[hminfo] perl warning
Begonnen von frank, 11 Oktober 2016, 15:44:11
frank
hallo martin,
hminfo autoupdate löst regelmässig folgende warnung aus:
2016.10.10 10:04:37.626 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 8970.
2016.10.10 10:04:37.629 3: stacktrace:
2016.10.10 10:04:37.629 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (8970)
2016.10.10 10:04:37.630 3:     main::CUL_HM_cleanShadowReg         called by ./FHEM/98_HMinfo.pm (250)
2016.10.10 10:04:37.630 3:     main::HMinfo_status                 called by ./FHEM/98_HMinfo.pm (1552)
2016.10.10 10:04:37.630 3:     main::HMinfo_SetFn                  called by ./FHEM/98_HMinfo.pm (387)
2016.10.10 10:04:37.630 3:     main::HMinfo_autoUpdate             called by fhem.pl (2816)
2016.10.10 10:04:37.630 3:     main::HandleTimeout                 called by fhem.pl (601)
FHEM: 6.0(SVN) => Pi3(buster)
