Deep recursion on subroutine "main::readingsSingleUpdate"
Begonnen von ToM_ToM, 06 Januar 2018, 18:01:32
ToM_ToM
Hallo Zusammen,
ich sehe den Wald vor lauter Bäumen nicht. Bin schon den ganzen Tag auf Fehlersuche, aber verstehe nicht wo hier eine Rekursion sein soll. Mein Fhem hängt sich leider mit folgendem UserReading auf.
EnergyToday:2.ENERGY_COUNTER:.* {
my $power = ReadingsVal("$NAME", "2.POWER", 0);
my @PowerMaxAll = split('\|', ReadingsVal("RepDB_Solarstrom", "POWER_MAX_ALL", "0|0"));
if($power > $PowerMaxAll[0]) {
fhem('set RepDB_Solarstrom sqlCmd SELECT \'POWER_MAX_ALL\' AS \'MaxPower\', VALUE, TIMESTAMP FROM history WHERE DEVICE = \'HM_GN_Solarstrom\' AND READING = \'2.POWER\' AND VALUE = (SELECT MAX(CONVERT(VALUE, DECIMAL(15,5))) FROM history WHERE DEVICE = \'HM_GN_Solarstrom\' AND READING = \'2.POWER\');');
my $energyTotal = ReadingsVal("$NAME", "2.ENERGY_COUNTER", 0);
my $energyTotalToday = ReadingsVal("$NAME", "EnergyTotalToday", 0);
my $energyToday = $energyTotal - $energyTotalToday;
my @EnergyMaxAll = split('\|', ReadingsVal("RepDB_Solarstrom", "ENERGY_MAX_DAY_ALL", "0|0"));
if($energyToday > $EnergyMaxAll[0]) {
fhem('set RepDB_Solarstrom sqlCmd SELECT \'ENERGY_MAX_DAY_ALL\' AS \'MaxEnergy\', VALUE, TIMESTAMP FROM history WHERE DEVICE = \'HM_GN_Solarstrom\' AND READING = \'EnergyToday\' AND VALUE = (SELECT MAX(CONVERT(VALUE, DECIMAL(15,5))) FROM history WHERE DEVICE = \'HM_GN_Solarstrom\' AND READING = \'EnergyToday\');');
my $localtime = (strftime("%Y-%m-%d %H:%M:%S",localtime()));
my $time = ReadingsTimestamp("$NAME", "2.ENERGY_COUNTER", 0);
fhem("setreading $NAME LastTelegramMessageSent $time");
return $energyToday;
Hier noch mein RepDB:
defmod RepDB_Solarstrom DbRep logdb
attr RepDB_Solarstrom device HM_GN_Solarstrom
attr RepDB_Solarstrom group Solar
attr RepDB_Solarstrom reading 2.POWER
attr RepDB_Solarstrom room Garten
attr RepDB_Solarstrom sqlResultFormat separated
attr RepDB_Solarstrom userReadings POWER_MAX_ALL:SqlResultRow_1.* { \
my $sqlResult = ReadingsVal("$NAME", "SqlResultRow_1", "");; \
if ($sqlResult =~ m/POWER_MAX_ALL\|(.*)/i ) { \
return $1;; \
ENERGY_MAX_DAY_ALL:SqlResultRow_1.* { \
if ($sqlResult =~ m/ENERGY_MAX_DAY_ALL\|(.*)/i ) { \
return $1;; \
Im LOG taucht folgendes auf:
2018.01.06 17:41:04 1: PERL WARNING: Deep recursion on subroutine "main::readingsSingleUpdate" at fhem.pl line 2245.
