FHEM => fhem-users => Thema gestartet von: Guest am 15 Oktober 2012, 18:04:47
Titel: logging temperature using FHT80b or HMS100TF
Beitrag von: Guest am 15 Oktober 2012, 18:04:47
If I need a detailed portable temperature logger, can i use the FHT80b from
Conrad? (I like it since it also displays the temperature and there is an
article on FHEMWiki about it - http://www.fhemwiki.de/wiki/FHT80b - so it
seems to work well). The only problem i see is that the wiki article says:
Ausserdem sendet FHT80b ca 4 mal pro Stunde folgenden Statusbericht:
FHT actuator: 0%
FHT measured-temp: 23.1 (Celsius)
FHT battery: ok
FHT lowtemp: ok
FHT window: closed
FHT windowsensor: ok
FHT warnings: none
Does that mean I cannot simply do "getstatus " or "get
measured-temp"?
Or is dedicated device HMS100TF better for my purpose? Any experience with
this?
Thanks
Rok
Titel: Re: logging temperature using FHT80b or HMS100TF
Beitrag von: UliM am 15 Oktober 2012, 19:13:47
Hi rok,
Am Montag, 15. Oktober 2012 18:04:47 UTC+2 schrieb rok:
> from Conrad?
well, portable... in a way, yes.
To be precise: it displays the _desired_ temperature, not the measured temp.
> and there is an article on FHEMWiki about it -
> http://www.fhemwiki.de/wiki/FHT80b - so it seems to work well).
Yes, works well. Usinfg it since 2 years. Just that it sometimes stops
transmitting data for a while, but that's just temporary and happended
twice in two years now. That's also described in the mentioned wiki though.
> FHT actuator: 0%
> FHT battery: ok
> FHT lowtemp: ok
> FHT window: closed
> FHT warnings: none
> measured-temp"?
Right. It sends tha actuator-value (calculated heating-valve-open%) every 2
minutes to react prmoptly to a drop in temperature e.g. due to an open
window, other than that just 4 times an hour.
You can send a request named 'report' , but I'm not sure what that report
contains - and the device won't reply promptly anyways.
However, the last measured temperature is stored in fhem together with a
timestamp.
> this?
 Don't have one, so I can't tell.
Cheers, Uli
Beitrag von: Guest am 15 Oktober 2012, 19:21:57
Thanks Uli, that's really valuable info to me. I bought the FS20GHS device
2 weeks ago and figured out later that i cannot actually read the
temperature and humidity information from it, quite a disappointment. So,
the FHT80b does not display the measured temp, just the preset/desired? In
that case, it definitely has no use to me, hopefully someone can recommend
the HMS100TF then...
Thanks again!
Rok
On Monday, October 15, 2012 7:13:48 PM UTC+2, UliM wrote:
> Hi rok,
>> from Conrad?
> temp.
>> FHT actuator: 0%
>> FHT battery: ok
>> FHT lowtemp: ok
>> FHT window: closed
>> FHT warnings: none
>> measured-temp"?
> 2 minutes to react prmoptly to a drop in temperature e.g. due to an open
> timestamp.
>> with this?
> Cheers, Uli
Beitrag von: UliM am 15 Oktober 2012, 19:23:03
... for just measuring temp you'd porbably want to consider S300TH, see
http://www.fhemwiki.de/wiki/S300TH
=8-)
Beitrag von: Guest am 15 Oktober 2012, 20:19:53
Yeah, I was looking at that one, the problem is Lieferzeit is 9 wochen :(
and the other one is sofort versandfertig
http://www.elv.de/funk-temperatur-luftfeuchteaussensensor-s-300-th-fuer-z-b-elv-ws-200-300-elv-ws-300-pc-usb-wde1-und-ipwe-1.html
so hopefully someone can confirm that hms100tf can act as a sensor from
which I can read temperature and feuchtigkeit at any time.
Thanks
Rok
> =8-)
