FHEM => Anfängerfragen => Thema gestartet von: Badflex am 19 August 2017, 15:06:35
Titel: Seit update kein zugriff auf weboberfläche
Beitrag von: Badflex am 19 August 2017, 15:06:35
Im log finde ich das.
Stimmt da was nicht mit der 01_fhemweb.pm oder Pearl?
2017.08.19 09:21:05 1: update finished, "shutdown restart" is needed to activate the changes.
2017.08.19 09:21:05 1: Please consider using the global attribute sendStatistics
2017.08.19 09:21:45 0: Server shutdown
2017.08.19 09:21:46 1: Timeout for MPD_IdleStart reached, terminated process 1086
2017.08.19 09:21:48 1: Including fhem.cfg
2017.08.19 09:21:48 1: reload: Error:Modul 01_FHEMWEB deactivated:
Too many arguments for main::TcpServer_Close at ./FHEM/01_FHEMWEB.pm line 583, near "1)"
Too many arguments for main::TcpServer_Close at ./FHEM/01_FHEMWEB.pm line 708, near "1)"
BEGIN not safe after errors--compilation aborted at ./FHEM/01_FHEMWEB.pm line 886, <$fh> line 35.
2017.08.19 09:21:48 0: Too many arguments for main::TcpServer_Close at ./FHEM/01_FHEMWEB.pm line 583, near "1)"
2017.08.19 09:21:48 1: PERL WARNING: Subroutine FHEMWEB_Initialize redefined at ./FHEM/01_FHEMWEB.pm line 125, <$fh> line 48.
2017.08.19 09:21:48 1: PERL WARNING: Subroutine FW_SecurityCheck redefined at ./FHEM/01_FHEMWEB.pm line 231, <$fh> line 48.
2017.08.19 09:21:48 1: PERL WARNING: Subroutine FW_Define redefined at ./FHEM/01_FHEMWEB.pm line 262, <$fh> line 48.
2017.08.19 09:21:48 1: PERL WARNING: Subroutine FW_Undef redefined at ./FHEM/01_FHEMWEB.pm line 297, <$fh> line 48.
BEGIN not safe after errors--compilation aborted at ./FHEM/01_FHEMWEB.pm line 886, <$fh> line 48.
2017.08.19 09:21:49 1: PERL WARNING: Subroutine FHEMWEB_Initialize redefined at ./FHEM/01_FHEMWEB.pm line 125, <$fh> line 59.
2017.08.19 09:21:49 1: PERL WARNING: Subroutine FW_SecurityCheck redefined at ./FHEM/01_FHEMWEB.pm line 231, <$fh> line 59.
2017.08.19 09:21:49 1: PERL WARNING: Subroutine FW_Define redefined at ./FHEM/01_FHEMWEB.pm line 262, <$fh> line 59.
2017.08.19 09:21:49 1: PERL WARNING: Subroutine FW_Undef redefined at ./FHEM/01_FHEMWEB.pm line 297, <$fh> line 59.
2017.08.19 09:21:49 1: reload: Error:Modul 01_FHEMWEB deactivated:
BEGIN not safe after errors--compilation aborted at ./FHEM/01_FHEMWEB.pm line 886, <$fh> line 59.
2017.08.19 09:21:49 0: Too many arguments for main::TcpServer_Close at ./FHEM/01_FHEMWEB.pm line 583, near "1)"
2017.08.19 09:21:54 1: PERL WARNING: Prototype mismatch: sub main::deg2rad ($;$) vs none at /usr/share/perl/5.20/Exporter.pm line 66, <DATA> line 129.
2017.08.19 09:21:54 1: PERL WARNING: "my" variable $host masks earlier declaration in same scope at ./FHEM/30_MilightBridge.pm line 72, <$fh> line 1204.
2017.08.19 09:21:55 1: PERL WARNING: Use of uninitialized value $port in lc at ./FHEM/42_SYSMON.pm line 192, <$fh> line 1322.
2017.08.19 09:21:57 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4096, <$fh> line 1534.
2017.08.19 09:21:57 1: PERL WARNING: Use of uninitialized value $FW_wname in concatenation (.) or string at ./FHEM/55_GDS.pm line 662, <$fh> line 1534.
2017.08.19 09:21:58 1: Including ./log/fhem.save
2017.08.19 09:21:59 1: configfile: Cannot load module FHEMWEB
2017.08.19 09:22:02 1: usb create starting
2017.08.19 09:22:03 1: define CUL_1 CUL /dev/ttyACM1@9600 1134
2017.08.19 09:22:09 1: usb create end
Use of uninitialized value in concatenation (.) or string at ./FHEM/38_netatmo.pm line 1625.
Titel: Antw:Seit update kein zugriff auf weboberfläche
Beitrag von: CoolTux am 19 August 2017, 16:13:06
Dein Update ist nicht sauber durchgelaufen. Es gab einen Abbruch. Du musst nun sehen das du irgendwie ein. Sau erwähnt Update hinbekommst.
/usr/bin/perl fhem.pl 7072 "update"
Könnte helfen.
Beitrag von: Badflex am 19 August 2017, 17:47:56
Hab nochmal ein update gemacht, aber leider ohne erfolg.
Im log steht jetzt:
BlockingInformParent (BlockingStart): Can't connect to localhost:40905: IO::Socket::INET: connect: Verbindungsaufbau abgelehnt
2017.08.19 17:42:37 1: BlockingInformParent (FRITZBOX_Readout_Done): Can't connect to localhost:40905: IO::Socket::INET: connect: Verbindungsaufbau abgelehnt
2017.08.19 17:42:39 1: Including fhem.cfg
woran kann das liegen?
Beitrag von: amenomade am 19 August 2017, 19:02:53
Die Log vom Update wäre hilfreich.
Beitrag von: Badflex am 20 August 2017, 07:11:06
Hat sich erledigt, ich habe die vorherige cfg eingespielt. Jetzt geht's wieder.