2018.01.06 17:41:04 3: eval: {
2018.01.06 17:41:04 3: DbRep RepDB_Solarstrom - WARNING - old process 5190 will be killed now to start a new BlockingCall
2018.01.06 17:41:04 1: DbRep RepDB_Solarstrom -> BlockingCall sqlCmd_DoParse pid:5190 Timeout: process terminated
2018.01.06 17:41:04 3: DbRep RepDB_Solarstrom - WARNING - old process 5191 will be killed now to start a new BlockingCall
2018.01.06 17:41:04 1: DbRep RepDB_Solarstrom -> BlockingCall sqlCmd_DoParse pid:5191 Timeout: process terminated
2018.01.06 17:41:04 3: DbRep RepDB_Solarstrom - WARNING - old process 5192 will be killed now to start a new BlockingCall
2018.01.06 17:41:04 1: DbRep RepDB_Solarstrom -> BlockingCall sqlCmd_DoParse pid:5192 Timeout: process terminated
2018.01.06 17:41:04 3: DbRep RepDB_Solarstrom - WARNING - old process 5193 will be killed now to start a new BlockingCall
2018.01.06 17:41:04 1: DbRep RepDB_Solarstrom -> BlockingCall sqlCmd_DoParse pid:5193 Timeout: process terminated
2018.01.06 17:41:04 3: DbRep RepDB_Solarstrom - WARNING - old process 5194 will be killed now to start a new BlockingCall
2018.01.06 17:41:04 1: DbRep RepDB_Solarstrom -> BlockingCall sqlCmd_DoParse pid:5194 Timeout: process terminated
Ich hoffe, ihr habt eine Idee.
VG, Thomas
Hardware: Radxa RockPi 5B+, Busmaster CUL, Software: Armbian, Docker, FHEM als Container
KernSani
Ich vermute, dass FHEM es nicht mag, wenn du innerhalb eines userreadings ein set auf das gleiche Device machst, was widerum die Erstellung eines userreadings zur Folge hätte etc...
ToM_ToM
ZitatIch vermute, dass FHEM es nicht mag, wenn du innerhalb eines userreadings ein set auf das gleiche Device machst, was widerum die Erstellung eines userreadings zur Folge hätte etc...
Selbst wenn ich dieses weglasse, hängt es sich mit dem gleichen Fehler auf.
Irgendwie merkwürdig.
herrmannj
Kann man so auch nicht beantworten.
Wenn Du am Anfang ein Log3 oder print einbaust wirst aber sehen _das_ es so ist. Um es einzugrenzen muss man den gesamten Verlauf event - trigger - set etc kennen.
Schau Dir an ob das userReading wirklich bei jeder Aktualisierung ( jetzt EnergyToday:2.ENERGY_COUNTER:.* ) erzeugt werden muss. Wenn nein, setze ein spezifischere Regex und verhindere damit die Rekursion.
ToM_ToM
Vielen Dank für eure Antworten. Ich habe es jetzt alles nochmal komplett umgebaut. Da nun mehrere Devices betroffen sind, denke ich, ist es wenig sinnvoll wenn ich den Code von den ganzen Definitionen hier poste, da wahrscheinlich niemand die gleiche Komplexität mit der gleichen Struktur haben wird.
VG, Thomas
Torxgewinde
#5
Reduziert auf ein minimales Beispiel kann man den Fehler nachvollziehen:
defmod Blatest dummy
attr Blatest readingList wert
attr Blatest setList wert
attr Blatest userReadings meinUserReading:wert.* {\
    my $hash = $defs{$NAME};;\
    readingsBeginUpdate($hash);;\
    readingsEndUpdate($hash, 0);;\
    return "fertig";\
setstate Blatest 2023-08-31 19:21:40 wert 123
Das Log besagt dann:
2023.08.31 18:13:31 1: PERL WARNING: Deep recursion on subroutine "main::readingsEndUpdate" at (eval 6273741) line 4.
2023.08.31 18:13:31 3: eval: {
 return "fertig";
Workaround, um aus einem Userreading ein anderes, eigenes Reading zu setzen ist dann zeitversetzt einen FHEM-Befehl abzusetzen:
fhem("sleep 0.1;; setreading $name noch_Ein_Reading 456");;\
return "fertig";;\
Frage: Geht das nicht doch ohne umständliche Zeitversetzung aus einem userReading heraus?
