FHEM => fhem-users => Thema gestartet von: Guest am 05 März 2012, 07:06:02
Titel: Fehler in fhem nach update am 04.03.2012
Beitrag von: Guest am 05 März 2012, 07:06:02
Folgender Inhalt in fhem.cfg
define ctrl_heizung_bad_on notify HZ_Badezimmer:*.*on-for-timer.* {\
  my $m = ReadingsVal("FS_Badezimmer", "Window", "Open");;\
  my $hm = sprintf("%sprintf("%c", 02)d:%sprintf("%c", 02)d", $hour,
$min);;\
  if ($m eq "Open") {\
    fhem("set HZ_Badezimmer off-for-timer");;\
    fhem("set HZ_ST_Badezimmer off-for-timer");;\
  } else {\
    if( $hm gt "04:30" && $hm lt "24:00") {\
      fhem("set HZ_ST_Badezimmer on-for-timer 512");;\
define ctrl_heizung_bad_off notify HZ_Badezimmer:*.*off-for-timer {\
define ctrl_window_bad notify FS_Badezimmer:Window.*(Open|Closed) {\
define ctrl_window_gaeste_on notify HZ_Gaeste:*.*on-for-timer.* {\
  my $m = ReadingsVal("FS_Gaeste", "Window", "Open");;\
$min);;\
    fhem("set HZ_Gaeste off-for-timer");;\
    fhem("set HZ_ST_Gaeste off-for-timer");;\
  } else {\
      fhem("set HZ_ST_Gaeste on-for-timer 512");;\
define ctrl_window_gaeste_off notify HZ_Gaeste:*.*off-for-timer {\
define ctrl_window_gaeste notify FS_Gaeste:Window.*(Open|Closed) {\
führt zu folgenden logs:
Bareword found where operator expected at (eval 14) line 1, near ""on-
for-timer 512sprintf("on"
   (Missing operator before on?)
Number found where operator expected at (eval 14) line 1, near "timer
512"
   (Do you need to predeclare timer?)
"512c"
   (Missing operator before c?)
String found where operator expected at (eval 14) line 1, near "c",
02)d:on-for-timer 512sprintf(""
Bareword found where operator expected at (eval 14) line 1, near "",
02)d:on-for-timer 512sprintf("on"
512"
"512c"
02)d""
Bareword found where operator expected at (eval 229) line 1, near ""on-
Number found where operator expected at (eval 229) line 1, near "timer
512"
"512c"
String found where operator expected at (eval 229) line 1, near "c",
Bareword found where operator expected at (eval 229) line 1, near "",
512"
"512c"
02)d""
Argument "3.5 (Celsius)" isn't numeric in addition (+) at (eval 230)
line 1.
Bareword found where operator expected at (eval 653) line 1, near ""on-
Number found where operator expected at (eval 653) line 1, near "timer
512"
"512c"
String found where operator expected at (eval 653) line 1, near "c",
Bareword found where operator expected at (eval 653) line 1, near "",
512"
"512c"
02)d""
Bareword found where operator expected at (eval 1735) line 1, near
""on-for-timer 512sprintf("on"
Number found where operator expected at (eval 1735) line 1, near
"timer 512"
"512c"
String found where operator expected at (eval 1735) line 1, near "c",
Bareword found where operator expected at (eval 1735) line 1, near "",
"timer 512"
"512c"
02)d""
Argument "3.5 (Celsius)" isn't numeric in addition (+) at (eval 1736)
line 1.
