FHEM => Frontends => Sprachsteuerung => Thema gestartet von: PingPong am 20 März 2019, 10:58:41
Titel: ständige Reconnects bei alexa-fhem und gassistant
Beitrag von: PingPong am 20 März 2019, 10:58:41
ich habe seit gestern ständige reconnects im Log bzgl. alexa und gassistant.
Hier mal ein Auszug aus dem alexa log:
*** FHEM: connected
[2019-3-20 09:13:02] [FHEM] got: 5 results
[2019-3-20 09:13:02] [FHEM] Gartenbeleuchtung is light
[2019-3-20 09:13:02] [FHEM] Gartenbeleuchtung has
[2019-3-20 09:13:02] [FHEM]   On [onoff;on,off]
[2019-3-20 09:13:02] [FHEM]   Brightness [bri]
[2019-3-20 09:13:02] [FHEM] Kugellampen is light
[2019-3-20 09:13:02] [FHEM] Kugellampen has
[2019-3-20 09:13:02] [FHEM] SchlafzimmerLampen is light
[2019-3-20 09:13:02] [FHEM] SchlafzimmerLampen has
[2019-3-20 09:13:02] [FHEM]   On [state;on,off]
  2019-03-20 09:13:02 caching: SchlafzimmerLampen-state: off
[2019-3-20 09:13:02] [FHEM] aussen_alle is light
[2019-3-20 09:13:02] [FHEM] aussen_alle has
[2019-3-20 09:13:02] [FHEM]   Hue [hue;hue;0-65535]
[2019-3-20 09:13:02] [FHEM]   Saturation [sat;sat;0-254]
[2019-3-20 09:13:02] [FHEM]   Custom Color Temperature [ct]
[2019-3-20 09:13:02] [FHEM] aussen_alle-ct not a number: undefined
[2019-3-20 09:13:02] [FHEM] ku.Staubsauger_dummy is switch
[2019-3-20 09:13:02] [FHEM] ku.Staubsauger_dummy has
  2019-03-20 09:13:02 caching: ku.Staubsauger_dummy-state: off
[2019-3-20 09:13:02] [FHEM] alexa device is alexa
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] Server listening on: http://127.0.0.1:38505 for proxy connections
[2019-3-20 09:13:02] *** SSH: checking proxy configuration
[2019-3-20 09:13:02] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2019-3-20 09:13:02] Passed config: {"connections":[{"port":"8083","name":"FHEM","uid":999,"webname":"fhem","server":"127.0.0.1","filter":"room=30_Sprachassistent->01_Alexa"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":38505}}
[2019-3-20 09:13:02] sshautoconf: SSH key seems to exist
[2019-3-20 09:13:02] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] BearerToken '...89F02' read from alexa
[2019-3-20 09:13:02] [FHEM] got .eventToken
[2019-3-20 09:13:02] refreshing token
[2019-3-20 09:13:02] 39_alexa.pm is new version: true
[2019-3-20 09:13:02] sshautoconf: completed successfully
[2019-3-20 09:13:02] *** SSH: proxy configuration set up done
[2019-3-20 09:13:02] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2019-3-20 09:13:02] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] Starting SSH with -R 1234:127.0.0.1:38505 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2019-3-20 09:13:02] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2019-3-20 09:13:03] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2019-3-20 09:13:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:03] *** SSH: proxy connection established
[2019-3-20 09:13:03] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2019-3-20 09:14:01] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:14:01] [FHEM] trying longpoll to listen for fhem events
[2019-3-20 09:14:01] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069641904
[2019-3-20 09:14:03] [FHEM] got csrfToken: csrf_927594780954401
[2019-3-20 09:14:03] [FHEM] Checking devices and attributes...
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20TYPE%3Dalexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM] waiting for events ...
[2019-3-20 09:14:03] [FHEM] Fetching FHEM devices...
[2019-3-20 09:14:03] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E01_Alexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM] alexa device is alexa
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] Server emitted error: {"errno":"EADDRINUSE","code":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":38505}
[2019-3-20 09:14:03] Terminating - starting the listener not possible (another instance running?)
[2019-3-20 09:14:04] using config from ./alexa-fhem.cfg
*** CONFIG: parsed completely
[2019-3-20 09:14:04] os.homedir()=/opt/fhem
[2019-3-20 09:14:04] this is alexa-fhem 0.5.24
[2019-3-20 09:14:04] connecting to FHEM ...
[2019-3-20 09:14:05] [FHEM] trying longpoll to listen for fhem events
[2019-3-20 09:14:05] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069645215
[2019-3-20 09:14:05] [FHEM] got csrfToken: csrf_927594780954401
[2019-3-20 09:14:05] [FHEM] Checking devices and attributes...
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM] waiting for events ...
[2019-3-20 09:14:05] [FHEM] Fetching FHEM devices...
[2019-3-20 09:14:05] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E01_Alexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM] alexa device is alexa
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:05] Server listening on: http://127.0.0.1:35507 for proxy connections
[2019-3-20 09:14:05] *** SSH: checking proxy configuration
[2019-3-20 09:14:05] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2019-3-20 09:14:05] Passed config: {"connections":[{"port":"8083","name":"FHEM","uid":999,"webname":"fhem","server":"127.0.0.1","filter":"room=30_Sprachassistent->01_Alexa"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":35507}}
[2019-3-20 09:14:05] sshautoconf: SSH key seems to exist
[2019-3-20 09:14:06] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2019-3-20 09:14:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
*** FHEM: connected
[2019-3-20 09:14:06] [FHEM] got: 5 results
[2019-3-20 09:14:06] [FHEM] Gartenbeleuchtung is light
[2019-3-20 09:14:06] [FHEM] Gartenbeleuchtung has
[2019-3-20 09:14:06] [FHEM]   On [onoff;on,off]
[2019-3-20 09:14:06] [FHEM]   Brightness [bri]
[2019-3-20 09:14:06] [FHEM] Kugellampen is light
[2019-3-20 09:14:06] [FHEM] Kugellampen has
[2019-3-20 09:14:06] [FHEM] SchlafzimmerLampen is light
[2019-3-20 09:14:06] [FHEM] SchlafzimmerLampen has
[2019-3-20 09:14:06] [FHEM]   On [state;on,off]
  2019-03-20 09:14:06 caching: SchlafzimmerLampen-state: off
[2019-3-20 09:14:06] [FHEM] aussen_alle is light
[2019-3-20 09:14:06] [FHEM] aussen_alle has
[2019-3-20 09:14:06] [FHEM]   Hue [hue;hue;0-65535]
[2019-3-20 09:14:06] [FHEM]   Saturation [sat;sat;0-254]
[2019-3-20 09:14:06] [FHEM]   Custom Color Temperature [ct]
[2019-3-20 09:14:06] [FHEM] aussen_alle-ct not a number: undefined
[2019-3-20 09:14:06] [FHEM] ku.Staubsauger_dummy is switch
[2019-3-20 09:14:06] [FHEM] ku.Staubsauger_dummy has
  2019-03-20 09:14:06 caching: ku.Staubsauger_dummy-state: off
[2019-3-20 09:14:06] [FHEM] got .eventToken
[2019-3-20 09:14:06] refreshing token
[2019-3-20 09:14:06] BearerToken '...89F02' read from alexa
[2019-3-20 09:14:06] 39_alexa.pm is new version: true
[2019-3-20 09:14:06] sshautoconf: completed successfully
[2019-3-20 09:14:06] *** SSH: proxy configuration set up done
[2019-3-20 09:14:06] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2019-3-20 09:14:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:06] Starting SSH with -R 1234:127.0.0.1:35507 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2019-3-20 09:14:06] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2019-3-20 09:14:06] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2019-3-20 09:14:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:06] *** SSH: proxy connection established
[2019-3-20 09:14:06] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2019-3-20 09:15:05] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:15:05] [FHEM] trying longpoll to listen for fhem events
[2019-3-20 09:15:05] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069705415
[2019-3-20 09:15:06] [FHEM] got csrfToken: csrf_927594780954401
[2019-3-20 09:15:06] [FHEM] Checking devices and attributes...
[2019-3-20 09:15:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20TYPE%3Dalexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:06] [FHEM] waiting for events ...
[2019-3-20 09:15:06] [FHEM] Fetching FHEM devices...
[2019-3-20 09:15:06] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E01_Alexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:07] [FHEM] alexa device is alexa
[2019-3-20 09:15:07] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:07] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:07] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:07] Server emitted error: {"errno":"EADDRINUSE","code":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":35507}
[2019-3-20 09:15:07] Terminating - starting the listener not possible (another instance running?)
[2019-3-20 09:15:07] using config from ./alexa-fhem.cfg
[2019-3-20 09:15:07] os.homedir()=/opt/fhem
[2019-3-20 09:15:07] this is alexa-fhem 0.5.24
[2019-3-20 09:15:07] connecting to FHEM ...
[2019-3-20 09:15:08] [FHEM] trying longpoll to listen for fhem events
[2019-3-20 09:15:08] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069708574
[2019-3-20 09:15:08] [FHEM] got csrfToken: csrf_927594780954401
[2019-3-20 09:15:08] [FHEM] Checking devices and attributes...
[2019-3-20 09:15:08] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:08] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:08] [FHEM] waiting for events ...
[2019-3-20 09:15:08] [FHEM] Fetching FHEM devices...
