| # TIMESTAMP, DEVICE, TYPE, EVENT, reading, value, UNIT 2018-03-27 06:00:51, EG_Toilette_H, MAX, desiredTemperature: 20.0, desiredTemperature, 20.0, °C 2018-03-27 05:30:19, EG_Toilette_H, MAX, desiredTemperature: 20.0, desiredTemperature, 20.0, °C 2018-03-27 05:30:05, EG_Toilette_H, MAX, desiredTemperature auto, desiredTemperature, , °C 2018-03-27 05:02:35, EG_Toilette_H, MAX, desiredTemperature: 18.0, desiredTemperature, 18.0, °C 2018-03-27 05:02:34, EG_Toilette_H, MAX, desiredTemperature 18.0, desiredTemperature, 18.0, °C |
set output '<OUT>.png'
set xdata time
set xlabel " "
set ytics
set y2tics
set grid y2tics
set ylabel "Ventil in %"
set y2label "Temperatur in Grad Celsius"
#logdb <SPEC1>:desiredTemperature
#logdb <SPEC1>:temperature
#logdb <SPEC1>:valveposition
plot "<IN>" using 1:2 axes x1y2 title 'Soll-Temperatur (C)' ls l0fill_gyr lw 2 with lines,\
"<IN>" using 1:2 axes x1y2 title 'Ist-Temperatur (C)' ls l1 lw 2 with lines,\
"<IN>" using 1:2 axes x1y1 title 'Ventil (%)' ls l2 lw 3 with lines
#logdb <SPEC1>:desiredTemperature:::$val=($val=''?20:$val)
