ich habe ein Perl Warning, welche ich nicht zuordnen kann.
Über Stacktrace kommen dann folgende Meldungen:
2019.01.13 23:01:10 1: PERL WARNING: Invalid conversion in sprintf: end of string at ./FHEM/33_readingsGroup.pm line 1404.
2019.01.13 23:01:10 1: stacktrace:
2019.01.13 23:01:10 1: main::__ANON__ called by ./FHEM/33_readingsGroup.pm (1401)
2019.01.13 23:01:10 1: main::readingsGroup_Notify called by fhem.pl (3610)
2019.01.13 23:01:10 1: main::CallFn called by fhem.pl (3530)
2019.01.13 23:01:10 1: main::DoTrigger called by fhem.pl (3888)
2019.01.13 23:01:10 1: main::Dispatch called by ./FHEM/36_JeeLink.pm (865)
2019.01.13 23:01:10 1: main::JeeLink_Parse called by ./FHEM/36_JeeLink.pm (678)
2019.01.13 23:01:10 1: main::JeeLink_Read called by fhem.pl (3610)
2019.01.13 23:01:10 1: main::CallFn called by fhem.pl (727)
2019.01.13 23:01:54 1: PERL WARNING: Invalid conversion in sprintf: end of string at ./FHEM/33_readingsGroup.pm line 1404.
2019.01.13 23:01:54 1: stacktrace:
2019.01.13 23:01:54 1: main::__ANON__ called by ./FHEM/33_readingsGroup.pm (1401)
2019.01.13 23:01:54 1: main::readingsGroup_Notify called by fhem.pl (3610)
2019.01.13 23:01:54 1: main::CallFn called by fhem.pl (3530)
2019.01.13 23:01:54 1: main::DoTrigger called by fhem.pl (3888)
2019.01.13 23:01:54 1: main::Dispatch called by ./FHEM/36_JeeLink.pm (865)
2019.01.13 23:01:54 1: main::JeeLink_Parse called by ./FHEM/36_JeeLink.pm (678)
2019.01.13 23:01:54 1: main::JeeLink_Read called by fhem.pl (3610)
2019.01.13 23:01:54 1: main::CallFn called by fhem.pl (727)
2019.01.13 23:01:58 1: PERL WARNING: Invalid conversion in sprintf: end of string at ./FHEM/33_readingsGroup.pm line 1404.
2019.01.13 23:01:58 1: stacktrace:
2019.01.13 23:01:58 1: main::__ANON__ called by ./FHEM/33_readingsGroup.pm (1401)
2019.01.13 23:01:58 1: main::readingsGroup_Notify called by fhem.pl (3610)
2019.01.13 23:01:58 1: main::CallFn called by fhem.pl (3530)
2019.01.13 23:01:58 1: main::DoTrigger called by fhem.pl (3888)
2019.01.13 23:01:58 1: main::Dispatch called by ./FHEM/36_JeeLink.pm (865)
2019.01.13 23:01:58 1: main::JeeLink_Parse called by ./FHEM/36_JeeLink.pm (678)
2019.01.13 23:01:58 1: main::JeeLink_Read called by fhem.pl (3610)
2019.01.13 23:01:58 1: main::CallFn called by fhem.pl (727)
2019.01.13 23:02:03 1: PERL WARNING: Invalid conversion in sprintf: end of string at ./FHEM/33_readingsGroup.pm line 1404.
2019.01.13 23:02:03 1: stacktrace:
2019.01.13 23:02:03 1: main::__ANON__ called by ./FHEM/33_readingsGroup.pm (1401)
2019.01.13 23:02:03 1: main::readingsGroup_Notify called by fhem.pl (3610)
2019.01.13 23:02:03 1: main::CallFn called by fhem.pl (3530)
2019.01.13 23:02:03 1: main::DoTrigger called by fhem.pl (3888)
2019.01.13 23:02:03 1: main::Dispatch called by ./FHEM/36_JeeLink.pm (865)
2019.01.13 23:02:03 1: main::JeeLink_Parse called by ./FHEM/36_JeeLink.pm (678)
2019.01.13 23:02:03 1: main::JeeLink_Read called by fhem.pl (3610)
2019.01.13 23:02:03 1: main::CallFn called by fhem.pl (727)
2019.01.13 23:02:07 1: PERL WARNING: Invalid conversion in sprintf: end of string at ./FHEM/33_readingsGroup.pm line 1404.