[2019-3-20 09:15:08] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E01_Alexa&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] [FHEM] alexa device is alexa
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] Server listening on: http://127.0.0.1:41705 for proxy connections
[2019-3-20 09:15:09] *** SSH: checking proxy configuration
[2019-3-20 09:15:09] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2019-3-20 09:15:09] Passed config: {"connections":[{"port":"8083","name":"FHEM","uid":999,"webname":"fhem","server":"127.0.0.1","filter":"room=30_Sprachassistent->01_Alexa"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":41705}}
[2019-3-20 09:15:09] sshautoconf: SSH key seems to exist
[2019-3-20 09:15:09] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
*** FHEM: connected
[2019-3-20 09:15:09] [FHEM] got: 5 results
[2019-3-20 09:15:09] [FHEM] Gartenbeleuchtung is light
[2019-3-20 09:15:09] [FHEM] Gartenbeleuchtung has
[2019-3-20 09:15:09] [FHEM]   On [onoff;on,off]
[2019-3-20 09:15:09] [FHEM]   Brightness [bri]
[2019-3-20 09:15:09] [FHEM] Kugellampen is light
[2019-3-20 09:15:09] [FHEM] Kugellampen has
[2019-3-20 09:15:09] [FHEM] SchlafzimmerLampen is light
[2019-3-20 09:15:09] [FHEM] SchlafzimmerLampen has
[2019-3-20 09:15:09] [FHEM]   On [state;on,off]
  2019-03-20 09:15:09 caching: SchlafzimmerLampen-state: off
[2019-3-20 09:15:09] [FHEM] aussen_alle is light
[2019-3-20 09:15:09] [FHEM] aussen_alle has
[2019-3-20 09:15:09] [FHEM]   Hue [hue;hue;0-65535]
[2019-3-20 09:15:09] [FHEM]   Saturation [sat;sat;0-254]
[2019-3-20 09:15:09] [FHEM]   Custom Color Temperature [ct]
[2019-3-20 09:15:09] [FHEM] aussen_alle-ct not a number: undefined
[2019-3-20 09:15:09] [FHEM] ku.Staubsauger_dummy is switch
[2019-3-20 09:15:09] [FHEM] ku.Staubsauger_dummy has
  2019-03-20 09:15:09 caching: ku.Staubsauger_dummy-state: off
[2019-3-20 09:15:09] BearerToken '...89F02' read from alexa
[2019-3-20 09:15:09] [FHEM] got .eventToken
[2019-3-20 09:15:09] refreshing token
[2019-3-20 09:15:09] 39_alexa.pm is new version: true
[2019-3-20 09:15:09] sshautoconf: completed successfully
[2019-3-20 09:15:09] *** SSH: proxy configuration set up done
[2019-3-20 09:15:09] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2019-3-20 09:15:09] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:09] Starting SSH with -R 1234:127.0.0.1:41705 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2019-3-20 09:15:10] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2019-3-20 09:15:10] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:15:10] *** SSH: proxy connection established
[2019-3-20 09:15:10] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2019-3-20 09:15:10] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2019-3-20 09:16:05] Got SIGTERM, shutting down alexa-fhem...
[2019-3-20 09:16:05] Reading alexaFHEM.ProxyConnection set to stopping;; alexa-fhem terminating
[2019-3-20 09:16:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopping%3B%3B%20alexa-fhem%20terminating%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:16:05] Stopping SSH ...
[2019-3-20 09:16:05] Reading alexaFHEM.ProxyConnection set to stopped
[2019-3-20 09:16:05] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopped%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:16:05] *** SSH: exited with 143
und ein Auszug aus dem gassitant log:
[2019-3-20 09:09:40] ---
[2019-3-20 09:09:40] Google Assistant FHEM Connect 1.3.0 started
[2019-3-20 09:09:40] Fetching FHEM connections...
[2019-3-20 09:09:40] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069380808
  executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dgassistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:01] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-version%201.3.0&fwcsrf=csrf_927594780954401&XHR=1
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3Dg2Hy0t8LiEZW9xXERS8V0GZixyMMc2YS3D-xD-IvHgM%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:01] [FHEM] Get refresh token...
  executing: http://127.0.0.1:8083/fhem?cmd=get%20gassistant%20refreshToken&fwcsrf=csrf_927594780954401&XHR=1
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:03] [FHEM] Found refresh token in reading
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-versionAvailable%201.3.0&fwcsrf=csrf_927594780954401&XHR=1
Refresh tokens finished. Next refresh in 86400 seconds.
[2019-3-20 09:10:05] [FHEM] refreshAllTokens executed
[2019-3-20 09:10:05] [FHEM] Fetching FHEM devices...
[2019-3-20 09:10:05] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:06] [FHEM] start connection executed
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20none&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:06] [FHEM] Checking devices and attributes...
(node:9020) DeprecationWarning: grpc.load: Use the @grpc/proto-loader module with grpc.loadPackageDefinition instead
DynamicFunctions updated
[2019-3-20 09:10:07] [FHEM] got: 1 results
[2019-3-20 09:10:07] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
SERVER FeatureLevel:{"featurelevel":2,"changelog":"implement Google Report State"}
SYNC   FeatureLevel:{"featurelevel":0}
>>> VERSION UPGRADE STARTED
[2019-3-20 09:10:07] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:10:07] [FHEM] Fetching FHEM devices...
[2019-3-20 09:10:07] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_927594780954401&XHR=1
update reading: HUEDevice19:colormode = ct
update reading: HUEDevice19:ct = 250 (4000K)
update reading: HUEDevice19:hue = 0
update reading: HUEDevice19:onoff = 0
update reading: HUEDevice19:pct = 0
update reading: HUEDevice19:reachable = 1
update reading: HUEDevice19:rgb = ffe4ce
update reading: HUEDevice19:sat = 0
>>> VERSION UPGRADE FINISHED - SYNC INITIATED
reportstateall initiated
[2019-3-20 09:10:49] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:10:50] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069450008
[2019-3-20 09:10:52] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3DrwHIgrtqwZ_rWPF8myC6-som9oiojJXgaij2WK4m6Ng%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:52] [FHEM] Get refresh token...
[2019-3-20 09:10:52] [FHEM] Found refresh token in reading
[2019-3-20 09:10:54] [FHEM] refreshAllTokens executed
[2019-3-20 09:10:54] [FHEM] Fetching FHEM devices...
[2019-3-20 09:10:54] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:54] [FHEM] start connection executed
[2019-3-20 09:10:54] [FHEM] Checking devices and attributes...
[2019-3-20 09:10:54] [FHEM] got: 1 results
[2019-3-20 09:10:54] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[2019-3-20 09:10:55] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:10:55] [FHEM] Fetching FHEM devices...
[2019-3-20 09:10:55] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:10:55] [FHEM] got: 1 results
[2019-3-20 09:11:53] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:11:53] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069513939
[2019-3-20 09:11:55] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3D1DbdpgUgkAMCttVZl27MSVhxvCcBR-FM-BlYYvQgr5E%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:11:55] [FHEM] Get refresh token...
[2019-3-20 09:11:56] [FHEM] Found refresh token in reading
[2019-3-20 09:11:58] [FHEM] refreshAllTokens executed
[2019-3-20 09:11:58] [FHEM] Fetching FHEM devices...
[2019-3-20 09:11:58] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:11:58] [FHEM] start connection executed
[2019-3-20 09:11:58] [FHEM] Checking devices and attributes...
[2019-3-20 09:11:58] [FHEM] got: 1 results
[2019-3-20 09:11:59] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[2019-3-20 09:11:59] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:11:59] [FHEM] Fetching FHEM devices...
[2019-3-20 09:11:59] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:11:59] [FHEM] got: 1 results
[2019-3-20 09:12:57] [FHEM] longpoll ended, reconnect in: 200msec
[2019-3-20 09:12:57] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069577892
[2019-3-20 09:13:00] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3Dv8GH1Wd5yJajSYgogsaSq7zYWt6m85IJo0KPFUTHkH4%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:00] [FHEM] Get refresh token...
[2019-3-20 09:13:00] [FHEM] Found refresh token in reading
[2019-3-20 09:13:02] [FHEM] refreshAllTokens executed
[2019-3-20 09:13:02] [FHEM] Fetching FHEM devices...
[2019-3-20 09:13:02] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:02] [FHEM] start connection executed
[2019-3-20 09:13:02] [FHEM] Checking devices and attributes...
[2019-3-20 09:13:02] [FHEM] got: 1 results
[2019-3-20 09:13:03] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[2019-3-20 09:13:03] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:13:03] [FHEM] Fetching FHEM devices...
[2019-3-20 09:13:03] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:13:03] [FHEM] got: 1 results
[2019-3-20 09:14:01] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553069641895
[2019-3-20 09:14:03] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3DBb2EyP8rMVcgEH7X_Y7JFH9ShKy2We4J60MoLL-HtB8%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:03] [FHEM] Get refresh token...
[2019-3-20 09:14:03] [FHEM] Found refresh token in reading
[2019-3-20 09:14:05] [FHEM] refreshAllTokens executed
[2019-3-20 09:14:06] [FHEM] Fetching FHEM devices...
[2019-3-20 09:14:06] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:06] [FHEM] start connection executed
[2019-3-20 09:14:06] [FHEM] Checking devices and attributes...
[2019-3-20 09:14:06] [FHEM] got: 1 results
[2019-3-20 09:14:07] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[2019-3-20 09:14:07] [FHEM] reloading http://127.0.0.1:8083/fhem
[2019-3-20 09:14:07] [FHEM] Fetching FHEM devices...
