ALARM 1
ASYNC 0
CHANGED
DEF DS18B20 FF0DA5011703
ERRCOUNT 0
INTERVAL 1
IODev 1wire
NAME OWX_28_FF0DA5011703
NOTIFYDEV global
NR 61
NTFY_ORDER 50-OWX_28_FF0DA5011703
OW_FAMILY 28
OW_ID FF0DA5011703
PRESENT 1
ROM_ID 28.FF0DA5011703.47
STATE T: 24.5 °C
TYPE OWTHERM
owg_cf 9
owg_temp 24.5
owg_th 75
owg_tl 70
2018-06-03 17:09:53 state T: 24.50 °C ↓
2018-06-03 17:09:53 temperature 24.5
tempf:
factor 1
offset 0
IODev 1wire
alias Mischer Ausgang OWX_28_FF0DA5011703
event-on-change-reading temperature:.1
fp_Grundriss 513,846,0,OWX_28_FF0DA5011703,
model DS18B20
resolution 9
room Bad,OWX
stateFormat {sprintf("T: %.1f °C", ReadingsVal("OWX_28_FF0DA5011703","temperature",0))}
tempHigh 75
tempLow 70define FileLog_OWX_28_FF0DA5011703 FileLog ./log/OWX_28_FF0DA5011703-%Y.log OWX_28_FF0DA5011703
attr FileLog_OWX_28_FF0DA5011703 alias Mischer Ausgang FF0DA5011702018-06-03_12:18:54 OWX_28_FF0DA5011703 temperature: 24
2018-06-03_12:18:54 OWX_28_FF0DA5011703 T: 24.00 °C ↓
2018-06-03_12:38:54 OWX_28_FF0DA5011703 temperature: 23.5
2018-06-03_12:38:54 OWX_28_FF0DA5011703 T: 23.50 °C ↓
2018-06-03_13:23:54 OWX_28_FF0DA5011703 temperature: 23
2018-06-03_13:23:54 OWX_28_FF0DA5011703 T: 23.00 °C ↓
2018-06-03_13:28:54 OWX_28_FF0DA5011703 temperature: 23.5
2018-06-03_13:28:54 OWX_28_FF0DA5011703 T: 23.50 °C ↓
2018-06-03_13:33:54 OWX_28_FF0DA5011703 temperature: 23
2018-06-03_13:33:54 OWX_28_FF0DA5011703 T: 23.00 °C ↓
2018-06-03_13:53:54 OWX_28_FF0DA5011703 temperature: 36
2018-06-03_13:53:54 OWX_28_FF0DA5011703 T: 36.00 °C ↓
2018-06-03_13:58:54 OWX_28_FF0DA5011703 temperature: 39
2018-06-03_13:58:54 OWX_28_FF0DA5011703 T: 39.00 °C ↓
2018-06-03_14:08:54 OWX_28_FF0DA5011703 temperature: 23
2018-06-03_14:08:54 OWX_28_FF0DA5011703 T: 23.00 °C ↓
2018-06-03_14:13:54 OWX_28_FF0DA5011703 temperature: 22
2018-06-03_14:13:54 OWX_28_FF0DA5011703 T: 22.002018-02-09_16:31:09 OWX_28_FF0DA5011703 T: 22.69 °C ↓
2018-02-09_16:31:14 OWX_28_FF0DA5011703 temperature: 22.6875
2018-02-09_16:31:14 OWX_28_FF0DA5011703 T: 22.69 °C ↓
2018-02-09_16:31:19 OWX_28_FF0DA5011703 temperature: 22.6875
2018-02-09_16:31:19 OWX_28_FF0DA5011703 T: 22.69 °C ↓
2018-02-09_16:31:24 OWX_28_FF0DA5011703 temperature: 23.0625
2018-02-09_16:31:24 OWX_28_FF0DA5011703 T: 23.06 °C ↓
2018-02-09_16:31:29 OWX_28_FF0DA5011703 temperature: 24.75
2018-02-09_16:31:29 OWX_28_FF0DA5011703 T: 24.75 °C ↓
2018-02-09_16:31:34 OWX_28_FF0DA5011703 temperature: 26
2018-02-09_16:31:34 OWX_28_FF0DA5011703 T: 26.00 °C ↓
2018-02-09_16:31:39 OWX_28_FF0DA5011703 temperature: 26.9375
2018-02-09_16:31:39 OWX_28_FF0DA5011703 T: 26.94 °C ↓
2018-02-09_16:31:44 OWX_28_FF0DA5011703 temperature: 27.625
