FHEM Log zeigt "attack:012BAA..." Meldungen??
Begonnen von dieoma, 02 Februar 2016, 18:16:04
dieoma
seit ein paar Tagen beobachte ich im Log immer wieder mal folgende Meldungen:2016.02.02 16:57:41 2: CUL_HM HM_34FB12 attack:012BAA2234FB12010E,012BAA2234FB1200040000000000:135D4C434FB120201000000
2016.02.02 16:57:41 2: CUL_HM HM_36BC91 attack:012BAA2236BC91010E,012BAA2236BC9100040000000000:135D4C436BC910201000000
2016.02.02 17:05:01 2: CUL_HM HM_34FB12 attack:012BAA2234FB12010E,012BAA2234FB1200040000000000:135D4C434FB120201C80000
2016.02.02 17:05:02 2: CUL_HM HM_36BC91 attack:012BAA2236BC91010E,012BAA2236BC9100040000000000:135D4C436BC910201C80000
2016.02.02 17:09:42 2: CUL_HM HM_34FB12 attack:012BAA2234FB12010E,012BAA2234FB1200040000000000:135D4C434FB120201000000
2016.02.02 17:09:42 2: CUL_HM HM_36BC91 attack:012BAA2236BC91010E,012BAA2236BC9100040000000000:135D4C436BC910201000000
2016.02.02 17:17:58 2: CUL_HM HM_34FB12 attack:012BAA2234FB12010E,012BAA2234FB1200040000000000:135D4C434FB120201C80000
2016.02.02 17:17:59 2: CUL_HM HM_36BC91 attack:012BAA2236BC91010E,012BAA2236BC9100040000000000:135D4C436BC910201C80000
2016.02.02 17:22:39 2: CUL_HM HM_34FB12 attack:012BAA2234FB12010E,012BAA2234FB1200040000000000:135D4C434FB120201000000
2016.02.02 17:22:39 2: CUL_HM HM_36BC91 attack:012BAA2236BC91010E,012BAA2236BC9100040000000000:135D4C436BC910201000000
2016.02.02 17:22:47 2: CUL_HM HM_34FB12 attack:012BAA2234FB12010E,012BAA2234FB1200040000000000:135D4C434FB120201C80000
2016.02.02 17:22:47 2: CUL_HM HM_36BC91 attack:012BAA2236BC91010E,012BAA2236BC9100040000000000:135D4C436BC910201C80000
2016.02.02 17:27:28 2: CUL_HM HM_34FB12 attack:012BAA2234FB12010E,012BAA2234FB1200040000000000:135D4C434FB120201000000
2016.02.02 17:27:28 2: CUL_HM HM_36BC91 attack:012BAA2236BC91010E,012BAA2236BC9100040000000000:135D4C436BC910201000000
2016.02.02 17:30:40 2: CUL_HM HM_34FB12 attack:012BAA2234FB12010E,012BAA2234FB1200040000000000:135D4C434FB120201C80000
2016.02.02 17:30:40 2: CUL_HM HM_36BC91 attack:012BAA2236BC91010E,012BAA2236BC9100040000000000:135D4C436BC910201C80000
welche ich mir nicht richtig erklären kann. Ein "list HM_36BC91" ergibt folgendes: Internals:
   DEF        36BC91
   HMLAN1_MSGCNT 191
   HMLAN1_RAWMSG E36BC91,0000,A319E52D,FF,FFA4,54800236BC9135D4C40101C80028
   HMLAN1_RSSI -92
   HMLAN1_TIME 2016-02-02 18:08:23
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     191
   NAME       HM_36BC91
   NR         200
   NTFY_ORDER 50-HM_36BC91
   STATE      on
   TYPE       CUL_HM
   lastMsg    No:54 - t:02 s:36BC91 d:35D4C4 0101C80028
   protCmdDel 4
   protErrIoAttack 96 last_at:2016-02-02 18:08:23
   protErrIoId_35D4C4 96 last_at:2016-02-02 18:08:23
   protLastRcv 2016-02-02 18:08:23
   protResnd  6 last_at:2016-02-01 21:11:00
   protResndFail 2 last_at:2016-02-01 21:11:05
   protSnd    2 last_at:2016-02-01 21:10:46
   protState  CMDs_done_Errors:1
   rssi_at_HMLAN1 avg:-95.03 min:-101 max:-91 lst:-92 cnt:95
   rssi_unknown_HM2 avg:-39.14 min:-43 max:-37 lst:-40 cnt:95
   Readings:
     2016-02-02 18:08:23   CommandAccepted yes
     2016-01-08 22:23:02   D-firmware      2.5
     2016-01-08 22:23:02   D-serialNr      MEQ0325613
     2016-02-02 18:08:23   deviceMsg       on (to unknown_HM2)
     2016-02-02 18:08:23   level           100
     2016-02-02 18:08:23   pct             100
     2016-01-30 18:16:36   powerOn         2016-01-30 18:16:36
     2016-02-02 18:08:23   recentStateType ack
     2016-02-02 18:08:23   sabotageAttackId_ErrIoId_35D4C4  cnt:96
     2016-02-01 21:09:06   sabotageAttack_ErrIoAttack cnt 5
     2016-02-02 18:08:23   sabotageAttack_ErrIoAttack cnt 96
     2016-02-02 18:08:23   state           on
     2016-02-02 18:08:23   timedOn         off
     Regl_00.:
       VAL
   Helper:
     HM_CMDNR   84
     PONtest    1
     cSnd       012BAA2236BC91010E,012BAA2236BC9100040000000000
     getCfgList all
     getCfgListNo ,3
     mId        0004
     rxType     1
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +36BC91,00,00,00
       nextSend   1454432903.8664
       prefIO
       rxt        0
       vccu
       p:
         36BC91
         00
         00
         00
     Mrssi:
       mNo        54
       Io:
         HMLAN1     -90
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       prs        1
     Rssi:
       At_hmlan1:
         avg        -95.0315789473684
         cnt        95
         lst        -92
         max        -91
         min        -101
       Unknown_hm2:
         avg        -39.1473684210526
         cnt        95
         lst        -40
         max        -37
         min        -43
   IODev      HMLAN1
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   2.5
   model      HM-LC-SW1-FM
   room       Unsorted
   serialNr   MEQ0325613
   subType    switch
   webCmd     statusRequest:toggle:on:off
Ergo ist das wohl ein Aktor, aber mit einer Seriennummer welche keiner meiner Autoren hat. Hat da ein Nachbar mit Homematic angefangen und ich schnappe hier etwas auf? Kann ich das mit ignore einfach wegfiltern?
FHEM5.8 auf Raspi 2, HomeMatic über HMLan mit einigen Aktoren, IT433 Steckosen über CUL, Squeezebox und Tablet-UI
stromer-12
Wenn es nicht dein Aktor ist, setze das Ignore Attribut.
FHEM (SVN) auf RPi1B mit HMser | ESPLink
FHEM (SVN) virtuell mit HMLAN | HMUSB | CUL