[2019-3-20 09:14:07] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_927594780954401&XHR=1
[2019-3-20 09:14:07] [FHEM] got: 1 results
[2019-3-20 09:14:43] Got SIGTERM, shutting down...
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20disconnected&fwcsrf=csrf_927594780954401&XHR=1
Hat einer von Euch Idee, woran das liegen könnte?
VieleN Dank
Marc
Titel: Antw:ständige Reconnects bei alexa-fhem und gassistant
Beitrag von: PingPong am 22 März 2019, 09:57:38
kann ich vielleicht noch zusätzliche Informationen beisteuern?
Bin ich wirklich der einzige, mit dem Problem?
Beitrag von: SouzA am 23 März 2019, 03:46:43
Ich nutze nur Google, habe aber keine reconnects.
Könnte es sein, dass deine Internetleitung nicht stabil ist?
Mal ins log des Routers geschaut?
Hast du eine Automatik laufen, die Module oä updaten soll?
Bis denn
SouzA
Beitrag von: PingPong am 23 März 2019, 06:23:25
Hi, danke für Deine Antwort.
Ja, ins Routerlog habe ich geschaut, da sind keine Auffälligkeiten - keine Anzeichen für ein Problem.
An was für eine Automatik denkst Du? Bewusst habe ich in der Art nichts laufen.
Beitrag von: justme1968 am 23 März 2019, 14:51:23
was ist das für ein system?
setz mal verbose 4 für fhemweb. was sieht du dort im log wenn die verbindung beendet wird?
Beitrag von: PingPong am 23 März 2019, 21:38:50
was meinst Du mit "Was ist das für ein System?"
Hier das Log:
2019.03.23 21:31:41 4: Connection accepted from WEB_127.0.0.1_55200
2019.03.23 21:31:41 4: WEB_127.0.0.1_55200 GET /fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:41 4: WEB: /fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_166221922029187&XHR=1 / RL:274 / text/plain; charset=UTF-8 / Content-Encoding: gzip
/ Cache-Control: no-cache, no-store, must-revalidate
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55196: EOF
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55198: EOF
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55200: EOF
2019.03.23 21:31:41 4: Connection accepted from WEB_127.0.0.1_55218
2019.03.23 21:31:41 4: WEB_127.0.0.1_55218 GET /fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:41 4: WEB: /fhem?cmd=jsonlist2%20room=30_Sprachassistent-%3E03_GoogleAssistant&fwcsrf=csrf_166221922029187&XHR=1 / RL:1673 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55218: EOF
2019.03.23 21:31:41 4: Connection accepted from WEB_127.0.0.1_55224
2019.03.23 21:31:41 4: WEB_127.0.0.1_55224 GET /fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:41 4: WEB: /fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_166221922029187&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.23 21:31:41 4: Connection closed for WEB_127.0.0.1_55224: EOF
2019.03.23 21:31:42 4: Connection accepted from WEB_127.0.0.1_55264
2019.03.23 21:31:42 4: WEB_127.0.0.1_55264 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:42 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_166221922029187&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.23 21:31:42 4: Connection closed for WEB_127.0.0.1_55264: EOF
2019.03.23 21:31:42 4: Connection accepted from WEB_127.0.0.1_55272
2019.03.23 21:31:42 4: WEB_127.0.0.1_55272 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=csrf_166221922029187&XHR=1; BUFLEN:0
2019.03.23 21:31:42 4: Connection closed for WEB_127.0.0.1_55272: EOF
2019.03.23 21:31:43 4: WEB_192.168.178.35_52697 GET /fhem/FileLog_logWrapper&dev=gassistantFHEMlog&type=text&file=gassistant-2019-03-23.log; BUFLEN:0
2019.03.23 21:31:43 4: Connection closed for WEB_192.168.178.35_52723: EOF
2019.03.23 21:31:44 4: Connection accepted from WEB_192.168.178.35_52724
2019.03.23 21:31:50 4: Connection closed for WEB_192.168.178.35_52712: EOF
2019.03.23 21:31:50 4: Connection closed for WEB_192.168.178.35_52713: EOF
2019.03.23 21:31:50 4: Connection closed for WEB_192.168.178.35_52715: EOF
2019.03.23 21:31:50 4: Connection closed for WEB_192.168.178.35_52714: EOF
2019.03.23 21:32:09 4: WEB_192.168.178.35_52697 GET /fhem/FileLog_logWrapper&dev=gassistantFHEMlog&type=text&file=gassistant-2019-03-23.log; BUFLEN:0
2019.03.23 21:32:09 4: Connection closed for WEB_192.168.178.35_52724: EOF
2019.03.23 21:32:11 4: Connection accepted from WEB_192.168.178.35_52725
2019.03.23 21:32:20 4: Connection closed for WEB_192.168.178.35_52711: EOF
2019.03.23 21:32:20 4: WEB_192.168.178.35_52697 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
Beitrag von: amenomade am 23 März 2019, 22:03:08
Zitat[2019-3-20 09:15:07] Server emitted error: {"errno":"EADDRINUSE","code":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":35507}
Das ist m.M.n. nicht normal. Was lauscht schon auf dem port 35507 ? Hast Du noch ne alte alexa-fhem Installation als Dienst?
Beitrag von: PingPong am 23 März 2019, 22:07:11
Nein, eigentlich nicht.
Habe FHEM komplett neu aufgesetzt. Da können eigentlich keine alten Reste sein.
Beitrag von: dominik am 23 März 2019, 22:09:27
Guter Punkt, im Log betrifft es nicht nur den Port 35507, sondern auch ein anderer Port 38505 wird ebenfalls als belegt gemeldet.
Kann es sein, dass du irgendwelche extra Sicherheitseinstellungen nutzt die die Ports blockieren?
Beitrag von: PingPong am 23 März 2019, 22:11:23
Auch da nicht wissentlich.
Habe mMn keine besonderen Einstellungen vorgenommen.
Du meinst jetzt schon in fhem oder?
Beitrag von: amenomade am 23 März 2019, 22:13:13
Was sagt :
sudo netstat -lntp |grep 35507
sudo netstat -lntp |grep 38505
Beitrag von: PingPong am 23 März 2019, 22:28:08
beim dem Befehl kommt leider kein Ergebnis als Antwort. Der Cursor springt direkt wieder in die Eingabezeile.
Muss ich hier vorher etwas installieren? Oder wird das Ergebnis irgendwo weggeschrieben?
Beitrag von: dominik am 23 März 2019, 22:29:36
Nein, nicht FHEM, sondern die Linux Installation. Was nutzt du? Raspbian stretch?
Beitrag von: PingPong am 23 März 2019, 22:34:57
Habe mein System auf Basis über die Installation Homematic All-In-One Images von der io-broker Seite aufgesetzt.
Grundlage dürfte gem. Doku ein Raspbian light Stretch sein.
Beitrag von: dominik am 23 März 2019, 22:42:57
Mach mal ein komplett sauberes Raspbian stretch. Die Installation von NOOBS kann ich auch empfehlen, geht schneller und viele Sachen werden gleich bei der Installation abgefragt und richtig gesetzt.
Beitrag von: PingPong am 23 März 2019, 22:47:16
Oh... Schon wieder neu aufsetzen? :-(
Naja, was soll's... Was muss das muss....
Hauptsache es läuft irgendwann mal wieder :-(
Das tue ich mir dann in den nächsten Tagen an.
Ich danke Euch für Eure Hilfe.
Beitrag von: PingPong am 26 März 2019, 21:28:32
So, da bin ich wieder  :'(
Habe mein System jetzt komplett neu aufgesetzt (2018-11-13-raspbian-stretch-lite).
Kurz vor Ende ist wieder das bekannte Problem aufgetaucht.
