Moin zusammen,
ich hab den Eindruck, dass die internen Uhren meiner Heizkörperthermostate ziemlich genau 3 Stunden falsch laufen.
Hier mal eines der Thermostate:
CFGFN /opt/fhem/conf.d/max.cfg
DEF HeatingThermostat 139934
IODev cm
LASTInputDev cm
MSGCNT 53
NAME HT_Bu
NR 311
RSSI -59.5
STATE 58
TYPE MAX
addr 139934
backend cm
cm_MSGCNT 53
cm_TIME 2018-11-19 11:12:40
dstsetting 1
mode 0
rferror 0
type HeatingThermostat
Helper:
DBLOG:
RSSI:
logdb:
TIME 1542622360.39244
VALUE -59.5
battery:
logdb:
VALUE ok
batteryState:
logdb:
VALUE ok
desiredTemperature:
logdb:
VALUE 19.0
mode:
logdb:
VALUE
state:
logdb:
VALUE 19.0
temperature:
logdb:
VALUE 19.4
valveposition:
logdb:
VALUE 53
weekProfile:
logdb:
TIME 1542622282.70466
VALUE Mon
weekprofile-0-Sat-temp:
logdb:
TIME 1542622300.5124
VALUE 18.0
weekprofile-0-Sat-time:
logdb:
VALUE 00:00-07:30
weekprofile-1-Sun-temp:
logdb:
VALUE 18.0
weekprofile-1-Sun-time:
logdb:
VALUE 00:00-07:30
weekprofile-2-Mon-temp:
logdb:
VALUE 18.0
weekprofile-2-Mon-time:
logdb:
VALUE 00:00-06:30
weekprofile-3-Tue-temp:
logdb:
VALUE 18.0
weekprofile-3-Tue-time:
logdb:
VALUE 00:00-06:30
weekprofile-4-Wed-temp:
logdb:
VALUE 18.0
weekprofile-4-Wed-time:
logdb:
VALUE 00:00-06:30
weekprofile-5-Thu-temp:
logdb:
VALUE 18.0
weekprofile-5-Thu-time:
logdb:
VALUE 00:00-06:30
weekprofile-6-Fri-temp:
logdb:
VALUE 18.0
weekprofile-6-Fri-time:
logdb:
VALUE 00:00-06:30
2018-11-19 11:12:40 RSSI -59.5
2016-03-25 08:57:49 TimeInformationHour 1
2018-11-19 11:12:40 battery ok
2018-11-19 11:12:40 batteryState ok
2016-04-04 13:58:14 boostDuration 5
2016-04-04 13:58:18 boostValveposition 100
2016-03-28 10:45:34 comfortTemperature 21
2016-04-04 13:58:14 decalcification Sat 12:00
2018-11-19 11:12:40 desiredTemperature 19.0
2018-01-16 22:29:03 ecoTemperature 14.0
2017-11-08 16:12:40 firmware 1.0
2017-11-08 16:12:40 groupid 0
2018-02-12 11:53:41 maxValveSetting 100
2016-03-28 10:45:34 maximumTemperature on
2018-02-12 20:16:35 measurementOffset -1
2016-03-28 10:45:34 minimumTemperature off
2018-11-19 11:12:40 mode auto
2018-11-19 11:11:22 msgcnt 37
2018-11-19 11:12:40 state 19.0 °C
2018-11-19 11:12:40 temperature 19.4
2017-11-08 16:12:40 testresult 160
2016-04-04 13:58:14 valveOffset 0
2018-11-19 11:12:40 valveposition 53
2018-11-19 11:11:40 weekprofile-0-Sat-temp 18.0 °C / 19.0 °C / 19.0 °C
2018-11-19 11:11:40 weekprofile-0-Sat-time 00:00-07:30 / 07:30-23:55 / 23:55-00:00
2018-11-19 11:11:40 weekprofile-1-Sun-temp 18.0 °C / 19.0 °C / 19.0 °C
2018-11-19 11:11:40 weekprofile-1-Sun-time 00:00-07:30 / 07:30-23:55 / 23:55-00:00
2018-11-19 11:11:40 weekprofile-2-Mon-temp 18.0 °C / 19.0 °C / 18.0 °C
2018-11-19 11:11:40 weekprofile-2-Mon-time 00:00-06:30 / 06:30-23:55 / 23:55-00:00
2018-11-19 11:11:40 weekprofile-3-Tue-temp 18.0 °C / 19.0 °C / 18.0 °C
2018-11-19 11:11:40 weekprofile-3-Tue-time 00:00-06:30 / 06:30-23:55 / 23:55-00:00
2018-11-19 11:11:40 weekprofile-4-Wed-temp 18.0 °C / 19.0 °C / 18.0 °C
2018-11-19 11:11:40 weekprofile-4-Wed-time 00:00-06:30 / 06:30-23:55 / 23:55-00:00
2018-11-19 11:11:40 weekprofile-5-Thu-temp 18.0 °C / 19.0 °C / 18.0 °C
2018-11-19 11:11:40 weekprofile-5-Thu-time 00:00-06:30 / 06:30-23:55 / 23:55-00:00
2018-11-19 11:11:40 weekprofile-6-Fri-temp 18.0 °C / 19.0 °C / 18.0 °C
