Mit diesen beiden neuen Widgets kann man sich ein iOS ähnliches Controlcenter bauen.
Controller: ein vertikales Slider Widget optimal für Touchbedienung
- kann durch class="fullsize" die volle Breite/Höhe seines Containers ausfüllen (z.B.ein ganzes Gridster-Feld)
- Icon zur Visualisierung der Bedeutung (Lautstärke, Licht ...)
Controlbutton: ähnlich dem Switch Widget, nur minimaler
<!DOCTYPE html>
<html>
<head>
/* FHEM tablet ui */
* UI builder framework for FHEM
* Version: 2.6.*
* URL: https://github.com/knowthelist/fhem-tablet-ui
* Copyright (c) 2015-2017 Mario Stephan <mstephan@shared-files.de>
* Under MIT License (http://www.opensource.org/licenses/mit-license.php)
<link rel="icon" href="favicon.ico" type="image/x-icon" />
<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no" />
<meta name="mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="gridster_base_width" content="70">
<meta name="gridster_base_height" content="70">
<meta name="gridster_margin" content="5">
<script src="js/fhem-tablet-ui.js" defer></script>
<title>FTUI-Control</title>
</head>
<body style="background-image:url(bgimage-tablet.jpg)">
<div class="gridster bg-transparent">
<ul>
<!-- ROW 1-2 Left -->
<li data-row="1" data-col="1" data-sizey="2" data-sizex="2" class="bg-gray-trans round">
<div class="row-5"></div>
<div class="row-45">
<div class="col-5"></div>
<div class="col-45 center" data-type="switch" data-device="dummy1" data-color="white" data-size="130" data-on-background-color="blue" data-icon="fa-wifi"></div>
<div class="col-45 center" data-type="switch" data-device="dummy2" data-color="white" data-size="130" data-on-background-color="green" data-icon="fa-lock"></div>
</div>
<div class="col-45 center" data-type="switch" data-device="dummy1" data-color="white" data-size="130" data-on-background-color="blue" data-icon="fa-bluetooth-b"></div>
<div class="col-45 center" data-type="switch" data-device="dummy3" data-color="white" data-size="130" data-on-background-color="blue" data-icon="fa-podcast"></div>
</div>
</li>
<!-- ROW 1-2 Right -->
<li data-row="1" data-col="3" data-sizey="2" data-sizex="2" class="bg-gray-trans round">
<div class="row-10"></div>
<div class="row-20">
<div class="bold center " data-type="label" data-device="MPD1" data-get="Artist"></div>
</div>
<div class="center" data-type="label" data-device="MPD1" data-get="Title"></div>
</div>
<div class="row-50">
<div class="col center" data-type="push" data-device="MPD1" data-icon="fa-step-backward" data-background-icon="-" data-set-on="previous" data-off-color="#000" data-on-color="white">
</div>
<div class="col center" data-type="switch" data-device="MPD1" data-states='["play","pause","stop"]' data-set-states='["pause","play","play"]' data-background-icon="none" data-colors='["#000","#ddd","#ddd"]' data-icons='["fa-pause","fa-play","fa-play"]'>
</div>
<div class="col center" data-type="push" data-device="MPD1" data-icon="fa-step-forward" data-background-icon="-" data-set-on="next" data-off-color="#000" data-on-color="white">
</div>
</div>
</li>
<!-- ROW 3-->
<li data-row="3" data-col="3" data-sizey="2" data-sizex="1" class="bg-gray-trans round">
<div class="row-100">
<div class="fullsize" data-type="controller" data-device="EsstischLampe" data-background-color="transparent" data-get="state" data-set="value"></div>
</div>
</li>
<li data-row="3" data-col="4" data-sizey="2" data-sizex="1" class="bg-gray-trans round">
