Hallo und guten Abend,
habe meinen RPi neu aufgesetzt und das Zip für FTUI heruntergeladen = Version 2.5
<head>
/* FHEM tablet ui */
* UI builder framework for FHEM
* Version: 2.5.*
* URL: https://github.com/knowthelist/fhem-tablet-ui
* Copyright (c) 2015-2017 Mario Stephan <mstephan@shared-files.de>
* Under MIT License (http://www.opensource.org/licenses/mit-license.php)
* - create a new folder named 'tablet' in /<fhem-path>/www
* - copy all files incl. sub folders into /<fhem-path>/www/tablet
* - add 'define TABLETUI HTTPSRV ftui ./www/tablet Tablet' in fhem.cfg
* - Tadaaa! A new fhem ui in http://<fhem-url>:8083/fhem/tablet/
<link rel="icon" href="favicon.ico" type="image/x-icon" />
<!-- define your personal style here, it wont be overwritten -->
<!-- link rel="stylesheet" href="css/fhem-green-ui.css" / -->
<!-- link rel="stylesheet" href="css/fhem-tablet-ui-user.css" / -->
<script src="js/fhem-tablet-ui.js" defer></script>
<!-- Remove this line to enable for usage with WebViewControl
<script defer>var wvcDevices = {'12345': 'Tablet'}; var wvcUserCssFile="webviewcontrol.css"</script>
<script src="../pgm2/cordova-2.3.0.js" defer></script>
<script src="../pgm2/webviewcontrol.js" defer></script>
<!-- End for WebViewControl -->
<title>Poolsteuerung</title>
</head>
<body>
<div class="gridster">
<ul>
<li data-row="1" data-col="1" data-sizex="1" data-sizey="1">
<header>Einfahrt</header>
<div data-type="symbol" data-device="Einfahrt"
data-get-on='["Offen","Zu"]'
data-icons='["oa-fts_garage_door_10","oa-fts_garage_door_100"]'
data-on-colors='["red","green"]'
class="bigger" >
</div>
<div data-type="label" class="bold"></div>
</li>
<li data-row="2" data-col="1" data-sizex="1" data-sizey="1">
<header>Garagentor</header>
<div data-type="symbol" data-device="GaragenTor"
class="bigger" >
</div>
<div data-type="label" data-device="Tuer"
</li>
Ich bekomme die Einfahrt und das Garagentor nicht angezeigt ist ausgegraut??
Hier das List der Einfahrt
DEF 4D242F
IODev HMUSB
NAME Einfahrt
NOTIFYDEV global
NR 79
NTFY_ORDER 50-Einfahrt
STATE Zu
TYPE CUL_HM
2018-05-14 19:34:19 Activity alive
2018-05-10 13:10:32 D-firmware 2.4
2018-05-10 13:10:32 D-serialNr NEQ0755120
2018-05-11 06:49:27 PairedTo 0x220355
2018-05-11 06:49:27 R-cyclicInfoMsg off
2018-05-11 06:49:28 R-eventDlyTime 0 s
2018-05-11 06:49:27 R-pairCentral 0x220355
2018-05-11 06:49:27 R-sabotageMsg on
2018-05-11 06:49:28 R-sign off
2018-05-11 06:49:27 RegL_00. 02:01 09:00 0A:22 0B:03 0C:55 10:01 14:06 00:00
2018-05-11 06:49:28 RegL_01. 08:00 20:60 21:00 22:64 30:06 00:00
2018-05-14 19:31:01 battery ok
2018-05-14 19:31:01 contact closed (to VCCU)
2018-05-14 19:31:01 state closed
2018-05-14 19:31:01 trigger_cnt 107
helper:
HM_CMDNR 97
mId 00B1
regLst ,0,1,4p
rxType 28
expert:
def 1
det 0
raw 1
tpl 0
io:
newChn +4D242F,00,00,00
prefIO
rxt 2
vccu
p:
4D242F
00
00
00
mRssi:
mNo
prt:
bErr 0
sProc 0
q:
qReqConf
qReqStat
role:
chn 1
dev 1
tmpl:
IODev HMUSB
actCycle 028:00
actStatus alive
autoReadReg 4_reqStatus
devStateIcon Offen:fts_yard_gate_2w_open@red Zu:fts_yard_gate_2w@green
eventMap open:Offen closed:Zu
expert 2_raw
firmware 2.4
model HM-SEC-SC-2
peerIDs 00000000,
room Einfahrt
serialNr NEQ0755120
subType threeStateSensor
webCmd :
Was übersehe ich hier bitte?
Gruß und Danke
Helmut
meine Definition sieht so aus:
<li data-row="1" data-col="4" data-sizex="4" data-sizey="3">
<header class="">Balkontür</header>
<table class="">
<tr>
<td>
<div class="">
<div class=""></div>
<div data-type="label" data-device="HM_50F361" data-get="alias" data-color="white" class="left-space big""></div>
</div>
</td>
<td>
<div class="">
<div data-type="symbol" data-device="HM_50F361" data-get="state" data-states='["open","tilted","closed"]' data-colors='["red","red","green"]'
data-icons='["oa-fts_door_open","oa-fts_door_tilt","oa-fts_door"]' data-background-color="black" class="left-space bigger">
</div>
</div>
</td>
<td>
<div class="">
<div data-type="label" data-device="HM_50F361" data-get="LastOpen" data-color="white" class="big"></div>
</div>
</td>
</tr>
</table>
</li>
Das funktioniert bestens
Jürgen
D.h. die Farben werden nicht angezeigt? Dann liegt es wahrscheinlich an
data-on-colors='["red","green"]'Probiere mal
data-get-on='["Offen","Zu"]' :o ???
data-states='["Offen","Zu"]'
data-colors='["red","green"]'Hier gab es im Frühjahr eine Änderung.
data-on-colors wird nicht mehr unterstützt.
Nützliche Infos wie immer siehe Wiki.
Herzlichen Dank genau das wars.
Sorry da war ich anscheinend zu schlampig beim Lesen.
Schönen Tag
