FHEM - Hausautomations-Systeme => Homematic => Thema gestartet von: PSI69 am 27 November 2017, 18:10:01
Titel: HM-LC-Bl1PBU-FM - MISSING ACK nach statusRequest
Beitrag von: PSI69 am 27 November 2017, 18:10:01
Hallo alle zusammen...
Ich betreibe 12 HM-LC-Bl1PBU-FM in identischer Konfuguration (AES an VCCU) und bin bei einer über ein Problem gestolpert:
Jedes Mal nach einem StatusRequest erhalte ich 'MISSING ACK'; unter aesCommToDev steht dann 'fail'.
   DEF        5676A6
   HMUSB_MSGCNT 3638
   HMUSB_RAWMSG E5676A6,0000,6666C52A,FF,FFBB,47A4105676A6DBDBDB0601000031
   HMUSB_RSSI -69
   HMUSB_TIME 2017-11-27 17:58:03
   HmLGWKG_MSGCNT 5978
   HmLGWKG_RAWMSG 0500005247A0035676A6DBDBDB58D13D286A36397CC6468D59DDA2B15C
   HmLGWKG_RSSI -82
   HmLGWKG_TIME 2017-11-27 17:58:03
   HmLGWOG_MSGCNT 15084
   HmLGWOG_RAWMSG 0503002247A4105676A6DBDBDB0601000031
   HmLGWOG_RSSI -34
   HmLGWOG_TIME 2017-11-27 17:58:03
   IODev      HmLGWOG
   LASTInputDev HmLGWOG
   MSGCNT     24700
   NAME       Jalousie.OG.AZ
   NOTIFYDEV  global
   NR         295
   STATE      MISSING ACK
   TYPE       CUL_HM
   lastMsg    No:46 - t:02 s:5676A6 d:DBDBDB 01016B2032
   protCmdDel 889
   protEvt_AESCom-ok 42 last_at:2017-11-27 17:54:49
   protLastRcv 2017-11-27 17:55:45
   protResnd  2550 last_at:2017-11-27 17:58:02
   protResndFail 849 last_at:2017-11-27 17:58:07
   protSnd    3642 last_at:2017-11-27 17:57:46
   protState  CMDs_done_Errors:1
   rssi_HmLGWOG cnt:50 avg:-48.39 max:-45 lst:-50 min:-57
   rssi_at_HmLGWOG lst:-40 min:-54 cnt:104 avg:-41.88 max:-35
     2017-11-27 17:55:45   CommandAccepted yes
     2017-06-04 14:12:07   D-firmware      2.11
     2017-06-04 14:12:07   D-serialNr      OEQ0294147
     2017-11-27 17:42:07   PairedTo        0xDBDBDB
     2017-10-25 19:45:06   R-driveDown     28 s
     2017-10-25 19:45:06   R-driveTurn     0.5 s
     2017-10-25 19:45:06   R-driveUp       30 s
     2017-06-04 13:49:28   R-pairCentral   0xDBDBDB
     2017-10-25 19:45:06   R-powerUpAction off
     2017-06-04 14:16:05   R-self01-lgActionType jmpToTarget
     2017-06-04 14:16:05   R-self01-lgOnLevel 100 %
     2017-06-04 14:16:05   R-self01-shActionType jmpToTarget
     2017-06-04 14:16:05   R-self01-shOnLevel 100 %
     2017-06-04 14:16:06   R-self02-lgActionType jmpToTarget
     2017-06-04 14:16:06   R-self02-lgOnLevel 100 %
     2017-06-04 14:16:06   R-self02-shActionType jmpToTarget
     2017-06-04 14:16:06   R-self02-shOnLevel 100 %
     2017-11-22 21:38:19   R-sign          off
     2017-11-27 17:58:03   aesCommToDev    fail
     2017-11-27 17:54:49   aesKeyNbr       02
     2017-11-27 17:55:45   deviceMsg       53.5 (to VCCU)
     2017-11-27 17:48:05   fwUpdate        done
     2017-11-27 17:55:45   level           53.5
     2017-11-27 17:55:45   motor           down:53.5
     2017-11-27 17:55:45   pct             53.5
