FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 03 November 2017, 21:01:09
Titel: Revision 15386: fhemweb_iconRadio.js: add a user defined class to svg icons by prefix ...
Beitrag von: System am 03 November 2017, 21:01:09
fhemweb_iconRadio.js: add a user defined class to svg icons by prefix class<classname>@, improved matching for a numeric sequence of compare values, color numbers are now case insensitive, fhemweb_iconButtons.js, fhemweb_iconLabel.js, fhemweb_iconSwitch.js: add a user defined class to svg icons by prefix class<classname>@, color numbers are now case insensitive
Source: Revision 15386: fhemweb_iconRadio.js: add a user defined class to svg icons by prefix ... (http://svn.fhem.de/trac/changeset/15386/trunk)