Hier ein Auszug aus dem Log:
2019.03.26 21:09:51 0: Server started with 373 defined entities (fhem.pl:19006/2019-03-23 perl:5.024001 os:linux user:fhem pid:419)
diff: /opt/fhem/FHEM/controls_fhemtabletui.txt: No such file or directory
2019.03.26 21:19:40 4: WEB: /fhem?cmd.attrWEB%3Dattr%20WEB%20verbose%204&XHR=1&fwcsrf=myhcconnToken&fw_id=612 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:19:40 4: WEB_192.168.178.35_64018 GET /fhem?detail=WEB&fw_id=612; BUFLEN:0
2019.03.26 21:19:40 4: WEB: /fhem?detail=WEB&fw_id=612 / RL:7849 / text/html; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:19:40 4: Connection closed for WEB_192.168.178.35_64021: EOF
2019.03.26 21:19:40 4: WEB_192.168.178.35_64018 GET /fhem?cmd=%7BReadingsVal(%22WEB%22%2C%22clearSvgCache%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:19:40 4: WEB: /fhem?cmd=%7BReadingsVal(%22WEB%22%2C%22clearSvgCache%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:19:40 4: WEB_192.168.178.35_64020 GET /fhem?cmd=%7BAttrVal(%22WEB%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:19:40 4: WEB: /fhem?cmd=%7BAttrVal(%22WEB%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:39 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:19:40 4: Connection accepted from WEB_192.168.178.35_64022
2019.03.26 21:19:42 4: WEB_192.168.178.35_64018 POST /fhem?cmd=save&XHR=1&fwcsrf=myhcconnToken&fw_id=612; BUFLEN:0
2019.03.26 21:19:42 4: WEB: /fhem?cmd=save&XHR=1&fwcsrf=myhcconnToken&fw_id=612 / RL:52 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:19:56 4: WEB_192.168.178.35_64018 GET /fhem?cmd=shutdown+restart&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:19:56 0: Server shutdown
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_709001145135012J
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_7094180852420ECD
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_G090L90964971MNW
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_G090L909652213DM
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_G090L91174360B4F
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_G000N607811408W6
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_G0W0H404702601MU
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_G090U507837219KA
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_G090U50984760F20
2019.03.26 21:20:05 0: [echodevice] load ECHO Device ECHO_b66462925fe542989162a67a72490d2e
2019.03.26 21:20:24 0: Featurelevel: 5.9
2019.03.26 21:20:24 0: Server started with 373 defined entities (fhem.pl:19006/2019-03-23 perl:5.024001 os:linux user:fhem pid:1113)
2019.03.26 21:20:33 4: Connection accepted from WEB_192.168.178.35_64026
2019.03.26 21:20:35 4: WEB_192.168.178.35_64026 GET /; BUFLEN:0
2019.03.26 21:20:35 4: WEB: redirecting / to /fhem
2019.03.26 21:20:35 4: Connection accepted from WEB_192.168.178.83_50769
2019.03.26 21:20:35 4: WEB_192.168.178.35_64026 GET /fhem; BUFLEN:0
2019.03.26 21:20:35 4: WEB: /fhem / RL:4202 / text/html; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:36 4: Connection accepted from WEB_192.168.178.83_50778
2019.03.26 21:20:37 4: Connection accepted from WEB_127.0.0.1_46432
2019.03.26 21:20:38 4: WEB_192.168.178.35_64026 GET /fhem/pgm2/style.css?v=1553631599; BUFLEN:0
2019.03.26 21:20:38 4: WEB_127.0.0.1_46432 GET /fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553631627983; BUFLEN:0
2019.03.26 21:20:38 4: Connection accepted from WEB_127.0.0.1_46434
2019.03.26 21:20:38 4: WEB_127.0.0.1_46434 GET /fhem?XHR=1; BUFLEN:0
2019.03.26 21:20:38 4: WEB: /fhem?XHR=1 / RL:0 / text/plain; charset=UTF-8 /  / Cache-Control: no-cache, no-store, must-revalidate
2019.03.26 21:20:38 4: Connection accepted from WEB_127.0.0.1_46438
2019.03.26 21:20:39 4: Connection accepted from WEB_192.168.178.35_64028
2019.03.26 21:20:39 4: WEB_127.0.0.1_46438 GET /fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553631628675; BUFLEN:0
2019.03.26 21:20:41 4: Connection closed for WEB_127.0.0.1_46434: EOF
2019.03.26 21:20:41 4: Connection accepted from WEB_127.0.0.1_46646
2019.03.26 21:20:41 4: WEB_127.0.0.1_46646 GET /fhem?cmd=%7BAttrVal(%22global%22,%22userattr%22,%22%22)%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:41 4: WEB: /fhem?cmd=%7BAttrVal(%22global%22,%22userattr%22,%22%22)%7D&fwcsrf=myhcconnToken&XHR=1 / RL:306 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:41 4: Connection accepted from WEB_127.0.0.1_46648
2019.03.26 21:20:41 4: WEB_127.0.0.1_46648 GET /fhem?cmd=jsonlist2%20TYPE=alexa&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:41 4: WEB: /fhem?cmd=jsonlist2%20TYPE=alexa&fwcsrf=myhcconnToken&XHR=1 / RL:1717 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.26 21:20:42 4: Connection accepted from WEB_127.0.0.1_46650
2019.03.26 21:20:42 4: Connection accepted from WEB_127.0.0.1_46660
2019.03.26 21:20:42 4: Connection closed for WEB_127.0.0.1_46646: EOF
2019.03.26 21:20:42 4: WEB_127.0.0.1_46650 GET /fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:42 4: WEB: /fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=myhcconnToken&XHR=1 / RL:4461 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.26 21:20:42 4: WEB_127.0.0.1_46660 GET /fhem?cmd=jsonlist2%20TYPE%3Dgassistant&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:42 4: WEB: /fhem?cmd=jsonlist2%20TYPE%3Dgassistant&fwcsrf=myhcconnToken&XHR=1 / RL:1263 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.26 21:20:42 4: Connection accepted from WEB_127.0.0.1_46670
2019.03.26 21:20:42 4: Connection closed for WEB_127.0.0.1_46648: EOF
2019.03.26 21:20:42 4: WEB_127.0.0.1_46670 GET /fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:42 4: WEB: /fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=myhcconnToken&XHR=1 / RL:3949 / application/json; charset=utf-8 /  / Cache-Control: no-cache, no-store, must-revalidate
2019.03.26 21:20:42 4: Connection closed for WEB_127.0.0.1_46650: EOF
2019.03.26 21:20:43 4: Connection accepted from WEB_127.0.0.1_46696
2019.03.26 21:20:43 4: WEB_127.0.0.1_46696 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;%7B$defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20=%20%220.5.7%22%7D;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:43 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;%7B$defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20=%20%220.5.7%22%7D;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:26 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:43 4: Connection accepted from WEB_127.0.0.1_46698
2019.03.26 21:20:43 4: Connection closed for WEB_127.0.0.1_46660: EOF
2019.03.26 21:20:43 4: Connection closed for WEB_127.0.0.1_46670: EOF
2019.03.26 21:20:43 4: WEB_127.0.0.1_46698 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;get%20alexa%20proxyToken;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:43 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;get%20alexa%20proxyToken;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:37 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:43 4: Connection accepted from WEB_127.0.0.1_46700
2019.03.26 21:20:43 4: Connection closed for WEB_127.0.0.1_46696: EOF
2019.03.26 21:20:43 4: WEB_127.0.0.1_46700 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;list%20alexa%20.eventToken;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:43 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;list%20alexa%20.eventToken;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:671 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:43 4: Connection accepted from WEB_127.0.0.1_46718
2019.03.26 21:20:43 4: Connection closed for WEB_127.0.0.1_46698: EOF
2019.03.26 21:20:43 4: WEB_127.0.0.1_46718 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-version%201.3.0&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:43 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-version%201.3.0&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:44 4: Connection accepted from WEB_127.0.0.1_46720
2019.03.26 21:20:44 4: Connection closed for WEB_127.0.0.1_46700: EOF
2019.03.26 21:20:44 4: Connection accepted from WEB_127.0.0.1_46722
2019.03.26 21:20:44 4: WEB_127.0.0.1_46720 GET /fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3DNOaBGhnSOEnzdXgOA997Tf9M70KIbMvi68l355OCeXE%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:44 4: WEB: /fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3DNOaBGhnSOEnzdXgOA997Tf9M70KIbMvi68l355OCeXE%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:45 4: WEB_127.0.0.1_46722 GET /fhem?cmd=get%20gassistant%20refreshToken&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:45 4: WEB: /fhem?cmd=get%20gassistant%20refreshToken&fwcsrf=myhcconnToken&XHR=1 / RL:66 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:45 4: Connection accepted from WEB_127.0.0.1_46728
2019.03.26 21:20:46 4: Connection closed for WEB_127.0.0.1_46718: EOF
2019.03.26 21:20:46 4: WEB_127.0.0.1_46728 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;setreading%20alexa%20alexaFHEM.ProxyConnection%20starting,%20starting%20SSH;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:46 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;setreading%20alexa%20alexaFHEM.ProxyConnection%20starting,%20starting%20SSH;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:46 4: Connection accepted from WEB_127.0.0.1_46742
2019.03.26 21:20:46 4: Connection closed for WEB_127.0.0.1_46720: EOF
2019.03.26 21:20:46 4: Connection closed for WEB_127.0.0.1_46722: EOF
2019.03.26 21:20:46 4: WEB_127.0.0.1_46742 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;setreading%20alexa%20alexaFHEM.ProxyConnection%20running,%20SSH%20connected;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:46 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;setreading%20alexa%20alexaFHEM.ProxyConnection%20running,%20SSH%20connected;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:47 4: Connection accepted from WEB_127.0.0.1_46782
