bekomme meinen HM-LC-SW1-BA-PCB nicht zum laufen: MISSING ACK
Begonnen von iamandy, 11 November 2016, 16:24:43
iamandy
Hallo!
Ich komme nicht weiter. Habt ihr eine Idee warum das Pairing scheinbar (für mich) OK ist, aber ich z.b. kein ON oder OFF hinbekomme (Missing Ack)?
   CFGFN
   DEF        4D471C
   HMLAN0_MSGCNT 72
   HMLAN0_RAWMSG E4D471C,0000,005E499F,FF,FFC1,2FA0104D471C295A02030000
   HMLAN0_RSSI -63
   HMLAN0_TIME 2016-11-11 15:57:30
   IODev      HMLAN0
   LASTInputDev HMLAN0
   MSGCNT     72
   NAME       switch.bat.flurhinten1
   NOTIFYDEV  global
   NR         277
   STATE      MISSING ACK
   TYPE       CUL_HM
   hmPairSerial NEQ0696674
   lastMsg    No:2F - t:10 s:4D471C d:295A02 030000
   peerList   VCCU_Btn2,
   protCmdDel 8
   protLastRcv 2016-11-11 15:57:30
   protResnd  6 last_at:2016-11-11 16:08:22
   protResndFail 6 last_at:2016-11-11 16:08:28
   protSnd    69 last_at:2016-11-11 16:08:18
   protState  CMDs_done_Errors:1
   rssi_HMLAN0 cnt:2 lst:-58 min:-58 max:-53 avg:-55.5
   rssi_at_HMLAN0 max:-52 avg:-59.8 min:-66 cnt:72 lst:-63
   Readings:
     2016-11-11 15:57:23   CommandAccepted yes
     2016-11-11 15:36:14   D-firmware      1.7
     2016-11-11 15:36:14   D-serialNr      NEQ0696674
     2016-11-11 15:57:28   PairedTo        0x295A02
     2016-11-11 15:57:30   R-VCCU_Btn2-lgActionType jmpToTarget
     2016-11-11 15:57:30   R-VCCU_Btn2-shActionType jmpToTarget
     2016-11-11 15:16:39   R-pairCentral   0x295A02
     2016-11-11 15:16:40   R-sign          off
     2016-11-11 15:57:28   RegL_00.          02:01 05:00 0A:29 0B:5A 0C:02 12:3C  00:00
     2016-11-11 15:57:28   RegL_01.         08:00 00:00
     2016-11-11 15:57:30   RegL_03.VCCU_Btn2  02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:14 0C:63 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:14 8C:63 00:00
     2016-11-11 15:19:30   battery         ok
     2016-11-11 15:18:50   deviceMsg       off (to VCCU)
     2016-11-11 15:19:30   level           0
     2016-11-11 15:18:50   levelMissed     desired:100
     2016-11-11 15:19:30   pct             0
     2016-11-11 15:57:29   peerList        VCCU_Btn2,
     2016-11-11 15:19:30   powerOn         2016-11-11 15:19:30
     2016-11-11 15:19:30   recentStateType info
     2016-11-11 16:08:28   state           MISSING ACK
     2016-11-11 15:19:30   timedOn         off
   Helper:
     HM_CMDNR   51
     PONtest    0
     cSnd       01295A024D471C010E,01295A024D471C010E
     mId        006C
     peerIDsRaw ,295A0202,00000000
     rxType     2
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +4D471C,00,00,00
       nextSend   1478876250.59658
       prefIO
       rxt        0
       vccu
       p:
         4D471C
         00
         00
         00
     Mrssi:
       mNo        2F
       Io:
         HMLAN0     -61
     Prt:
       bErr       0
       sProc      0
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       prs        1
     Rpt:
       IO         HMLAN0
       flg        A
       ts         1478876250.52393
       ack:
         HASH(0x2022ee0)
         2F8002295A024D471C00
     Rssi:
       Hmlan0:
         avg        -55.5
         cnt        2
         lst        -58
         max        -53
         min        -58
       At_hmlan0:
         avg        -59.8055555555556
         cnt        72
         lst        -63
         max        -52
         min        -66
     Shadowreg:
   IODev      HMLAN0
   IOgrp      VCCU:HMLAN0
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   1.7
   model      HM-LC-SW1-BA-PCB
   msgRepeat  1
   peerIDs    00000000,295A0202,
   room       CUL_HM
   serialNr   NEQ0696674
   subType    switch
   webCmd     statusRequest:toggle:on:off
Pfriemler
Liest FHEM den Status bei lokaler Bedienung am Aktor sauber mit?
Ist die eingetragene pairCentral wirklich die des steuernden HM-Interfaces?
Funktioniert getConfig?
iamandy
Gute Frage. Ich habe es über eine vccu und einen hmlan adapter angebunden. logisch hängt es an der vccu. alle anderen HM Komponenten habe ich auch so angebunden, diese funktionieren auch.
