Hallo
Ich versuche auf einer Debian 8 VM FHEM mit DbLog ans Laufen zu bekommen. Leider ohne Erfolg.
db.conf
%dbconfig= (
connection => "mysql:database=fhem;host=127.0.0.1;port=3306",
user => "fhemuser",
password => "xxxxx",
# optional enable(1) / disable(0) UTF-8 support (at least V 4.042 is necessary)
utf8 => 1,
fhem.cfg
define myDbLog DbLog /opt/fhem/db.conf .*:.*
my.cnf
# MariaDB database server configuration file.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
[mysqld_safe]
nice = 0
[mysqld]
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
lc_messages_dir = /usr/share/mysql
lc_messages = en_US
skip-external-locking
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address = 127.0.0.1
mysql -u fhemuser -p
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 22
Server version: 10.1.25-MariaDB-1~jessie mariadb.org binary distribution
Copyright (c) 2000, 2017, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> show databases;
| Database |
| fhem |
| information_schema |
2 rows in set (0.00 sec)
Die Datenbank läuft! Aber FHEM stürzt ab. >:(
fhem.log
2017.07.19 11:00:29 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at ./FHEM/93_DbLog.pm line 2085.
2017.07.19 11:00:29 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at ./FHEM/93_DbLog.pm line 2087.
2017.07.19 11:00:29 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at ./FHEM/93_DbLog.pm line 2089.
2017.07.19 11:00:29 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at ./FHEM/93_DbLog.pm line 2091.
2017.07.19 11:00:29 3: Unknown dbmodel type in configuration file /opt/fhem/db.conf.
2017.07.19 11:00:29 3: Only Mysql, Postgresql, Oracle, SQLite are fully supported.
2017.07.19 11:00:29 3: It may cause SQL-Erros during generating plots.
2017.07.19 11:00:29 1: PERL WARNING: Use of uninitialized value $dbconn in concatenation (.) or string at ./FHEM/93_DbLog.pm line 2116.
2017.07.19 11:00:29 1: PERL WARNING: Use of uninitialized value $dbuser in concatenation (.) or string at ./FHEM/93_DbLog.pm line 2116.
2017.07.19 11:00:29 3: DbLog myDbLog: Creating Push-Handle to database with user
2017.07.19 11:00:29 1: PERL WARNING: Use of uninitialized value $dbconn in concatenation (.) or string at ./FHEM/93_DbLog.pm line 2117.
Can't connect to data source 'dbi:' because I can't work out what driver to use (it doesn't seem to contain a 'dbi:driver:' prefix and the DBI_DRIVER env var is not $
Dann habe ich eine Environment Variable gesetzt.
DBI_DRIVER="mysql"; export DBI_DRIVER
fhem.log
2017.07.19 13:36:03 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/93_DbLog.pm line 413.
2017.07.19 13:36:06 3: DbLog myDbLog: Creating Push-Handle to database with user
2017.07.19 13:36:06 1: PERL WARNING: Use of uninitialized value $dbconn in concatenation (.) or string at ./FHEM/93_DbLog.pm line 2154.
2017.07.19 13:36:11 3: DbLog myDbLog: Creating Push-Handle to database with user
2017.07.19 13:36:16 3: DbLog myDbLog: Creating Push-Handle to database with user
Can't connect to database :(
Was kann das sein? Sollte ich es lieber mit SQLite machen? Oder wäre das spürbar langsamer?
Olaf
Hallo Olaf,
Vorab, DbLog läuft einwandfrei mit MariaDB. Siehe meine Signatur.
Jetzt ist es gerade schlecht, aber heute Abend können wir mal die Konfiguration vergleichen.
Heiko
utf8 => 1,
Mach Mal bitte das Komma hinten weg. Denke zwar nicht wirklich das es das ist aber wer weiß.
Zweite Frage. Die perlibs für MySQL hast du installiert?
libdbd-mysql-perl
Das Komma war es schon mal nicht. Wäre ja zu einfach.
Das Log schreibt unverändert:
2017.07.19 16:18:26 3: DbLog myDbLog: Creating Push-Handle to database with user
libdbd-mysql-perl ist schon die neueste Version, sagt "apt-get install libdbd-mysql-perl"
Kommt mir so vor als könnte die DB.conf nicht gelesen werden. Lage und vor allem Rechte OK ?
Edit: schreib im Def nur ./db.conf
Die def Änderung hat es auch nicht gebracht.
ls /opt/fhem -la
insgesamt 464
drwxr-xr-x 10 fhem dialout 4096 Jul 19 10:49 .
drwxr-xr-x 3 root root 4096 Jul 3 16:55 ..