2019.03.26 21:20:47 4: Connection closed for WEB_127.0.0.1_46728: EOF
2019.03.26 21:20:47 4: Connection accepted from WEB_127.0.0.1_46788
2019.03.26 21:20:47 4: WEB_127.0.0.1_46782 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:47 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:48 4: Connection closed for WEB_127.0.0.1_46742: EOF
2019.03.26 21:20:48 4: WEB_127.0.0.1_46788 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-versionAvailable%201.3.1&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:48 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-versionAvailable%201.3.1&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:48 4: Connection closed for WEB_127.0.0.1_46782: EOF
2019.03.26 21:20:48 4: Connection closed for WEB_127.0.0.1_46788: EOF
2019.03.26 21:20:51 4: Connection accepted from WEB_127.0.0.1_46882
2019.03.26 21:20:51 4: Connection accepted from WEB_127.0.0.1_46884
2019.03.26 21:20:51 4: WEB_127.0.0.1_46882 GET /fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:51 4: WEB: /fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1 / RL:92 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.26 21:20:51 4: WEB_127.0.0.1_46884 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20none&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:51 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20none&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:51 4: Connection accepted from WEB_127.0.0.1_46886
2019.03.26 21:20:51 4: WEB_127.0.0.1_46886 GET /fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:51 4: WEB: /fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=myhcconnToken&XHR=1 / RL:306 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:51 4: Connection accepted from WEB_127.0.0.1_46898
2019.03.26 21:20:51 4: Connection closed for WEB_127.0.0.1_46882: EOF
2019.03.26 21:20:51 4: Connection accepted from WEB_127.0.0.1_46920
2019.03.26 21:20:51 4: WEB_127.0.0.1_46898 GET /fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:52 4: WEB: /fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1 / RL:92 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.26 21:20:52 4: Connection closed for WEB_127.0.0.1_46884: EOF
2019.03.26 21:20:52 4: Connection closed for WEB_127.0.0.1_46886: EOF
2019.03.26 21:20:52 4: WEB_127.0.0.1_46920 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:52 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:20:52 4: Connection closed for WEB_127.0.0.1_46898: EOF
2019.03.26 21:20:52 4: Connection closed for WEB_127.0.0.1_46920: EOF
2019.03.26 21:20:52 4: Connection accepted from WEB_127.0.0.1_46934
2019.03.26 21:20:52 4: WEB_127.0.0.1_46934 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:20:52 4: Connection closed for WEB_127.0.0.1_46934: EOF
2019.03.26 21:21:29 4: WEB_192.168.178.35_64026 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
2019.03.26 21:21:32 4: Connection closed for WEB_192.168.178.35_64028: EOF
2019.03.26 21:21:32 4: Connection accepted from WEB_192.168.178.35_64029
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48004
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48006
2019.03.26 21:21:33 4: WEB_127.0.0.1_48004 GET /fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553631692624; BUFLEN:0
2019.03.26 21:21:33 4: WEB_127.0.0.1_48006 GET /fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553631692625; BUFLEN:0
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48022
2019.03.26 21:21:33 4: WEB_127.0.0.1_48022 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;%7BAttrVal(%22global%22,%22userattr%22,%22%22)%7D;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;%7BAttrVal(%22global%22,%22userattr%22,%22%22)%7D;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:306 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48024
2019.03.26 21:21:33 4: WEB_127.0.0.1_48024 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;jsonlist2%20TYPE=alexa;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;jsonlist2%20TYPE=alexa;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:1747 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48026
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48030
2019.03.26 21:21:33 4: WEB_127.0.0.1_48026 GET /fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=myhcconnToken&XHR=1 / RL:4453 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.26 21:21:33 4: Connection closed for WEB_127.0.0.1_48022: EOF
2019.03.26 21:21:33 4: WEB_127.0.0.1_48030 GET /fhem?cmd=jsonlist2%20TYPE%3Dgassistant&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=jsonlist2%20TYPE%3Dgassistant&fwcsrf=myhcconnToken&XHR=1 / RL:1504 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.26 21:21:33 4: Connection closed for WEB_127.0.0.1_48024: EOF
2019.03.26 21:21:33 4: Connection closed for WEB_127.0.0.1_48026: EOF
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48040
2019.03.26 21:21:33 4: WEB_127.0.0.1_48040 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;%7B$defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20=%20%220.5.7%22%7D;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;%7B$defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20=%20%220.5.7%22%7D;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:26 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48042
2019.03.26 21:21:33 4: Connection closed for WEB_127.0.0.1_48030: EOF
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48044
2019.03.26 21:21:33 4: WEB_127.0.0.1_48042 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;get%20alexa%20proxyToken;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;get%20alexa%20proxyToken;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:37 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:33 4: WEB_127.0.0.1_48044 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;list%20alexa%20.eventToken;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;list%20alexa%20.eventToken;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:671 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:33 4: Connection closed for WEB_127.0.0.1_48040: EOF
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48050
2019.03.26 21:21:33 4: WEB_127.0.0.1_48050 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-version%201.3.0&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-version%201.3.0&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48052
2019.03.26 21:21:33 4: Connection closed for WEB_127.0.0.1_48042: EOF
2019.03.26 21:21:33 4: WEB_127.0.0.1_48052 GET /fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3D2UX-WOZSHO24nTImfKg2OiB2phoq566lpWXRTA2305w%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3D2UX-WOZSHO24nTImfKg2OiB2phoq566lpWXRTA2305w%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:33 4: Connection closed for WEB_127.0.0.1_48044: EOF
2019.03.26 21:21:33 4: Connection accepted from WEB_127.0.0.1_48054
2019.03.26 21:21:33 4: Connection closed for WEB_127.0.0.1_48050: EOF
2019.03.26 21:21:33 4: WEB_127.0.0.1_48054 GET /fhem?cmd=get%20gassistant%20refreshToken&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:33 4: WEB: /fhem?cmd=get%20gassistant%20refreshToken&fwcsrf=myhcconnToken&XHR=1 / RL:66 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:34 4: Connection closed for WEB_127.0.0.1_48052: EOF
2019.03.26 21:21:34 4: Connection closed for WEB_127.0.0.1_48054: EOF
2019.03.26 21:21:34 4: Connection accepted from WEB_127.0.0.1_48068
2019.03.26 21:21:34 4: WEB_127.0.0.1_48068 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:34 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:34 4: Connection accepted from WEB_127.0.0.1_48082
2019.03.26 21:21:34 4: Connection closed for WEB_127.0.0.1_48068: EOF
2019.03.26 21:21:34 4: WEB_127.0.0.1_48082 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-versionAvailable%201.3.1&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:34 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-versionAvailable%201.3.1&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:34 4: Connection closed for WEB_127.0.0.1_48082: EOF
2019.03.26 21:21:36 4: Connection accepted from WEB_127.0.0.1_48154
2019.03.26 21:21:36 4: Connection accepted from WEB_127.0.0.1_48156
2019.03.26 21:21:36 4: Connection accepted from WEB_127.0.0.1_48158
2019.03.26 21:21:36 4: WEB_127.0.0.1_48154 GET /fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:36 4: WEB: /fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1 / RL:92 / application/json; charset=utf-8 / Content-Encoding: gzip
2019.03.26 21:21:36 4: WEB_127.0.0.1_48156 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20none&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:36 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20none&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:36 4: WEB_127.0.0.1_48158 GET /fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:36 4: WEB: /fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=myhcconnToken&XHR=1 / RL:306 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:36 4: Connection closed for WEB_127.0.0.1_48154: EOF
2019.03.26 21:21:36 4: Connection closed for WEB_127.0.0.1_48158: EOF
2019.03.26 21:21:36 4: Connection accepted from WEB_127.0.0.1_48166
2019.03.26 21:21:36 4: Connection closed for WEB_127.0.0.1_48156: EOF
2019.03.26 21:21:36 4: WEB_127.0.0.1_48166 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:36 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:36 4: Connection closed for WEB_127.0.0.1_48166: EOF
2019.03.26 21:21:36 4: Connection accepted from WEB_127.0.0.1_48184
2019.03.26 21:21:36 4: WEB_127.0.0.1_48184 GET /fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:36 4: Connection accepted from WEB_127.0.0.1_48188
2019.03.26 21:21:36 4: Connection closed for WEB_127.0.0.1_48184: EOF
