Revision 18308: mqtt2.template: add zigbee2mqtt temp hum pressure sensor Forum: #94495 ...
mqtt2.template: add zigbee2mqtt temp hum pressure sensor Forum: #94495 #msg890157
Source: Revision 18308: mqtt2.template: add zigbee2mqtt temp hum pressure sensor Forum: #94495 ... (http://svn.fhem.de/trac/changeset/18308/trunk)
