FHEM - Hardware => Einplatinencomputer => Thema gestartet von: HarryT am 13 Juli 2017, 23:06:03
Titel: Raspberry and Reboot from fhem
Beitrag von: HarryT am 13 Juli 2017, 23:06:03
Hi I am trying to start a reboot of the rapsberry from  fhem with:
  system("sudo reboot &");
I tried this:
  http://ueberueck.com/index.php/fhem-hausautomatisierung/fhem-how-to-s/raspberry-aus-fhem-neu-starten
In my password file I have:
  fhem:x:999:20::/opt/fhem:/bin/bash
In groups I have:
  sudo:x:27:pi,fhem
In the fhem logging I get:
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
sudo: no tty present and no askpass program specified
Has anybody succeeded in getting this to work? If so, how?
Thanks
Titel: Antw:Raspberry and Reboot from fhem
Beitrag von: amenomade am 13 Juli 2017, 23:18:17
What do you have in /etc/sudoers ?
Beitrag von: HarryT am 14 Juli 2017, 15:56:21
Hi
my /etc/sudoers: ( it is the standard version. as far as I see, it is sufficient to add fhem to the group sudoers)
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults        env_reset
Defaults        mail_badpass
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root    ALL=(ALL:ALL) ALL
# Allow members of group sudo to execute any command
%sudo   ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
Beitrag von: Manul am 14 Juli 2017, 16:07:33
That would need to be
%sudo   ALL=(ALL:ALL) NOPASSWD: ALL
or better still
fhem ALL=(root) NOPASSWD: /sbin/shutdown
Beitrag von: HarryT am 14 Juli 2017, 18:26:05
Cool
worked.
BTW I guess adding fhem to the sudoers group is not necessary when this line is add to the sudoers file?
Thanks
Beitrag von: Manul am 14 Juli 2017, 19:21:33
Right.
