Neuer Befehl / new command: backup
Begonnen von Martin Fischer, 02 Juni 2012, 00:29:58
Martin Fischer
Heute (01.06.12) habe ich den neuen Befehl backup für FHEM fertig gestellt und
im SVN veröffentlicht. Ab morgen 07:45 Uhr sollte er über updatefhem zur
Verfügung stehen. Er wird in Kürze das in updatefhem enthaltene backup
ersetzen.
backup unterstützt nun neben den globalen Attributen backupdir und
backupsymlink auch das globale Attribut backupcmd, mit dem man sein eigenes
Script einbinden kann. Dadurch kann z.B. ein Backup aus FHEM heraus direkt in
die "Cloud" gesichert werden, sofern man sich das passende Script erstellt.
Hier ein Auszug aus der commandref.html:
global Attributes
backupcmd
You could pass the backup to your own command / script by using this
attribute. If this attribute is specified, then it will be started as a shell
command and passes a space separated list of files / directories as one
argument to the command, like e.g.:
"/etc/fhem.cfg /var/log/fhem/fhem.save /usr/share/fhem/contrib
/usr/share/fhem/FHEM /usr/share/fhem/foo /usr/share/fhem/foobar
/usr/share/fhem/www"
This Attribute is used by the backup command.
Example:
    attr global backupcmd /usr/local/bin/myBackupScript.sh
backupdir
A folder to store the compressed backup file. This Attribute is used by the
backup command.
Example:
    attr global backupdir /Volumes/BigHD
backupsymlink
If this attribute is set to everything else as "no", the archive command tar
will support symlinks in your backup. Otherwise, if this attribute is set to
"no" symlinks are ignored by tar. This Attribute is used by the backup
command.
Example:
    attr global backupsymlinks yes
Command
backup
The complete FHEM directory (containing the modules), the WebInterface pgm2
(if installed) and the config-file will be saved into a .tar.gz file by
default. The file is stored with a timestamp in the modpath/backup directory
or to a directory specified by the backupdir global attribute.
Note: tar and gzip must be installed to use this feature.
If you need to call tar with support for symlinks, you could set the global
attribute backupsymlink to everything else as "no".
You could pass the backup to your own command / script by using the global
attribute backupcmd.
Admin, Developer, Gründungsmitglied des FHEM e.V.
