Hallo an alle,
ich hoffe das ist der richtiger Bereich vom Forum dafür. Ich hab gerade dies hier im Netz gefunden: http://labalec.fr/erwan/?p=1534 (http://labalec.fr/erwan/?p=1534).
Das ist ein Anttiny85 mit einen DHT11 und einen RF433MHz Sender. Jetzt kommt der Clou. Das ganze soll mit dem Oregon V2.1 Protokoll laufen.
Meint Ihr das würde der Signalduino erkennen?
* connectingStuff, Oregon Scientific v2.1 Emitter
* http://connectingstuff.net/blog/encodage-protocoles-oregon-scientific-sur-arduino/
* Copyright (C) 2013 olivier.lebrun@gmail.com
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* as published by the Free Software Foundation; either version 2
* of the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
#include <avr/sleep.h>
#include <avr/wdt.h>
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
volatile boolean f_wdt = 1;
#include <dht11.h>
#define DHT11PIN PB1
dht11 DHT11;
#include <SoftwareSerial.h>
#define SERIAL_RX PB3 //pin 2 //INPUT
#define SERIAL_TX PB4 //pin 3 //OUTPUT
SoftwareSerial TinySerial(SERIAL_RX, SERIAL_TX); // RX, TX
//#define THN132N
const byte TX_PIN = 0;
const unsigned long TIME = 512;
const unsigned long TWOTIME = TIME*2;
#define SEND_HIGH() digitalWrite(TX_PIN, HIGH)
#define SEND_LOW() digitalWrite(TX_PIN, LOW)
// Buffer for Oregon message
#ifdef THN132N
byte OregonMessageBuffer[8];
#else
byte OregonMessageBuffer[9];
#endif
* \brief Send logical "0" over RF
* \details azero bit be represented by an off-to-on transition
* \ of the RF signal at the middle of a clock period.
* \ Remenber, the Oregon v2.1 protocol add an inverted bit first
inline void sendZero(void)
SEND_HIGH();
delayMicroseconds(TIME);
SEND_LOW();
delayMicroseconds(TWOTIME);
SEND_HIGH();
* \brief Send logical "1" over RF
* \details a one bit be represented by an on-to-off transition
inline void sendOne(void)
SEND_LOW();
SEND_HIGH();
SEND_LOW();
* Send a bits quarter (4 bits = MSB from 8 bits value) over RF
* @param data Source data to process and sent
* \brief Send a bits quarter (4 bits = MSB from 8 bits value) over RF
* \param data Data to send
inline void sendQuarterMSB(const byte data)
(bitRead(data, 4)) ? sendOne() : sendZero();
(bitRead(data, 5)) ? sendOne() : sendZero();
(bitRead(data, 6)) ? sendOne() : sendZero();
(bitRead(data, 7)) ? sendOne() : sendZero();
* \brief Send a bits quarter (4 bits = LSB from 8 bits value) over RF
inline void sendQuarterLSB(const byte data)
(bitRead(data, 0)) ? sendOne() : sendZero();
(bitRead(data, 1)) ? sendOne() : sendZero();
(bitRead(data, 2)) ? sendOne() : sendZero();
(bitRead(data, 3)) ? sendOne() : sendZero();
* \brief Send a buffer over RF
* \param size size of data to send
void sendData(byte *data, byte size)
for(byte i = 0; i < size; ++i)
sendQuarterLSB(data[i]);
sendQuarterMSB(data[i]);
* \brief Send an Oregon message
* \param data The Oregon message
void sendOregon(byte *data, byte size)
sendPreamble();
//sendSync();
sendData(data, size);
sendPostamble();
* \brief Send preamble
* \details The preamble consists of 16 "1" bits
inline void sendPreamble(void)
byte PREAMBLE[]={0xFF,0xFF};
sendData(PREAMBLE, 2);
* \brief Send postamble
* \details The postamble consists of 8 "0" bits
inline void sendPostamble(void)
#ifdef THN132N
sendQuarterLSB(0x00);
#else
byte POSTAMBLE[]={0x00};
sendData(POSTAMBLE, 1);
#endif
* \brief Send sync nibble
* \details The sync is 0xA. It is not use in this version since the sync nibble
* \ is include in the Oregon message to send.
