Revision 18442: change : in 'Parse' will be '[NEXT]' as first element returned ...
change : in 'Parse' will be '[NEXT]' as first element returned (continue to call another clients)
improvement: dont forward received mqtt messages if no value changes (avoid endlos loops)
change/fix : recursive eval: allows multiple {}-Blocks
Source: Revision 18442: change : in 'Parse' will be '[NEXT]' as first element returned ... (http://svn.fhem.de/trac/changeset/18442/trunk)