2019.03.26 21:21:36 4: WEB_127.0.0.1_48188 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:36 4: Connection closed for WEB_127.0.0.1_48188: EOF
2019.03.26 21:21:43 4: WEB_192.168.178.35_64026 GET /fhem?room=11%5fSystem%2d%3e02%5fFHEM; BUFLEN:0
2019.03.26 21:21:43 4: WEB: /fhem?room=11%5fSystem%2d%3e02%5fFHEM / RL:4729 / text/html; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:43 4: Connection closed for WEB_192.168.178.35_64029: EOF
2019.03.26 21:21:43 4: Connection accepted from WEB_192.168.178.35_64030
2019.03.26 21:21:47 4: WEB_192.168.178.35_64026 GET /fhem?room=11%5fSystem%2d%3e01%5fSystem; BUFLEN:0
2019.03.26 21:21:47 4: WEB: /fhem?room=11%5fSystem%2d%3e01%5fSystem / RL:19412 / text/html; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:47 4: Connection accepted from WEB_192.168.178.35_64031
2019.03.26 21:21:47 4: WEB_192.168.178.35_64031 GET /fhem/jscolor/jscolor.js; BUFLEN:0
2019.03.26 21:21:47 4: WEB_192.168.178.35_64031 => 304 Not Modified
2019.03.26 21:21:47 4: Connection accepted from WEB_192.168.178.35_64032
2019.03.26 21:21:47 4: WEB_192.168.178.35_64032 GET /fhem/jscolor/arrow.gif; BUFLEN:0
2019.03.26 21:21:47 4: WEB_192.168.178.35_64032 => 304 Not Modified
2019.03.26 21:21:47 4: Connection closed for WEB_192.168.178.35_64030: EOF
2019.03.26 21:21:47 4: Connection accepted from WEB_192.168.178.35_64033
2019.03.26 21:21:47 4: Connection accepted from WEB_192.168.178.35_64034
2019.03.26 21:21:47 4: WEB_192.168.178.35_64033 GET /fhem/jscolor/cross.gif; BUFLEN:0
2019.03.26 21:21:47 4: WEB_192.168.178.35_64033 => 304 Not Modified
2019.03.26 21:21:47 4: WEB_192.168.178.35_64034 GET /fhem/jscolor/hs.png; BUFLEN:0
2019.03.26 21:21:47 4: WEB_192.168.178.35_64034 => 304 Not Modified
2019.03.26 21:21:47 4: WEB_192.168.178.35_64026 GET /fhem/pgm2/fhemweb_colorpicker.js; BUFLEN:0
2019.03.26 21:21:47 4: WEB_192.168.178.35_64026 => 304 Not Modified
2019.03.26 21:21:48 4: Connection accepted from WEB_192.168.178.35_64035
2019.03.26 21:21:51 4: WEB_192.168.178.35_64026 GET /fhem?detail=alexa; BUFLEN:0
2019.03.26 21:21:51 4: WEB: /fhem?detail=alexa / RL:17012 / text/html; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:51 4: WEB_192.168.178.35_64032 GET /fhem?cmd=%7BAttrVal(%22alexa%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:21:51 4: WEB: /fhem?cmd=%7BAttrVal(%22alexa%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:34 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:51 4: WEB_192.168.178.35_64031 GET /fhem?cmd=%7BReadingsVal(%22alexa%22%2C%22add%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:21:51 4: WEB: /fhem?cmd=%7BReadingsVal(%22alexa%22%2C%22add%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:51 4: Connection closed for WEB_192.168.178.35_64035: EOF
2019.03.26 21:21:51 4: Connection accepted from WEB_192.168.178.35_64036
2019.03.26 21:21:55 4: WEB_192.168.178.35_64031 POST /fhem?cmd=help%20alexa&XHR=1&fwcsrf=myhcconnToken&fw_id=385; BUFLEN:0
2019.03.26 21:21:56 4: WEB: /fhem?cmd=help%20alexa&XHR=1&fwcsrf=myhcconnToken&fw_id=385 / RL:1497 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:56 4: WEB_192.168.178.35_64026 GET /fhem?cmd=%7BReadingsVal(%22alexa%22%2C%22stop%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:21:56 4: WEB: /fhem?cmd=%7BReadingsVal(%22alexa%22%2C%22stop%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:56 4: Connection closed for WEB_192.168.178.35_64026: EOF
2019.03.26 21:21:56 4: Connection closed for WEB_192.168.178.35_64031: EOF
2019.03.26 21:21:56 4: WEB_192.168.178.35_64032 POST /fhem&detail=alexa&dev.setalexa=alexa&fwcsrf=myhcconnToken&cmd.setalexa=set&arg.setalexa=stop&val.setalexa=; BUFLEN:0
2019.03.26 21:21:56 4: Connection accepted from WEB_127.0.0.1_48734
2019.03.26 21:21:56 4: WEB_127.0.0.1_48734 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;setreading%20alexa%20alexaFHEM.ProxyConnection%20stopping,%20alexa-fhem%20terminating;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:56 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;setreading%20alexa%20alexaFHEM.ProxyConnection%20stopping,%20alexa-fhem%20terminating;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:56 4: WEB_192.168.178.35_64032 GET /fhem?detail=alexa&fw_id=; BUFLEN:0
2019.03.26 21:21:56 4: WEB: /fhem?detail=alexa&fw_id= / RL:16969 / text/html; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:56 4: Connection accepted from WEB_127.0.0.1_48738
2019.03.26 21:21:56 4: WEB_127.0.0.1_48738 GET /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;setreading%20alexa%20alexaFHEM.ProxyConnection%20stopped;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:21:56 4: WEB: /fhem?cmd=%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%201;;undef%7D;setreading%20alexa%20alexaFHEM.ProxyConnection%20stopped;%7B$defs%7Balexa%7D-%3E%7B%22active%22%7D%20=%200;;undef%7D&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:56 4: Connection closed for WEB_192.168.178.35_64036: EOF
2019.03.26 21:21:56 4: Connection closed for WEB_127.0.0.1_48734: EOF
2019.03.26 21:21:56 4: Connection closed for WEB_127.0.0.1_48738: EOF
2019.03.26 21:21:56 4: WEB_192.168.178.35_64033 GET /fhem?cmd=%7BAttrVal(%22alexa%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:21:56 4: WEB: /fhem?cmd=%7BAttrVal(%22alexa%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:34 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:56 4: WEB_192.168.178.35_64032 GET /fhem?cmd=%7BReadingsVal(%22alexa%22%2C%22add%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:21:56 4: WEB: /fhem?cmd=%7BReadingsVal(%22alexa%22%2C%22add%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:21:56 4: Connection accepted from WEB_192.168.178.35_64037
2019.03.26 21:21:58 4: Connection closed for WEB_127.0.0.1_48004: EOF
2019.03.26 21:22:03 4: WEB_192.168.178.35_64032 GET /fhem?room=11%5fSystem%2d%3e01%5fSystem; BUFLEN:0
2019.03.26 21:22:03 4: WEB: /fhem?room=11%5fSystem%2d%3e01%5fSystem / RL:19660 / text/html; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:03 4: Connection closed for WEB_192.168.178.35_64037: EOF
2019.03.26 21:22:03 4: Connection accepted from WEB_192.168.178.35_64038
2019.03.26 21:22:06 4: WEB_192.168.178.35_64033 GET /fhem?cmd=%7BReadingsVal(%22gassistant%22%2C%22authcode%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:22:06 4: WEB: /fhem?cmd=%7BReadingsVal(%22gassistant%22%2C%22authcode%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:06 4: WEB_192.168.178.35_64034 GET /fhem?cmd=%7BAttrVal(%22gassistant%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:22:06 4: WEB: /fhem?cmd=%7BAttrVal(%22gassistant%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:34 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:06 4: WEB_192.168.178.35_64032 GET /fhem?detail=gassistant; BUFLEN:0
2019.03.26 21:22:06 4: WEB: /fhem?detail=gassistant / RL:8049 / text/html; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:06 4: Connection closed for WEB_192.168.178.35_64038: EOF
2019.03.26 21:22:06 4: Connection accepted from WEB_192.168.178.35_64039
2019.03.26 21:22:09 4: WEB_192.168.178.35_64032 GET /fhem?cmd=%7BReadingsVal(%22gassistant%22%2C%22stop%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:22:09 4: WEB: /fhem?cmd=%7BReadingsVal(%22gassistant%22%2C%22stop%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:09 4: WEB_192.168.178.35_64033 POST /fhem?cmd=help%20gassistant&XHR=1&fwcsrf=myhcconnToken&fw_id=456; BUFLEN:0
2019.03.26 21:22:09 4: WEB: /fhem?cmd=help%20gassistant&XHR=1&fwcsrf=myhcconnToken&fw_id=456 / RL:896 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:10 4: WEB_192.168.178.35_64032 POST /fhem&detail=gassistant&dev.setgassistant=gassistant&fwcsrf=myhcconnToken&cmd.setgassistant=set&arg.setgassistant=stop&val.setgassistant=; BUFLEN:0
2019.03.26 21:22:10 4: Connection accepted from WEB_127.0.0.1_49116
2019.03.26 21:22:10 4: WEB_127.0.0.1_49116 GET /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20disconnected&fwcsrf=myhcconnToken&XHR=1; BUFLEN:0
2019.03.26 21:22:10 4: WEB: /fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20disconnected&fwcsrf=myhcconnToken&XHR=1 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:10 4: Connection closed for WEB_127.0.0.1_49116: EOF
2019.03.26 21:22:10 4: Connection closed for WEB_127.0.0.1_48006: EOF
2019.03.26 21:22:10 4: WEB_192.168.178.35_64032 GET /fhem?detail=gassistant&fw_id=; BUFLEN:0
2019.03.26 21:22:10 4: WEB: /fhem?detail=gassistant&fw_id= / RL:7724 / text/html; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:10 4: Connection closed for WEB_192.168.178.35_64039: EOF
2019.03.26 21:22:10 4: WEB_192.168.178.35_64032 GET /fhem?cmd=%7BReadingsVal(%22gassistant%22%2C%22authcode%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:22:10 4: WEB: /fhem?cmd=%7BReadingsVal(%22gassistant%22%2C%22authcode%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:10 4: WEB_192.168.178.35_64033 GET /fhem?cmd=%7BAttrVal(%22gassistant%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken; BUFLEN:0
2019.03.26 21:22:10 4: WEB: /fhem?cmd=%7BAttrVal(%22gassistant%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=myhcconnToken / RL:34 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2019.03.26 21:22:11 4: Connection accepted from WEB_192.168.178.35_64040
2019.03.26 21:22:13 4: WEB_192.168.178.35_64032 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
aus dem gassistant log:
[26/03/2019, 21:20:42] [FHEM] Get refresh token...
  executing: http://127.0.0.1:8083/fhem?cmd=get%20gassistant%20refreshToken&fwcsrf=myhcconnToken&XHR=1
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connecting...&fwcsrf=myhcconnToken&XHR=1
[26/03/2019, 21:20:46] [FHEM] Found refresh token in reading
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-versionAvailable%201.3.1&fwcsrf=myhcconnToken&XHR=1
[26/03/2019, 21:20:48] [FHEM] refreshAllTokens executed
[26/03/2019, 21:20:49] [FHEM] Fetching FHEM devices...