     2017-07-15 11:44:27   powerOn         2017-07-15 11:44:27
     2017-11-27 17:55:45   recentStateType ack
     2017-11-27 17:58:07   state           MISSING ACK
     2017-11-27 17:55:45   timedOn         off
   helper:
     HM_CMDNR   71
     cSnd       11DBDBDB5676A60201000000,01DBDBDB5676A6010E
     dlvlCmd    ++A011DBDBDB5676A60201000000
     getCfgList all
     getCfgListNo ,3
     mId        006A
     peerIDsRaw ,00000000
     rxType     1
     supp_Pair_Rep 0
     ack:
     dir:
       cur        down
       rct        err
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +5676A6,01,00,02
       nextSend   1511801883.70074
       rxt        0
       vccu       VCCU
       p:
         5676A6
         01
         00
         02
       prefIO:
         HmLGWOG
     mRssi:
       mNo        46
       io:
         HmLGWOG    -38
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rssi:
       HmLGWOG:
         avg        -48.4
         cnt        50
         lst        -50
         max        -45
         min        -57
       at_HmLGWOG:
         avg        -41.8846153846154
         cnt        104
         lst        -40
         max        -35
         min        -54
     shadowReg:
     tmpl:
   role:
   IODev      HmLGWOG
   IOgrp      VCCU:HmLGWOG
   aesCommReq 1
   alias      Jalousie OG AZ
   autoReadReg 4_reqStatus
   devStateIcon hoch:fts_shutter_1w_0 on:fts_shutter_1w_0 runter:fts_shutter_1w_100 off:fts_shutter_1w_100 9\d.*:fts_shutter_1w_10 8\d.*:fts_shutter_1w_20 7\d.*:fts_shutter_1w_30 6\d.*:fts_shutter_1w_40 5\d.*:fts_shutter_1w_50 4\d.*:fts_shutter_1w_60 3\d.*:fts_shutter_1w_70 2\d.*:fts_shutter_1w_80 1\d.*:fts_shutter_1w_90 0\d.*:fts_shutter_1w_100
   eventMap   eventMap on:hoch off:runter stop:stop
   expert     2_raw
   firmware   2.11
   group      Jalousie
   icon       fts_shutter
   model      HM-LC-Bl1PBU-FM
   peerIDs    00000000,
   room       IS Jalousien,OG Arbeitszimmer
   serialNr   OEQ0294147
   subType    blindActuator
   webCmd     hoch:runter:stop
Nach assignHmKey gefolgt von einem stop/hoch/runter sieht erst einmal alles gut aus, bis zum nächsten StatusRequest:
   DEF        5676A6
   HMUSB_MSGCNT 3643
   HMUSB_RAWMSG E5676A6,0000,666AFEA7,FF,FFBB,4A80025676A6DBDBDB0101000031
   HMUSB_RSSI -69
   HMUSB_TIME 2017-11-27 18:02:40
   HmLGWKG_MSGCNT 5983
   HmLGWKG_RAWMSG 0500004E4A80025676A6DBDBDB0101000031
   HmLGWKG_RSSI -78
   HmLGWKG_TIME 2017-11-27 18:02:40
   HmLGWOG_MSGCNT 15091
   HmLGWOG_RAWMSG 040301264A80025676A6DBDBDB0101000031
   HmLGWOG_RSSI -38
   HmLGWOG_TIME 2017-11-27 18:02:40
   IODev      HmLGWOG
   LASTInputDev HMUSB
   MSGCNT     24717
   NAME       Jalousie.OG.AZ
   NOTIFYDEV  global
   NR         295
   STATE      runter
   TYPE       CUL_HM
   lastMsg    No:4A - t:02 s:5676A6 d:DBDBDB 0101000031
   protCmdDel 889