-rw-r--r-- 1 fhem dialout 204377 Jul 19 09:44 CHANGED
-rw-r--r-- 1 fhem dialout 36715 Jul 19 09:44 configDB.pm
drwxr-xr-x 42 fhem dialout 12288 Jul 3 16:56 contrib
-rw-r--r-- 1 fhem dialout 245 Jul 19 16:17 db.conf
drwxr-xr-x 3 fhem dialout 4096 Jul 3 16:56 demolog
drwxr-xr-x 4 fhem dialout 4096 Jul 3 16:56 docs
drwxr-xr-x 5 fhem dialout 24576 Jul 14 08:42 FHEM
-rw-r--r-- 1 fhem dialout 1303 Jul 19 12:52 fhem.cfg
-rw-r--r-- 1 fhem dialout 15703 Jul 3 07:56 fhem.cfg.demo
-rwxr-xr-x 1 fhem dialout 134636 Jul 10 20:01 fhem.pl
drwxr-xr-x 2 fhem dialout 4096 Jul 10 20:01 log
-rw-r--r-- 1 fhem dialout 935 Jul 3 07:56 README_DEMO.txt
drwxr-xr-x 5 fhem dialout 4096 Jul 19 09:44 restoreDir
drwxr-xr-x 2 fhem dialout 4096 Jul 10 20:01 unused
drwxr-xr-x 8 fhem dialout 4096 Jul 3 16:56 www
- mit welchem Editor hast Du die db.conf erstellt?
- hast Du am Ende der db.conf einen (notwendigen) Zeilenbruch eingefügt?
Habe eine V2.21.2 angehängt. Die Version bringt beim Start etwas mehr Infos wenn es beim Lesen der db.conf Probleme gibt.
Vielleicht hilfts etwas weiter.
Heiko
Das Problem dürfte ja hauptsächlich nach diesen beiden Hinweise zu suchen sein:
Sehe ich auch so. Ich versuche Fehler auszugeben wenn die Keys Connection, User, Password nicht geladen werden können. Mal schauen ob es hilft.
Mit der V2.21.2 bekomme ich
DbLog myDbLog - Error while reading ./db.conf: 'could not read connection'
Ich hatte noch DbLog verbose 5 gesetzt, macht aber keinen Unterschied
Das bedeutet das File als solches kann geöffnet werden, aber bereits der erste Eintrag wird nicht erkannt.
Wie betateilchen schon vermutete bin ich auch der Meinung dass es im File eventuell Steuerzeichen gibt die man nicht sieht. Erstelle dir mal ein neues File am Besten mit vi ohne Copy and Paste.
Es war tatsächlich ein unsichtbarer Copy&Paste Fehler. Einfach alles per Hand eingetippt und es läuft. Jetzt kann es weiter gehen :-)
Vielen Dank euch allen!
Prima :). Die Version übernehme ich ins SVN, scheint hilfreich zu sein.
Heiko
ich hänge mich mal hier dran.
Bekomme dblog auch nicht mehr zum laufen (nach umzug auf Pi3).
libdbd-mysql-perl ist installiert. Lokaler Login als fhemuser klappt.
fhemlog sagt
2017.09.07 16:08:20 4: DbLog logdb -> check Device: logdb , Event: state: Can't connect to database.
2017.09.07 16:08:20 4: DbLog logdb -> added event - Timestamp: 2017-09-07 16:08:20, Device: logdb, Type: DBLOG, Event: state: Can't connect to database., Reading: state, Value: Can't connect to database., Unit:
2017.09.07 16:08:20 5: DbLog logdb -> DbLog_Push Returncode: Can't connect to database
List vom dblog
COLUMNS field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
CONFIGURATION ./db.conf
DEF ./db.conf .*:.*
MODE synchronous
MODEL MYSQL
NAME logdb
NR 525
NTFY_ORDER 50-logdb
PID 1394
REGEXP .*:.*
STATE Can't connect to database.
TYPE DbLog
UTF8 1
VERSION 2.22.5
dbconn mysql:database=fhem;host=localhost;port=3306
dbuser fhemuser
HELPER:
COLSET 1
DEVICECOL 64
EVENTCOL 512
READINGCOL 64
TYPECOL 64
UNITCOL 32
VALUECOL 128
Helper:
DBLOG:
state:
logdb:
TIME 1504800578.04837
VALUE disconnected
2017-09-07 15:13:03 countCurrent
2017-09-07 15:13:03 countHistory
2017-09-07 15:13:03 reduceLogState
2017-09-07 16:09:38 state Can't connect to database.
cache:
index 0
verbose 5
db.conf mit Zeilenumbruch am Ende
## for MySQL
%dbconfig= (
connection => "mysql:database=fhem;host=localhost;port=3306",
user => "fhemuser",
password => "ABC",
utf8 => 1
Hallo darkness,
was steht denn im Log beim Start von FHEM ?
