Hallo zusammen.
Bin ich hier Richtig?
Beim heutigen Update auf zwei Systemen kam folgende Fehlermeldung im Log:
2017.06.09 13:21:22 1 : UPD FHEM/98_fheminfo.pm
2017.06.09 13:21:23 1 : saving fhem.cfg
2017.06.09 13:21:23 1 : saving ./log/fhem.save
2017.06.09 13:21:23 1 : New entries in the CHANGED file:
2017.06.09 13:21:23 1 : - bugfix: 93_DbLog: V2.16.11, lock SQLite from logging if deleteOldDaysNbl
2017.06.09 13:21:23 1 : or reduceLogNbL is running in async mode
2017.06.09 13:21:23 1 : - feature: ESPEasy: improved dual ip stack support
2017.06.09 13:21:23 1 : Calling /usr/bin/perl ./contrib/commandref_join.pl -noWarnings, this may take a while
2017.06.09 13:22:07 1 :
2017.06.09 13:22:07 1 : update finished, "shutdown restart" is needed to activate the changes.
2017.06.09 13:22:07 1 : PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/98_fheminfo.pm line 163.
2017.06.09 13:22:07 1 : fheminfo <html><table><tr><td colspan='3'>Following statistics data will be sent to server:</br>(see Logfile for server response)</td></tr><tr><td>System Info</td></tr><tr><td> </td><td>Release:</td><td>5.8</td></tr><tr><td> </td><td>FeatureLevel:</td><td>5.8</td></tr><tr><td> </td><td>OS:</td><td>linux</td></tr><tr><td> </td><td>Arch:</td><td>arm-linux-gnueabihf-thread-multi-64int</td></tr><tr><td> </td><td>Perl:</td><td>5.14.2</td></tr><tr><td> </td><td>uniqueId:</td><td>84cfbdaf6c97e23ff0a4236cfb257a7a</td></tr><tr><td> </td><td>upTime:</td><td>3 days, 17:05:38</td></tr><tr><td>Modules</td><td>Model</td><td>Count</td></tr><tr><td>DOIF</td><td> </td><td>3</td></tr><tr><td>Dashboard</td><td> </td><td>1</td></tr><tr><td>FHEMWEB</td><td> </td><td>9</td></tr><tr><td>FRM</td><td> </td><td>1</td></tr><tr><td>FRM_OUT</td><td> </td><td>4</td></tr><tr><td>FileLog</td><td> </td><td>15</td></tr><tr><td>Global</td><td> </td><td>1</td></tr><tr><td>IPCAM</td><td> </td><td>1</td></tr><tr><td>NETIO230</td><td> </td><td>4</td></tr><tr><td>OWMULTI</td><td> </td><td></td></tr><tr><td> </td><td>DS2438</td><td>3</td></tr><tr><td>OWTHERM</td><td> </td><td></td></tr><tr><td> </td><td>DS18B20</td><td>10</td></tr><tr><td>OWX</td><td> </td><td>5</td></tr><tr><td>PostMe</td><td> </td><td>1</td></tr><tr><td>SVG</td><td> </td><td>7</td></tr><tr><td>THRESHOLD</td><td> </td><td>1</td></tr><tr><td>TelegramBot</td><td> </td><td>1</td></tr><tr><td>allowed</td><td> </td><td>4</td></tr><tr><td>at</td><td> </td><td>2</td></tr><tr><td>autocreate</td><td> </td><td>1</td></tr><tr><td>cmdalias</td><td> </td><td>5</td></tr><tr><td>dummy</td><td> </td><td>1</td></tr><tr><td>eventTypes</td><td> </td><td>1</td></tr><tr><td>holiday</td><td> </td><td>2</td></tr><tr><td>notify</td><td> </td><td>10</td></tr><tr><td>remotecontrol</td><td> </td><td>1</td></tr><tr><td>telnet</td><td> </td><td>2</td></tr><tr><td>weblink</td><td> </td><td>7</td></tr></table></html>
Gruss Gerd
Ja, hier bist Du richtig. ;)
Aber ich habe heute morgen schonmal einen Thread dazu eröffnet, wenn auch noch ohne Antwort: [fheminfo] nach Update v. 09.06.: PERL WARNING: Use of uninitialized value... (https://forum.fhem.de/index.php/topic,72971.0.html)
jaja... ruhig bleiben. Das ist alles kein Weltuntergang, ich bin da schon dran.
Kann es sein, dass Ihr devices ohne TYPE in Euren FHEM Installationen habt?
Habe gerade eine korrigierte Modulversion eingecheckt.
Die Warnung bzgl. "uninitialized value" sollte nun nicht mehr kommen.
Was die Ausgabe von HTML Code angeht: Das ist so gewollt, damit die Informationen im Web-Frontend richtig dargestellt werden, siehe Anhang.
Wer sich per telnet verbindet, bekommt eine ähnliche Ausgabe ohne HTML Code.
Da "fheminfo send" beim Update aufgerufen wird, wird die Ausgabe in diesem Fall ins Logfile geschrieben. Das ist an sich kein Fehler. Ich werde mal mit Rudi diskutieren, wie wir das unterbinden können (Rudi ist für update zuständig, ich für fheminfo).
Was ich aber überhaupt noch nicht verstehe, ist der Titel dieses Threads:
ZitatFehlermeldung beim erzeugen der Hilfe
Wo geht es denn hier um das Erzeugen der Hilfe?
Ab dem morgigen Update wird bei der Ausführung von "update" kein html code mehr ins Logfile geschrieben.
Danke.
Ich bin ruhig und entspannt. ;)
Wissentlich habe ich keine Geräte ohne TYPE.
