Moin liebes Forum, ich benutze das CALVIEW Modul um mir diverse Kalendereinträge darstellen zu lassen.
Ich bekomme täglich zu gleichmäßigen Uhrzeiten immer Einträge im Log, die so ausschauen:
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 185) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 186) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 187) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 188) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 189) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 190) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 191) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 192) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 193) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 194) line 1.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/57_CALVIEW.pm line 221.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value $endday in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 224.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 224.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value in numeric eq (==) at ./FHEM/57_CALVIEW.pm line 226.
2018.11.08 07:54:09 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 228.
Ich habe dann mal stacktrace angeschaltet, dabei kam dann folgendes heraus.
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386000) line 1.
2018.11.11 17:00:00 1: stacktrace:
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386000) (1)
2018.11.11 17:00:00 1: (eval) called by ./FHEM/57_Calendar.pm (588)
2018.11.11 17:00:00 1: Calendar::Event::formatted called by ./FHEM/57_Calendar.pm (2035)
2018.11.11 17:00:00 1: main::Calendar_Get called by fhem.pl (3599)
2018.11.11 17:00:00 1: main::CallFn called by ./FHEM/57_CALVIEW.pm (346)
2018.11.11 17:00:00 1: main::getsummery called by ./FHEM/57_CALVIEW.pm (92)
2018.11.11 17:00:00 1: main::CALVIEW_GetUpdate called by ./FHEM/57_CALVIEW.pm (378)
2018.11.11 17:00:00 1: main::CALVIEW_Notify called by fhem.pl (3599)
2018.11.11 17:00:00 1: main::CallFn called by fhem.pl (3519)
2018.11.11 17:00:00 1: main::DoTrigger called by fhem.pl (4570)
2018.11.11 17:00:00 1: main::readingsEndUpdate called by ./FHEM/57_Calendar.pm (3109)
2018.11.11 17:00:00 1: main::Calendar_CheckTimes called by ./FHEM/57_Calendar.pm (2601)
2018.11.11 17:00:00 1: main::Calendar_CheckAndRearm called by ./FHEM/57_Calendar.pm (2612)
2018.11.11 17:00:00 1: main::Calendar_SynchronousUpdateCalendar called by ./FHEM/57_Calendar.pm (2578)
2018.11.11 17:00:00 1: main::Calendar_ProcessUpdate called by FHEM/HttpUtils.pm (593)
2018.11.11 17:00:00 1: main::__ANON__ called by fhem.pl (723)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386001) line 1.
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386001) (1)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386002) line 1.
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386002) (1)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386003) line 1.
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386003) (1)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386004) line 1.
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386004) (1)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386005) line 1.
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386005) (1)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386006) line 1.
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386006) (1)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386007) line 1.
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386007) (1)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386008) line 1.
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386008) (1)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $d in concatenation (.) or string at (eval 1386009) line 1.
2018.11.11 17:00:00 1: main::__ANON__ called by (eval 1386009) (1)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/57_CALVIEW.pm line 221.
2018.11.11 17:00:00 1: main::__ANON__ called by ./FHEM/57_CALVIEW.pm (221)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value $endday in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 224.
2018.11.11 17:00:00 1: main::__ANON__ called by ./FHEM/57_CALVIEW.pm (224)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 224.
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value in numeric eq (==) at ./FHEM/57_CALVIEW.pm line 226.
2018.11.11 17:00:00 1: main::__ANON__ called by ./FHEM/57_CALVIEW.pm (226)
2018.11.11 17:00:00 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 228.
2018.11.11 17:00:00 1: main::__ANON__ called by ./FHEM/57_CALVIEW.pm (228)
.... gekürzt
Benötigt ihr noch weitere "list" von meinen CALVIEW Devices?
Oder muss ich mich in ein anderes Unterforum an den Dev wenden?
Falls ich hier falsch bin, bitte einmal Bescheid geben, wo der Post richtig aufgehoben ist.
FHEM ist sowieso ziemlich aktuell.
Mathze
Ich geh mal davon aus du hast Termine die nicht Regelkonform sind (kein Ende gesetzt oder keine Laufzeit). Das Thema hatten wir hier schon ein paar mal.
Wenn dies so ist Termin richtig anlegen oder mit den Meldungen leben.
Richtiges Board wäre dieses https://forum.fhem.de/index.php/board,85.0.html ;)
Moin Chris, wo kann ich denn nachlesen, wie ich meine Termine eintragen muss?
Bzw. welche Termine evtl. falsch eingetragen wurden?
Ich habe einige Termine, die ganztägig laufen bzw. wiederholende Einträge, daran kann es aber nicht liegen?
Gruß Mathze
Du kannst zb im Calendar device ein
get [kalendername] events format:full machen oder im CLAVIEW die Termine kontrollieren. Ein valider Termin hat ein Start und Enddatum, eine Start und Endzeit die bei zb ganztägig nicht 00:00:00 ist bei selben Datum, also er muss eine duration/Laufzeit haben.
https://forum.fhem.de/index.php/topic,89592.msg820543.html#msg820543
hier war das mal ein Thema. RFC 5545 ist dafür ausschlaggebend und alles was dem nicht entspricht bekommt im CALENDAR keine Sonderbehandlung und somit entstehen Folgefehler im CALVIEW.
