu anlegen (lassen) würde ich erst mal das PAIREN erfolgreich abschließen.
Sieht so aus als würde das noch nicht passen...
Hast du eine vccu!?
Evtl. wird versucht eben alle IODev zu probieren, weil die RSSI-Werte alle nicht sonderlich sind...
Wie steht es um die Entfernung?
Feuchtigkeit (weil du was von Umbau als Feuchtesensor schreibst)?
Was steht im Handbuch/Anleitung bzgl. Anlernen an Zentrale?
Was muss da beim Sensor gedrückt werden?
Evtl. den Knopf (oder was auch immer im Handbuch steht) erneut (ab und an mit Pausen) drücken, bis keine cmds-Pending sind.
Bzw. vorher clear msgEvents
Und dann ein neues getConfig absetzen und halt noch mal den "Anlernknopf" drücken.
Allerdings erst mal prüfen, wie es um den Empfang steht...
Und evtl. auch mal einen HMLAN als preferredIO setzen, halt den der noch die besten RSSI Werte hat.
Dann schaltet die vccu (nehme an du hast eine) nicht "ständig" die IODev durch, macht gerade das Pairing deutlich stabiler...
Gruß, Joachim
Guten Morgen Joachim
danke das du dir die Zeit für mein Problem nimmst
Hast du eine vccu!?ja ich habe auch eine vccu
ZitatUnd evtl. auch mal einen HMLAN als preferredIO setzen, halt den der noch die besten RSSI Werte hat.
rssi_at_HMLAN1 avg:-80.28 max:-62 min:-105 lst:-80 cnt:469
rssi_at_HMLAN2 avg:-90.48 max:-73 min:-106 lst:-105 cnt:37
rssi_at_HMLAN3 cnt:476 lst:-94 avg:-93.04 min:-99 max:-55 ein Teil des List vom Sensor
IODev HMLAN3
IOgrp vccu1:HMLAN3
actCycle 012:00
actStatus alive
expert 2_raw
firmware 1.1
room CUL_HM
serialNr NEQ0532876
subType THSensor
webCmd getConfig:clear msgEvents Evtl. wird versucht eben alle IODev zu probieren, weil die RSSI-Werte alle nicht sonderlich sind...ich werde heute mal die anderen HMLAN während des Pairens abschalten, denn die HMLAN3 ist nur 7m offene Sicht weg,und die rssi Werte des Hmlan3 die geeignetesten sind
ZitatFeuchtigkeit (weil du was von Umbau als Feuchtesensor schreibst)?
die Elektrik des Sensors (kleine Kasten)ist nicht der Witterung ausgesetzt,die Messenden sind aus Edelstahl und die Verbindung vom Kabel zum Messende wurden mit Schrumpfschlauch versehen
ZitatWas steht im Handbuch/Anleitung bzgl. Anlernen an Zentrale?......
Anlernen wie bei Homematic gewohnt - Anlernzustand des anderen Gerätes +Taste drücken......
ich werde nachher alles noch einmal Schritt für schritt durchgehen,denn ich bin mir sicher .... der Fehler.....vor dem PC
ich melde mich dann
gruss annette
Zitatund die rssi Werte des Hmlan3 die geeignetesten sind
Du hast aber schon gesehen, das der Hmlan3 die schlechtesten RSSI Werte hat.
Alles was unter -80 ist kann kritisch werden.
Dieser Funk-Temperaturdifferenz-Sensor HM-WDS30-OT2-SM kam doch als Bausatz, oder?
Ich habe auch so einen im Einsatz. Nach dem Zusammenlöten hatte ich auch derartige Probleme - vielleicht sogar exakt so. Ist ein wenig her.
Jedenfalls habe ich auch von Neu-Pairen über Löschen, Wiederanlernen bis hmPairSerial alles versucht. Ich war schon versucht, die Hotline anzurufen, aber erst wollte ich alles abschließend prüfen. Jedenfalls hatte ich mindestens einen Lötfehler am Funkmodul. Ist ja auch eine gruselige Konstruktion, die passgenauen Halt UND Kontakt gleichzeitig nur mit den Lötstellen herstellen soll. Also alles wieder auseinander, entlöten und nochmal - zumindest das Funkmodul an die Hauptplatine. Funzte sofort.