2018-11-19 11:11:40 weekprofile-6-Fri-time 00:00-06:30 / 06:30-23:55 / 23:55-00:00
2016-03-28 10:45:34 windowOpenDuration 15
2016-03-28 10:45:34 windowOpenTemperature 12
internals:
interfaces thermostat;battery;temperature
IODev cm
alias Heizkoerper Buero
devStateIcon 0:sani_heating_level_0 \d:sani_heating_level_0 1\d:sani_heating_level_10 2\d:sani_heating_level_20 3\d:sani_heating_level_30 4\d:sani_heating_level_40 5\d:sani_heating_level_50 6\d:sani_heating_level_60 7\d:sani_heating_level_70 8\d:sani_heating_level_80 9\d:sani_heating_level_90 100:sani_heating_level_100
icon hc_wht_regler
room Office,MAX,Heizkoerper
scanTemp 1
scnProcessByDesiChange 0
scnShutterList SC_Bu
stateFormat {max(ReadingsVal("HT_Bu","valveposition",0)+5,100)}
userattr scnProcessByDesiChange scnShutterList weekprofile
weekprofile Sommer
der Temperaturgraph (siehe Anhang) zeigt deutlich, dass die Umschaltung von 18° Nachttemperatur auf 20° Tag statt um 7:30 um 4:30 geschah.
Soweit ich gelesen habe, geschieht die Übertragung der Uhrzeit automatisch einmal am Tag - zumindest bei Verwendung des original MAX Cube. Macht das Max Modul das auch über einen "normalen" CUL?
hier mal die Definition:
CFGFN /opt/fhem/conf.d/cul.cfg
CUL0_MSGCNT 557
CUL0_RAWMSG Z0F000460139A160000000018172400BD
CUL0_RSSI -84.5
CUL0_TIME 2018-11-19 11:28:21
DEF xxxxxx
IODev CUL0
LASTInputDev CUL0
MSGCNT 557
NAME cm
NR 19
STATE Defined
TYPE CUL_MAX
addr xxxxxx
cnt 0
pairmode 0
retryCount 0
Helper:
DBLOG:
packetsLost:
logdb:
TIME 1542623454.70618
VALUE 13159
2018-11-19 11:30:54 packetsLost 13159
sendQueue:
IODev CUL0
icon cul_868
room MAX
verbose 2
CMDS mBbCFiAZGMYRTVWXef*ltuxz
CUL0_MSGCNT 557
Clients :CUL_MAX:HMS:CUL_IR:STACKABLE_CC:TSSTACKED:STACKABLE:
DEF /dev/ttyS0@38400 1034
DeviceName /dev/ttyS0@38400
FD 10
FHTID 1034
NAME CUL0
NR 17
NR_CMD_LAST_H 30
PARTIAL
RAWMSG Z0F000460139A160000000018172400BDEB
RSSI -84.5
STATE Initialized
TYPE CUL
VERSION V 1.25.01 a-culfw Build: private build (unknown) CSM868 (F-Band: 868MHz)
initString X21
Zr
Zaxxxxxx
Zwyyyyyy
Helper:
DBLOG:
credit10ms:
logdb:
TIME 1542623451.65821
VALUE 1314
MatchList:
1:CUL_MAX ^Z........................
8:HMS ^810e04....(1|5|9).a001
D:CUL_IR ^I............
H:STACKABLE_CC ^\*
M:TSSTACKED ^\*
N:STACKABLE ^\*
2018-01-14 20:17:57 ccconf freq:868.300MHz bWidth:101KHz rAmpl:33dB sens:8dB
2018-11-18 15:29:37 cmds m B b C F i A Z G M Y R T V W X e f * l t u x z
2018-11-19 11:30:51 credit10ms 1314
2018-01-14 20:17:36 fhtbuf No answer
2018-01-14 20:17:36 raw No answer
2018-11-19 11:28:21 state Initialized
2016-11-08 19:31:37 uptime 0 00:09:16
2018-01-14 20:16:42 version V 1.25.01 a-culfw Build: private build (unknown) CSM868 (F-Band: 868MHz)
XMIT_TIME:
1542622282.68962
1542622289.21248
1542622290.83719
1542622292.4708
1542622294.1057
1542622295.73855
1542622297.37293
1542622299.00828
1542622300.63954
1542622302.28447
1542622303.90586
1542622305.53303
1542622307.15946
1542622308.78533
1542622310.41177
1542622312.03729
1542622313.6736
1542622315.35048
1542622316.98715
1542622318.76041
1542622320.36289
1542622321.99383
1542623409.22196
1542623415.27642
1542623422.06583
1542623428.57426
1542623432.12274
1542623438.64436
1542623445.16418
1542623451.68532
rfmode MAX
verbose 2
pj