[26/03/2019, 21:20:49] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1
[26/03/2019, 21:20:50] [FHEM] start connection executed
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lasterror%20none&fwcsrf=myhcconnToken&XHR=1
[26/03/2019, 21:20:50] [FHEM] Checking devices and attributes...
  executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=myhcconnToken&XHR=1
(node:1143) DeprecationWarning: grpc.load: Use the @grpc/proto-loader module with grpc.loadPackageDefinition instead
[26/03/2019, 21:20:51] DynamicFunctions updated
[26/03/2019, 21:20:51] SERVER FeatureLevel:{"featurelevel":2,"changelog":"implement Google Report State"}
[26/03/2019, 21:20:51] SYNC   FeatureLevel:{"featurelevel":1}
[26/03/2019, 21:20:51] >>> VERSION UPGRADE STARTED
[26/03/2019, 21:20:51] [FHEM] reloading http://127.0.0.1:8083/fhem
[26/03/2019, 21:20:51] [FHEM] Fetching FHEM devices...
[26/03/2019, 21:20:51] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1
[26/03/2019, 21:20:51] [FHEM] got: 0 results
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&fwcsrf=myhcconnToken&XHR=1
[26/03/2019, 21:20:52] [FHEM] got: 0 results
[26/03/2019, 21:20:52] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[26/03/2019, 21:20:52] >>> VERSION UPGRADE FINISHED - SYNC INITIATED
[26/03/2019, 21:21:32] [FHEM] longpoll ended, reconnect in: 200msec
[26/03/2019, 21:21:32] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1553631692625
  executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dgassistant&fwcsrf=myhcconnToken&XHR=1
[26/03/2019, 21:21:33] [FHEM] FHEM Google Assistant device detected: gassistant
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-version%201.3.0&fwcsrf=myhcconnToken&XHR=1
  executing: http://127.0.0.1:8083/fhem?cmd=set%20gassistant%20loginURL%20https%3A%2F%2Ffhemconnector.eu.auth0.com%2Fauthorize%3Faudience%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2F%26scope%3Doffline_access%2520openid%2520profile%26response_type%3Dcode%26client_id%3DEI0TI2Y0W1743Ico53Nvsg1FsmoZniCC%26code_challenge%3D2UX-WOZSHO24nTImfKg2OiB2phoq566lpWXRTA2305w%26code_challenge_method%3DS256%26redirect_uri%3Dhttps%3A%2F%2Feurope-west1-fhem-ga-connector.cloudfunctions.net%2Fcodelanding%2Fstart&fwcsrf=myhcconnToken&XHR=1
[26/03/2019, 21:21:33] [FHEM] Get refresh token...
[26/03/2019, 21:21:34] [FHEM] Found refresh token in reading
[26/03/2019, 21:21:35] [FHEM] refreshAllTokens executed
[26/03/2019, 21:21:36] [FHEM] Fetching FHEM devices...
[26/03/2019, 21:21:36] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=GoogleAssistant&fwcsrf=myhcconnToken&XHR=1
[26/03/2019, 21:21:36] [FHEM] start connection executed
[26/03/2019, 21:21:36] [FHEM] Checking devices and attributes...
[26/03/2019, 21:21:36] [FHEM] got: 0 results
[26/03/2019, 21:21:36] DynamicFunctions updated
[26/03/2019, 21:21:36] [FHEM] Supported Google Device Types: switch,outlet,light,thermostat,aircondition,airfreshener,airpurifier,blinds,camera,coffeemaker,dishwasher,dryer,fan,fireplace,heater,kettle,oven,refrigerator,scene,sprinkler,vacuum,washer
[26/03/2019, 21:21:36] SERVER FeatureLevel:{"featurelevel":2,"changelog":"implement Google Report State"}
[26/03/2019, 21:21:36] SYNC   FeatureLevel:{"featurelevel":1}
[26/03/2019, 21:21:36] >>> VERSION UPGRADE STARTED
[26/03/2019, 21:21:36] [FHEM] reloading http://127.0.0.1:8083/fhem
[26/03/2019, 21:21:36] >>> VERSION UPGRADE FINISHED - SYNC INITIATED
[26/03/2019, 21:22:10] Got SIGTERM, shutting down...
  executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20disconnected&fwcsrf=myhcconnToken&XHR=1
Habe fhem dieses Mal (für mich) verkehrt herum gefüllt. Bin mir alexa-fhem und gassistant gestartet und habe erst im Anschluss meine Geräte hinzugefügt.
Die Probleme traten erst später auf. Habe natürlich nicht dokumentiert, zu welchem Modul ein zeitlicher Zusammenhang besteht.
Bin langsam echt am verzweifeln :-(
Beitrag von: amenomade am 26 März 2019, 21:44:43
Zumindest hast Du nicht mehr EADDR in use.
Alexa hast Du noch nicht weider aktiviert?
Dein Google Assistant findet keine Devices, aber nach deinem Vorgang schein es normal zu sein
Was ist jetzt genau das Problem? Und was hat die IP 192.168.178.35 ?
Beitrag von: PingPong am 26 März 2019, 21:50:43
Doch, Alexa habe ich auch wieder aktiviert. Habe jetzt nur das Log nicht mitgeliefert.
Ich hatte noch keine Geräte für Google Assistant aktiviert, da ich noch mit dem Einrichten meiner Geräte beschäftigt war.
Mein Problem ist, dass ich quasi minütlich wieder reconnects im google Assistant Modul habe.
Vermute jetzt einfach mal, dass die Verbindungsmeldungen der gen. IP damit zu tun haben?
Beitrag von: amenomade am 26 März 2019, 22:02:12
Mich irritieren die wiederkehrende SYNC, wie ob die nicht erfolgreich wären.
Hat es mit dem Hinweis im Wiki zu tun?
https://wiki.fhem.de/wiki/Google_Assistant_FHEM_Connect
ZitatACHTUNG: Alle vor 10.3.2019 verknüpften Konten müssen über die Home App einmal neu verknüpft werden, ansonsten funktioniert der SYNC nicht.
Beitrag von: PingPong am 26 März 2019, 22:23:56
Nein, die Verknüpfung hatte ich vorgenommen.
Habe das jetzt auch gerade nochmal getan.
Keine Besserung.
Beitrag von: dominik am 26 März 2019, 22:30:23
Auf was fuer einer Hardware arbeitest du? Was bedeutet 'kurz vor Ende'? Was hattest du davor gemacht? Mach mal nur gassistant in FHEM und sonst alle anderen Devices rauswerfen.
Beitrag von: PingPong am 26 März 2019, 22:33:46
Arbeite auf einem Raspberry Pi 3.
Was ich genau "davor" gemacht habe, weiss ich leider nicht mehr. Es könnte sein, dass ich um die Zeit herum angefangen habe, meine MAX! Devices einzubinden, ist aber reine Spekulation.
Mit deinem Vorschlag bin ich ja gestartet. Nacktes fhem + gassistant -> keine Probleme / keine Reconnects.
Befürchte, ich muss wieder von vorne anfangen und nach jedem hinzugefügten Device/Modul ins gassistant Log schauen und feststellen, wann das Problem aufzutreten beginnt
Beitrag von: dominik am 26 März 2019, 22:52:22
Entferne einfach mal die MAX! Devices und lass nur gassistant und einen on/off dummy. Da brauchst noch nicht neu aufsetzen.
Beitrag von: PingPong am 27 März 2019, 05:20:18
Das könnte jetzt ein Treffer gewesen sein.
Aktuell seit 5 Minuten keine Meldungen mehr im alexa-fhem und gassistant log.
Die Meldungen im fhem Log bleiben bei verbose 4 weiterhin.
Sind die ggf. normal?
2019.03.27 05:16:29 4: Connection closed for WEB_192.168.178.35_65264: EOF
2019.03.27 05:16:29 4: Connection accepted from WEB_192.168.178.35_65265
2019.03.27 05:16:51 4: WEB_192.168.178.35_65165 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
2019.03.27 05:16:52 4: Connection closed for WEB_192.168.178.35_65265: EOF
2019.03.27 05:16:52 4: Connection accepted from WEB_192.168.178.35_65266
2019.03.27 05:17:00 4: WEB_192.168.178.35_65165 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
2019.03.27 05:17:00 4: Connection closed for WEB_192.168.178.35_65266: EOF
2019.03.27 05:17:00 4: Connection accepted from WEB_192.168.178.35_65267
2019.03.27 05:17:02 4: WEB_192.168.178.35_65165 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
2019.03.27 05:17:02 4: Connection closed for WEB_192.168.178.35_65267: EOF
2019.03.27 05:17:02 4: Connection accepted from WEB_192.168.178.35_65268
2019.03.27 05:17:04 4: WEB_192.168.178.35_65165 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
2019.03.27 05:17:04 4: Connection closed for WEB_192.168.178.35_65268: EOF
2019.03.27 05:17:04 4: Connection accepted from WEB_192.168.178.35_65269
2019.03.27 05:17:06 4: WEB_192.168.178.35_65165 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
2019.03.27 05:17:06 4: Connection closed for WEB_192.168.178.35_65269: EOF
2019.03.27 05:17:06 4: Connection accepted from WEB_192.168.178.35_65270
2019.03.27 05:17:07 4: WEB_192.168.178.35_65165 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
2019.03.27 05:17:07 4: Connection closed for WEB_192.168.178.35_65270: EOF
2019.03.27 05:17:08 4: Connection accepted from WEB_192.168.178.35_65271
2019.03.27 05:17:13 4: WEB_192.168.178.35_65165 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
2019.03.27 05:17:13 4: Connection closed for WEB_192.168.178.35_65271: EOF
2019.03.27 05:17:13 4: Connection accepted from WEB_192.168.178.35_65272
2019.03.27 05:17:14 4: Connection closed for WEB_192.168.178.35_65214: EOF
2019.03.27 05:17:14 4: Connection closed for WEB_192.168.178.35_65245: EOF
2019.03.27 05:17:15 4: WEB_192.168.178.35_65165 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
2019.03.27 05:17:15 4: Connection closed for WEB_192.168.178.35_65272: EOF
2019.03.27 05:17:15 4: Connection accepted from WEB_192.168.178.35_65273
2019.03.27 05:17:17 4: WEB_192.168.178.35_65165 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2019-03.log; BUFLEN:0
Werde die Logs jetzt in ein paar Stündchen nochmal kontrollieren und dann nochmal das MAX! Gateway hinzufügen.