Nimm mal ein Multimeter zur Hand und prüf das sorgfältig, bevor Du den Sensor an die Wand wirfst. Soweit war ich auch fast. ;)
Hallo Annette,
da muss ich den anderen zustimmen, wenn der HMLAN nur 7m entfernt ist, dann sind die RSSI nicht gut...
...eigentlich von keinem.
Was noch eigenartig ist, sind die starken Schwankungen von eigentlich allen 3 HMLAN.
War der Sensor ein Bausatz?
Oder "nur" umgebaut?
Daher kann das mit dem Löten schon auch sein (wenn Bausatz)...
...oder hast du ihn bei verschiedenen Pairing-Versuchen viel bewegt (also mal näher und mal deutlich weit weg? Aber für weniger als -100 muss das normalerweise schon sehr weit sein, meist deuten solche Werte auf Geräte des Nachbarn ;) ).
Bzgl. Feuchtigkeit hab ich nur gefragt, ob der Sendeteil außen feucht/nass ist, da das auch den Funk beeinflussen kann...
Hat sich am list des Sensors inzwischen was geändert?
Bzw. was will uns das Teil-List des Sensors sagen? ;)
D.h. wie geraten würde ich noch den Schritt der Lötkontrolle mit dazu nehmen (sofern es ein Bausatz war).
Viel Erfolg, Joachim
hallo zusammen
danke für Eure grossartige Unterstützung, ich habe mit diesen Angaben ein grosses Maß an neuen Informationen erhalten, die ich vorher nicht zuordnen konnte :)
Bausatz ?kann ich nicht sagen, denn ich habe das Teilchen einsatzbereit erworben -einen Selbstbau habe ich mir hier nicht zugetraut :-[
Nachdem ich den Sensor mehrmals hinter einander resetet habe und nur ein HMLAN an war, liess er sich auch richtig pairen -jetzt habe ich folgendes list
CFGFN
DEF 4BDC74
HMLAN1_MSGCNT 105
HMLAN1_RAWMSG E4BDC74,0000,00EB9DAE,FF,FFAE,1886534BDC74000000004102B842026743005144FFAF
HMLAN1_RSSI -82
HMLAN1_TIME 2017-04-22 14:12:37
HMLAN2_MSGCNT 39
HMLAN2_RAWMSG E4BDC74,0000,00ACD445,FF,FF9A,1886534BDC74000000004102B842026743005144FFAF
HMLAN2_RSSI -102
HMLAN2_TIME 2017-04-22 14:12:36
HMLAN3_MSGCNT 120
HMLAN3_RAWMSG E4BDC74,0000,001F81E4,FF,FFA3,1886534BDC74000000004102B842026743005144FFAF
HMLAN3_RSSI -93
HMLAN3_TIME 2017-04-22 14:12:37
IODev HMLAN3
LASTInputDev HMLAN1
MSGCNT 264
NAME HM_4BDC74
NOTIFYDEV global
NR 23579
STATE CMDs_done
TYPE CUL_HM
lastMsg No:18 - t:53 s:4BDC74 d:000000 004102B842026743005144FFAF
protCmdDel 13
protLastRcv 2017-04-22 14:12:37
protResnd 9 last_at:2017-04-22 10:57:26
protResndFail 1 last_at:2017-04-22 10:51:27
protSnd 76 last_at:2017-04-22 13:14:34
protState CMDs_done
rssi_at_HMLAN1 lst:-82 max:-78 cnt:105 min:-101 avg:-86.37
rssi_at_HMLAN2 avg:-100.82 cnt:39 min:-103 max:-95 lst:-102
rssi_at_HMLAN3 min:-104 cnt:120 lst:-93 max:-77 avg:-91.43
Readings:
2017-04-22 13:14:17 Activity alive
2017-04-22 13:57:56 CommandAccepted yes
2017-04-22 13:14:17 D-firmware 1.1
2017-04-22 13:14:17 D-serialNr NEQ0532876
2017-04-22 13:14:27 PairedTo 0x456DEF
2017-04-22 10:44:59 R-burstRx off
2017-04-22 10:44:59 R-cyclicInfoMsgDis 0
2017-04-22 13:14:19 R-pairCentral 0x456DEF
2017-04-22 10:44:59 R-paramSel T1_T2