Bareword found where operator expected at (eval 1737) line 1, near
Number found where operator expected at (eval 1737) line 1, near
"timer 512"
"512c"
String found where operator expected at (eval 1737) line 1, near "c",
Bareword found where operator expected at (eval 1737) line 1, near "",
"timer 512"
"512c"
02)d""
Bareword found where operator expected at (eval 1952) line 1, near
Number found where operator expected at (eval 1952) line 1, near
"timer 512"
"512c"
String found where operator expected at (eval 1952) line 1, near "c",
Bareword found where operator expected at (eval 1952) line 1, near "",
"timer 512"
"512c"
02)d""
Bareword found where operator expected at (eval 1954) line 1, near
Number found where operator expected at (eval 1954) line 1, near
"timer 512"
"512c"
String found where operator expected at (eval 1954) line 1, near "c",
Bareword found where operator expected at (eval 1954) line 1, near "",
"timer 512"
"512c"
02)d""
Bareword found where operator expected at (eval 1955) line 1, near
Number found where operator expected at (eval 1955) line 1, near
"timer 512"
"512c"
String found where operator expected at (eval 1955) line 1, near "c",
Bareword found where operator expected at (eval 1955) line 1, near "",
"timer 512"
"512c"
02)d""
Argument "3.6 (Celsius)" isn't numeric in addition (+) at (eval 1956)
line 1.
Bareword found where operator expected at (eval 1959) line 1, near
Number found where operator expected at (eval 1959) line 1, near
"timer 512"
"512c"
String found where operator expected at (eval 1959) line 1, near "c",
Bareword found where operator expected at (eval 1959) line 1, near "",
"timer 512"
"512c"
Was läuft falsch ?!
Grüße Jörg
Beitrag von: rudolfkoenig am 05 März 2012, 07:46:06
fuehrt also zu
Finde ich total korrekt, und hat mit dem update  nichts zu tun.  Bitte keine
irreleitende Meldungen in dem Subject.
Titel: Re: Fehler in fhem nach update am 04.03.2012
Beitrag von: Guest am 05 März 2012, 16:52:25
Hallo Rudolf,
nun präzieser:
vor update:
  my $hm = sprintf("%%02d:%%02d", $hour, $min);;\
update gemacht und etwas in fhem.cfg über WebFrontend geändert und
wunderbarerweise:
$min);;\
ich denke damit scheint es, dass das subject gerechtfertigt ist.
Herzliche Grüße Jörg
> fuehrt also zu
Beitrag von: m.zielinski am 05 März 2012, 18:20:39
Ich habe auch seit dem Update vom 4.3.2012 um 8:50 Fehler die vorher
nicht da waren:
2012.03.04 21:32:59 3: n_Fenster return value: Bareword "FHTTK_status"
not allowed while "strict subs" in use at (eval 35) line 1.
Der zugehörige Code ist seit über einer Woche nicht geändert:
define n_Fenster notify .*:Window.*(Open|Closed) { \
  my $window_state=ReadingsVal("@", "Window", "nA");;\
  my $deftype=$defs{@}{TYPE};;\
  return if ( $deftype ne "CUL_FHTTK" );;\
  if ( $defs{@}{PREVSTATE} ne $window_state ) { \
    my $fhttk_anzahl=FHTTK_status;;\
    if($fhttk_anzahl > 0) {\
      fhem("set w_fenster off")\
    } else {\
      fhem("set w_aus off")\
    Log 3, "@: Window ".$window_state;;\
    Log 3, "@: Fenster offen:".$fhttk_anzahl;;\
Beitrag von: rudolfkoenig am 05 März 2012, 18:27:10
Klar:
Jetzt stellt sich die Frage ob die Aenderung durch fhem oder etwas anderes
zustande kam. Wenn das fhem war, dann brauche ich zum fixen eine
nachvollziehbare Anleitung.
Beitrag von: rudolfkoenig am 05 März 2012, 18:51:16
Stimmt, war es auch.  Durch diesen Fehler werden beim editieren von Dateien mit
fhem Konstrukte wie %xy (x und y hex Ziffer) durch "sprintf("%c", xy)" ersetzt.
Habs gefixed und eingecheckt.
Beitrag von: m.zielinski am 05 März 2012, 19:18:29
On Mar 5, 6:27 pm, Rudolf Koenig wrote:
> Klar:
Sorry - gesehen hatte ich die Zeile auch - hab aus versehen die
99_fenster.pm gelöscht in der die Funktion war.
Also von meiner Seite ist das Problem nicht vorhanden.
Danke für deine Hilfe.
Beitrag von: Guest am 05 März 2012, 19:29:09
Hallo Rudolf,
danke für die schnelle Korrektur.