   protEvt_AESCom-ok 44 last_at:2017-11-27 18:02:38
   protLastRcv 2017-11-27 18:02:40
   protSnd    3645 last_at:2017-11-27 18:02:39
   protState  CMDs_done
   rssi_HmLGWOG cnt:51 avg:-48.41 max:-45 lst:-49 min:-57
   rssi_at_HmLGWOG lst:-38 min:-54 cnt:107 avg:-41.89 max:-35
     2017-11-27 18:02:40   CommandAccepted yes
     2017-11-27 18:02:38   aesCommToDev    ok
     2017-11-27 18:02:38   aesKeyNbr       02
     2017-11-27 18:02:40   deviceMsg       off (to VCCU)
     2017-11-27 18:02:40   level           0
     2017-11-27 18:02:40   motor           stop:off
     2017-11-27 18:02:40   pct             0
     2017-11-27 18:02:40   recentStateType ack
     2017-11-27 18:02:40   state           off
     2017-11-27 18:02:40   timedOn         off
   helper:
     HM_CMDNR   74
     cSnd       01DBDBDB5676A6010E,11DBDBDB5676A60301
     getCfgList all
     getCfgListNo ,3
     mId        006A
     rxType     1
     supp_Pair_Rep 0
     ack:
     dir:
       cur        stop
       rct        down
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       nextSend   1511802160.07084
       rxt        0
       vccu       VCCU
       p:
         5676A6
         01
         00
         02
       prefIO:
         HmLGWOG
     mRssi:
       mNo        4A
       io:
         HmLGWOG    -36
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rssi:
       HmLGWOG:
         avg        -48.4117647058823
         cnt        51
         lst        -49
         max        -45
         min        -57
       at_HmLGWOG:
         avg        -41.8971962616823
         cnt        107
         lst        -38
         max        -35
         min        -54
     shadowReg:
     tmpl:
   role:
   IODev      HmLGWOG
   IOgrp      VCCU:HmLGWOG
   aesCommReq 1
   expert     2_raw
   firmware   2.11
   group      Jalousie
   icon       fts_shutter
   peerIDs    00000000,
   serialNr   OEQ0294147
Die Firmware noch einmal zu flashen, hat auch nichts gebracht.
2017-11-27 17:44:44 CUL_HM Jalousie.OG.AZ set_fwUpdate /opt/fhem/FHEM/firmware/HM-LC-Bl1PBU-FM_update_V2_11_1_161212.eq3
2017.11.27 17:44:44 2: CUL_HM fwUpdate started for Jalousie.OG.AZ
2017.11.27 17:44:44 3: CUL_HM set Jalousie.OG.AZ fwUpdate /opt/fhem/FHEM/firmware/HM-LC-Bl1PBU-FM_update_V2_11_1_161212.eq3
2017.11.27 17:44:45 2: CUL_HM fwUpdate Jalousie.OG.AZ entered mode. IO-speed: fast
2017.11.27 17:48:05 2: CUL_HM fwUpdate Jalousie.OG.AZ end. IO-speed: normal
2017.11.27 17:48:05 2: CUL_HM fwUpdate completed
Wie gesagt, auch in diesem komischen Status kann ich die Jalousie bedienen und die Automatik fährt die auch regelmäßig hoch und runter; nur auf einen Statusrequest immer keine Reaktion.
Hat jemand eine Idee?
Danke Peter
Titel: Antw:HM-LC-Bl1PBU-FM - MISSING ACK nach statusRequest
Beitrag von: isy am 27 November 2017, 18:23:55
Muss nicht das Attribut Sign auf on stehen?
