FHEM - Hausautomations-Systeme => 1Wire => Thema gestartet von: Marlen am 28 August 2017, 07:41:52
Titel: Viele Log Einträge mit 1-wire-zu-WLAN-Bridge
Beitrag von: Marlen am 28 August 2017, 07:41:52
ich habe die 1-wire-zu-WLAN-Bridge vom Hexenmeister.
Die Bridge hab ich mit dem ESPEasy-FHEM-Modul eingebunden.
Jetzt hab ich aber jede Menge Fehler im Log:
2017.08.28 07:38:42 5: ESPEasy Fuehler_Ez: Received: 1_Wire_Bridge_Wohnzimmer_2::192.168.178.52::1::1::1::i||unit||0||0|||i||sleep||0||0|||i||build||20000||0|||i||build_git||||0|||i||build_notes|| - Mega||0|||i||version||2||0|||i||node_type_id||17||0|||r||Temperature||20.5||1
2017.08.28 07:38:42 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220.
2017.08.28 07:38:42 1: stacktrace:
2017.08.28 07:38:42 1:     main::__ANON__                      called by ./FHEM/34_ESPEasy.pm (1220)
2017.08.28 07:38:42 1:     main::ESPEasy_dispatchParse         called by fhem.pl (3629)
2017.08.28 07:38:42 1:     main::Dispatch                      called by ./FHEM/34_ESPEasy.pm (1159)
2017.08.28 07:38:42 1:     main::ESPEasy_dispatch              called by ./FHEM/34_ESPEasy.pm (794)
2017.08.28 07:38:42 1:     main::ESPEasy_Read                  called by fhem.pl (3433)
2017.08.28 07:38:42 1:     main::CallFn                        called by fhem.pl (689)
2017.08.28 07:38:42 2: ESPEasy Fuehler_Ez: Unknown command received via dispatch
2017.08.28 07:38:42 4: ESPEasy Fuehler_Ez: Temperature: 20.5
2017.08.28 07:38:42 5: ESPEasy Fuehler_Ez: Internals: unit:0 sleep:0 build:20000 build_git:not defined build_notes: - Mega version:2 node_type_id:17: ESP Easy Mega
Mein Device ist so definiert:
   CFGFN
   DEF        192.168.178.52 80 espBridge 1_Wire_Bridge_Wohnzimmer_2
   ESP_BUILD  20000
   ESP_BUILD_GIT not defined
   ESP_BUILD_NOTES  - Mega
   ESP_NODE_TYPE_ID 17: ESP Easy Mega
   ESP_SLEEP  0
   ESP_UNIT   0
   ESP_VERSION 2
   HOST       192.168.178.52
   IDENT      1_Wire_Bridge_Wohnzimmer_2
   INTERVAL   300
   IODev      espBridge
   LASTInputDev espBridge
   MSGCNT     5128
   NAME       Fuehler_Ez
   NOTIFYDEV  global
   NR         63210
   NTFY_ORDER 50-ESPEasy_1_Wire_Bridge_Wohnzimmer_2
   PORT       80
   STATE      20.5
   SUBTYPE    device
   TYPE       ESPEasy
   VERSION    1.32
   espBridge_MSGCNT 5128
   espBridge_TIME 2017-08-28 07:40:42
     2017-08-28 07:40:42   Temperature     20.5
     2017-08-28 07:40:37   presence        present
     2017-08-28 07:40:42   state           Tem: 20.5
   helper:
     fpc        1503601619
     pm:
       Encode     1
       JSON       1
     received:
       Temperature 1503898842
   IODev      espBridge
   Interval   300
   group      Wohnzimmer
   presenceCheck 1
   readingSwitchText 1
   room       Heizung
   setState   3
   stateFormat Temperature
   verbose    5
Kann mir hier jemand helfen?
  Marlen
Titel: Antw:Viele Log Einträge mit 1-wire-zu-WLAN-Bridge
Beitrag von: Bartimaus am 28 August 2017, 11:52:01
wie hast Du den Fühler im Modul eingebunden ?
Beitrag von: Marlen am 28 August 2017, 19:39:15
So:
Beitrag von: Bartimaus am 28 August 2017, 19:44:17
Soweit ok.
Ich meine es gibt hier zu dem Interface einen Thread, wo andere auch das Problem mit den Logs hatten.
Ich habe es so "gelöst", das ich Verbose auf 1 gesetzt habe.....   ::) 8)
Beitrag von: Marlen am 28 August 2017, 20:46:09
Hmmm ja.....wenn es nicht anders geht.
Allerdings hab ich dann immernoch diese Einträge:
2017.08.28 20:29:44 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7732866.
2017.08.28 20:31:44 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7733758.
2017.08.28 20:32:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7734300.
2017.08.28 20:33:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7734794.
2017.08.28 20:35:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7735604.
2017.08.28 20:36:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7736111.
2017.08.28 20:37:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7736639.
2017.08.28 20:39:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7737405.
2017.08.28 20:40:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN27> line 1088625.
2017.08.28 20:42:46 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7738875.
2017.08.28 20:43:46 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7739198.
2017.08.28 20:44:46 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7739713.
  Marlen
Beitrag von: DerBodo am 01 September 2017, 12:56:57
Probier bei FORMULA mal %TEMP%
Beitrag von: Bartimaus am 01 September 2017, 22:33:23
Oder %value%
Beitrag von: Frank_Huber am 01 September 2017, 22:37:22
Oder verbose 0
Gesendet von meinem S3_32 mit Tapatalk
Beitrag von: Marlen am 01 September 2017, 22:47:09
Mit %TEMP% geht es fehlerfrei!  :)
Danke!
