ist es normal, dass die Fibaro Fernbedienung KEYFOB in der zWave neighbour map keinerlei Verknüpfungen zu anderen Devices hat?
Oder ist er noch nicht richtig konfiguriert?
Hier sein List:
DEF fd1cb8e9 29
IMAGE /fhem/deviceimages/zwave/ZC10-16125346
IODev ZWDongle_0
LASTInputDev ZWDongle_0
MSGCNT 67
NAME JarvisRemote
NR 389
STATE wakeupInterval 86400 1
TYPE ZWave
ZWDongle_0_MSGCNT 67
ZWDongle_0_RAWMSG 0004001d055b034d8005
ZWDongle_0_TIME 2017-12-16 18:09:29
ZWaveSubDevice no
cmdsPending 1
homeId fd1cb8e9
isWakeUp 1
lastMsgSent 1513372086.2392
nodeIdHex 1d
2017-12-15 21:34:19 assocGroup_1 Max 1 Nodes ZWDongle_0
2017-12-15 21:34:19 assocGroup_10 Max 5 Nodes
2017-12-15 21:34:19 assocGroup_11 Max 5 Nodes
2017-12-15 21:34:20 assocGroup_12 Max 5 Nodes
2017-12-15 21:34:20 assocGroup_13 Max 5 Nodes
2017-12-15 21:34:19 assocGroup_2 Max 5 Nodes
2017-12-15 21:34:19 assocGroup_3 Max 5 Nodes
2017-12-15 21:34:19 assocGroup_4 Max 5 Nodes
2017-12-15 21:34:19 assocGroup_5 Max 5 Nodes
2017-12-15 21:34:19 assocGroup_6 Max 5 Nodes
2017-12-15 21:34:19 assocGroup_7 Max 5 Nodes
2017-12-15 21:34:19 assocGroup_8 Max 5 Nodes
2017-12-15 21:34:19 assocGroup_9 Max 5 Nodes
2017-12-15 21:34:19 assocGroups 13
2017-12-15 22:21:06 battery 87 %
2017-12-16 18:09:29 cSceneSet 5
2017-12-15 21:29:48 model FIBARO System FGKF601 Keyfob
2017-12-15 21:29:48 modelConfig fibaro/fgkf601.xml
2017-12-15 21:29:48 modelId 010f-1001-1000
2017-12-15 21:33:05 neighborUpdate failed
2017-12-15 21:26:40 state wakeupInterval 86400 1
2017-12-15 22:08:06 timeToAck 0.025
2017-12-15 22:08:06 transmit OK
2017-12-15 22:08:04 wakeup notification
SendStack:
set:481d04
IODev ZWDongle_0
classes ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO BATTERY CENTRAL_SCENE CONFIGURATION CRC_16_ENCAP DEVICE_RESET_LOCALLY FIRMWARE_UPDATE_MD MANUFACTURER_SPECIFIC MULTI_CHANNEL_ASSOCIATION POWERLEVEL SECURITY VERSION WAKE_UP PROTECTION APPLICATION_STATUS
icon it_remote
room Arbeitszimmer,System,ZWave
vclasses APPLICATION_STATUS:1 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BATTERY:1 CENTRAL_SCENE:3 CONFIGURATION:1 CRC_16_ENCAP:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:3 MANUFACTURER_SPECIFIC:2 MULTI_CHANNEL_ASSOCIATION:3 POWERLEVEL:1 PROTECTION:2 SECURITY:1 VERSION:2 WAKE_UP:2 ZWAVEPLUS_INFO:2
Und noch eine Frage:
Wenn ich auf das Quadrat drücke, erscheint folgendes Event:
2017-12-16 18:21:31 ZWave JarvisRemote cSceneSet: 1
Wie müsste ein Notify damit aussehen?
Das hier tut nicht:
Define n_remoteWandlampe notify JarvisRemote cSceneSet: 1 set ArbeitszimmerWandlampe toggle
Markus
ZitatWie müsste ein Notify damit aussehen?
Wenn einem Regexp noch nicht gelaeufig ist, dann sollte man die notifies aus dem Event-Monitor anlegen.
Wg. den Nachbarn: ich vermute, es wurde beim KEYFOB noch kein neighborUpdate abgesetzt.
Meine ZWave-Fernbedienung hat Nachbarn.
Stimmt!
Mir war so, als hätten die abgesetzten NeighborUpdates funktioniert, aber vermutlich war die Reihenfolge von OK drücken und und remote aufwecken falsch.
Dass man sich direkt aus dem Event ein Notify basteln lassen kann, wusste ich noch gar nicht.
Damit hat jetzt jedenfalls auch das geklappt.
Vielen Dank!