inline void sendSync(void)
sendQuarterLSB(0xA);
* \brief Set the sensor type
* \param data Oregon message
* \param type Sensor type
inline void setType(byte *data, byte* type)
data[0] = type[0];
data[1] = type[1];
* \brief Set the sensor channel
* \param channel Sensor channel (0x10, 0x20, 0x30)
inline void setChannel(byte *data, byte channel)
data[2] = channel;
* \brief Set the sensor ID
* \param ID Sensor unique ID
inline void setId(byte *data, byte ID)
data[3] = ID;
* \brief Set the sensor battery level
* \param level Battery level (0 = low, 1 = high)
void setBatteryLevel(byte *data, byte level)
if(!level) data[4] = 0x0C;
else data[4] = 0x00;
* \brief Set the sensor temperature
* \param temp the temperature
void setTemperature(byte *data, float temp)
// Set temperature sign
if(temp < 0)
data[6] = 0x08;
temp *= -1;
else
data[6] = 0x00;
// Determine decimal and float part
int tempInt = (int)temp;
int td = (int)(tempInt / 10);
int tf = (int)round((float)((float)tempInt/10 - (float)td) * 10);
int tempFloat = (int)round((float)(temp - (float)tempInt) * 10);
// Set temperature decimal part
data[5] = (td << 4);
data[5] |= tf;
// Set temperature float part
data[4] |= (tempFloat << 4);
* \brief Set the sensor humidity
* \param hum the humidity
void setHumidity(byte* data, byte hum)
data[7] = (hum/10);
data[6] |= (hum - data[7]*10) << 4;
* \brief Sum data for checksum
* \param count number of bit to sum
int Sum(byte count, const byte* data)
int s = 0;
for(byte i = 0; i<count;i++)
s += (data[i]&0xF0) >> 4;
s += (data[i]&0xF);
if(int(count) != count)
s += (data[count]&0xF0) >> 4;
return s;
* \brief Calculate checksum
void calculateAndSetChecksum(byte* data)
#ifdef THN132N
int s = ((Sum(6, data) + (data[6]&0xF) - 0xa) & 0xff);
data[6] |= (s&0x0F) << 4; data[7] = (s&0xF0) >> 4;
#else
data[8] = ((Sum(8, data) - 0xa) & 0xFF);
#endif
void setup()
setup_watchdog(9);
//pinMode(PB3, OUTPUT);
//digitalWrite(PB3,HIGH);delay(500);
//digitalWrite(PB3,LOW);delay(500);
pinMode(TX_PIN, OUTPUT);
pinMode(PB4, OUTPUT); //tx
TinySerial.begin(9600);
TinySerial.println("\n[Oregon V2.1 encoder]");
SEND_LOW();
#ifdef THN132N
// Create the Oregon message for a temperature only sensor (TNHN132N)
byte ID[] = {0xEA,0x4C};
#else
// Create the Oregon message for a temperature/humidity sensor (THGR2228N)
byte ID[] = {0x1A,0x2D};
#endif
setType(OregonMessageBuffer, ID);
setChannel(OregonMessageBuffer, 0x20);
setId(OregonMessageBuffer, 0xEE);
// set system into the sleep state
// system wakes up when wtchdog is timed out
void system_sleep() {
cbi(ADCSRA,ADEN); // switch Analog to Digitalconverter OFF
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
sleep_enable();
sleep_mode(); // System sleeps here
sleep_disable(); // System continues execution here when watchdog timed out
sbi(ADCSRA,ADEN); // switch Analog to Digitalconverter ON
// 0=16ms, 1=32ms,2=64ms,3=128ms,4=250ms,5=500ms
// 6=1 sec,7=2 sec, 8=4 sec, 9= 8sec
void setup_watchdog(int ii) {
byte bb;
int ww;
if (ii > 9 ) ii=9;
bb=ii & 7;
if (ii > 7) bb|= (1<<5);
bb|= (1<<WDCE);
ww=bb;
MCUSR &= ~(1<<WDRF);
// start timed sequence
WDTCR |= (1<<WDCE) | (1<<WDE);
// set new watchdog timeout value
WDTCR = bb;
WDTCR |= _BV(WDIE);
// Watchdog Interrupt Service / is executed when watchdog timed out
ISR(WDT_vect) {
f_wdt=1; // set global flag
void loop()
int chk = DHT11.read(DHT11PIN);
switch (chk)
case DHTLIB_OK:
TinySerial.println("OK");
break;
case DHTLIB_ERROR_CHECKSUM:
TinySerial.println("Checksum error");
break;
case DHTLIB_ERROR_TIMEOUT:
TinySerial.println("Time out error");
break;
default:
TinySerial.println("Unknown error");
break;
TinySerial.print("Temperature : ");TinySerial.print(DHT11.temperature);TinySerial.write(176); // caractère °
TinySerial.write('C'); TinySerial.println();
TinySerial.print("Humidity : ");TinySerial.print(DHT11.humidity);
TinySerial.write('%'); TinySerial.println();
// (ie: 1wire DS18B20 for température, ...)