2018-02-09_16:31:44 OWX_28_FF0DA5011703 T: 27.62 °C ↓
2018-02-09_16:31:49 OWX_28_FF0DA5011703 temperature: 28.125
2018-02-09_16:31:49 OWX_28_FF0DA5011703 T: 28.12 °C ↓
2018-02-09_16:31:54 OWX_28_FF0DA5011703 temperature: 28.5625
2018-02-09_16:31:54 OWX_28_FF0DA5011703 T: 28.56 °C ↓
2018-02-09_16:31:59 OWX_28_FF0DA5011703 temperature: 28.9375
2018-02-09_16:31:59 OWX_28_FF0DA5011703 T: 28.94 °C ↓
2018-02-09_16:32:04 OWX_28_FF0DA5011703 temperature: 29.25
2018-02-09_16:32:04 OWX_28_FF0DA5011703 T: 29.25 °C ↓
2018-02-09_16:32:09 OWX_28_FF0DA5011703 temperature: 29.625
2018-02-09_16:32:09 OWX_28_FF0DA5011703 T: 29.62 °C ↓
2018-02-09_16:32:14 OWX_28_FF0DA5011703 temperature: 29.875
2018-02-09_16:32:14 OWX_28_FF0DA5011703 T: 29.88 °C ↓
2018-02-09_16:32:19 OWX_28_FF0DA5011703 temperature: 30.1875
2018-02-09_16:32:19 OWX_28_FF0DA5011703 T: 30.19 °C ↓
2018-02-09_16:32:24 OWX_28_FF0DA5011703 temperature: 30.5
2018-02-09_16:32:24 OWX_28_FF0DA5011703 T: 30.50 °C ↓
2018-02-09_16:32:29 OWX_28_FF0DA5011703 temperature: 30.75
2018-02-09_16:32:29 OWX_28_FF0DA5011703 T: 30.75 °C ↓
2018-02-09_16:32:34 OWX_28_FF0DA5011703 temperature: 31
2018-02-09_16:32:34 OWX_28_FF0DA5011703 T: 31.00 °C ↓
2018-02-09_16:32:39 OWX_28_FF0DA5011703 temperature: 31.1875
2018-02-09_16:32:39 OWX_28_FF0DA5011703 T: 31.19 °C ↓
2018-02-09_16:32:44 OWX_28_FF0DA5011703 temperature: 31.4375
2018-02-09_16:32:44 OWX_28_FF0DA5011703 T: 31.44 °C ↓
2018-02-09_16:32:49 OWX_28_FF0DA5011703 temperature: 31.625
2018-02-09_16:32:49 OWX_28_FF0DA5011703 T: 31.62 °C ↓
2018-02-09_16:32:54 OWX_28_FF0DA5011703 temperature: 31.8125
2018-02-09_16:32:54 OWX_28_FF0DA5011703 T: 31.81 °C ↓
2018-02-09_16:32:59 OWX_28_FF0DA5011703 temperature: 31.9375
2018-02-09_16:32:59 OWX_28_FF0DA5011703 T: 31.94 °C ↓
2018-02-09_16:33:04 OWX_28_FF0DA5011703 temperature: 32.125
2018-02-09_16:33:04 OWX_28_FF0DA5011703 T: 32.12 °C ↓
2018-02-09_16:33:09 OWX_28_FF0DA5011703 temperature: 32.25
2018-02-09_16:33:09 OWX_28_FF0DA5011703 T: 32.25 °C ↓
2018-02-09_16:33:14 OWX_28_FF0DA5011703 temperature: 32.4375
2018-02-09_16:33:14 OWX_28_FF0DA5011703 T: 32.44 °C ↓
2018-02-09_16:33:19 OWX_28_FF0DA5011703 temperature: 32.5625
2018-02-09_16:33:19 OWX_28_FF0DA5011703 T: 32.56 °C ↓
2018-02-09_16:33:24 OWX_28_FF0DA5011703 temperature: 32.6875
2018-02-09_16:33:24 OWX_28_FF0DA5011703 T: 32.69 °C ↓
2018-02-09_16:33:29 OWX_28_FF0DA5011703 temperature: 32.8125
2018-02-09_16:33:29 OWX_28_FF0DA5011703 T: 32.81 °C ↓
2018-02-09_16:33:34 OWX_28_FF0DA5011703 temperature: 32.9375
2018-02-09_16:33:34 OWX_28_FF0DA5011703 T: 32.94 °C ↓
2018-02-09_16:33:39 OWX_28_FF0DA5011703 temperature: 33.0625
2018-02-09_16:33:39 OWX_28_FF0DA5011703 T: 33.06 °C ↓
