nach einer Woche mal wieder ein Update von FHEM gemacht, nach Restart können aber einige Module nicht geladen werden.
Hier der Auszug aus dem FHEM-Log:
2019.04.05 10:03:14.421 1: reload: Error:Modul 59_Wunderground deactivated:
This Perl not built to support threads
Compilation failed in require at FHEM/Meta.pm line 8, <$fh> line 6475.
BEGIN failed--compilation aborted at FHEM/Meta.pm line 8, <$fh> line 6475.
Compilation failed in require at /opt/fhem/FHEM/59_Wunderground.pm line 15, <$fh> line 6475.
BEGIN failed--compilation aborted at /opt/fhem/FHEM/59_Wunderground.pm line 15, <$fh> line 6475.
2019.04.05 10:03:14.421 0: This Perl not built to support threads
2019.04.05 10:03:16.627 1: reload: Error:Modul 73_AMADCommBridge deactivated:
Attempt to reload FHEM/Meta.pm aborted.
Compilation failed in require at /opt/fhem/FHEM/73_AMADCommBridge.pm line 65, <$fh> line 8605.
BEGIN failed--compilation aborted at /opt/fhem/FHEM/73_AMADCommBridge.pm line 65, <$fh> line 8605.
2019.04.05 10:03:16.627 0: Attempt to reload FHEM/Meta.pm aborted.
2019.04.05 10:03:16.647 1: reload: Error:Modul 74_AMADDevice deactivated:
Compilation failed in require at /opt/fhem/FHEM/74_AMADDevice.pm line 51, <$fh> line 8610.
BEGIN failed--compilation aborted at /opt/fhem/FHEM/74_AMADDevice.pm line 51, <$fh> line 8610.
2019.04.05 10:03:16.647 0: Attempt to reload FHEM/Meta.pm aborted.
2019.04.05 10:03:18.262 1: reload: Error:Modul 73_GardenaSmartBridge deactivated:
Compilation failed in require at /opt/fhem/FHEM/73_GardenaSmartBridge.pm line 60, <$fh> line 10723.
BEGIN failed--compilation aborted at /opt/fhem/FHEM/73_GardenaSmartBridge.pm line 60, <$fh> line 10723.
2019.04.05 10:03:18.262 0: Attempt to reload FHEM/Meta.pm aborted.
Nach Auskommentieren von Zeile 8 in Meta.pm
use threads;
startet FHEM ohne Fehler.
Kann jetzt leider nicht beurteilen, ob es wirklich an Meta.pm liegt oder all den anderen Modulen?
Da ich im Bereich "FHEM Development (https://forum.fhem.de/index.php/board,48.0.html)" im Thread "Meta.pm: Metadaten über FHEM Module (https://forum.fhem.de/index.php/topic,97589.0.html)" leider nichts erstellen darf bin ich nun hier gelandet. Den Maintainer der Meta.pm habe ich per PN informiert.
Vielen Dank und Grüße,
Andreas
PS: Perl Version ist
This is perl 5, version 26, subversion 0 (v5.26.0) built for x86_64-linux
PPS: Mir ist bewußt, dass 59_Wunderground wegen geändertem API nicht mehr läuft, das entsprechende Device möchte ich aber erst einmal drin lassen, ist disabled.
Ich denke ich kann den Workaround in Meta.pm entfernen, damit die Abhängigkeit an dieser Stelle nicht mehr gegeben ist.
Fix ist ins SVN eingecheckt.
Vielen Dank für die prompte Behebung!
Andreas
