Hallo
ich habe von hier etwas "gestohlen" https://forum.fhem.de/index.php/topic,53500.msg472864.html#msg472864. (Danke dafür)
Nun wird die Windrichtung aber nicht angezeigt (zeigt immer nur Norden)
Nun meine Frage ob ich den Neuen "sub" richtig angelegt habe?
# Save this file as 99_myUtils.pm, and create your own functions in the new
# file. They are then available in every Perl expression.
package main;
use strict;
use warnings;
use POSIX;
use JSON;
sub
myUtils_Initialize($$)
my ($hash) = @_;
# Enter you functions below _this_ line.
sub
replaceJSON ($$) {
my ($valToReplace, $value) = @_;
$value = InternalVal("Ofen", "value", $value);
Log3 ("Ofen", 3, "replaceJSON Internalvalue: $value");
fhem ("get Ofen revision");
my $json = ReadingsVal("Ofen", "controlsJSON","");
Log3 ("Ofen", 3, "replaceJSON configsJSON: $json");
return if ($json eq "");
my $decoded = decode_json($json);
my $result;
for my $key ( keys %$decoded ) {
$result .= "$key=";
if ($key eq $valToReplace) {
$result .= $value."&";
} else {
$result .= $decoded->{$key}."&";
chop($result);
Log3("Ofen", 3, "replaceJSON Result: $result");
return $result;
sub Twilight_CompassPoint_T($) {
my ($azimuth) = @_;
my $compassPoint = "unknown";
if ($azimuth < 22.5) {
$compassPoint = "N";
} elsif ($azimuth < 45) {
$compassPoint = "N-NO";
} elsif ($azimuth < 67.5) {
$compassPoint = "NO";
} elsif ($azimuth < 90) {
$compassPoint = "O-NO";
} elsif ($azimuth < 112.5){
$compassPoint = "O";
} elsif ($azimuth < 135) {
$compassPoint = "O-SO";
} elsif ($azimuth < 157.5){
$compassPoint = "SO";
} elsif ($azimuth < 180) {
$compassPoint = "S-SO";
} elsif ($azimuth < 202.5){
$compassPoint = "S";
} elsif ($azimuth < 225) {
$compassPoint = "S-SW";
} elsif ($azimuth < 247.5){
$compassPoint = "SW";
} elsif ($azimuth < 270) {
$compassPoint = "W-SW";
} elsif ($azimuth < 292.5){
$compassPoint = "W";
} elsif ($azimuth < 315) {
$compassPoint = "W-NW";
} elsif ($azimuth < 337.5){
$compassPoint = "NW";
} elsif ($azimuth <= 361) {
$compassPoint = "N-NW";
return $compassPoint;
1;
Danke für eure Hilfe
Gruß Helmut
Hilfreich wäre noch ein List vom Device in dem die sub eingesetzt wird.
Sorry hab ich vergessen - ist ein NETATMO Windmesser
DEF MODULE 70:ee:50:36:f1:c2 06:00:00:03:1c:b0
Device 70:ee:50:36:f1:c2
IODev netatmo
LAST_POLL 2018-12-17 15:34:11
Module 06:00:00:03:1c:b0
NAME netatmo_M06_00_00_03_1c_b0
NOTIFYDEV global
NR 487
NTFY_ORDER 50-netatmo_M06_00_00_03_1c_b0
STATE Wind: 1 km/h (0 bft, N), Böen: 3 km/h (0 bft, N), Max: 11 km/h (0 bft, N)
SUBTYPE MODULE
TYPE netatmo
dataTypes WindStrength,WindAngle,GustStrength,GustAngle
firmware 19
last_message 2018-12-17 15:19:14
last_seen 2018-12-17 15:19:14
last_setup 2018-12-07 14:41:30
model NAModule2
moduleName Windmesser
openRequests 0
rf_status 73
status ok
2018-12-17 15:34:11 active ok
2018-12-17 15:23:42 batteryPercent 100
2018-12-17 15:23:42 batteryState ok
2018-12-17 15:23:42 batteryVoltage 6.115
2018-12-17 15:29:03 gustangle 115
2018-12-17 15:34:11 gustdirection N
2018-12-17 15:29:03 guststrength 3
2018-12-17 15:34:11 guststrength_bft 0
2018-12-17 15:29:03 windangle 90
2018-12-17 14:13:32 windangle_max 249
2018-12-17 15:34:11 winddirection N
2018-12-17 15:34:11 winddirection_max N
2018-12-17 15:29:03 windstrength 1
2018-12-17 15:34:11 windstrength_bft 0
2018-12-17 14:13:32 windstrength_max 11
2018-12-17 15:34:11 windstrength_max_bft 0
helper:
INTERVAL 300
NEXT_POLL 1545057551
last_status_store 1545056943
readingNames:
windstrength,windangle,guststrength,gustangle
IODev netatmo
devStateIcon .*:no-icon
interval 300
room netatmo
stateFormat Wind: windstrength km/h (windstrength_bft bft, winddirection), Böen: guststrength km/h (guststrength_bft bft, gustdirection), Max: windstrength_max km/h (windstrength_max_bft bft, winddirection_max)
userReadings guststrength_bft { int((ReadingsVal("netatmo_M06_00_00_03_1c_b0
","guststrength",0)*0.33227)**0.666666667+0.5);; },
windstrength_max_bft { int((ReadingsVal("netatmo_M06_00_00_03_1c_b0
","windstrength_max",0)*0.33227)**0.666666667+0.5);; },
windstrength_bft { int((ReadingsVal("netatmo_M06_00_00_03_1c_b0
","windstrength",0)*0.33227)**0.666666667+0.5);; },
winddirection {Twilight_CompassPoint_T(ReadingsVal("netatmo_M06_00_00_03_1c_b0
","windangle",0));; },
gustdirection {Twilight_CompassPoint_T(ReadingsVal("netatmo_M06_00_00_03_1c_b0
","gustangle",0));; },
winddirection_max {Twilight_CompassPoint_T(ReadingsVal("netatmo_M06_00_00_03_1c_b0
","windangle_max",0));; }
Hast Du wirklich jedes Mal einen Zeilenumbruch nach ReadingsVal("netatmo_M06_00_00_03_1c_b0 ?
Servus tja leider als "Nichtwissender" hat sich das beim Kopieren eingeschlichen. Werde das heute noch ändern und sehen was dann passiert.
Melde mich am späten Nachmittag wieder
Helmut
P.S. Ofen funktioniert tadellos - Danke
Servus
Danke du bist mein Retter - wieder etwas dazu gelernt.
Kaum macht man(n) es richtig funktioniert es.
Wünsche dir schöne Feiertage
Helmut