2018-02-09_16:33:44 OWX_28_FF0DA5011703 temperature: 33.1875
2018-02-09_16:33:44 OWX_28_FF0DA5011703 T: 33.19 °C ↓
2018-02-09_16:33:49 OWX_28_FF0DA5011703 temperature: 33.25
2018-02-09_16:33:49 OWX_28_FF0DA5011703 T: 33.25 °C ↓
2018-02-09_16:33:54 OWX_28_FF0DA5011703 temperature: 33.375
2018-02-09_16:33:54 OWX_28_FF0DA5011703 T: 33.38 °C ↓
2018-02-09_16:33:59 OWX_28_FF0DA5011703 temperature: 33.4375
2018-02-09_16:33:59 OWX_28_FF0DA5011703 T: 33.44 °C ↓
2018-02-09_16:34:04 OWX_28_FF0DA5011703 temperature: 33.5625
2018-02-09_16:34:04 OWX_28_FF0DA5011703 T: 33.56 °C ↓
2018-02-09_16:34:09 OWX_28_FF0DA5011703 temperature: 33.625
2018-02-09_16:34:09 OWX_28_FF0DA5011703 T: 33.62 °C ↓
2018-02-09_16:34:14 OWX_28_FF0DA5011703 temperature: 33.6875
2018-02-09_16:34:14 OWX_28_FF0DA5011703 T: 33.69 °C ↓
2018-02-09_16:34:19 OWX_28_FF0DA5011703 temperature: 33.75
Zitat von: Thomas24568 am 03 Juni 2018, 17:37:07Du bekommst mit der Einstellung von 9 für Resolution keine kleineren Sprünge - dafür wäre eine höhere Auflösung anzugeben (z.B. 11=0,125°C, was bei dem von dir angegebenen event-on-change ggf. mehr Sinn machen würde; dafür dauert das Auslesen dann aber auch fast eine halbe Sekunde).Code Auswählen
resolution 9
Ausserdem bekomme ich zeitweise nur Temperaturanzeigen in 0,5 Grad Sprüngen angezeigt, obwohl event-on change auf 0,1 Grad eingestellt ist (sein soll? Habe ich das fehlerfrei übernommen?).
[/t][/t] |
ZitatHabe ich irgendwie noch nicht mitbekommen::)
Zitat von: Prof. Dr. Peter Henning am 05 Juni 2018, 07:31:39Weil es Pflicht ist ;)
Warum schreibe ich wohl eine CommandRef ?
pah
Zitat von: Thomas24568 am 04 Juni 2018, 19:48:22Wie bereits geschrieben: 9 Bit = 0.5-Grad-Schritte (1/2°), 11 Bit = 0.125-Grad (1/8°)...
#4: okay, 9 Bit ist dann wieviel Nachkommastellen?
ZitatWeil es Pflicht istNö, damit ich nach 4 Jahren immer noch weiß, was das Modul macht ;D
ZitatSorry, CommandRef auf Englisch habe ich zwar gelesen, aber auf Englisch bin ich nicht so gut, und habe nicht alles verstanden, kann mir jemand bitte dies und das übersetzen / erklären?als wenn man wegen fehlender deutscher Doku auf einem deutschen Forum meckert und die Helfer und Modulentwickler anschimpft.
Zitat von: CommandeRef auf ENGLISCHAttributesbedeutet:
attr <name> asynchronous 0(default)|1
if 1 the interface will run asynchronously;if 0 (default) then not
Zitatwenn 1, wird die Schnittstelle asynchron laufen; wenn 0 (Standard-Wert) dann nicht
ZitatUns uns Deutsche zu verarschen:
Zitat von: amenomade am 05 Juni 2018, 19:21:34Ups, überrascht mich. Oder bist du (wie ich) aus Sachsen ;-)
Deutsch ist übrigens auch nicht meine Muttersprache...