Bitte kopiere mal die Zeilen raus die "DbLog" enthalten.
Darf der verwendete Nutzer sich denn von dem speziellen oder jedem Host aus anmelden ? (String "%" im Feld Hostname des Benutzerkontos in der DB)
Hallo DS_Starter,
fhemuser darf sich nur mir localhost anmelden.
hilft dir das weiter?
2017.09.08 19:11:02 3: DbLog logdb: Creating Push-Handle to database mysql:database=fhem;host=localhost;port=3306 with user fhemuser
2017.09.08 19:11:02 4: DbLog $name: Trying to connect to database
2017.09.08 19:11:02 4: DbLog logdb -> ################################################################
2017.09.08 19:11:02 4: DbLog logdb -> ### start of new Logcycle ###
2017.09.08 19:11:02 4: DbLog logdb -> amount of events received: 1 for device: logdb
2017.09.08 19:11:02 4: DbLog logdb -> check Device: logdb , Event: state: disconnected
2017.09.08 19:11:02 4: DbLog logdb -> added event - Timestamp: 2017-09-08 19:11:02, Device: logdb, Type: DBLOG, Event: state: disconnected, Reading: state, Value: disconnected, Unit:
2017.09.08 19:11:02 4: Waiting for database connection
2017.09.08 19:11:02 4: DbLog logdb -> amount of events received: 1 for device: stat_utg
2017.09.08 19:11:02 4: DbLog logdb -> check Device: stat_utg , Event: state: Updated stats for: kueche.utg
2017.09.08 19:11:02 4: DbLog logdb -> added event - Timestamp: 2017-09-08 19:11:02, Device: stat_utg, Type: STATISTICS, Event: state: Updated stats for: kueche.utg, Reading: state, Value: Updated stats for, Unit: kueche.utg
2017.09.08 19:11:02 4: DbLog logdb -> check Device: logdb , Event: state: Can't connect to database.
2017.09.08 19:11:02 4: DbLog logdb -> added event - Timestamp: 2017-09-08 19:11:02, Device: logdb, Type: DBLOG, Event: state: Can't connect to database., Reading: state, Value: Can't connect to database., Unit:
Zitatfhemuser darf sich nur mir localhost anmelden.
Jetzt habe ich natürlich ganz vergessen zu fragen wo die DB läuft. Also mit auf dem RPi oder läuft die DB und FHEM getrennt.
Wenn es getrennt läuft, müsste der fhemuser die Berechtigung bekommen sich von dem FHEM-Host aus anzumelden (im einfachsten Fall "%").
Den Zugriff kannst du vom RPi aus testen mit
mysql -u fhemuser -p -h <IP des DB-Host>Schau auch mal ob auf dem RPi die Client-Software installiert ist:
sudo apt-get install mysql-clientGrüße
Heiko
Mariadb läuft lokal.
Login per Konsole mit Fhemuser funktioniert.
Kurze Antwort per Handy
Kann mir momentan schlecht vorstellen was hier das Problem sein könnte.
DbLog kann das Konfigfile lesen, sonst kämen schon Fehlerhinweise beim FHEM-Start. Sicherheitshalber kannst du das Konfigfile nochmal neu erstellen (ohne Cut & Paste).
Statt localhost kannst du mal die (eigene) IP-Adresse angeben und schauen wie es dann aussieht.
Ansonsten wären eventuell noch Fehlerhinweise in der MySQL Logdatei zu finden. Sie sollte hier zu finden sein:
ZitatThe error log is active by default. The log-error=filename option determines where the output will be written. If no file name is specified, the log will be written to host-name.err. If no absolute path is specified, the file will be written to the data directory (determined by the value of the datadir system variable).
Habe gerade die Datenbank und den User neu angelegt. Jetzt läuft es :o
Die db.conf hatte ich vom alten Rechner mit umgezogen, die Datenbank als Dump eingespielt.
Naja, jetzt scheint es zu laufen. Vielen Dank für die Hilfe!
Hallo Leute,
bekomme die Verbindung leider auch nicht hin.