Beide Module berücksichtigen also keine Sonderlocken. Ich werde dennoch mal schauen zumindest die Meldung weg zu bekommen
Moin Chris, so schaut einer meiner Kalender aus:
9D8BB06B190A424AB7D17275A11A467A end 15.10.2018 16:30-15.10.2018 19:45 Arbeiten A3,25o
F22F9CB4950045F58330F375B3C99BDD end 22.10.2018 16:30-22.10.2018 19:45 Arbeiten A3,25o
A1BC755E635945D3BAB2930F7F33DAEC end 23.10.2018 16:30-23.10.2018 19:45 Arbeiten A3,25o
9C1F6828EE8447A4829514007149DB73 end 25.10.2018 17:00-25.10.2018 19:00 Besprechung Hauswirtschaft
5878529BCDB74F36B2A09DB2A5C09135 end 29.10.2018 16:30-29.10.2018 19:45 Abgegeben - Arbeiten A3,25o
EF8712FEEF10410CB6E9FF50983C89A3 end 30.10.2018 16:30-30.10.2018 19:45 Arbeiten A3,25o
3D468AAD8DF348189B1CDB551F798055 end 01.11.2018 00:00-02.11.2018 00:00 Wunschfreiplan für RH machen
D4C34799B9994D168DFA2C27923544CF end 03.11.2018 16:45-03.11.2018 20:00 Arbeiten A3,25u
F9FE0B39FE594EAFB4C309A38386F9FC end 04.11.2018 16:45-04.11.2018 20:00 Arbeiten A3,25u
494186DB07834758B1CC1C3BB8219295 end 06.11.2018 16:45-06.11.2018 20:00 Arbeiten A3,25u
ED0DB0E023F74DD49CE4D16D42D453FF upcoming 17.11.2018 16:00-17.11.2018 19:30 Arbeiten A3,75o
4EE0E6EC83A742CC80EF0D6BE6F1E256 upcoming 18.11.2018 16:00-18.11.2018 19:45 Arbeiten A3,75o
74E89EF5FD704BBD91C5E99FD638F12D upcoming 23.11.2018 16:30-23.11.2018 19:30 Arbeiten A3,25o
3D468AAD8DF348189B1CDB551F798055 upcoming 01.12.2018 00:00-02.12.2018 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.01.2019 00:00-02.01.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.02.2019 00:00-02.02.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.03.2019 00:00-02.03.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.04.2019 00:00-02.04.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.05.2019 00:00-02.05.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.06.2019 00:00-02.06.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.07.2019 00:00-02.07.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.08.2019 00:00-02.08.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.09.2019 00:00-02.09.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.10.2019 00:00-02.10.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.11.2019 00:00-02.11.2019 00:00 Wunschfreiplan für RH machen
3D468AAD8DF348189B1CDB551F798055 upcoming 01.12.2019 00:00-02.12.2019 00:00 Wunschfreiplan für RH machen
D.h. er hat Probleme mit den ganzen upcoming Termine "Wunschfreiplan für RH machen", richtig?
Im CALVIEW schaut es dann wie folgt aus:
DEF iCloud_RH 1
INTERVAL 43200
KALENDER iCloud_RH
NAME view_iCloud_RH
NR 297
NTFY_ORDER 50-view_iCloud_RH
STATE t: 26 td: 0 tm: 0
TYPE CALVIEW
Helper:
DBLOG:
c-term:
myDbLog:
TIME 1541995248.54465
VALUE 26
c-today:
myDbLog:
VALUE 0
c-tomorrow:
myDbLog:
VALUE 0
state:
myDbLog:
VALUE t: 26 td: 0 tm: 0
t_014_bdate:
myDbLog:
VALUE 01.12.2018
t_014_btime:
myDbLog:
VALUE 00:00
t_014_daysleft:
myDbLog:
VALUE 19
t_014_daysleftLong:
myDbLog:
VALUE in 19 Tagen
t_014_description:
myDbLog:
TIME 1541952007.83114
VALUE Mit Marion
t_014_duration:
myDbLog:
VALUE ganztägig
t_014_edate:
myDbLog:
VALUE 02.12.2018
t_014_etime:
myDbLog:
VALUE 00:00
t_014_mode:
myDbLog:
VALUE next
t_014_source:
myDbLog:
VALUE iCloud_RH
t_014_sourcecolor:
myDbLog:
VALUE white
t_014_summary:
myDbLog:
VALUE Wunschfreiplan für RH machen
t_014_timeshort:
myDbLog:
VALUE ganztägig
t_014_weekday:
myDbLog:
VALUE 6
t_014_weekdayname:
myDbLog:
VALUE Samstag
Ich frage mich gerade, warum das Datum der 01.12.2018 ist, denn diesen Termin habe ich in meinem iCloud Kalender auf dem iPhone am 29.11.2018 als ganztägiges Ereignis. Am 01.12.2018 gibt es diesen Eintrag nicht.
Mathze
Ola, nachdem ich gerade das gleiche Problem habe (und der Thread noch nicht alt ist ;)) - kann ich den Kalender irgendwie gezielt nach Fehlern durchsuchen? Das get [kalendername] events format:full liefert mir ca. 400 Termine (und ich habe hideolderthan 1 gesetzt, ich habe leider wirklich so einen elend vollen Kalender) und das nicht gerade lesefreundlich. Da finde ich nicht wirklich was. Ich bin leider kein Perl-Fuchs, so dass ich selbst nicht weiß, wie ich das vernünftig durchsuchen kann.
doc
Das ist was für Calendar, Calview zeigt nur was das Calendar Modul aus den Kalender holt
doc
mein erster Gedanke -> txt mit der Ausgabe speichern -> exel -> Reiter Daten -> Daten in Spalte und schauen das man dann nach Enddatum/Zeit leer filtert.
Alternativ im Klenderclient deiner Wahl (Outlook kann das zb) Listenansicht und nach Ende sortieren