setBatteryLevel(OregonMessageBuffer, 0); // 0 : low, 1 : high
setTemperature(OregonMessageBuffer, DHT11.temperature);
#ifndef THN132N
// Set Humidity
setHumidity(OregonMessageBuffer, DHT11.humidity);
#endif
// Calculate the checksum
calculateAndSetChecksum(OregonMessageBuffer);
// Show the Oregon Message
for (byte i = 0; i < sizeof(OregonMessageBuffer); ++i) {
//TinySerial.print(OregonMessageBuffer[i] >> 4, HEX);
//TinySerial.print(OregonMessageBuffer[i] & 0x0F, HEX);
// Send the Message over RF
sendOregon(OregonMessageBuffer, sizeof(OregonMessageBuffer));
// Send a "pause"
SEND_LOW();
delayMicroseconds(TWOTIME*8);
// Send a copie of the first message. The v2.1 protocol send the
// message two time
// Wait for 30 seconds before send a new message
SEND_LOW();
//9 secs * 6 = 54 secs
system_sleep();
system_sleep();
system_sleep();
system_sleep();
system_sleep();
system_sleep();
//delay(30000);
Ich weiß nur noch nicht wo ich in dem Sketch eine ID einstellen kann oder so damit man die Sender unterscheiden kann. Ich würde das auch gerne gegen einen DHT22 tauschen. Da müßte der Sketch doch nur umgeschrieben werden bzw. die andere Libary geladen werden oder irre ich mich da jetzt. Bin auf den Gebiet Arduino leider noch etwas unbeleckt.
Danke für eure Meinung bzw. Tipps.
Jörg
Hier kannst du die ID setzen:
data[3] = ID;
}wird im "Setup" aufgerufen:
setId(OregonMessageBuffer, 0xEE);Und laut dem hier:
Zitathttps://forum.fhem.de/index.php?topic=60170.0
werden Oregon Sensoren mit V2 und V3 vom Signalduino unterstützt.
Und hier findest du eine Bibliothek für den DHT22:
Zitathttp://forum.arduino.cc/index.php?topic=174340.0
Ja supi,
Mach mal fertig und poste hier Deinen DHT22 Code und die Pinbelegung. Wer hat gute Ideen für Gehäuse?
Was sind die Kosten inkl. aller Teile aus Eurer Erfahrung?
Gruß Arnd
das der Signalduino das auf dem Papier kann hatte ich damals schon gesehen darum fand ich das was ich gefunden habe ja so Genial. Frage ist nur ob er es dann auch erkennt :).
Ich hab gerade versucht den DHT22 einzubinden aber schaff es nicht. Kommt immer ein Fehler beim kompilieren aber wie gesagt ist das absolutes Neuland für mich. Kann da aber erst nach meinen Urlaub weiter machen.
Zu den Kosten kann ich nichts sagen aber denke wird nicht viel sein.
hab gerade das im FHEM Forum gefunden: https://forum.fhem.de/index.php?topic=52755.15 (https://forum.fhem.de/index.php?topic=52755.15)
Seite 2 Antwort 19 und 21
Eigentlich das gleiche aber schon mit DHT22 aber mit LaCrosse was der Signalduino ja auch kann.