Ich bin gespannt.
Danke weiterhin.
Beitrag von: PingPong am 27 März 2019, 11:46:58
Also: Es war ein Treffer.
Nachdem ich das MAX! Gateway aus FHEM entfernt hatte, traten keine weiteren Reconnects mehr in google Assistant auf.
Sobald ich das Gateway wieder hinzufüge, treten die Reconnects erneut auf.
Daraus ergibt sich dann jetzt die Frage, weshalb sich die beiden Module dermaßen in die Quere kommen.
Und noch viel wichtiger, wie sich das Problem nachhaltig lösen lässt.
Beitrag von: dominik am 27 März 2019, 22:51:50
Ich glaube da musst du einen Bug Report beim MAX Modulbetreuer aufmachen, das sollte zumindest schneller weitere Informationen zu Tage liefern als wenn ich mich nun in den MAX Code einlesen muss. Wenn es wo nicht weiter geht, unterstuetze ich gerne.
Beitrag von: PingPong am 28 März 2019, 08:46:46
Danke für Eure Mühen.
Ich habe das Problem mal im MAX! Bereich des Forums gepostet:
https://forum.fhem.de/index.php/topic,99089.0.html (https://forum.fhem.de/index.php/topic,99089.0.html)
Beitrag von: PingPong am 14 April 2019, 17:00:54
leider gibt es bzgl. meines Problems auch im Max Bereich des Forums keinen Fortschritt.
Habe mein FHEM jetzt eine ganze Zeit lang ohne gassistant und Alexa-fhem ohne Auffälligkeiten laufen lassen.
Jetzt dann aber doch mal wieder alexa-fhem installiert... und die Probleme treten wieder auf. :-(
Ich bin leider völlig ahnungslos- und ideenlos, wo ich noch suchen soll.
Hier nochmal ein aktueller Auszug aus dem Log.
[2019-4-14 00:00:01] [FHEM] alexa device is alexa
[2019-4-14 00:00:01] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.26%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:01] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:01] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:01] Server emitted error: {"code":"EADDRINUSE","errno":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":44907}
[2019-4-14 00:00:01] Terminating - starting the listener not possible (another instance running?)
[2019-4-14 00:00:03] using config from ./alexa-fhem.cfg
*** CONFIG: parsed completely
[2019-4-14 00:00:03] os.homedir()=/opt/fhem
[2019-4-14 00:00:03] this is alexa-fhem 0.5.26
[2019-4-14 00:00:03] connecting to FHEM ...
[2019-4-14 00:00:03] [FHEM] trying longpoll to listen for fhem events
[2019-4-14 00:00:03] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1555192803638
[2019-4-14 00:00:03] [FHEM] got csrfToken: myhcconnToken
[2019-4-14 00:00:03] [FHEM] Checking devices and attributes...
[2019-4-14 00:00:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:03] [FHEM] waiting for events ...
[2019-4-14 00:00:03] [FHEM] Fetching FHEM devices...
[2019-4-14 00:00:03] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:03] [FHEM] alexa device is alexa
[2019-4-14 00:00:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.26%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:03] Server listening on: http://127.0.0.1:42017 for proxy connections
[2019-4-14 00:00:03] *** SSH: checking proxy configuration
[2019-4-14 00:00:03] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2019-4-14 00:00:03] Passed config: {"connections":[{"filter":"alexaName=..*","name":"FHEM","webname":"fhem","uid":999,"port":"8083","server":"127.0.0.1"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":42017}}
[2019-4-14 00:00:03] sshautoconf: SSH key seems to exist
[2019-4-14 00:00:04] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2019-4-14 00:00:04] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
*** FHEM: connected
[2019-4-14 00:00:04] [FHEM] got: 0 results
[2019-4-14 00:00:04] BearerToken '...7072A' read from alexa
[2019-4-14 00:00:04] [FHEM] got .eventToken
[2019-4-14 00:00:04] refreshing token
[2019-4-14 00:00:04] 39_alexa.pm is new version: true
[2019-4-14 00:00:04] sshautoconf: completed successfully
[2019-4-14 00:00:04] *** SSH: proxy configuration set up done
[2019-4-14 00:00:04] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2019-4-14 00:00:04] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:04] Starting SSH with -R 1234:127.0.0.1:42017 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2019-4-14 00:00:04] got fresh token
[2019-4-14 00:00:04] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2019-4-14 00:00:04] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:04] *** SSH: proxy connection established
[2019-4-14 00:00:04] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2019-4-14 00:00:54] [FHEM] longpoll ended, reconnect in: 200msec
[2019-4-14 00:00:54] [FHEM] trying longpoll to listen for fhem events
[2019-4-14 00:00:54] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1555192854716
[2019-4-14 00:00:57] [FHEM] got csrfToken: myhcconnToken
[2019-4-14 00:00:57] [FHEM] Checking devices and attributes...
[2019-4-14 00:00:57] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:57] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20TYPE%3Dalexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:00:57] [FHEM] waiting for events ...
[2019-4-14 00:00:57] [FHEM] Fetching FHEM devices...
[2019-4-14 00:00:57] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:00] [FHEM] alexa device is alexa
[2019-4-14 00:01:00] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.26%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:00] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:00] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:00] Server emitted error: {"code":"EADDRINUSE","errno":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":42017}
[2019-4-14 00:01:00] Terminating - starting the listener not possible (another instance running?)
[2019-4-14 00:01:20] using config from ./alexa-fhem.cfg
[2019-4-14 00:01:20] os.homedir()=/opt/fhem
[2019-4-14 00:01:20] this is alexa-fhem 0.5.26
[2019-4-14 00:01:20] connecting to FHEM ...
[2019-4-14 00:01:21] [FHEM] trying longpoll to listen for fhem events
[2019-4-14 00:01:21] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1555192881345
[2019-4-14 00:01:21] [FHEM] got csrfToken: myhcconnToken
[2019-4-14 00:01:21] [FHEM] Checking devices and attributes...
[2019-4-14 00:01:21] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:21] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:21] [FHEM] waiting for events ...
[2019-4-14 00:01:21] [FHEM] Fetching FHEM devices...
[2019-4-14 00:01:21] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:21] [FHEM] alexa device is alexa
[2019-4-14 00:01:21] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.26%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:21] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:21] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:21] Server listening on: http://127.0.0.1:46511 for proxy connections
[2019-4-14 00:01:21] *** SSH: checking proxy configuration
[2019-4-14 00:01:21] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2019-4-14 00:01:21] Passed config: {"connections":[{"filter":"alexaName=..*","name":"FHEM","webname":"fhem","uid":999,"port":"8083","server":"127.0.0.1"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":46511}}
[2019-4-14 00:01:21] sshautoconf: SSH key seems to exist
[2019-4-14 00:01:21] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2019-4-14 00:01:21] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
*** FHEM: connected
[2019-4-14 00:01:21] [FHEM] got: 0 results
[2019-4-14 00:01:22] BearerToken '...7072A' read from alexa
[2019-4-14 00:01:22] 39_alexa.pm is new version: true
[2019-4-14 00:01:22] sshautoconf: completed successfully
[2019-4-14 00:01:22] *** SSH: proxy configuration set up done
[2019-4-14 00:01:22] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2019-4-14 00:01:22] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:22] Starting SSH with -R 1234:127.0.0.1:46511 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2019-4-14 00:01:22] [FHEM] got .eventToken
[2019-4-14 00:01:22] refreshing token
[2019-4-14 00:01:22] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2019-4-14 00:01:22] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:22] *** SSH: proxy connection established
[2019-4-14 00:01:22] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2019-4-14 00:01:22] got fresh token
[2019-4-14 00:01:57] [FHEM] longpoll ended, reconnect in: 200msec
[2019-4-14 00:01:58] [FHEM] trying longpoll to listen for fhem events
[2019-4-14 00:01:58] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1555192918108
[2019-4-14 00:01:59] [FHEM] got csrfToken: myhcconnToken
[2019-4-14 00:01:59] [FHEM] Checking devices and attributes...
[2019-4-14 00:01:59] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:59] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20TYPE%3Dalexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:01:59] [FHEM] waiting for events ...
[2019-4-14 00:01:59] [FHEM] Fetching FHEM devices...
[2019-4-14 00:01:59] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:02:03] [FHEM] alexa device is alexa
[2019-4-14 00:02:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.26%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:02:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:02:03] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=myhcconnToken&XHR=1
[2019-4-14 00:02:03] Server emitted error: {"code":"EADDRINUSE","errno":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":46511}
[2019-4-14 00:02:03] Terminating - starting the listener not possible (another instance running?)
[2019-4-14 00:02:24] using config from ./alexa-fhem.cfg
[2019-4-14 00:02:24] os.homedir()=/opt/fhem
[2019-4-14 00:02:24] this is alexa-fhem 0.5.26
[2019-4-14 00:02:24] connecting to FHEM ...