<div class="fullsize" data-type="controller" data-device="AvReceiver" data-get="volume" data-background-color="transparent" data-set="volume" data-icon="fa-volume-up" data-max="60"></div>
</div>
</li>
<li data-row="3" data-col="1" data-sizey="1" data-sizex="1" class="bg-gray-trans round">
<div class="fullsize" data-type="controlbutton" data-device="SchrankLicht_Sw" data-icon="fa-book"></div>
</li>
<li data-row="3" data-col="2" data-sizey="1" data-sizex="1" class="bg-gray-trans round">
<div class="fullsize" data-type="controlbutton" data-device="KuechenArbeitsLicht" data-icon="fa-beer"></div>
</li>
<li data-row="4" data-col="1" data-sizey="1" data-sizex="2" class="bg-gray-trans round">
<div class="row">
<div class="col-30 center fa fa-2x fa-sign-in"></div>
<div class="col-70 center" data-type="label" data-device="AvReceiver" data-get="input"></div>
</div>
</li>
<!-- ROW 5 -->
<li data-row="5" data-col="1" data-sizey="1" data-sizex="1" class="bg-gray-trans round">
<div class="fullsize" data-type="controlbutton" data-device="BadWandlicht" data-icon="fa-shower"></div>
</li>
<li data-row="5" data-col="2" data-sizey="1" data-sizex="1" class="bg-gray-trans round">
<div class="fullsize" data-type="controlbutton" data-device="SchlafzimmerLicht" data-icon="fa-bed"></div>
</li>
<li data-row="5" data-col="3" data-sizey="1" data-sizex="1" class="bg-gray-trans round">
<div class="fullsize" data-type="controlbutton" data-device="WohnenDeckenLicht" data-icon="fa-tv"></div>
</li>
<li data-row="5" data-col="4" data-sizey="1" data-sizex="1" class="bg-gray-trans round">
<div class="fullsize" data-type="controlbutton" data-device="GartenLicht" data-icon="fa-envira"></div>
</li>
</ul>
</div>
</body>
</html>
Hi setstate,
sehr coole Widgets. Aber kann es sein, dass die Beschreibung vom Controlbutton im Github nicht stimmt? Ich habe es nicht ausprobiert, aber Vorher- und Hintergrundfarbe sind doch sicher nicht gleich, oder?
data-on-background-color : color for ON state or DEVICE:READING for dynamic setting (default '#aa6900')
data-off-background-color : color for OFF state or DEVICE:READING for dynamic setting (default '#505050')
data-on-color : color for ON state or DEVICE:READING for dynamic setting (default '#aa6900')
data-off-color : color for Off state or DEVICE:READING for dynamic setting (default '#505050')
Wiki-Links:
https://wiki.fhem.de/wiki/FTUI_Widget_Controlbutton
https://wiki.fhem.de/wiki/FTUI_Widget_Controller
Moin Setzstatus,
cooles Teil der Controlbutton. Definiert habe ich ihn so:
<div data-type="controlbutton"
data-device="Licht_hinten"
data-icon="fa-lightbulb-o"
data-off-background-color="light-gray"
data-off-color="gray"
class="top-space big">
</div>
Nach einem erstmaligen Laden der Seite wie erwartet wenn Device aus, Hintergrund grau, Symbol hellgrau.
Einschalten : Hintergrund grün, Symbol weiss
Ausschalten: Symbol grau, Hintergrund bleibt grün. <-- nicht ganz wie erwartet.
Kannst Du bitte mal schauen? Das Widget-JS sieht in der Funktion "drawElement" ein wenig merkwürdig aus....
Danke und Grüße
Marie
Ok,
light-gray wird lightgray geschrieben..wie immer der Fehler hinter der Tastatur...sieht aber trotzdem irgendwie komisch aus....
muss das noch einmal genau evaluieren
OK,
mit
<div class="cell centered">
data-off-background-color="#505050"
data-off-color="black"
class=" big">
geht es wie es soll. Ist das so richtig und wo liegt mein Fehler ?