Reading:
R-sign on
Gruß Helmut
Beitrag von: PSI69 am 27 November 2017, 20:01:00
Hi Helmut,
korrekt - muss es - hatte ich übersehen, dass das rausgeflogen war. Bringt aber nichts:
nach
assignAesKey
getConfig
sign off
sign on
folgendes:
   DEF        5676A6
   HMUSB_MSGCNT 3759
   HMUSB_RAWMSG E5676A6,0000,66D4EDEA,FF,FFB2,9BA0105676A6DBDBDB0100000000
   HMUSB_RSSI -78
   HMUSB_TIME 2017-11-27 19:58:22
   HmLGWKG_MSGCNT 6133
   HmLGWKG_RAWMSG 0500004F9BA0105676A6DBDBDB0100000000
   HmLGWKG_RSSI -79
   HmLGWKG_TIME 2017-11-27 19:58:22
   HmLGWOG_MSGCNT 15308
   HmLGWOG_RAWMSG 050101239BA0105676A6DBDBDB0100000000
   HmLGWOG_RSSI -35
   HmLGWOG_TIME 2017-11-27 19:58:22
   IODev      HmLGWOG
   MSGCNT     25200
   NAME       Jalousie.OG.AZ
   NOTIFYDEV  global
   NR         295
   STATE      runter
   TYPE       CUL_HM
   lastMsg    No:9B - t:10 s:5676A6 d:DBDBDB 0100000000
   protCmdDel 890
   protEvt_AESCom-ok 57 last_at:2017-11-27 19:58:00
   protLastRcv 2017-11-27 19:58:22
   protResnd  2553 last_at:2017-11-27 19:50:12
   protResndFail 850 last_at:2017-11-27 19:50:17
   protSnd    3752 last_at:2017-11-27 19:58:22
   protState  CMDs_done
   rssi_HmLGWOG min:-57 lst:-50 max:-45 cnt:52 avg:-48.44
   rssi_at_HmLGWOG min:-59 lst:-35 max:-27 cnt:186 avg:-42.22
     2017-11-27 19:58:17   CommandAccepted yes
     2017-11-27 19:58:21   PairedTo        0xDBDBDB
     2017-11-27 19:58:22   R-sign          on
     2017-11-27 19:58:21   RegL_00.          02:01 0A:DB 0B:DB 0C:DB 15:FF 18:00 00:00
     2017-11-27 19:58:22   RegL_01.         08:01 09:00 0A:00 0B:01 0C:18 0D:01 0E:2C 0F:05 10:00  30:06 57:24 56:00 00:00
     2017-11-27 19:58:00   aesCommToDev    ok
     2017-11-27 19:58:00   aesKeyNbr       02
     2017-11-27 19:56:36   deviceMsg       off (to VCCU)
     2017-11-27 19:56:36   level           0
     2017-11-27 19:56:36   motor           stop:off
     2017-11-27 19:56:36   pct             0
     2017-11-27 19:56:36   recentStateType ack
     2017-11-27 19:56:36   state           off
     2017-11-27 19:56:36   timedOn         off
   helper:
     HM_CMDNR   155
     cSnd       01DBDBDB5676A601040000000001,01DBDBDB5676A60103
     mId        006A
     rxType     1
     supp_Pair_Rep 0
     ack:
     dir:
       cur        stop
       rct        down
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       nextSend   1511809102.81056
       rxt        0
       vccu       VCCU
       p:
         5676A6
         01
         00
         02
       prefIO:
         HmLGWOG
     mRssi:
       mNo        9B
       io:
         HmLGWOG    -33
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rpt:
       IO         HmLGWOG
       flg        A
       ts         1511809102.51944
       ack:
         HASH(0x5ef4598)
         9B8002DBDBDB5676A600
     rssi:
       HmLGWOG:
         avg        -48.4423076923077
