FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 03 Januar 2018, 13:00:22
Titel: Revision 15764: 59_HCS: Do not even start the check interval timer in case HCS is ...
Beitrag von: System am 03 Januar 2018, 13:00:22
59_HCS: Do not even start the check interval timer in case HCS is switched off.
Source: Revision 15764: 59_HCS: Do not even start the check interval timer in case HCS is ... (http://svn.fhem.de/trac/changeset/15764/trunk)