2017-04-22 13:14:27 RegL_00. 01:00 02:01 0A:45 0B:6D 0C:EF 11:00 18:00 1B:03 00:00
2017-04-22 14:12:36 battery ok
2017-04-22 13:14:14 powerOn 2017-04-22 13:14:14
2017-04-22 13:14:14 recentStateType info
2017-04-22 13:14:34 state CMDs_done
2017-04-22 10:51:24 temperature 12.3
Helper:
HM_CMDNR 24
PONtest 0
cSnd 01456DEF4BDC740403,01456DEF4BDC740503
mId 00A8
rxType 140
supp_Pair_Rep 0
Ack:
Expert:
def 1
det 0
raw 1
tpl 0
Io:
nextSend 1492863156.10129
prefIO
rxt 2
vccu
p:
4BDC74
00
00
00
Mrssi:
mNo 18
Io:
HMLAN1 -82
HMLAN2 -102
HMLAN3 -91
Prt:
bErr 0
sProc 0
try 1
Rspwait:
Q:
qReqConf
qReqStat
Role:
dev 1
Rssi:
At_hmlan1:
avg -86.3714285714286
cnt 105
lst -82
max -78
min -101
At_hmlan2:
avg -100.820512820513
cnt 39
lst -102
max -95
min -103
At_hmlan3:
avg -91.4333333333333
cnt 120
lst -93
max -77
min -104
Shadowreg:
IODev HMLAN3
IOgrp vccu1:HMLAN3
actCycle 012:00
actStatus alive
expert 2_raw
firmware 1.1
room 03-10,Aussen,Beregnungsanlage,CUL_HM
serialNr NEQ0532876
subType THSensor
webCmd getConfig:clear msgEvents das dürfte soweit passen?
Technik der Nachbarn? Glaube ich nicht, denn hier ist keiner für das Neue - selbst die Telefone wurden nicht gegen Smartphones eingetauscht = alles Rentner, welche früher in der Landwirtschaft gearbeitet haben ;)
@Joachim
ZitatBzgl. Feuchtigkeit hab ich nur gefragt, ob der Sendeteil außen feucht/nass ist, da das auch den Funk beeinflussen kann...
habe ich auch so verstanden, und bei so viel Mühe, mir zu helfen, ist eine Antwort auf die Fragen wohl das mindeste
kann das mit den rssi werten auch an etwas anderem liegen ? denn ein Fertiggerät, welches noch etwas näher am HMLAN3 eingesetzt wird, hat ähnliche Werte ?
rssi_at_HMLAN1 avg:-90.62 min:-97 cnt:8 lst:-83 max:-83
rssi_at_HMLAN3 avg:-85.37 cnt:8 min:-91 max:-79 lst:-91 Vielleicht weil der HMLAN3 in einem Alucontainer ist?
der HMLAN1 ist im Haus, im Obergeschoss Massivbau mit Betondecken
gruss tagedieb
Hallo Annette,
jep sieht ganz gut aus.
Jetzt sollten ja in den entsprechenden Kanälen die Tempwerte bzw. Feuchtigkeitswerte kommen...
Ich habe auch noch 2 von denen (aber als Bausatz, einer schon fertig) rumliegen wartend auf Umbau auf Feuchtigkeit...
...bin dann allerdings über die Xiaomi Pflanzensensoren gestolpert und werde diesen Sommer mal mit denen experimentieren...
https://forum.fhem.de/index.php/topic,60914.0.html
Zum Pairen ist es oft besser mal nur ein Funkmodul zu nutzen...
@Joachimhabe ich auch so verstanden, und bei so viel Mühe, mir zu helfen, ist eine Antwort auf die Fragen wohl das mindeste
Ah, das hat auch Vorteile.
Störungen im WLAN sind dann wohl auch eher nicht zu erwarten ;)
Aber die RSSI sind schon eigenartig und wie gesagt, wenn ich mal irgendwo Werte so -100 und schlechter sehe (oder wenn man hier im Forum liest), dann sind es meist die von Nachbarn...
Wenn eigene solche Werte zeigen, dann sollte man versuchen das zu verbessern.