         cnt        52
         lst        -50
         max        -45
         min        -57
       at_HmLGWOG:
         avg        -42.2204301075269
         cnt        186
         lst        -35
         max        -27
         min        -59
     shadowReg:
     tmpl:
   role:
   IODev      HmLGWOG
   IOgrp      VCCU:HmLGWOG
   aesCommReq 1
   expert     2_raw
   firmware   2.11
   group      Jalousie
   icon       fts_shutter
   peerIDs    00000000,
   serialNr   OEQ0294147
Nach statusRequest:
   DEF        5676A6
   HMUSB_MSGCNT 3763
   HMUSB_RAWMSG E5676A6,0000,66D5F6D7,FF,FFBA,9CA4105676A6DBDBDB0601000031
   HMUSB_RSSI -70
   HMUSB_TIME 2017-11-27 19:59:30
   HmLGWKG_MSGCNT 6141
   HmLGWKG_RAWMSG 0500004B9CA0035676A6DBDBDB44C84E1BD7683E1131FE2F1AE11F7EEB
   HmLGWKG_RSSI -75
   HmLGWKG_TIME 2017-11-27 19:59:30
   HmLGWOG_MSGCNT 15324
   HmLGWOG_RAWMSG 050300399CA4105676A6DBDBDB0601000031
   HmLGWOG_RSSI -57
   HmLGWOG_TIME 2017-11-27 19:59:30
   IODev      HmLGWOG
   LASTInputDev HmLGWKG
   MSGCNT     25228
   NAME       Jalousie.OG.AZ
   NOTIFYDEV  global
   NR         295
   STATE      MISSING ACK
   TYPE       CUL_HM
   protCmdDel 891
   protResnd  2556 last_at:2017-11-27 19:59:30
   protResndFail 851 last_at:2017-11-27 19:59:35
   protSnd    3753 last_at:2017-11-27 19:59:17
     2017-11-27 19:59:30   aesCommToDev    fail
     2017-11-27 19:59:35   state           MISSING ACK
   helper:
     HM_CMDNR   156
     cSnd       01DBDBDB5676A60103,01DBDBDB5676A6010E
     mId        006A
     rxType     1
     supp_Pair_Rep 0
     ack:
     dir:
       cur        stop
       rct        down
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       nextSend   1511809170.8987
       rxt        0
       vccu       VCCU
       p:
         5676A6
         01
         00
         02
       prefIO:
         HmLGWOG
     mRssi:
       mNo        9B
       io:
         HmLGWOG    -33
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rpt:
       IO         HmLGWOG
       flg        A
       ts         1511809102.51944
       ack:
         HASH(0x5ef4598)
     rssi:
       HmLGWOG:
         cnt        52
         lst        -50
         max        -45
         min        -57
       at_HmLGWOG:
         cnt        186
         lst        -35
         max        -27
         min        -59
     shadowReg:
     tmpl:
   role:
   IODev      HmLGWOG
   IOgrp      VCCU:HmLGWOG
   aesCommReq 1
   expert     2_raw
   firmware   2.11
   group      Jalousie
   icon       fts_shutter
   peerIDs    00000000,
   serialNr   OEQ0294147
... nur diese eine reagiert nicht sauber. Hm...
Peter
Beitrag von: frank am 28 November 2017, 12:10:56
sniffe die rawmessages, wie im wiki homematic sniffen.
am besten je ein statusrequest vom problem device und von einem "guten" zum vergleichen.