Getconfig ist wie das bedienen am aktor. mal sieht man es, aber meist bekommt man RESPONSE TIMEOUT:RegisterRead oder MISSING ACK.
Insgesamt bin ich unzufrieden das ich keine konkreten Aussagen treffen kann, denn es verhält sich unkonkret
iamandy
Pfriemler
Ha ... ich könnte mich glatt anschließen. Seit gestern zickt mein SW1-BA-PCB, der den Garagenantrieb triggert, extrem. Nimmt die lokale Tastenbedienung nicht mehr an, reagiert nur sporadisch auf Funk und liefert Timeouts statt Daten. configCheck meckert nicht. rssi sind zwischen -40 und -65 auf beiden IOs (HMLAN und Raspimodul). Morgen werde ich schlauer.
iamandy
Ich kann leider erst am Mo/Di weiter machen. In der Zwischenzeit habe ich gelesen das wohl auch schon mal Teile defekt geliefert wurden, ich habe das fertig Model.
Zum Anlernen des Teils genügt es doch die VCCU mit hmPairForSec 120 zu aktivieren und beim Aktor 4 Sek. den Knopf zu drücken, oder?
Danach wird es auch sofort bei mir in FHEM angezeigt...
Ich betreibe es übrigens mit 4x AA Batterien die voll sind (gemessen 6,4Volt). Aber egal ob ich auf der Schaltseite nen Verbraucher anschließe, oder nicht, es geht nicht.
Ist es ein Problem wenn ich Batterie Plus direkt an Plus Stromversorgung und auch das Plus der Schalterseite anschließe? Auf dem Bild der Beschreibung sieht man das Man erst den Verbraucher an Plus und quasi nur die Masse Seite schaltet... Könnte das der Fehler sein?
Ich hoffe ich habe Dich jetzt nicht falsch verstanden. Es könnte sein, dass Du einen Kurzschluss produzierst.
Der Schaltausgang ist ein Mosfet, Du kannst entweder:
- Den Plus Aktor mit Schaltspannung verbinden und den Verbraucher zwischen am Minus Aktor und Minus der Schaltspannung schalten.
- Den Minus Aktor mit Minus Schaltspannnung und zwischen Plus Aktor und Plus Schaltspannung den Verbraucher schalten
Hier ein Beispiel
iamandy
Hallo Otto, ich vermute genau das ist das Problem und hoffentlich nicht der Tot meines Aktors!?
Falsch ( mein aktueller Stand):
Spannungsversorgung Aktor
+ => Direkt verbunden mit Batt +
- => Direkt verbunden mit Batt -
Schaltausgang Aktor
- => verbunden mit Lampe +
Lampe
+ => verbunden mit Aktor -
Richtig wäre:
Schaltausgang Aktor
+ => verbunden mit Lampe
Lampe
- => verbunden mit Aktor +
Ich hatte die Zeichnung 6.3 (die 2.) aus der Anleitung nur kurz überflogen und dann falsch gedacht...
Werde es morgen Abend testen. Falls der Aktor noch funktioniert...
Naja er sendet ja noch. Schlimmstenfalls ist der Mosfet kaputt, der kostet glaube ich bloß ein paar Cent.
Probiere doch erstmal ohne das irgendetwas am Schaltausgang angeschlossen ist.
iamandy
Das mach ich!
Und den Mosfet tauschen ist ne gute alternetive, falls er doch defekt ist.
Pfriemler
Bestenfalls ist nichts passiert. In Deinem Fall hast Du mit dem Aktor die Batterie kurzgeschlossen. Dadurch wird der Aktor stromlos und startet anschließend regulär neu mit deaktiviertem Ausgang. Gute Batterien haben zwar mehr Bums als 3A, aber mit ein paar dünnen Käbelchen zwischendurch ist die Kuh vom Eis. Logisch, dass bei Kurzschluss dann auch kein geänderter Status mehr an FHEM zurückkommt, möglichweise fällt sogar schon das ACK des Schaltbefehls aus. Für mich passt das alles.
Wäre der MOSFET kaputt, würde der Aktor brav ein und aus zurückmelden, ohne dass (bei richtigem Anschluss) was an der Lampe passiert.
Mein Aktor hat sich heute, als ich ihm mit Handy und Messgerät zu Leibe rücken wollte, spontan wieder zum Dienst gemeldet. Sowas hasse ich ja...
stgeran
FHEM auf Raspberry
CSM 866MHz für EM1010 mit Strom und Gaszähler
CUL 866MHz für MAX! Radiator Thermostat
CUL 433MHz für Innen und Aussen Temp
HMLAN für HM-LC-Sw1-PI-2
iamandy
Hallo allerseits,
vielen Dank noch mal für die tolle Hilfe und die vielen Ideen!
Nachdem ich nun nicht mehr Batterie plus direkt mit der Spannungsversorgung und dem Schaltausgang verbunden, noch mal das Device gelöscht, einen Werks Reset und neu angelernt habe... Funktioniert es  :D :D :D
Sogar der Mosfet hat es überlebt, danke ELV!
Danke Euch!
