Revision 15931: 93_DbLog: V3.6.5, avoid shutdown problem if database is too slow,
extend configCheck with shutdown preparation check,
fix logentries if device disabled and db not available
Source: Revision 15931: 93_DbLog: V3.6.5, avoid shutdown problem if database is too slow,
... (http://svn.fhem.de/trac/changeset/15931/trunk)