Beitrag von: PSI69 am 28 November 2017, 20:24:09
Hallo Frank,
hier die Ergebnisse:
Gut
2017.11.28 20:10:27.119 0: HMUARTLGW HmLGWOG send: 00 08
2017.11.28 20:10:27.187 0: HMUARTLGW HmLGWOG recv: 00 040200, state 98
2017.11.28 20:10:27.187 0: HMUARTLGW HmLGWOG GetSet Ack: 02, state 98
2017.11.28 20:10:27.188 0: HMUARTLGW HmLGWOG roundtrip delay: 0.0666
2017.11.28 20:10:27.189 0: HMUARTLGW HmLGWOG send: 01 02 00 00 00 msg: 7A A0 01 DBDBDB 567442 010E
2017.11.28 20:10:30.409 0: HMUARTLGW HmLGWOG recv: 01 0402, state 100
2017.11.28 20:10:30.410 0: HMUARTLGW HmLGWOG Ack: 02
2017.11.28 20:10:30.411 0: HMUARTLGW HmLGWOG recv: 01 05 02 01 3E msg: 7A A4 10 567442 DBDBDB 0601000046
2017.11.28 20:10:33.484 0: HMUARTLGW HmLGWOG recv: 01 05 00 01 3F msg: 95 A0 02 246977 28CA3C 04CAF39C4E618002
2017.11.28 20:10:33.620 0: HMUARTLGW HmLGWOG recv: 01 05 00 01 4E msg: 95 A0 03 28CA3C 246977 89F0B91DB80D54DDCC86483E8ABCBB06
2017.11.28 20:10:33.744 0: HMUARTLGW HmLGWOG recv: 01 05 00 01 3F msg: 95 80 02 246977 28CA3C 00A952DC95
Schlecht
2017.11.28 20:15:44.566 0: HMUARTLGW HmLGWOG send: 00 08
2017.11.28 20:15:44.635 0: HMUARTLGW HmLGWOG recv: 00 040200, state 98
2017.11.28 20:15:44.636 0: HMUARTLGW HmLGWOG GetSet Ack: 02, state 98
2017.11.28 20:15:44.636 0: HMUARTLGW HmLGWOG roundtrip delay: 0.0684
2017.11.28 20:15:49.238 0: HMUARTLGW HmLGWOG recv: 01 05 00 01 41 msg: 03 A6 10 4E502D DBDBDB 06010000
2017.11.28 20:15:49.339 0: HMUARTLGW HmLGWOG recv: 01 05 00 01 32 msg: 03 80 02 DBDBDB 4E502D 00
2017.11.28 20:15:52.141 0: HMUARTLGW HmLGWOG send: 01 02 00 00 00 msg: 48 A0 01 DBDBDB 5676A6 010E
2017.11.28 20:15:52.301 0: HMUARTLGW HmLGWOG recv: 01 0402, state 100
2017.11.28 20:15:52.301 0: HMUARTLGW HmLGWOG Ack: 02
2017.11.28 20:15:52.567 0: HMUARTLGW HmLGWOG recv: 01 05 02 01 2A msg: 48 A4 10 5676A6 DBDBDB 0601000032
2017.11.28 20:15:59.574 0: HMUARTLGW HmLGWOG send: 00 08
2017.11.28 20:15:59.585 0: HMUARTLGW HmLGWOG recv: 00 040200, state 98
2017.11.28 20:15:59.587 0: HMUARTLGW HmLGWOG GetSet Ack: 02, state 98
2017.11.28 20:15:59.587 0: HMUARTLGW HmLGWOG roundtrip delay: 0.0090
Wobei - die 'schlechte' läuft jetzt ebenso sauber durch - ohne irgend eine Änderung im FHEM. Ich hatte auch definitiv nichts, was noch nicht in der Cfg gespeichert war; meine einzige Änderung: ein Reboot vom Raspi 3 - das kann es doch nicht sein?!? Der Grund für den Reboot war, dass ich sehen wollte, ob die geänderte WLAN Konfig, die ich eben vorgenommen habe, nach einem Reboot greift; wobei, das Teil hängt primär über 100BT am Netz, WLAN ist jetzt nur zusätzlich konfiguriert...
Kann das jemand verstehen? Ich nicht!
Peter
Beitrag von: frank am 29 November 2017, 00:16:34
ZitatKann das jemand verstehen?
vodoo?  8)
Beitrag von: PSI69 am 29 November 2017, 07:52:38
Zitat von: frank am 29 November 2017, 00:16:34
vodoo?  8)
So kommt es mir auch vor; und ich mag Problemlösungen, die ich nicht sauber nachvollziehen/erkären kann überhaupt nicht - aber da muss ich wohl in diesem Fall damit leben. Zumindest, bis mich das Thema wieder ereilt - dann sniffe ich gleich; ohne Reboot :)
Peter
