seit heute (nach einem reboot) startet ha-bridge nicht mehr. Zuvor hatte ich es als service im boot-Vorgang starten lassen.
Es wunderte mich, dass nach dem heutigen reboot Alexa auf kein FHEM Gerät zugreifen konnte. Beim manuellen Start über
/usr/bin/java -jar /services/haBridge/ha-bridge-5.0.0.jar
kommen nur wirre Fehlermeldungen:
2017-12-05 19:05:59,729 [main] INFO com.bwssystems.HABridge.plugins.somfy.SomfyHome - Somfy Home created. No Somfys configured.
2017-12-05 19:05:59,739 [main] INFO com.bwssystems.HABridge.plugins.lifx.LifxHome - LifxDevice Home created. No LifxDevices configured.
2017-12-05 19:05:59.741:INFO:oejs.Server:Thread-0: jetty-9.4.z-SNAPSHOT
2017-12-05 19:05:59,758 [main] WARN com.bwssystems.HABridge.dao.DeviceRepository - Error reading the file: data/device.db - Does not exist or is not readable. continuing...
2017-12-05 19:05:59,766 [main] WARN com.bwssystems.HABridge.dao.GroupRepository - Error reading the file: data/group.db - Does not exist or is not readable. continuing...
2017-12-05 19:05:59,768 [main] INFO com.bwssystems.HABridge.devicemanagmeent.DeviceResource - HABridge device management service started....
2017-12-05 19:05:59,892 [main] INFO com.bwssystems.HABridge.hue.HueMulator - Hue emulator service started....
2017-12-05 19:06:00.551:INFO:oejs.AbstractConnector:Thread-0: Started ServerConnector@ef34f4{HTTP/1.1,[http/1.1]}{0.0.0.0:80}
Exception in thread "Thread-0" java.lang.InternalError: internal error: SHA-1 not available.
at sun.security.provider.SecureRandom.init(SecureRandom.java:108)
at sun.security.provider.SecureRandom.<init>(SecureRandom.java:79)
at java.security.SecureRandom.getDefaultPRNG(SecureRandom.java:198)
at java.security.SecureRandom.<init>(SecureRandom.java:162)
at org.eclipse.jetty.server.session.DefaultSessionIdManager.initRandom(DefaultSessionIdManager.java:406)
at org.eclipse.jetty.server.session.DefaultSessionIdManager.doStart(DefaultSessionIdManager.java:356)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:131)
at org.eclipse.jetty.server.Server.start(Server.java:452)
at org.eclipse.jetty.util.component.ContainerLifeCycle.addBean(ContainerLifeCycle.java:294)
at org.eclipse.jetty.util.component.ContainerLifeCycle.addBean(ContainerLifeCycle.java:226)
at org.eclipse.jetty.util.component.ContainerLifeCycle.updateBean(ContainerLifeCycle.java:775)
at org.eclipse.jetty.server.Server.setSessionIdManager(Server.java:635)
at org.eclipse.jetty.server.session.SessionHandler.doStart(SessionHandler.java:444)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:105)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
at org.eclipse.jetty.server.Server.doStart(Server.java:419)
at spark.embeddedserver.jetty.EmbeddedJettyServer.ignite(EmbeddedJettyServer.java:149)
at spark.Service.lambda$init$2(Service.java:496)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.security.NoSuchAlgorithmException: SHA MessageDigest not available
at sun.security.jca.GetInstance.getInstance(GetInstance.java:159)
at java.security.Security.getImpl(Security.java:695)
at java.security.MessageDigest.getInstance(MessageDigest.java:167)
at sun.security.provider.SecureRandom.init(SecureRandom.java:106)
... 23 more
Hat jemand eine Idee ?
VG Jolanda-Anne
Die Fehlermeldung besagt das es in Java den SHA-1 Algorithmus nicht gibt. Allerdings stehen da auch einige Fehlermeldungen die fehlende Configs bedeuten. Daher bin ich mir nicht sicher ob das jetzt alles auf ein Problem mit dem Filesystem hindeutet oder ob die fehlenden Configs normal sind und dann der SHA-1 nur deaktiviert wurde über ein Update. Allerdings gibt es beim Java 1.8.0_65 keine Deaktivierung des SHA-1, das hätte ich mit bekommen. SHA-1 wurde nur in Zusammenhang mit Zertifikaten für zum Beispiel Webseiten im Java 8 als unsicher deklariert aber das ist eine komplett andere Baustelle. Deswegen würde ich zu einen Filesystemfehler tendieren wenn sonst keine Updates oder sonst was gemacht wurde am System.
In welchem Pfad stehst du, wenn du das Kommando ausführst?
Versuch es mal direkt dort wo die ha-bridge.jar liegt.
Gibt es dort die Verzeichnisse?
Also /services/haBridge/data und die gesuchten Dateiein.
Warum hast du es nach /services/haBridge "installiert"?
Welches System hast du?
Gruß, Joachim
Vielen Dank für die Antworten !
Gestern Abend habe ich einfach mal Java mittels apt-get de- und dann wieder installiert. Und dann funktionierte es schlagartig wieder.........
Könnte wohl wirklich am Filesystem liegen.
Ich hatte Anfang des Jahres schonmal eine defekte SD-Karte. Da stand in vielen conf-Dateien nur noch wirrer Müll.
Gibt es spezielle SD-Karten für den Raspberry/Betrieb ? Aktuell habe ich ganz normale genommen, die wohl sonst eher in Kameras eingesetzt werden.