2019.01.13 23:02:07 1: stacktrace:
2019.01.13 23:02:07 1: main::__ANON__ called by ./FHEM/33_readingsGroup.pm (1401)
2019.01.13 23:02:07 1: main::readingsGroup_Notify called by fhem.pl (3610)
2019.01.13 23:02:07 1: main::CallFn called by fhem.pl (3530)
2019.01.13 23:02:07 1: main::DoTrigger called by fhem.pl (3888)
2019.01.13 23:02:07 1: main::Dispatch called by ./FHEM/36_JeeLink.pm (865)
2019.01.13 23:02:07 1: main::JeeLink_Parse called by ./FHEM/36_JeeLink.pm (678)
2019.01.13 23:02:07 1: main::JeeLink_Read called by fhem.pl (3610)
2019.01.13 23:02:07 1: main::CallFn called by fhem.pl (727)
2019.01.13 23:02:42 1: PERL WARNING: Invalid conversion in sprintf: end of string at ./FHEM/33_readingsGroup.pm line 1404.
2019.01.13 23:02:42 1: stacktrace:
2019.01.13 23:02:42 1: main::__ANON__ called by ./FHEM/33_readingsGroup.pm (1401)
2019.01.13 23:02:42 1: main::readingsGroup_Notify called by fhem.pl (3610)
2019.01.13 23:02:42 1: main::CallFn called by fhem.pl (3530)
2019.01.13 23:02:42 1: main::DoTrigger called by fhem.pl (3888)
2019.01.13 23:02:42 1: main::Dispatch called by ./FHEM/36_JeeLink.pm (865)
2019.01.13 23:02:42 1: main::JeeLink_Parse called by ./FHEM/36_JeeLink.pm (678)
2019.01.13 23:02:42 1: main::JeeLink_Read called by fhem.pl (3610)
2019.01.13 23:02:42 1: main::CallFn called by fhem.pl (727)
Kann mir da bitte jemand helfen?
Die Meldungen machen das log so ziemlich randvoll.
Thx und bis denn
SouzA
EDIT:
Btw...
Da gibt es zwischendurch auch noch was mit nem DOIF:
2019.01.13 23:09:14 1: PERL WARNING: Redundant argument in sprintf at (eval 142870) line 1.
2019.01.13 23:09:14 1: stacktrace:
2019.01.13 23:09:14 1: main::__ANON__ called by (eval 142870) (1)
2019.01.13 23:09:14 1: (eval) called by ./FHEM/98_DOIF.pm (1075)
2019.01.13 23:09:14 1: main::EvalAllDoIf called by ./FHEM/98_DOIF.pm (1547)
2019.01.13 23:09:14 1: main::ParseCommandsDoIf called by ./FHEM/98_DOIF.pm (1991)
2019.01.13 23:09:14 1: main::DOIF_cmd called by ./FHEM/98_DOIF.pm (1996)
2019.01.13 23:09:14 1: main::DOIF_cmd called by ./FHEM/98_DOIF.pm (2250)
2019.01.13 23:09:14 1: main::DOIF_Trigger called by ./FHEM/98_DOIF.pm (2394)
2019.01.13 23:09:14 1: main::DOIF_Notify called by fhem.pl (3610)
2019.01.13 23:09:14 1: main::CallFn called by fhem.pl (3530)
2019.01.13 23:09:14 1: main::DoTrigger called by fhem.pl (4586)
2019.01.13 23:09:14 1: main::readingsEndUpdate called by ./FHEM/98_HTTPMOD.pm (2684)
2019.01.13 23:09:14 1: main::HTTPMOD_Read called by FHEM/HttpUtils.pm (606)
2019.01.13 23:09:14 1: main::__ANON__ called by fhem.pl (724)
habs gefunden.
War ein Dummy für Berechnungen (Wertvorgabe in €).
Anstatt Punkt habe ich leider ein Komma während des set verwendet. Dann hats gesponnen.
Mit Punkt ist alles wieder im Lot.
Vielen dank für eure Aufmerksamkeit.
Bis denn
SouzA