Es gibt bei HM auch die Möglichkeit ein HM-MOD-PCB (Raspi-Aufsteckmodul) per ESP8266 als WLAN-HM-Funkmodul einzusetzen, falls WLAN ausreichend gut vorhanden ist...
Ab und an werden auch fertig zusammengebaute hier angeboten, ansonsten findet sich sicher jemand, der bei einem Kaufgesuch einen zusammenbaut...
Und danke für die Antwort! :)
Werte in den 90ern (oder auch über -80) sind nicht sonderlich gut.
Kann gehen muss aber nicht.
In einer Alubox ist sicher nicht gut.
Sind wenigstens (große) Öffnungen/Schlitze drin!?
Oder die Antenne nach außen geführt!?
Warum Alubox?
Und ja, das kann schon sein.
Massivbau/Betondecken kann nat. auch sein, kommt drauf an wie weit die Sensoren vom jeweiligen HMLAN weg sind und wieviel Beton/Wände dazwischen sind...
Über HMINFO kann man sich auch einen Überblick über die aktuellen Funkeigenschaften des Systems "geben" lassen:
https://wiki.fhem.de/wiki/HomeMatic_HMInfo
https://wiki.fhem.de/wiki/HomeMatic_HMInfo#Anzeigen_zur_.C3.9Cbertragungssituation
Viel Spaß, Joachim
Hallo Joachim
danke für die vielen Links zu HM info etc da kann ich ja heute abend in Ruhe einiges ausprobieren
Zitat...bin dann allerdings über die Xiaomi Pflanzensensoren gestolpert und werde diesen Sommer mal mit denen experimentieren...
habe ich auch im Forum gefunden und schon einige zeit verfolgt, jedoch bin ich nicht so ein bluetooth "fan", und ob das im Garten auf die Dauer funktioniert ???
weder noch, ich bin froh das der Container wasser und ungeziefer dicht ist :)
dieser Alucontainer wurde früher für Zementsäcke etc besorgt, jetzt fungiert er als Elektroraum für die Gartentechnik und als Fahrradgarage, denn zu ihm wird im Winter die Stromverbindung abgestellt und die Schaltkästen für die ganze Gartenelektronik stillgelegt
das mit der zusätzlichen Antenne, werde ich aber noch einmal überdenken - das ist eine gute Idee - Danke
so der Sensor sendet fleißig Daten, jetzt noch ausprobieren, welche Werte für meine Bewässerugsschaltung optimal sind und wieder habe ich mit der tolle Hilfe im Forum ein Stück geschafft
Danke und ich wünsche allen ein schönes Wochenende
gruss annette
Hallo Annette,
Ah Container dann eher so richtig groß wie ein Baucontainer... ;)
Soll der HMLAN dort HM-Geräte im Container oder außerhalb (bzw. NUR außerhalb) des Containers erreichen?
Wenn nur außerhalb, dann evtl. den HMLAN in eine dichte Kunststoffbox (so ähnlich wie für den Feuchtesensor oder eine Aufputzdose für Außeneinsatz [wobei ich jetzt nicht weiß wie groß der HMLAN tatsächlich ist]) und dann außerhalb des Containers anbringen und nur Stromkabel und Netzwerkkabel dann nach außen durchlegen...
Das mit den Xiaomi Sensoren werde ich sehen.
Evtl. baue ich meine doch auch noch um, denn eigentlich wollte ich auch bei HM bleiben...
...aber zum Basteln aktuell zu wenig Zeit.
Viel Spaß und schönes WE, Joachim
Hallo Joachim
ZitatAh Container dann eher so richtig groß wie ein Baucontainer... ;)
genau :)
der HMLAN schaltet auch Aktoren IM Container, denn in diesem Sicherungskasten ist auch meine Rasenroboter- und Roboterliftsteuerung :) und ein paar Steckdosen für Geräte, die man auch so mal braucht und zum Akku laden des Rasentrimmer und für eine Kamera
....und ich kann ihn abschliessen!!! 8)
Mit der Kunststoffbox wäre schwierig, denn der HMLAN ist ca 12-14cm im Durchmesser
mit dem Basteln ist das bei mir auch so, und eh wieder das angefangene Projekt, an unfertigen Bastelarbeiten scheitert, habe ich mich dieses Mal für eine fertige Version entschieden ;)
Dir auch noch viel Spass ud schönes WE
gruss annette
