Ist es möglich den Loadlevel vom HMLAN grafisch oder farblich anzuzeigen ?
DEF 192.168.113.9:1000
DeviceName 192.168.113.9:1000
FD 113
HMLAN1_MSGCNT 7809
HMLAN1_TIME 2018-06-10 07:44:37
IFmodel LAN
NAME HMLAN1
NR 369
NTFY_ORDER 50-HMLAN1
PARTIAL
RAWMSG E5AF3D4,0000,00CC2E40,FF,FFA2,38845E5AF3D40000008050990000000000090E01
RSSI -94
STATE opened
TYPE HMLAN
XmitOpen 1
assignedIDsCnt 9
msgKeepAlive dlyMax:4.409 bufferMin:0
msgLoadCurrent 0
msgLoadHistoryAbs 5min steps: 0/0/0/0/0/0/0/0/0/0/0/0
msgParseDly min:-91 max:7628 last:1081 cnt:7748
owner AB1357
owner_CCU VCCU
uptime 000 03:43:01.184
2018-06-09 08:57:32 D-HMIdAssigned AB1357
2018-06-09 08:57:32 D-HMIdOriginal 272D21
2018-06-09 08:57:32 D-firmware 0.964
2018-06-09 08:57:32 D-serialNr LEQ0049740
2018-06-10 04:01:53 Xmit-Events init:3 disconnected:4 ok:3
2018-06-10 04:01:53 cond ok
2018-05-19 08:07:15 hmTrfHour %
2018-06-10 07:44:24 loadLvl low
2018-06-10 03:59:46 prot_disconnected last
2018-06-10 04:01:53 prot_init last
2018-06-06 05:52:00 prot_keepAlive last
2018-06-10 04:01:53 prot_ok last
2018-06-10 04:01:53 state opened
helper:
assIdCnt 9
assIdRep 9
info 03C4,LEQ0049740,272D21,AB1357
setTime 46649
cnd:
0 3
253 4
255 3
dly:
cnt 7748
lst 1081
max 7628
min -91
ids:
4BE1E1:
cfg +4BE1E1,00,00,00
flg 0
msg
name HM_4BE1E1
to 1528528029.07881
4E46B5:
cfg +4E46B5,00,00,00
chn 08
flg 0
msg
name HM_4E46B5
to 1528527470.61849
4E46B7:
cfg +4E46B7,00,00,00
chn 00
flg 0
msg
name HM_4E46B7
to 1528527816.47094
4F95BE:
cfg +4F95BE,00,00,00
chn 01
flg 0
msg
name HM_4F95BE
to 1528583712.09114
545D4B:
cfg +545D4B,00,00,00
chn 02
flg 0
msg
name HM_545D4B
to 1528568158.48628
55F13C:
cfg +55F13C,00,00,00
name HM_55F13C
5BAC30:
cfg +5BAC30,00,00,00
chn 01
flg 0
msg
name HM_5BAC30
to 1528527925.13501
5BAC56:
cfg +5BAC56,00,00,00
chn 01
flg 0
msg
name HM_5BAC56
to 1528527927.24789
5E89AC:
cfg +5E89AC,00,00,00
chn 01
flg 0
msg
name HM_5E89AC
to 1528583713.9075
k:
BufMin 0
DlyMax 4.409
Next 1528609489.27977
Start 1528609464.27977
loadLvl:
bl 40
a:
99
90
40
0
h:
0 low
40 batchLevel
90 high
99 suspended
log:
all 1
sys 0
ids:
q:
HMcndN 0
answerPend 0
hmLanQlen 1
keepAliveRec 1
keepAliveRpt 0
loadLastMax 0
loadNo 8
scnt 2
ald:
0
0
0
0
0
0
0
0
0
0
0
0
apIDs:
ref:
drft -0.000720403425918514
hmtL 13369116
kTs 0
offL 1528596095166
sysL 1528609464282
devStateIcon opened:remotecontrol/black_btn_GREEN disconnected:remotecontrol/black_btn_RED
group CUL
hmId AB1357
hmLanQlen 1_min
loadLevel 0:low,40:batchLevel,90:high,99:suspended
logIDs all
room Z_CUL
Wendelin
