Hi all,
kann es sein, dass sich ein Bug in das heutige Update eingeschlichen hat? Seit dem Update um 10:50 geht nichts mehr...
2018.02.11 10:51:04 1:
2018.02.11 10:51:04 1: update finished, "shutdown restart" is needed to activate the changes.
2018.02.11 10:51:21 0: Server shutdown
2018.02.11 10:51:21 1: PERL WARNING: Use of uninitialized value in numeric gt (>) at ./FHEM/00_HMUARTLGW.pm line 368.
2018.02.11 10:51:24 1: Including fhem.cfg
2018.02.11 10:51:24 3: TABLETUI: new ext defined infix:ftui: dir:./www/tablet:
2018.02.11 10:51:24 3: Registering HTTPSRV TABLETUI for URL /ftui and assigned link ftui ...
2018.02.11 10:51:24 2: FRITZBOX FritzBox_6360: Define.254 Modul functionality limited because of missing perl modules: Net::Telnet
2018.02.11 10:51:24 2: FRITZBOX FritzBox_7490: Define.254 Modul functionality limited because of missing perl modules: Net::Telnet
2018.02.11 10:51:24 3: Opening my_callmonitor device 192.168.200.1:1012
2018.02.11 10:51:24 2: Registering GEOFANCY geofancy for URL /geo...
2018.02.11 10:51:25 3: WEBhook: port 8088 opened
2018.02.11 10:51:25 3: TelegramBot_Define teleBot: called
2018.02.11 10:51:26 3: telnetPort: port 7072 opened
2018.02.11 10:51:26 3: WEB: port 8083 opened
2018.02.11 10:51:26 3: WEBphone: port 8084 opened
2018.02.11 10:51:26 3: WEBtablet: port 8085 opened
2018.02.11 10:51:26 3: Opening fbaha device localhost:2002
2018.02.11 10:51:26 3: Can't connect to localhost:2002: Connection refused
2018.02.11 10:51:27 2: eventTypes: loaded 10987 events from ./log/eventTypes.txt
2018.02.11 10:51:28 1: reload: Error:Modul 10_CUL_HM deactivated:
Global symbol "$oldIODevH" requires explicit package name (did you forget to declare "my $oldIODevH"?) at ./FHEM/10_CUL_HM.pm line 9095, <$fh> line 259.
Global symbol "$oldIODevH" requires explicit package name (did you forget to declare "my $oldIODevH"?) at ./FHEM/10_CUL_HM.pm line 9096, <$fh> line 259.
Global symbol "$newIODevH" requires explicit package name (did you forget to declare "my $newIODevH"?) at ./FHEM/10_CUL_HM.pm line 9126, <$fh> line 259.
2018.02.11 10:51:28 0: Global symbol "$oldIODevH" requires explicit package name (did you forget to declare "my $oldIODevH"?) at ./FHEM/10_CUL_HM.pm line 9095, <$fh> line 259.
2018.02.11 10:51:28 3: Opening CUL_0 device /dev/ttyACM0
2018.02.11 10:51:28 3: Setting CUL_0 serial parameters to 9600,8,N,1
2018.02.11 10:51:28 3: CUL_0: Possible commands: BCFiAZEGMRTVWXefmltux
2018.02.11 10:51:28 3: CUL_0 device opened
2018.02.11 10:51:28 3: Opening myJeeLink device /dev/ttyUSB0
2018.02.11 10:51:28 3: Setting myJeeLink serial parameters to 57600,8,N,1
2018.02.11 10:51:29 3: myJeeLink device opened
2018.02.11 10:51:29 3: LGW1 device closed
2018.02.11 10:51:29 3: Opening LGW1 device 192.168.100.6:2000
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 152, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 235, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 518, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 585, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 604, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 652, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 953, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 971, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 976, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 1013, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 1041, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 1057, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1094, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2970, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3522, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3533, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3551, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_parseSDteam_2 redefined at ./FHEM/10_CUL_HM.pm line 3612, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3673, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3694, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3721, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3987, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 6296, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 6367, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 6399, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 6408, <$fh> line 331.
2018.02.11 10:51:30 1: PERL WARNING: Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 6458, <$fh> line 331.
am besten restore machen, CUL_HM hat einen Schuss.
https://forum.fhem.de/index.php/topic,84181.0.html
Oh sorry, den hatte ich nicht gesehen...
Vielen Dank,
Mergat
Vielleicht noch ein [Erledigt] vor das Subject des ersten Posts
Kurz, weil mobil...