Ich habe den MariaDB Server auf einer separaten Virtuellen Maschine.
hier der auszug aus dem LOG:
2018-02-13 15:26:26 DbLog test install_driver(mysql) failed: Can't locate DBD/mysql.pm in @INC (you may need to install the DBD::mysql module) (@INC contains: . /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/x86_64-linux-gnu/perl5/5.20 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl ./FHEM) at (eval 4556) line 3. Perhaps the DBD::mysql perl module hasn't been fully installed, or perhaps the capitalisation of 'mysql' isn't right. Available drivers: DBM, ExampleP, File, Gofer, Proxy, Sponge. at ./FHEM/93_DbLog.pm line 2277.
2018-02-13 15:26:26 DbLog test disconnected
2018-02-13 15:26:26 DbLog test Can't connect to database.
2018-02-13 15:26:31 DbLog test install_driver(mysql) failed: Can't locate DBD/mysql.pm in @INC (you may need to install the DBD::mysql module) (@INC contains: . /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/x86_64-linux-gnu/perl5/5.20 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl ./FHEM) at (eval 4558) line 3. Perhaps the DBD::mysql perl module hasn't been fully installed, or perhaps the capitalisation of 'mysql' isn't right. Available drivers: DBM, ExampleP, File, Gofer, Proxy, Sponge. at ./FHEM/93_DbLog.pm line 2277.
2018-02-13 15:26:31 DbLog test disconnected
2018-02-13 15:26:31 DbLog test Can't connect to database.
hat jemand eine IDEE?
steht doch da...
Was ist daran unverständlich? Installiere den mysql Treiber und alles ist gut.
danke für die fixe Antwort.
sqlite3 libdbd-sqlite3-perl libtext-diff-perl
^^denke mal diese Pakete aus dem Howto sind nur für sqlite oder?
weißt du wie das benötigte Paket / Treiber heißt?
Franky
schon mal in commandref von dblog reingeschaut ? (oder help dblog)
Gleich zu Beginn springt es einem ins Auge ....
Ja commandref war die Lösung,
ZitatMySQL : sudo apt-get install [mysql-server] mysql-client libdbd-mysql libdbd-mysql-perl (mysql-server only if you use a local MySQL-server installation)
leider geht es nun mit einem deutlich weniger detaillierten Fehler weiter:
2018-02-13 16:17:51 DbLog test disconnected
2018-02-13 16:17:51 DbLog test Can't connect to database.db.conf
%dbconfig= (
connection => "mysql:database=fhem;host=192.168.0.12;port=3306",
user => "fhemuser",
password => "xxx",
Nach der Konfiguration ein set ... configCheck ausführen. steht auch in der Hilfe.
Schauen ob das was aussagt. Wenn nicht verbose level hochdrehen und im Logfile nach Hinweisen suchen.
Beliebter Fehler bei MySql ist dass der User sich von einem remoten Rechner nicht anmelden darf -> mal checken.
Super, Vielen Dank das war schonmal der Grundfehler habe die Bindadresse in der my.cnf auskommentiert und es geht!
Habe inzwischen vor verzweiflung eine mysql und eine mariadb VM aufgesetzt.
wo finde ich die bind-adress bei mariadb? in der my.cnf ist sie nicht!?
Ich benutze dazu eigentlich eher die host definition % im usereditor. aber lt. doku sollte die bindaddress in der sektion mysqld in der my.cnf sein. Kann heute abend ja mal auf meinem system schauen, aber auf synology ist alles immer etwas anders ;)
Grüsse
Auf meiner Syno befindet sich der bind-address Eintrag in der besagten Sektion "mysqld":
Heiko@SDS1:~$ more /usr/local/mariadb10/etc/mysql/my.cnf
[client]
port = 3307
socket = /run/mysqld/mysqld10.sock
[mysqld]
bind-address = 0.0.0.0
port = 3307
pid-file = /run/mysqld/mysqld10.pid
key_buffer_size = 16K
Super danke für die Hilfe, läuft erstmal so wie es aussieht :)
Bei Debian Stretch sind in der my.cnf alle Einträge der Ordner:
-/mariadb.conf.d
-/conf.d
inkludiert, und die Bindadress letztendlich unter /etc/mysql/mariadb.conf.d/50-server.cnf zu finden.
Verstehe ich das richtig das die bindadresse noch vor dem user filtert von wo aus zugegriffen werden darf !?
wenn die bind-address = 192.168.0.55 ist ist er wohl nur unter der IP ansprechbar (also nicht im Inet verfügbar ohne VPN)
Der Zusammenhang ist gut hier https://mariadb.com/kb/en/library/configuring-mariadb-for-remote-client-access/ erläutert.
ZitatMariaDB is bound to the loopback interface by default because it makes it impossible to connect to the TCP port on the server from a remote host
Heiko
